earlier i had a problem where the sound cards were not getting detected at all
so i switched kernel to 5.4 and they are now getting detected atleast but i hear no sound still
the process was:
i used this command systemctl --user disable --now pipewire.socket && systemctl --user disable --now pipewire.service && systemctl --user mask pipewire.socket to disable the pipewire service
i ran this command sudo pacman -S manjaro-pipewire(i found this somewhere in the forum) and i think all the pulseaudio modules were uninstalled in the process
rebooted and selected the pro audio option from the pavucontrol
now i get the cards and everything but i dont hear anything
here is a little info
inxi -Fxxxx
Device-1: Intel Comet Lake PCH-LP cAVS driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
Sound API: ALSA v: k5.4.218-2-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.58 running: yes
sudo lspci -v
00:1f.3 Multimedia audio controller: Intel Corporation Comet Lake PCH-LP cAVS
DeviceName: Onboard - Sound
Subsystem: Device 2782:0200
Flags: bus master, fast devsel, latency 32, IRQ 131
Memory at b2c18000 (64-bit, non-prefetchable) [size=16K]
Memory at b2000000 (64-bit, non-prefetchable) [size=1M]
Capabilities: [50] Power Management version 3
Capabilities: [80] Vendor Specific Information: Len=14 <?>
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_sof_pci
please i have been stuck at this for days and now it looks like i am getting somewhere
Olli
29 October 2022 13:47
2
please check your package-manager if “sof-firmware” is installed. if not install it first
Olli
29 October 2022 13:53
4
okay, may you post the basic inxi to us
Kernel: 5.4.218-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=d4fe0213-4a37-44a6-93a7-3f30b1de8d3a rw quiet
resume=UUID=9aeeb1c4-551c-45b7-983b-9a47fcf0e9d7 udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Flipkart India Pvt. product: NKi510TL85S v: N/A
serial: <superuser required>
Mobo: N/A model: N/A serial: <superuser required>
UEFI: American Megatrends v: CML_CM618_V1.0.1 date: 09/15/2021
ID-1: BAT0 charge: 35.5 Wh (78.9%) condition: 45.0/45.0 Wh (100.0%)
volts: 11.6 min: N/A model: Comet Lake Li-ion Battery type: Li-ion
serial: <filter> status: discharging
RAM: total: 7.61 GiB used: 1.99 GiB (26.1%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 high: 801 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 801 7: 801 8: 800 bogomips: 33615
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: nCipher Security
ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: Sunplus Innovation Hy HD Camera type: USB driver: uvcvideo
bus-ID: 1-4:2 chip-ID: 1bcf:2ced class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x0827 built: 2018 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
alternate: snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
bus-ID: 1-10:3 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 476.94 GiB used: 10.44 GiB (2.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Netac model: SSD 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0A0 scheme: GPT
ID-1: / raw-size: 116.7 GiB size: 114.31 GiB (97.95%) used: 10.44 GiB (9.1%)
fs: ext4 dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: d4fe0213-4a37-44a6-93a7-3f30b1de8d3a
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/sda6 maj-min: 8:6 label: NO_LABEL
uuid: 052B-17BF
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 9aeeb1c4-551c-45b7-983b-9a47fcf0e9d7
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: SYSTEM
uuid: A2B5-03C4
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 158.33 GiB fs: ntfs label: Local Disk
uuid: EA16C2AE16C27AD9
ID-4: /dev/sda4 maj-min: 8:4 size: 192.38 GiB fs: ntfs label: New Volume
uuid: D65A557B5A555977
ID-5: /dev/sda5 maj-min: 8:5 size: 1.12 GiB fs: ntfs label: N/A
uuid: C8420EBF420EB1EC
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-4:2 info: Sunplus Innovation Hy HD Camera type: Video
Device-2: 1-10:3 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 218 Uptime: 9m wakeups: 4 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1216 libs: 318 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
Olli
29 October 2022 13:59
6
okay, one possible issue is the kernel you’re using. a short search for “linux Intel Comet Lake PCH-LP” shows up that your kernel should be 5.19 or newer. please update/upgrade to a newer kernel that is 5.19 or higher.
i had that earlier but no sound cards were detected there
that was the reason i switched to an older version
here the sound cards are detected
but i get no sound
i’ll try switching to the latest kernel and see what happens
[quote=“tanishk, post:1, topic:125425”]
The above command reinstalled pipewire for you.
yes sir
now that i do aplay -l i get
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
and
http://alsa-project.org/db/?f=209cd664e9cee3a07abe4f122b35e3b8c3cea33d
so the cards are being detected but i am getting no sound
i am on kernel 5.14
5.15 kernel is the LTS one you should be using
not getting sound sir
cards are detected but no sound
I think it is probably your connections please explain your set up and if you have not got pavucontrol install it.
sir i have pavucontrol installed already
Ok so which one are you connected to?
i am connected to this audio pro one
And the playback tab shows?
how do i check those sir?
