[Testing Update] 2026-03-28 - Kernels, Plasma 6.6.3, LibreOffice, Systemd, Mesa
Hello Manjaro user community, here we have another set of package updates. This might mark the start of the development cycle of the upcoming ‘Bian-May’ release series. With this we aim to update the default kernel to 7.0 series. Also there will be Plasma 6.6 series, KDE Gears 26.04 and GNOME 50 release series. XFCE will stay at 4.20 this release cycle. A release of ‘Bian-May’ can be expected end of April, beginning of May. Let us know any issues you may found thus far …
Current Promotions
Recent News
New in Manjaro GNOME!
When choosing an accent color in Settings, the folder colors will now change automatically to match when using the Papirus Dark or Papirus Light icon theme.
To try it out, install gnome-shell-extension-papirus-folders-colorizer from Add/Remove Software, logout / login and enable Papirus Folder Colorizer from Extensions.
Or, if you prefer the command line:
Install:
sudo pacman -Syu gnome-shell-extension-papirus-folders-colorizer
Enable the extension:
 gnome-extensions enable papirus-folders-colorizer@NiffirgkcaJ.github.com
Logout:
gnome-session-quit --logout
Also, when applying accent colors from Layout Switcher settings, it will also set the matching folder color. Requires accent-color-change r172.c761c84-2 or newer.
KDE Plasma users with SDDM can now migrate to Plasma Login Manager
After ensuring plasma-login-manager 6.5.90-1 (or newer) is installed, run the following:
sudo pacman -Syu plasma-login-manager
systemctl disable sddm
systemctl enable plasmalogin
sudo pacman -R sddm-kcm sddm
NVIDIA 590 driver drops Pascal support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) GPUs or older.
Impact: Updating the NVIDIA packages on systems with Pascal, Maxwell, or older cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required for Pascal/older users: Users with GTX 10xx series and older cards must switch to a legacy driver to maintain support:
  • Install the official linuxXXX-nvidia-575xx, linuxXXX-nvidia-570xx, or related DKMS packages.
  • Manjaro 26.0 Anh-Linh released
  • Manjaro Summit public Alpha now available
  • As of Linux 5.4.302, the 5.4 series is now EOL (End Of Life). Please install 5.10 LTS (Long Term Support) or 5.15 LTS.
  • As of Linux 6.16.12, the 6.16 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.17.13, the 6.17 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
Previous News
Notable Package Updates
Additional Info
Python 3.14 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux510 5.10.252
  • linux515 5.15.202
  • linux61 6.1.167
  • linux66 6.6.130
  • linux612 6.12.78
  • linux618 6.18.20
  • linux619 6.19.10
  • linux70 7.0.0rc5
  • linux61-rt 6.1.166_rt61
  • linux66-rt 6.6.129_rt70
  • linux612-rt 6.12.74_rt16
  • linux617-rt 6.17.5_rt7
Package Changes (3/28/26 20:09 CET)
  • testing core x86_64: 45 new and 45 removed package(s)
  • testing extra x86_64: 4396 new and 4399 removed package(s)
  • testing multilib x86_64: 41 new and 41 removed package(s)
More details about the package changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2026-03-28
2025-12-29
NVIDIA 590 driver drops Pascal and Maxwell support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) or Maxwell (GTX 9xx) GPUs
Impact: Updating the NVIDIA packages on systems with Pascal or Maxwell cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required: Switch to a legacy driver to maintain support:
Install the official linuxXXX-nvidia-575xx, linuxXXX-nvidia-570xx, or related DKMS packages. You can use nvidia-driver-assistant to figure out which driver would support your hardware best.
2025-12-09
.NET packages may require manual intervention
2025-12-11 - George Rawlinson
The following packages may require manual intervention due to the upgrade from 9.0 to 10.0:
  • aspnet-runtime
  • aspnet-targeting-pack
  • dotnet-runtime
  • dotnet-sdk
  • dotnet-source-built-artifacts
  • dotnet-targeting-pack
pacman may display the following error failed to prepare transaction (could not satisfy dependencies) for the affected packages.
If you are affected by this and require the 9.0 packages, the following commands will update e.g. aspnet-runtime to aspnet-runtime-9.0:
pacman -Syu aspnet-runtime-9.0
pacman -Rs aspnet-runtime
– Arch Linux - News: .NET packages may require manual intervention
Previous testing threads:
:stuck_out_tongue:
Is that Bai Mai, from Young Justice?
On an nvidia system, suspend and resume both work fine, but I see these lines in the log related to the suspend and resume services being skipped. Can I safely ignore these ?
journalctl --reverse --grep=nvidia
Mar 29 11:03:55 REDACTED systemd[1]: Condition check resulted in NVIDIA system resume actions being skipped.
Mar 29 11:03:55 REDACTED systemd[1]: nvidia-resume.service: Skipped due to 'exec-condition'.
Mar 29 11:03:55 REDACTED systemd[1]: Starting NVIDIA system resume actions...
Mar 29 11:03:34 REDACTED systemd[1]: Condition check resulted in NVIDIA system suspend actions being skipped.
Mar 29 11:03:34 REDACTED systemd[1]: nvidia-suspend.service: Skipped due to 'exec-condition'.
Mar 29 11:03:34 REDACTED systemd[1]: Starting NVIDIA system suspend actions...
EDIT - also noticed some kernel errors in the log :
journalctl --reverse --grep=resume
Mar 29 11:03:55 REDACTED rtkit-daemon[900]: Resumed scheduling 6 threads.
Mar 29 11:03:54 REDACTED kernel: spd5118 9-0052: PM: failed to resume async: error -6
Mar 29 11:03:54 REDACTED kernel: spd5118 9-0052: PM: dpm_run_callback(): spd5118_resume [spd5118] returns -6
Mar 29 11:03:54 REDACTED kernel: spd5118 9-0050: PM: failed to resume async: error -6
Mar 29 11:03:54 REDACTED kernel: spd5118 9-0050: PM: dpm_run_callback(): spd5118_resume [spd5118] returns -6
Mar 29 11:03:54 REDACTED kernel: ACPI: PM: Low-level resume complete
Yes. They will only start if one is using the nvidia proprietary driver as they are no longer applicable for the nvidia-open driver in favor of using NVreg_UseKernelSuspendNotifiers=1 which is set by default. See Chapter 21. Configuring Power Management Support
Make sure you’re fully up to date and have nvidia-utils 595.58.03-2 as I added some fixes after the initial testing snap.
Post-28.3.26 update, qpwgraph segfaults on launch.
I am unable to confirm that. qpwgraph loads on my testing (KDE Plasma) install.
You might need to start a new thread for this, and supply System information with inxi -zv8
The update went fine, although I am getting occasional message flashes about a service crashing. It happens too fast for me to tell what service. But nothing happens after that so…I will just let it be.
You could try leaving a terminal open, running journalctl -f to see what transpired in the log when you notice the service crash.
4 posts were split to a new topic: Qdbus6 coredump
