[Testing Update] 2024-11-25 - Kernels, Qt5, ROCM, Deepin, Gnome
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: Get 4 months extra
Recent News
Previous News
Notable Package Updates
  • Kernels
    • Fixes to ASUS ALLY patches on 6.11 and 6.12 kernel series
  • More updates to Deepin and Gnome
  • Qt 5.15.16
  • Rocm 6.2.4
Additional Info
Nvidia driver downgrade
Nvidia drivers got downgraded to 550.100, therefore update with sudo pacman -Syuu. If you want to stay on the 555 driver series you may either switch to unstable or install nvidia-dkms via: sudo pacman -U https://mirror.easyname.at/manjaro/pool/overlay/nvidia-dkms-555.58.02-1-x86_64.pkg.tar.zst. More info about Nvidia drivers here:
555 release feedback & discussion - Linux - NVIDIA Developer Forums
550.78 release feedback & discussion thread - Linux - NVIDIA Developer Forums
Python 3.12 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.11.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.11/ :
pacman -Qoq /usr/lib/python3.11/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.11)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
Our current supported kernels
  • linux419 4.19.324
  • linux54 5.4.286
  • linux510 5.10.230
  • linux515 5.15.173
  • linux61 6.1.119
  • linux66 6.6.63
  • linux611 6.11.10
  • linux612 6.12.1
  • linux61-rt 6.1.112_rt43
  • linux66-rt 6.6.53_rt44
  • linux610-rt 6.10.2_rt14
Package Changes (Mon Nov 25 13:42:52 CET 2024)
  • testing core x86_64: 1 new and 1 removed package(s)
  • testing extra x86_64: 190 new and 187 removed package(s)
  • testing multilib x86_64: 1 new and 1 removed package(s)
Overlay Changes
  • testing core x86_64: 5 new and 5 removed package(s)
  • testing extra x86_64: 51 new and 52 removed package(s)
A list of all package changes can be found here. A complete list compared to current stable branch here.
0 voters
Known issues and solutions
:arrow_right: 2024-11-28
2024-11-27
Partial Cinnamon 6.4 updates
Linux Mint is currently preparing Cinnamon 6.4. The Arch Maintainers went ahead and released some Cinnamon packages which got already tagged 6.4. However, it seems this will break your installation of your Cinnamon desktop. We will monitor the situation and might downgrade to 6.2 packages if needed, before we do a stable branch update. Your feedback regarding Cinnamon overall is highly appreciated.
Known issues so far:
What you can do:
  • Ignore all cinnamon updates when updating.
  • You can try the newly added cinnamon-git package to see if it improves the situation.
  • Update: The issues are resolved with cinnamon >= 6.4.0-1. If you manually installed cinnamon-git, you may now install cinnamon again.
2024-11-13
v86d has been dropped from Manjaro repositories and is no longer required for mhwd
Re: Unstable Update MHWD disussion
If pamac GUI options Enable AUR support and Check for updates are enabled, users should check the package list before agreeing to update and un-check AUR packages
2024-11-01
KVM default behavior change on module loading in kernel 6.12
In kernel 6.12, KVM initializes virtualization on module loading by default. This prevents VirtualBox VMs from starting. In order to avoid this, either add kvm.enable_virt_at_load=0 parameter into kernel command line or unload the corresponding kvm_XXX module. Initial support for 6.12 kernel series was added with Virtualbox 7.1.4.
More info about that in the Linux mailing list
2024-10-20
Kernel 6.10 has been marked [EOL] on kernel.org
sddm login problems with multiple monitors
  • bug report
  • login only works on secondary monitor
  • switching sddm theme to maldives works around the issue
2024-09-13
:warning: Linux 6.9 is EOL
Linux 6.9 is EOL and has been removed from the repos.
Suggestion is to install latest LTS; i.e.,
sudo mhwd-kernel -i linux66
System freeze on suspend
A feature in systemd 256 freezing a user session when suspending may freeze the system.
The issue is most prominent with Nvidia systems but reports exist that it may affect other systems as well.
System freezes for 60 seconds and then wakes back up or hangs after waking up
Since systemd v256, systemd freezes user.slice before sleeping. This process can fail due to kernel bugs, particularly when KVM is in use.[13][14]
Messages in the logs will contain Failed to freeze unit 'user.slice' before sleep. When such an issue occurs, trying to login (start another session) would fail with pam_systemd(process:session): Failed to create session: Job 9876 for unit 'session-6.scope' failed with 'frozen'.
