[Testing Update] 2026-04-28 - Kernels, Thunderbird, QEMU, Octopi, Deepin, Haskell
Hello Manjaro user community, here we have another set of package updates. We are continuing our development of the upcoming release of ‘Bian-May’ which can be expected end of April, beginning of May. Development speed may be a little slower the upcoming weeks. However, still let us know any issues you may found thus far …
Current Promotions
Recent News
New in Manjaro GNOME!
When choosing an accent color in Settings, the folder colors will now change automatically to match when using the Papirus Dark or Papirus Light icon theme.
To try it out, install gnome-shell-extension-papirus-folders-colorizer from Add/Remove Software, logout / login and enable Papirus Folder Colorizer from Extensions.
Or, if you prefer the command line:
Install:
sudo pacman -Syu gnome-shell-extension-papirus-folders-colorizer
Enable the extension:
 gnome-extensions enable papirus-folders-colorizer@NiffirgkcaJ.github.com
Logout:
gnome-session-quit --logout
Also, when applying accent colors from Layout Switcher settings, it will also set the matching folder color. Requires accent-color-change r172.c761c84-2 or newer.
KDE Plasma users with SDDM can now migrate to Plasma Login Manager
After ensuring plasma-login-manager 6.5.90-1 (or newer) is installed, run the following:
sudo pacman -Syu plasma-login-manager
systemctl disable sddm
systemctl enable plasmalogin
sudo pacman -R sddm-kcm sddm
NVIDIA 590 driver drops Pascal support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) GPUs or older.
Impact: Updating the NVIDIA packages on systems with Pascal, Maxwell, or older cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required for Pascal/older users: Users with GTX 10xx series and older cards must switch to a legacy driver to maintain support:
  • Install the official linuxXXX-nvidia-575xx, linuxXXX-nvidia-570xx, or related DKMS packages.
  • Manjaro 26.0 Anh-Linh released
  • Manjaro Summit public Alpha now available
  • As of Linux 5.4.302, the 5.4 series is now EOL (End Of Life). Please install 5.10 LTS (Long Term Support) or 5.15 LTS.
  • As of Linux 6.16.12, the 6.16 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.17.13, the 6.17 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.19.14, the 6.19 series is now EOL (End Of Life). Please install 7.0, and/or 6.18 LTS (Long Term Support) and/or 6.12 LTS.
Previous News
Notable Package Updates
  • Some Kernels got updated
  • Thunderbird 150.0
  • QEMU 11.0
  • Octopi 0.19.0
  • Updates to Deepin, Python and Haskell
Additional Info
Python 3.14 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux510 5.10.252
  • linux515 5.15.202
  • linux61 6.1.168
  • linux66 6.6.136
  • linux612 6.12.84
  • linux618 6.18.25
  • linux619 6.19.14 [EOL]
  • linux70 7.0.2
  • linux71 7.1.0-rc1
  • linux61-rt 6.1.167_rt62
  • linux66-rt 6.6.133_rt73
  • linux612-rt 6.12.79_rt17
  • linux617-rt 6.17.5_rt7
Package Changes (4/28/26 14:49 CEST)
  • testing core x86_64: 22 new and 22 removed package(s)
  • testing extra x86_64: 1868 new and 1927 removed package(s)
  • testing multilib x86_64: 8 new and 8 removed package(s)
A list of all changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2026-04-28
2026-04-06
udev-usb-sync and kernel 7.0-rc
If you experience slow transfers to USB attached disks, remove the package udev-usb-sync. It is not known why the 7.0-rc kernel causes this. There may be a regression of some sort. Awaiting the final release of the 7.0 kernel before jumping to conclusions.
See [Unstable Update] April 2026 thread for more info
2026-04-23T22:00:00Z
The issue is solved with the release of 7.0 kernel
Previous testing threads:
Octopi Notifier is now a separate package and should be installed along with the update if you use it.
octopi-notifier-kstatus is for KDE Plasma users.
octopi-notifier-qt6 for everyone else.
Hmm. Not synced yet…
Check your mirrorlist with https://repo.manjaro.org/ to see if your mirror is in sync.
pacman-mirrors will output the current list of mirrors.
And…
sudo pacman-mirrors -f
… will refresh your mirror list and filter out the ones that have not synced yet.
(Every member of this forum should know that by now.)
Synced now. Thanks.
ISOs including this update can be found here: Release 202604301000 · manjaro/release-review · GitHub
