here are outputs:
$ inxi -zav7
Kernel: 6.0.19-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=95a539cf-d1ab-4d38-8c0c-6dafad00f1e0 rw quiet apparmor=1
security=apparmor resume=UUID=2a669694-38d9-487a-88e5-44633ec9c43d
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: GS75 Stealth 9SE v: REV:1.0
Mobo: Micro-Star model: MS-17G1 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E17G1IMS.111 date: 05/18/2020
ID-1: BAT1 charge: 68.9 Wh (96.4%) condition: 71.5/80.3 Wh (89.1%)
volts: 16.7 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
RAM: total: 15.47 GiB used: 5.94 GiB (38.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 1500 high: 2200 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 2200 2: 800 3: 800
4: 2200 5: 800 6: 2200 7: 2200 8: 2200 9: 2200 10: 800 11: 800 12: 800
bogomips: 52815
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f11
class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-11:3
chip-ID: 04f2:b695 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x509d built: 2019 res: 1920x1080
hz: 240 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Sound API: ALSA v: k6.0.19-4-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 1969:e0b1 class-ID: 0200
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 953.87 GiB used: 666.57 GiB (69.9%)
model: PC SN720 SDAPNTW-1T00 size: 953.87 GiB block-size: physical: 512 B
rev: 10126000 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 936.55 GiB size: 920.77 GiB (98.32%)
used: 666.57 GiB (72.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 95a539cf-d1ab-4d38-8c0c-6dafad00f1e0
label: NO_LABEL uuid: C064-FB25
ID-1: swap-1 type: partition size: 17.02 GiB used: 256 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 2a669694-38d9-487a-88e5-44633ec9c43d
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2 info: SteelSeries ApS KLC type: HID
power: 300mA chip-ID: 1038:1122 class-ID: 0300
Device-2: 1-11:3 info: Chicony HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b695
class-ID: 0e02
Device-3: 1-14:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 50.0 C pch: 51.0 C mobo: N/A
Processes: 333 Uptime: 52m wakeups: 1738 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 3893 pm: pacman pkgs: 1938 libs: 436 tools: pamac,yay pm: rpm
pkgs: N/A note: see --rpm tools: dnf pm: flatpak pkgs: 0 pm: snap pkgs: 17
Shell: sh default: Zsh v: 5.9 running-in: konsole inxi: 3.3.25
$ find /etc/X11/ -name "*.conf"
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/10-optimus-manager.conf
$ ls /etc/modprobe.d
mhwd-gpu.conf
$ journalctl -b0 -p4 --no-pager
úno 14 08:29:18 aurelius-msi kernel: x86/cpu: SGX disabled by BIOS.
úno 14 08:29:18 aurelius-msi kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
úno 14 08:29:18 aurelius-msi kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
úno 14 08:29:18 aurelius-msi kernel: #7 #8 #9 #10 #11
úno 14 08:29:18 aurelius-msi kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
úno 14 08:29:18 aurelius-msi kernel: pci 0000:03:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
úno 14 08:29:18 aurelius-msi kernel: usb: port power management may be unreliable
úno 14 08:29:18 aurelius-msi kernel: vboxdrv: loading out-of-tree module taints kernel.
úno 14 08:29:18 aurelius-msi kernel: VBoxNetAdp: Successfully started.
úno 14 08:29:18 aurelius-msi kernel: VBoxNetFlt: Successfully started.
úno 14 08:29:18 aurelius-msi systemd-udevd[419]: /etc/udev/rules.d/40-libsane.rules:26: GOTO="libsane_rules_end" has no matching label, ignoring
úno 14 08:29:18 aurelius-msi kernel: soc_button_array ACPI0011:00: Unknown button index 0 upage 01 usage c6, ignoring
úno 14 08:29:18 aurelius-msi kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:04)
úno 14 08:29:18 aurelius-msi systemd-udevd[419]: /etc/udev/rules.d/S99-2000S1.rules:26: GOTO="libsane_rules_end" has no matching label, ignoring
úno 14 08:29:18 aurelius-msi kernel: psmouse serio1: Failed to reset mouse on isa0060/serio1: -71
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 8
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 9
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 10
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 11
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 15
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 16
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 18
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 19
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 20
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 21
úno 14 08:29:19 aurelius-msi kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 28
úno 14 08:29:19 aurelius-msi kernel: kauditd_printk_skb: 90 callbacks suppressed
úno 14 08:29:19 aurelius-msi kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
úno 14 08:29:19 aurelius-msi systemd[789]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
úno 14 08:29:20 aurelius-msi bluetoothd[789]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
úno 14 08:29:20 aurelius-msi bluetoothd[789]: src/plugin.c:plugin_init() Failed to init vcp plugin
úno 14 08:29:20 aurelius-msi bluetoothd[789]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
úno 14 08:29:20 aurelius-msi bluetoothd[789]: src/plugin.c:plugin_init() Failed to init mcp plugin
úno 14 08:29:20 aurelius-msi bluetoothd[789]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
úno 14 08:29:20 aurelius-msi bluetoothd[789]: src/plugin.c:plugin_init() Failed to init bap plugin
úno 14 08:29:21 aurelius-msi kernel: nvidia: module license 'NVIDIA' taints kernel.
