[Testing Update] 2025-01-25 - Kernels, Deepin, Firefox, VirtualBox, Mesa
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: Get 4 months extra
Recent News
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.289
  • linux510 5.10.233
  • linux515 5.15.177
  • linux61 6.1.126
  • linux66 6.6.74
  • linux612 6.12.11
  • linux613 6.13.0
  • linux61-rt 6.1.120_rt47
  • linux66-rt 6.6.65_rt47
  • linux612-rt 6.12.8_rt8
Package Changes ( Sat Jan 25 02:00:22 CET 2025 )
  • testing core x86_64: 9 new and 9 removed package(s)
  • testing extra x86_64: 1855 new and 1842 removed package(s)
  • testing multilib x86_64: 18 new and 17 removed package(s)
Overlay Changes
  • testing core x86_64: 10 new and 10 removed package(s)
  • testing extra x86_64: 80 new and 83 removed package(s)
A list of all changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2025-01-25
2025-01-15
Critical rsync security release 3.4.0
2025-01-16 - Robin Candau
We’d like to raise awareness about the rsync security release version 3.4.0-1 as described in our advisory ASA-202501-1.
An attacker only requires anonymous read access to a vulnerable rsync server, such as a public mirror, to execute arbitrary code on the machine the server is running on. Additionally, attackers can take control of an affected server and read/write arbitrary files of any connected client. Sensitive data can be extracted, such as OpenPGP and SSH keys, and malicious code can be executed by overwriting files such as ~/.bashrc or ~/.popt.
We highly advise anyone who runs an rsync daemon or client prior to version 3.4.0-1 to upgrade and reboot their systems immediately. As Arch Linux mirrors are mostly synchronized using rsync, we highly advise any mirror administrator to act immediately, even though the hosted package files themselves are cryptographically signed.
All infrastructure servers and mirrors maintained by Arch Linux have already been updated.
– Arch Linux - News: Critical rsync security release 3.4.0
2024-12-11
Kernel 6.11 and 4.19 has been marked End Of Life (EOL) on kernel.org
2024-11-27
Partial Cinnamon 6.4 updates
Linux Mint is currently preparing Cinnamon 6.4. The Arch Maintainers went ahead and released some Cinnamon packages which got already tagged 6.4. However, it seems this will break your installation of your Cinnamon desktop. We will monitor the situation and might downgrade to 6.2 packages if needed, before we do a stable branch update. Your feedback regarding Cinnamon overall is highly appreciated.
Known issues so far:
What you can do:
  • Ignore all cinnamon updates when updating.
  • You can try the newly added cinnamon-git package to see if it improves the situation.
  • Update: The issues are resolved with cinnamon >= 6.4.0-1. If you manually installed cinnamon-git, you may now install cinnamon again.
2024-11-13
v86d has been dropped from Manjaro repositories and is no longer required for mhwd
Re: Unstable Update MHWD disussion
If pamac GUI options Enable AUR support and Check for updates are enabled, users should check the package list before agreeing to update and un-check AUR packages
2024-11-01
KVM default behavior change on module loading in kernel 6.12
In kernel 6.12, KVM initializes virtualization on module loading by default. This prevents VirtualBox VMs from starting. In order to avoid this, either add kvm.enable_virt_at_load=0 parameter into kernel command line or unload the corresponding kvm_XXX module. Initial support for 6.12 kernel series was added with Virtualbox 7.1.4.
More info about that in the Linux mailing list
Previous testing threads:
That was it with my VM after the update to Virtualbox 7.1.6, the W11 guest can no longer be started. Back to 7.1.4 everything is OK again.
[   45.166894] vboxdrv: 000000001078addd VMMR0.r0
[   45.330358] vboxdrv: 000000006ac6572c VBoxDDR0.r0
[   45.390009] VBoxNetFlt: attached to '4026531840/enp87s0' / 88:ae:dd:65:87:d8
[   45.450522] EMT-0[2282]: segfault at 790b8d600000 ip 0000790b514da00a sp 0000790b8d5fea70 error 7 in VBoxDD.so[da00a,790b5142b000+1ea000] likely on CPU 2 (core 8, socket 0)
[   45.450529] Code: 41 89 84 9c 88 11 01 00 48 83 c3 01 4c 89 f2 c7 45 9c 00 00 00 00 89 de 4c 89 ef 67 e8 6f 56 01 00 89 c2 8b 45 9c 85 d2 79 d6 <0f> ab 5d a0 31 c0 eb ce 48 8b 05 3f fe 18 00 bf 01 00 00 00 45 31
[   46.056096] vboxnetflt: 0 out of 0 packets were not sent (directed to host)
Addendum: seems to have something to do with the 3D acceleration. If I deactivate it, the W11 guest starts again without problems.
Did you read the part (and modify):
Thanks for the tip, I tested it but it doesn’t seem to have anything in common with my problem. Even with the kernel parameter, the W11 guest won’t start. Only disabling the 3D acceleration helps.
I thought I’d check, I’m guilty of missing release notes.
I have many guests, but I use qemu.
But first things I try with errors like that… Is different kernel versions (6.12, 6.6, etc). Given the file that’s segfaulting, different vGPU?
But only because I got nothing else.
There is some discussion on the Virtualbox forum here: VirtualBox 7.1.6 released - virtualbox.org . I’ve gotten good support from the forum people in the past. I wanted to go in there and start a thread about this bug outside of the general release thread but my long idle ID no longer works. I tried to resurrect or create new, but, Oracle Being Oracle, nothing so far has worked.
Edit: more specific discussion here: Can't start VMs with 3D Acceleration on - virtualbox.org
Most likely a regression in VirtualBox.
I also tested with kernel 6.6, but it didn’t help. I also suspected that my Meteorlake XE GPU seems to be difficult under Linux, the video hardware acceleration has been broken for several months. The post by @dad23innj means I’m not alone with the problem.
@philm
I also believe that it can work without 3D acceleration and wait. :sunglasses:
