I stated see below message since the new update, started see when booting system and shut down, [Failed]
Followed by more issue, I thought I did something wrong I did do a reset, will didnt help, iso didnt work! many issues later I come seek help here! I have over follow of info below… sorry
The Issue : Failed Remount Root and Kernel File Systems
> sudo systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
**● systemd-remount-fs.service loaded failed failed Remount Root and Kernel File Systems**
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
> sudo journalctl -p 3 -xb
– Journal begins at Sun 2021-11-21 12:39:46 GMT, ends at Sun 2021-11-21 12:48:33 GMT. –
Nov 21 12:39:46 Manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT1.SPT0._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
Nov 21 12:39:46 Manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.SAT1.SPT0._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 21 12:39:46 Manjaro kernel: BTRFS error (device nvme0n1p1): cannot disable free space tree
Nov 21 12:39:46 Manjaro systemd[1]: Failed to start Remount Root and Kernel File Systems.
Nov 21 12:39:46 Manjaro systemd-remount-fs[329]: /usr/bin/mount for / exited with exit status 32.
Nov 21 12:40:00 Manjaro kernel: nouveau 0000:06:00.0: bus: MMIO write of 800000e0 FAULT at 10eb14 [ PRIVRING ]
Nov 21 12:40:00 Manjaro kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
Nov 21 12:40:00 Manjaro kernel: EDAC sbridge: Couldn't find mci handler
Nov 21 12:40:00 Manjaro kernel: EDAC sbridge: Failed to register device with error -19.
at /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=f59c48d5-4494-4870-81c1-9485b9691dab / btrfs subvol=/@,defaults,noatime,space_cache,autodefrag,compress=zstd 0 0
UUID=f59c48d5-4494-4870-81c1-9485b9691dab /home btrfs subvol=/@home,defaults,noatime,space_cache,autodefrag,compress=zstd 0 0
UUID=f59c48d5-4494-4870-81c1-9485b9691dab /var/cache btrfs subvol=/@cache,defaults,noatime,space_cache,autodefrag,compress=zstd 0 0
UUID=f59c48d5-4494-4870-81c1-9485b9691dab /var/log btrfs subvol=/@log,defaults,noatime,space_cache,autodefrag,compress=zstd 0 0
blkid
/dev/nvme0n1p1: UUID="f59c48d5-4494-4870-81c1-9485b9691dab" UUID_SUB="820147c4-b5b0-437d-87db-c3d08c3e5a95" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="556ef186-01"
/dev/sdb4: LABEL="rpool" UUID="17353626452047158595" UUID_SUB="17711165529915024653" BLOCK_SIZE="4096" TYPE="zfs_member" PARTUUID="32d9cc14-0e72-a342-805d-ab6dd7ee6d1a"
/dev/sdb2: UUID="53b69b6e-ba67-4b22-b913-06d46619a140" TYPE="swap" PARTUUID="d7866eba-0193-e847-bfe2-c067b7e7ff9b"
/dev/sdb3: LABEL="bpool" UUID="7997028952633508358" UUID_SUB="10587871280532787431" BLOCK_SIZE="4096" TYPE="zfs_member" PARTUUID="9836ddfc-ac21-be46-93cb-57a8048076bb"
/dev/sdb1: UUID="D046-A8E8" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="7b5e9a29-0c27-4d5c-9acc-c38cc7593019"
/dev/sda2: LABEL_FATBOOT="NO_LABEL" LABEL="NO_LABEL" UUID="BD03-E980" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="Microsoft reserved partition" PARTUUID="d67c2d34-496e-11ec-b89e-243c200e1a4f"
/dev/sda3: LABEL="Software" BLOCK_SIZE="512" UUID="DA88AE1988ADF3E3" TYPE="ntfs" PARTLABEL="LDM data partition" PARTUUID="d67c2d38-496e-11ec-b89e-243c200e1a4f"