úno 14 08:29:21 aurelius-msi kernel: Disabling lock debugging due to kernel taint
úno 14 08:29:21 aurelius-msi kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 525.89.02 Wed Feb 1 23:23:25 UTC 2023
úno 14 08:29:23 aurelius-msi kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
úno 14 08:29:23 aurelius-msi kernel: psmouse serio1: Failed to deactivate mouse on isa0060/serio1: -71
úno 14 08:29:23 aurelius-msi kernel: psmouse serio1: Failed to enable mouse on isa0060/serio1
úno 14 08:29:24 aurelius-msi kernel: psmouse serio1: Failed to enable mouse on isa0060/serio1
úno 14 08:29:25 aurelius-msi kernel: kauditd_printk_skb: 23 callbacks suppressed
úno 14 08:29:25 aurelius-msi systemd[1009]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
úno 14 08:29:25 aurelius-msi systemd[1009]: Failed to start Update XDG user dir configuration.
úno 14 08:29:25 aurelius-msi sddm-greeter[1018]: QFont::fromString: Invalid description '(empty)'
úno 14 08:29:26 aurelius-msi sddm-greeter[1018]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffd9c8e5090), parent's thread is QThread(0x555a278b1660), current thread is QThread(0x555a27a0d490)
úno 14 08:29:26 aurelius-msi sddm-greeter[1018]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
úno 14 08:29:26 aurelius-msi sddm-greeter[1018]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
úno 14 08:29:26 aurelius-msi sddm-greeter[1018]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
úno 14 08:29:26 aurelius-msi sddm-greeter[1018]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
úno 14 08:29:27 aurelius-msi sddm-greeter[1018]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
úno 14 08:29:27 aurelius-msi sddm-greeter[1018]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.29'
úno 14 08:29:30 aurelius-msi kernel: kauditd_printk_skb: 135 callbacks suppressed
úno 14 08:31:58 aurelius-msi ksplashqml[1288]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
úno 14 08:31:58 aurelius-msi ksplashqml[1288]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
úno 14 08:31:59 aurelius-msi ksmserver[1353]: Qt: Session management error: networkIdsList argument is NULL
úno 14 08:31:59 aurelius-msi kglobalaccel5[1401]: kf.globalaccel.kglobalacceld: No desktop file found for service "Bloody7.desktop"
úno 14 08:31:59 aurelius-msi kglobalaccel5[1401]: kf.globalaccel.kglobalacceld: No desktop file found for service "Uninstall Bloody7.desktop"
úno 14 08:31:59 aurelius-msi ksmserver[1353]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.13'
úno 14 08:32:00 aurelius-msi kwin_x11[1356]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
úno 14 08:32:00 aurelius-msi kwin_x11[1356]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
úno 14 08:32:01 aurelius-msi plasmashell[1431]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
úno 14 08:32:01 aurelius-msi plasmashell[1431]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
úno 14 08:32:01 aurelius-msi org_kde_powerdevil[1485]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
úno 14 08:32:01 aurelius-msi pipewire-media-session[1583]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
úno 14 08:32:01 aurelius-msi pipewire-media-session[1583]: mod.rt: found session bus but no portal
úno 14 08:32:01 aurelius-msi pipewire[1580]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
úno 14 08:32:01 aurelius-msi pipewire[1580]: mod.rt: found session bus but no portal
úno 14 08:32:01 aurelius-msi kded5[1355]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
úno 14 08:32:01 aurelius-msi kded5[1355]: kscreen.kded: PowerDevil SuspendSession action not available!
úno 14 08:32:01 aurelius-msi org_kde_powerdevil[1485]: org.kde.powerdevil: Handle button events action could not check for screen configuration
úno 14 08:32:02 aurelius-msi org_kde_powerdevil[1485]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
úno 14 08:32:02 aurelius-msi optimus-manager-qt[1633]: libpng warning: iCCP: known incorrect sRGB profile
úno 14 08:32:02 aurelius-msi optimus-manager-qt[1633]: libpng warning: known incorrect sRGB profile
úno 14 08:32:02 aurelius-msi optimus-manager-qt[1633]: libpng warning: profile matches sRGB but writing iCCP instead
úno 14 08:32:02 aurelius-msi DiscoverNotifier[1663]: packagekitqt.transaction: Unknown Transaction property: "Sender" QVariant(QString, ":1.63")
úno 14 08:32:02 aurelius-msi bluetoothd[789]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
úno 14 08:32:02 aurelius-msi plasmashell[1431]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
úno 14 08:32:03 aurelius-msi DiscoverNotifier[1663]: packagekitqt.transaction: Unknown Transaction property: "Sender" QVariant(QString, ":1.63")
úno 14 08:32:03 aurelius-msi plasmashell[1431]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
úno 14 08:32:03 aurelius-msi plasmashell[1431]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
úno 14 08:32:03 aurelius-msi plasmashell[1431]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
úno 14 08:32:03 aurelius-msi plasmashell[1431]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
úno 14 08:32:03 aurelius-msi plasmashell[1431]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
úno 14 08:32:04 aurelius-msi plasmashell[1431]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
úno 14 08:32:04 aurelius-msi plasmashell[1431]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
úno 14 08:32:04 aurelius-msi pulseaudio[1828]: stat('/etc/pulse/default.pa.d'): No such file or directory
úno 14 08:32:04 aurelius-msi plasmashell[1431]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:18:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
úno 14 08:32:04 aurelius-msi plasmashell[1431]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
úno 14 08:32:04 aurelius-msi plasmashell[1431]: Both point size and pixel size set. Using pixel size.
