Sink #44
State: SUSPENDED
Description: Built-in Audio Pro
Driver: PipeWire
Sample Specification: s32le 8ch 48000Hz
Channel Map: aux0,aux1,aux2,aux3,aux4,aux5,aux6,aux7
Owner Module: 4294967295
Mute: no
Volume: aux0: 65536 / 100% / 0.00 dB, aux1: 65536 / 100% / 0.00 dB, aux2: 65536 / 100% / 0.00 dB, aux3: 65536 / 100% / 0.00 dB, aux4: 65536 / 100% / 0.00 dB, aux5: 65536 / 100% / 0.00 dB, aux6: 65536 / 100% / 0.00 dB, aux7: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_00_1f.3.pro-output-3.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:pcm:0:hw:0,3:playback"
api.alsa.path = "hw:0,3"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "8"
audio.position = "AUX0,AUX1,AUX2,AUX3,AUX4,AUX5,AUX6,AUX7"
device.routes = "0"
alsa.resolution_bits = "32"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "HDMI 0"
alsa.id = "HDMI 0"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "3"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xb2c18000 irq 131"
clock.name = "api.alsa.0"
device.profile.name = "pro-output-3"
device.profile.description = "Pro"
card.profile.device = "0"
device.id = "41"
factory.name = "api.alsa.pcm.sink"
priority.driver = "696"
priority.session = "696"
media.class = "Audio/Sink"
node.nick = "HDA Intel PCH"
node.name = "alsa_output.pci-0000_00_1f.3.pro-output-3"
device.description = "Built-in Audio"
device.icon_name = "audio-card"
device.bus = "pci"
node.pause-on-idle = "false"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "32"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "44"
object.serial = "44"
device.enum.api = "udev"
api.alsa.card = "0"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.card.longname = "HDA Intel PCH at 0xb2c18000 irq 131"
device.plugged.usec = "3758957"
sysfs.path = "/sys/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.subsystem = "sound"
device.vendor.id = "0x8086"
device.product.id = "0x02c8"
device.product.name = "Comet Lake PCH-LP cAVS"
device.name = "alsa_card.pci-0000_00_1f.3"
device.nick = "HDA Intel PCH"
api.alsa.use-acp = "true"
api.acp.auto-port = "false"
device.string = "0"
Formats:
pcm
Sink #45
State: SUSPENDED
Description: Built-in Audio Pro 7
Driver: PipeWire
Mute: no
Volume: aux0: 61791 / 94% / -1.53 dB, aux1: 61791 / 94% / -1.53 dB, aux2: 61791 / 94% / -1.53 dB, aux3: 61791 / 94% / -1.53 dB, aux4: 61791 / 94% / -1.53 dB, aux5: 61791 / 94% / -1.53 dB, aux6: 61791 / 94% / -1.53 dB, aux7: 61791 / 94% / -1.53 dB
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3.pro-output-7.monitor
Properties:
object.path = "alsa:pcm:0:hw:0,7:playback"
api.alsa.path = "hw:0,7"
device.routes = "0"
device.api = "alsa"
alsa.name = "HDMI 1"
alsa.id = "HDMI 1"
alsa.device = "7"
alsa.card = "0"
device.profile.name = "pro-output-7"
device.profile.description = "Pro 7"
card.profile.device = "1"
device.id = "41"
priority.driver = "632"
priority.session = "632"
node.name = "alsa_output.pci-0000_00_1f.3.pro-output-7"
device.bus = "pci"
factory.id = "18"
client.id = "32"
object.id = "45"
object.serial = "45"
api.alsa.card = "0"
device.string = "0"
Formats:
pcm
Sink #46
State: SUSPENDED
Description: Built-in Audio Pro 8
Driver: PipeWire
Mute: no
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3.pro-output-8.monitor
Properties:
object.path = "alsa:pcm:0:hw:0,8:playback"
api.alsa.path = "hw:0,8"
device.routes = "0"
device.api = "alsa"
alsa.name = "HDMI 2"
alsa.id = "HDMI 2"
alsa.device = "8"
alsa.card = "0"
device.profile.name = "pro-output-8"
device.profile.description = "Pro 8"
card.profile.device = "2"
device.id = "41"
priority.driver = "616"
priority.session = "616"
node.name = "alsa_output.pci-0000_00_1f.3.pro-output-8"
device.bus = "pci"
factory.id = "18"
client.id = "32"
object.id = "46"
object.serial = "46"
api.alsa.card = "0"
device.string = "0"
Formats:
pcm
Sink #47
State: SUSPENDED
Description: Built-in Audio Pro 9
Driver: PipeWire
Mute: no
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3.pro-output-9.monitor
Properties:
object.path = "alsa:pcm:0:hw:0,9:playback"
api.alsa.path = "hw:0,9"
device.routes = "0"
device.api = "alsa"
alsa.name = "HDMI 3"
alsa.id = "HDMI 3"
alsa.device = "9"
alsa.card = "0"
device.profile.name = "pro-output-9"
device.profile.description = "Pro 9"
card.profile.device = "3"
device.id = "41"
priority.driver = "600"
priority.session = "600"
node.name = "alsa_output.pci-0000_00_1f.3.pro-output-9"
device.bus = "pci"
factory.id = "18"
client.id = "32"
object.id = "47"
object.serial = "47"
api.alsa.card = "0"
device.string = "0"
Formats:
pcm
Sink #48
State: SUSPENDED
Description: Built-in Audio Pro 10
Driver: PipeWire
Mute: no
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3.pro-output-10.monitor
Properties:
object.path = "alsa:pcm:0:hw:0,10:playback"
api.alsa.path = "hw:0,10"
device.routes = "0"
device.api = "alsa"
alsa.name = "HDMI 4"
alsa.id = "HDMI 4"
alsa.device = "10"
alsa.card = "0"
device.profile.name = "pro-output-10"
device.profile.description = "Pro 10"
card.profile.device = "4"
device.id = "41"
priority.driver = "584"
priority.session = "584"
node.name = "alsa_output.pci-0000_00_1f.3.pro-output-10"
device.bus = "pci"
factory.id = "18"
client.id = "32"
object.id = "48"
object.serial = "48"
api.alsa.card = "0"
device.string = "0"
Formats:
pcm