úno 14 08:32:04 aurelius-msi plasmashell[1431]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:68:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
úno 14 08:32:05 aurelius-msi plasmashell[1431]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
úno 14 08:32:05 aurelius-msi plasmashell[1431]: Both point size and pixel size set. Using pixel size.
úno 14 08:32:05 aurelius-msi plasmashell[1431]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
úno 14 08:32:05 aurelius-msi plasmashell[1431]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
úno 14 08:32:05 aurelius-msi plasmashell[1431]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/MonthView.qml:381: TypeError: Cannot read property 'cellHeight' of null
úno 14 08:32:05 aurelius-msi plasmashell[1431]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
úno 14 08:32:05 aurelius-msi plasmashell[1431]: libpng warning: iCCP: known incorrect sRGB profile
úno 14 08:32:08 aurelius-msi kernel: kauditd_printk_skb: 10 callbacks suppressed
úno 14 08:32:08 aurelius-msi plasmashell[1431]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
úno 14 08:32:09 aurelius-msi plasmashell[1431]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
úno 14 08:32:10 aurelius-msi plasmashell[1431]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:22:5: Unable to assign [undefined] to bool
úno 14 08:32:19 aurelius-msi kstart5[1898]: Omitting both --window and --windowclass arguments is not recommended
úno 14 08:32:19 aurelius-msi kstart5[1898]: kf.config.core: "KConfigIni: In file /home/aurelius/.local/share/applications/roblox-malik.desktop, line 4: " "Invalid escape sequence \"\\\"\"."
úno 14 08:32:22 aurelius-msi konsole[1912]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
úno 14 08:32:22 aurelius-msi konsole[1912]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
úno 14 08:32:39 aurelius-msi kded5[1355]: kf.config.core: "KConfigIni: In file /home/aurelius/.local/share/applications/roblox-malik.desktop, line 4: " "Invalid escape sequence \"\\\"\"."
úno 14 08:32:42 aurelius-msi kwin_x11[1356]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
úno 14 08:32:45 aurelius-msi kstart5[2008]: Omitting both --window and --windowclass arguments is not recommended
úno 14 08:32:45 aurelius-msi konsole[2022]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
úno 14 08:32:45 aurelius-msi konsole[2022]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
úno 14 08:33:10 aurelius-msi kded5[1355]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
úno 14 08:33:10 aurelius-msi startplasma-x11[1252]: org.kde.startup: "kdeinit5_shutdown" () exited with code 255
úno 14 08:33:10 aurelius-msi kwalletd5[1251]: The X11 connection broke (error 1). Did the X11 server die?
úno 14 08:33:10 aurelius-msi konsole[2022]: The X11 connection broke (error 1). Did the X11 server die?
úno 14 08:33:10 aurelius-msi kwin_x11[1356]: The X11 connection broke: I/O error (code 1)
úno 14 08:33:10 aurelius-msi systemd[1237]: plasma-kwin_x11.service: Failed with result 'exit-code'.
úno 14 08:33:10 aurelius-msi pulseaudio[1828]: Error opening PCM device front:0: No such file or directory
úno 14 08:33:12 aurelius-msi systemd[2206]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
úno 14 08:33:12 aurelius-msi systemd[2206]: Failed to start Update XDG user dir configuration.
úno 14 08:33:12 aurelius-msi sddm-greeter[2215]: QFont::fromString: Invalid description '(empty)'
úno 14 08:33:12 aurelius-msi sddm-greeter[2215]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffd633c5910), parent's thread is QThread(0x562a1b826660), current thread is QThread(0x562a1b982420)
úno 14 08:33:12 aurelius-msi sddm-greeter[2215]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
úno 14 08:33:12 aurelius-msi sddm-greeter[2215]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
úno 14 08:33:12 aurelius-msi sddm-greeter[2215]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
úno 14 08:33:12 aurelius-msi sddm-greeter[2215]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
úno 14 08:33:13 aurelius-msi sddm-greeter[2215]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
úno 14 08:33:20 aurelius-msi kernel: kauditd_printk_skb: 5 callbacks suppressed
úno 14 08:33:20 aurelius-msi systemd[1237]: obex.service: Failed with result 'exit-code'.
úno 14 08:33:32 aurelius-msi ksplashqml[2294]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
úno 14 08:33:32 aurelius-msi ksplashqml[2294]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
úno 14 08:33:33 aurelius-msi kernel: ACPI Error: No handler for Region [VRTC] (00000000dbcd904c) [SystemCMOS] (20220331/evregion-130)
úno 14 08:33:33 aurelius-msi kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20220331/exfldio-261)
úno 14 08:33:33 aurelius-msi kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC._Q9A due to previous error (AE_NOT_EXIST) (20220331/psparse-529)
úno 14 08:33:33 aurelius-msi ksmserver[2362]: Qt: Session management error: networkIdsList argument is NULL
úno 14 08:33:33 aurelius-msi kglobalaccel5[2421]: kf.globalaccel.kglobalacceld: No desktop file found for service "Bloody7.desktop"
úno 14 08:33:33 aurelius-msi kglobalaccel5[2421]: kf.globalaccel.kglobalacceld: No desktop file found for service "Uninstall Bloody7.desktop"
úno 14 08:33:33 aurelius-msi ksmserver[2362]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.13'
úno 14 08:33:35 aurelius-msi kwin_x11[2365]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
úno 14 08:33:35 aurelius-msi kwin_x11[2365]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
úno 14 08:33:35 aurelius-msi kded5[2364]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
úno 14 08:33:35 aurelius-msi plasmashell[2460]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
úno 14 08:33:35 aurelius-msi plasmashell[2460]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
úno 14 08:33:35 aurelius-msi kded5[2364]: kscreen.kded: PowerDevil SuspendSession action not available!
úno 14 08:33:36 aurelius-msi org_kde_powerdevil[2505]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
úno 14 08:33:36 aurelius-msi pipewire[2579]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
úno 14 08:33:36 aurelius-msi pipewire[2579]: mod.rt: found session bus but no portal
úno 14 08:33:36 aurelius-msi pipewire-media-session[2581]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
úno 14 08:33:36 aurelius-msi pipewire-media-session[2581]: mod.rt: found session bus but no portal
úno 14 08:33:36 aurelius-msi org_kde_powerdevil[2505]: org.kde.powerdevil: Handle button events action could not check for screen configuration
úno 14 08:33:36 aurelius-msi optimus-manager-qt[2621]: libpng warning: iCCP: known incorrect sRGB profile
úno 14 08:33:36 aurelius-msi optimus-manager-qt[2621]: libpng warning: known incorrect sRGB profile
úno 14 08:33:36 aurelius-msi optimus-manager-qt[2621]: libpng warning: profile matches sRGB but writing iCCP instead
úno 14 08:33:37 aurelius-msi DiscoverNotifier[2651]: packagekitqt.transaction: Unknown Transaction property: "Sender" QVariant(QString, ":1.111")
úno 14 08:33:37 aurelius-msi plasmashell[2460]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
úno 14 08:33:37 aurelius-msi plasmashell[2460]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
úno 14 08:33:37 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
úno 14 08:33:37 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
úno 14 08:33:37 aurelius-msi plasmashell[2460]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
úno 14 08:33:38 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
úno 14 08:33:38 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
úno 14 08:33:38 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
úno 14 08:33:38 aurelius-msi plasmashell[2460]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
úno 14 08:33:38 aurelius-msi plasmashell[2460]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
úno 14 08:33:38 aurelius-msi pulseaudio[2808]: stat('/etc/pulse/default.pa.d'): No such file or directory
úno 14 08:33:38 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:18:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
úno 14 08:33:38 aurelius-msi plasmashell[2460]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
úno 14 08:33:38 aurelius-msi plasmashell[2460]: Both point size and pixel size set. Using pixel size.
úno 14 08:33:38 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:68:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
úno 14 08:33:39 aurelius-msi plasmashell[2460]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
úno 14 08:33:39 aurelius-msi plasmashell[2460]: Both point size and pixel size set. Using pixel size.
úno 14 08:33:39 aurelius-msi plasmashell[2460]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
úno 14 08:33:39 aurelius-msi plasmashell[2460]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
úno 14 08:33:39 aurelius-msi plasmashell[2460]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/MonthView.qml:381: TypeError: Cannot read property 'cellHeight' of null
úno 14 08:33:39 aurelius-msi plasmashell[2460]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
úno 14 08:33:39 aurelius-msi plasmashell[2460]: libpng warning: iCCP: known incorrect sRGB profile
úno 14 08:33:40 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:22:5: Unable to assign [undefined] to bool
úno 14 08:33:41 aurelius-msi plasmashell[2460]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
úno 14 08:33:42 aurelius-msi kernel: kauditd_printk_skb: 8 callbacks suppressed
úno 14 08:33:42 aurelius-msi plasmashell[2460]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
úno 14 08:33:43 aurelius-msi plasmashell[2460]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
úno 14 08:33:44 aurelius-msi kstart5[2845]: Omitting both --window and --windowclass arguments is not recommended
úno 14 08:33:45 aurelius-msi konsole[2859]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
úno 14 08:33:45 aurelius-msi konsole[2859]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
úno 14 08:33:49 aurelius-msi kded5[2364]: kf.config.core: "KConfigIni: In file /home/aurelius/.local/share/applications/roblox-malik.desktop, line 4: " "Invalid escape sequence \"\\\"\"."
úno 14 08:33:57 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
úno 14 08:34:14 aurelius-msi kded5[2364]: kf.config.core: "KConfigIni: In file /home/aurelius/.local/share/applications/roblox-malik.desktop, line 4: " "Invalid escape sequence \"\\\"\"."
úno 14 08:34:21 aurelius-msi steam[3330]: gtk_disable_setlocale() must be called before gtk_init()
úno 14 08:34:21 aurelius-msi steam[3330]: Unable to locate theme engine in module_path: "adwaita",
úno 14 08:34:22 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
úno 14 08:34:23 aurelius-msi plasmashell[2460]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
úno 14 08:34:23 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=77402 end=77403) time 1125 us, min 1053, max 1079, scanline start 969, end 137
úno 14 08:34:24 aurelius-msi plasmashell[2460]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
úno 14 08:34:24 aurelius-msi plasmashell[2460]: libpng warning: iCCP: known incorrect sRGB profile
úno 14 08:34:24 aurelius-msi plasmashell[2460]: libpng warning: known incorrect sRGB profile
úno 14 08:34:24 aurelius-msi plasmashell[2460]: libpng warning: profile matches sRGB but writing iCCP instead
úno 14 08:34:26 aurelius-msi kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
úno 14 08:34:26 aurelius-msi kwin_x11[2365]: kwin_core: XCB error: 152 (BadDamage), sequence: 25666, resource id: 16779620, major code: 143 (DAMAGE), minor code: 3 (Subtract)
úno 14 08:34:29 aurelius-msi ktraderclient5[4046]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/discord-356875057940791296" not found
úno 14 08:34:29 aurelius-msi ktraderclient5[4039]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/discord-363411468441354240" not found
úno 14 08:34:29 aurelius-msi ktraderclient5[4049]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/discord-363427839137153024" not found
úno 14 08:34:29 aurelius-msi ktraderclient5[4076]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/discord-356876176465199104" not found
úno 14 08:34:29 aurelius-msi ktraderclient5[4082]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/discord-421150698168909834" not found
úno 14 08:34:29 aurelius-msi ktraderclient5[4107]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/discord-356875057940791296" not found
úno 14 08:34:29 aurelius-msi ktraderclient5[4106]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/discord-363411468441354240" not found
úno 14 08:34:35 aurelius-msi kwin_x11[2365]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
úno 14 08:34:36 aurelius-msi krunner[4366]: QCommandLineParser: argument list cannot be empty, it should contain at least the executable name
úno 14 08:34:36 aurelius-msi krunner[4366]: kf.sonnet.core: No language dictionaries for the language: "en_US"
úno 14 08:34:36 aurelius-msi krunner[4366]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
úno 14 08:34:46 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=82923 end=82924) time 1022 us, min 1053, max 1079, scanline start 1050, end 175
úno 14 08:34:50 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
úno 14 08:36:16 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=104523 end=104524) time 956 us, min 1053, max 1079, scanline start 886, end 11
úno 14 08:36:36 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=109323 end=109324) time 846 us, min 1053, max 1079, scanline start 858, end 1066
úno 14 08:37:26 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=121323 end=121324) time 1293 us, min 1053, max 1079, scanline start 913, end 146
úno 14 08:38:36 aurelius-msi DiscoverNotifier[2651]: packagekitqt.transaction: Unknown Transaction property: "Sender" QVariant(QString, ":1.111")
úno 14 08:38:46 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=140524 end=140525) time 991 us, min 1053, max 1079, scanline start 1027, end 142
úno 14 08:39:26 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=150123 end=150124) time 413 us, min 1053, max 1079, scanline start 1052, end 51
úno 14 08:40:46 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=169324 end=169325) time 270 us, min 1053, max 1079, scanline start 1026, end 1073
úno 14 08:41:36 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=181324 end=181325) time 531 us, min 1053, max 1079, scanline start 957, end 1072
úno 14 08:44:16 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=219723 end=219724) time 502 us, min 1053, max 1079, scanline start 1022, end 45
úno 14 08:44:26 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=222123 end=222124) time 518 us, min 1053, max 1079, scanline start 1032, end 16
úno 14 08:45:16 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=234121 end=234122) time 1217 us, min 1053, max 1079, scanline start 1051, end 245
úno 14 08:45:35 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
úno 14 08:45:35 aurelius-msi plasmashell[2460]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
úno 14 08:45:35 aurelius-msi plasmashell[2460]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the xesam:url entry of the "Metadata" property
úno 14 08:45:39 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
úno 14 08:45:41 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=240064 end=240065) time 481 us, min 1053, max 1079, scanline start 963, end 1091
úno 14 08:45:45 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=240998 end=240999) time 278 us, min 1053, max 1079, scanline start 1014, end 1086
úno 14 08:45:45 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=241004 end=241005) time 938 us, min 1053, max 1079, scanline start 1007, end 126
úno 14 08:45:45 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=241081 end=241082) time 974 us, min 1053, max 1079, scanline start 906, end 27
úno 14 08:45:56 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=243817 end=243818) time 1246 us, min 1053, max 1079, scanline start 1030, end 252
úno 14 08:45:59 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=244454 end=244455) time 758 us, min 1053, max 1079, scanline start 929, end 20
úno 14 08:45:59 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=244461 end=244462) time 1304 us, min 1053, max 1079, scanline start 963, end 173
úno 14 08:46:01 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=244808 end=244809) time 1081 us, min 1053, max 1079, scanline start 973, end 150
úno 14 08:46:01 aurelius-msi kscreenlocker_greet[5703]: Qt: Session management error: networkIdsList argument is NULL
úno 14 08:46:01 aurelius-msi kscreenlocker_greet[5703]: kf.kirigami: Failed to find a Kirigami platform plugin
úno 14 08:46:02 aurelius-msi kscreenlocker_greet[5703]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
úno 14 08:46:02 aurelius-msi kscreenlocker_greet[5703]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/MediaControls.qml:81:9: QML Image: Blocked request.
úno 14 08:46:02 aurelius-msi plasmashell[2460]: qt.qpa.clipboard: QXcbClipboard::setMimeData: Cannot set X11 selection owner
úno 14 08:46:26 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=250922 end=250923) time 359 us, min 1053, max 1079, scanline start 1013, end 2
úno 14 08:46:46 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=255723 end=255724) time 1096 us, min 1053, max 1079, scanline start 948, end 130
úno 14 08:47:25 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=265084 end=265085) time 1381 us, min 1053, max 1079, scanline start 710, end 1063
úno 14 08:47:55 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=272283 end=272284) time 918 us, min 1053, max 1079, scanline start 971, end 60
úno 14 08:52:52 aurelius-msi plasmashell[2460]: org.kde.plasma.notifications: Trying to replace notification with id 1692 which doesn't exist, creating a new one. This is an application bug!
úno 14 08:52:52 aurelius-msi plasmashell[2460]: org.kde.plasma.notifications: Trying to replace notification with id 1693 which doesn't exist, creating a new one. This is an application bug!
úno 14 08:53:14 aurelius-msi plasmashell[2460]: org.kde.plasma.notifications: Trying to replace notification with id 1694 which doesn't exist, creating a new one. This is an application bug!
úno 14 08:53:39 aurelius-msi plasmashell[2460]: org.kde.plasma.notifications: Trying to replace notification with id 1695 which doesn't exist, creating a new one. This is an application bug!
úno 14 08:57:33 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=411003 end=411004) time 1428 us, min 1053, max 1079, scanline start 943, end 163
úno 14 09:00:33 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=454202 end=454203) time 1322 us, min 1053, max 1079, scanline start 933, end 136
úno 14 09:00:53 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=459002 end=459003) time 880 us, min 1053, max 1079, scanline start 894, end 1109
úno 14 09:01:03 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=461402 end=461403) time 904 us, min 1053, max 1079, scanline start 1052, end 153
úno 14 09:01:43 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=471002 end=471003) time 703 us, min 1053, max 1079, scanline start 990, end 66
úno 14 09:02:13 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=478202 end=478203) time 1046 us, min 1053, max 1079, scanline start 1018, end 186
úno 14 09:05:14 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
úno 14 09:05:15 aurelius-msi ktraderclient5[6947]: kf.config.core: "KConfigIni: In file /home/aurelius/.local/share/applications/roblox-malik.desktop, line 4: " "Invalid escape sequence \"\\\"\"."
úno 14 09:05:15 aurelius-msi krunner[4366]: kf.config.core: "KConfigIni: In file /home/aurelius/.local/share/applications/roblox-malik.desktop, line 4: " "Invalid escape sequence \"\\\"\"."
úno 14 09:05:16 aurelius-msi plasmashell[2460]: kf.config.core: "KConfigIni: In file /home/aurelius/.local/share/applications/roblox-malik.desktop, line 4: " "Invalid escape sequence \"\\\"\"."
úno 14 09:05:16 aurelius-msi plasmashell[2460]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
úno 14 09:07:18 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
úno 14 09:07:18 aurelius-msi konsole[7200]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
úno 14 09:07:18 aurelius-msi konsole[7200]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
úno 14 09:08:02 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
úno 14 09:08:33 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=569402 end=569403) time 619 us, min 1053, max 1079, scanline start 934, end 1099
úno 14 09:09:34 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
úno 14 09:09:56 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=589321 end=589322) time 732 us, min 1053, max 1079, scanline start 910, end 1079
úno 14 09:10:33 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=598202 end=598203) time 335 us, min 1053, max 1079, scanline start 1026, end 4
úno 14 09:10:57 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
úno 14 09:12:13 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=622202 end=622203) time 256 us, min 1053, max 1079, scanline start 1038, end 1107
úno 14 09:12:45 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=629882 end=629883) time 328 us, min 1053, max 1079, scanline start 1001, end 1089
úno 14 09:13:33 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=641401 end=641402) time 813 us, min 1053, max 1079, scanline start 899, end 5
úno 14 09:14:58 aurelius-msi kstart5[8136]: Omitting both --window and --windowclass arguments is not recommended
úno 14 09:14:58 aurelius-msi konsole[8150]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
úno 14 09:14:58 aurelius-msi konsole[8150]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
úno 14 09:15:04 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
úno 14 09:15:56 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=675719 end=675720) time 769 us, min 1053, max 1079, scanline start 930, end 1105
úno 14 09:17:36 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=699719 end=699720) time 1029 us, min 1053, max 1079, scanline start 889, end 24
úno 14 09:17:45 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=701882 end=701883) time 1074 us, min 1053, max 1079, scanline start 1041, end 178
úno 14 09:17:53 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
úno 14 09:17:53 aurelius-msi ktraderclient5[8601]: kf.config.core: "KConfigIni: In file /home/aurelius/.local/share/applications/roblox-malik.desktop, line 4: " "Invalid escape sequence \"\\\"\"."
úno 14 09:17:54 aurelius-msi krunner[4366]: kf.config.core: "KConfigIni: In file /home/aurelius/.local/share/applications/roblox-malik.desktop, line 4: " "Invalid escape sequence \"\\\"\"."
úno 14 09:17:54 aurelius-msi plasmashell[2460]: kf.config.core: "KConfigIni: In file /home/aurelius/.local/share/applications/roblox-malik.desktop, line 4: " "Invalid escape sequence \"\\\"\"."
úno 14 09:17:55 aurelius-msi plasmashell[2460]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
úno 14 09:17:59 aurelius-msi kwin_x11[2365]: kwin_core: XCB error: 152 (BadDamage), sequence: 52851, resource id: 16823608, major code: 143 (DAMAGE), minor code: 3 (Subtract)
úno 14 09:18:02 aurelius-msi plasmashell[2460]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
úno 14 09:18:06 aurelius-msi gwenview[8724]: kf.i18n.kuit: "Unknown subcue ':whatsthis,' in UI marker in context {@info:whatsthis, %1 the action's text}."
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-aptus-mos"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-arq"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-bay"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-bmq"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-cap"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-cine"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-cs1"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-dc2"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-drf"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-dxo"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-epson-eip"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-epson-erf"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-fff"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-hasselblad-3fr"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-iiq"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-kodak-dcs"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-kodak-kc2"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-mamiya-mef"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-mfw"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-minolta-mdc"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-mng"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-obm"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-ori"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-ptx"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-pxn"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-qtk"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-r3d"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-raw"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-rdc"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-rwl"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-rwz"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-samsung-srw"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-sti"
úno 14 09:18:06 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: Unresolved raw mime type "image/x-samsung-srw"
úno 14 09:18:07 aurelius-msi gwenview[8724]: org.kde.kdegraphics.gwenview.lib: No date in exif header of "/home/aurelius/Pictures/587782-Anime-Blonde.jpg"
úno 14 09:18:11 aurelius-msi kwin_x11[2365]: kwin_core: XCB error: 152 (BadDamage), sequence: 61000, resource id: 16824225, major code: 143 (DAMAGE), minor code: 3 (Subtract)
úno 14 09:18:15 aurelius-msi gwenview[8761]: kf.i18n.kuit: "Unknown subcue ':whatsthis,' in UI marker in context {@info:whatsthis, %1 the action's text}."
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-aptus-mos"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-arq"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-bay"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-bmq"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-cap"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-cine"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-cs1"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-dc2"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-drf"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-dxo"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-epson-eip"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-epson-erf"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-fff"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-hasselblad-3fr"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-iiq"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-kodak-dcs"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-kodak-kc2"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-mamiya-mef"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-mfw"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-minolta-mdc"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-mng"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-obm"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-ori"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-ptx"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-pxn"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-qtk"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-r3d"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-raw"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-rdc"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-rwl"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-rwz"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-samsung-srw"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-sti"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: Unresolved raw mime type "image/x-samsung-srw"
úno 14 09:18:15 aurelius-msi gwenview[8761]: org.kde.kdegraphics.gwenview.lib: No date in exif header of "/home/aurelius/Pictures/587782-Anime-Blonde.jpg"
úno 14 09:18:19 aurelius-msi kioslave5[8806]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:18:19 aurelius-msi kioslave5[8806]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
úno 14 09:18:19 aurelius-msi kioslave5[8806]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/gsthumbnail.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/gsthumbnail.so'"
úno 14 09:18:19 aurelius-msi kioslave5[8836]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
úno 14 09:18:31 aurelius-msi kioslave5[8836]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:18:31 aurelius-msi kioslave5[8836]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/gsthumbnail.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/gsthumbnail.so'"
úno 14 09:18:31 aurelius-msi kioslave5[8836]: qt.svg: Cannot read file '/home/aurelius/.local/share/Trash/files/images (1)/calc.svg', because: Encountered incorrectly encoded content. (line 1)
úno 14 09:18:32 aurelius-msi kioslave5[8916]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
úno 14 09:18:41 aurelius-msi kioslave5[8916]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:18:42 aurelius-msi kioslave5[8916]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:18:47 aurelius-msi kioslave5[8978]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:18:50 aurelius-msi kioslave5[8978]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:18:50 aurelius-msi kioslave5[9007]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:18:58 aurelius-msi gwenview[9038]: kf.i18n.kuit: "Unknown subcue ':whatsthis,' in UI marker in context {@info:whatsthis, %1 the action's text}."
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-aptus-mos"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-arq"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-bay"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-bmq"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-cap"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-cine"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-cs1"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-dc2"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-drf"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-dxo"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-epson-eip"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-epson-erf"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-fff"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-hasselblad-3fr"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-iiq"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-kodak-dcs"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-kodak-kc2"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-mamiya-mef"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-mfw"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-minolta-mdc"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-mng"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-obm"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-ori"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-ptx"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-pxn"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-qtk"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-r3d"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-raw"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-rdc"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-rwl"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-rwz"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-samsung-srw"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-sti"
úno 14 09:18:58 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.lib: Unresolved raw mime type "image/x-samsung-srw"
úno 14 09:18:59 aurelius-msi gwenview[9038]: org.kde.kdegraphics.gwenview.app: Found no root index for QUrl("trash:/")
úno 14 09:19:10 aurelius-msi kioslave5[9095]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:19:11 aurelius-msi gwenview[9122]: kf.i18n.kuit: "Unknown subcue ':whatsthis,' in UI marker in context {@info:whatsthis, %1 the action's text}."
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-aptus-mos"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-arq"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-bay"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-bmq"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-cap"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-cine"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-cs1"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-dc2"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-drf"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-dxo"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-epson-eip"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-epson-erf"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-fff"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-hasselblad-3fr"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-iiq"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-kodak-dcs"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-kodak-kc2"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-mamiya-mef"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-mfw"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-minolta-mdc"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-mng"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-obm"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-ori"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-ptx"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-pxn"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-qtk"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-r3d"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-raw"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-rdc"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-rwl"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-rwz"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-samsung-srw"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved mime type "image/x-sti"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.lib: Unresolved raw mime type "image/x-samsung-srw"
úno 14 09:19:11 aurelius-msi gwenview[9122]: org.kde.kdegraphics.gwenview.app: Found no root index for QUrl("trash:/")
úno 14 09:19:13 aurelius-msi kioslave5[9095]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:19:14 aurelius-msi kioslave5[9166]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
úno 14 09:19:14 aurelius-msi kioslave5[9166]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:19:17 aurelius-msi kioslave5[9166]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:19:22 aurelius-msi kate[9195]: kf.sonnet.core: No language dictionaries for the language: "en_US"
úno 14 09:19:23 aurelius-msi kioslave5[9227]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:19:33 aurelius-msi kioslave5[9270]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:19:33 aurelius-msi kioslave5[9270]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
úno 14 09:19:33 aurelius-msi kioslave5[9270]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/gsthumbnail.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/gsthumbnail.so'"
úno 14 09:19:33 aurelius-msi kioslave5[9333]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:19:33 aurelius-msi kioslave5[9333]: qt.svg: Cannot read file '/home/aurelius/.local/share/Trash/files/images (1)/calc.svg', because: Encountered incorrectly encoded content. (line 1)
úno 14 09:19:34 aurelius-msi kioslave5[9333]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:19:36 aurelius-msi kioslave5[9333]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
úno 14 09:19:36 aurelius-msi kioslave5[9333]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/gsthumbnail.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/gsthumbnail.so'"
úno 14 09:19:37 aurelius-msi kioslave5[9333]: qt.svg: Cannot read file '/home/aurelius/.local/share/Trash/files/images (1)/calc.svg', because: Encountered incorrectly encoded content. (line 1)
úno 14 09:19:37 aurelius-msi kioslave5[9366]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:19:38 aurelius-msi kioslave5[9394]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:19:57 aurelius-msi filelight[9533]: qrc:/ui/main.qml:171:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
úno 14 09:19:57 aurelius-msi filelight[9533]: qrc:/ui/MapPage.qml:145:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
úno 14 09:19:57 aurelius-msi filelight[9533]: qrc:/ui/MapPage.qml:139:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
úno 14 09:20:01 aurelius-msi kioslave5[9394]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
úno 14 09:20:27 aurelius-msi gedit[9625]: Error loading plugin: libnuspell.so.5: cannot open shared object file: No such file or directory
úno 14 09:20:27 aurelius-msi gedit[9625]: Error loading plugin: libvoikko.so.1: cannot open shared object file: No such file or directory
úno 14 09:20:27 aurelius-msi gedit[9625]: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
úno 14 09:20:27 aurelius-msi gedit[9625]: Error loading plugin: libaspell.so.15: cannot open shared object file: No such file or directory
úno 14 09:20:36 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=742923 end=742924) time 999 us, min 1053, max 1079, scanline start 959, end 77
úno 14 09:21:08 aurelius-msi kstart5[9796]: Omitting both --window and --windowclass arguments is not recommended
úno 14 09:21:08 aurelius-msi konsole[9810]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
úno 14 09:21:08 aurelius-msi konsole[9810]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
úno 14 09:21:46 aurelius-msi kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=759723 end=759724) time 698 us, min 1053, max 1079, scanline start 973, end 10
úno 14 09:22:18 aurelius-msi plasmashell[2460]: org.kde.klipper: Invalid or non-local url for preview: QUrl("")
úno 14 09:22:18 aurelius-msi plasmashell[2460]: org.kde.klipper: Invalid or non-local url for preview: QUrl("ls")
úno 14 09:22:42 aurelius-msi plasmashell[2460]: org.kde.klipper: Invalid or non-local url for preview: QUrl("$")
úno 14 09:22:42 aurelius-msi plasmashell[2460]: org.kde.klipper: Invalid or non-local url for preview: QUrl("ls")