To temporarily revert back to the old behavior, edit systemd-suspend.service, systemd-hibernate.service, systemd-hybrid-sleep.service, and systemd-suspend-then-hibernate.service with the following drop-in:
[Service]
Environment="SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=false"
– Power management/Suspend and hibernate - ArchWiki
KDE Plasma hangs on Shutdown, Restart and Logout
With KDE Plasma 6.1, the session saving feature can make Plasma hang.
A workaround is to disable it in System settings > Session > Desktop Session, by choosing “Start with an empty session”.
KDE Session auto login can't be re-enabled for X11
Once session auto login for X11 gets disabled, it can’t be re-enabled in settings.
A workaround is to edit the /etc/sddm.conf.d/kde_settings.conf file and replace Session=Plasma (X11) by Session=plasma
Previous testing threads:
5 posts were split to a new topic: After updating, I got a black screen
Added some more packages to this one:
:: Different overlay package(s) in repository core x86_64
                             PACKAGE           2024-11-25           2024-11-27
                             systemd              256.8-1              256.8-2
                        systemd-libs              256.8-1              256.8-2
                  systemd-resolvconf              256.8-1              256.8-2
                  systemd-sysvcompat              256.8-1              256.8-2
                       systemd-ukify              256.8-1              256.8-2
:: Different overlay package(s) in repository extra x86_64
                    broadcom-wl-dkms    6.30.223.271-38.1    6.30.223.271-38.2
             cinnamon-control-center            6.2.0-1.1            6.4.0-1.0
               folder-color-switcher              1.6.4-1              1.6.5-1
                gnome-control-center             47.1.1-1               47.2-1
    gnome-control-center-x11-scaling             47.1.1-2               47.2-1
                   gnome-keybindings             47.1.1-1               47.2-1
       gnome-keybindings-x11-scaling             47.1.1-2               47.2-1
                         gnome-shell             1:47.1-1             1:47.2-1
                        inputplumber             0.39.2-0                    -
               lightdm-slick-greeter              2.0.6-1              2.0.7-1
                   linux419-bbswitch              0.8-345              0.8-346
                   linux510-bbswitch              0.8-273              0.8-274
                   linux515-bbswitch              0.8-206              0.8-207
                    linux54-bbswitch              0.8-321              0.8-322
                    linux61-bbswitch              0.8-138              0.8-139
                 linux61-rt-bbswitch               0.8-33               0.8-34
                   linux611-bbswitch               0.8-23               0.8-24
                linux611-rt-bbswitch                0.8-1                0.8-2
                   linux612-bbswitch                0.8-6                0.8-7
                    linux66-bbswitch               0.8-94               0.8-95
                 linux66-rt-bbswitch               0.8-24               0.8-25
                        mint-l-icons              1.7.2-1              1.7.3-1
                         mint-themes            1:2.1.8-1            1:2.1.9-1
                        mint-x-icons              1.7.1-1              1.7.2-1
                        mint-y-icons              1.7.7-1              1.7.8-1
                  mutter-x11-scaling               47.1-2               47.2-1
                    plasma-workspace              6.2.3-1            6.2.4-1.1
                        powerline-go               1.24-1               1.25-1
                 tuxedo-drivers-dkms             4.11.3-1             4.11.4-1
              xdg-desktop-portal-kde              6.2.3-1            6.2.4-1.1
                     xviewer-plugins              3.4.0-1              3.4.1-1
                          alsa-utils                    -           1.2.13-1.1
                           bluedevil                    -            1:6.2.4-0
                              breeze                    -              6.2.4-0
                         breeze-grub                    -              6.2.4-0
                          breeze-gtk                    -              6.2.4-0
                     breeze-plymouth                    -              6.2.4-0
                             breeze5                    -              6.2.4-0
                            discover                    -              6.2.4-0
                             drkonqi                    -              6.2.4-0
                         flatpak-kcm                    -              6.2.4-0
                   kactivitymanagerd                    -              6.2.4-0
                       kde-cli-tools                    -              6.2.4-0
                      kde-gtk-config                    -              6.2.4-0
                         kdecoration                    -              6.2.4-0
                    kdeplasma-addons                    -              6.2.4-0
                              kgamma                    -              6.2.4-0
                       kglobalacceld                    -              6.2.4-0
                         kinfocenter                    -              6.2.4-0
                           kmenuedit                    -              6.2.4-0
                           kpipewire                    -              6.2.4-0
                                krdp                    -              6.2.4-0
                             kscreen                    -              6.2.4-0
                       kscreenlocker                    -              6.2.4-0
                         ksshaskpass                    -              6.2.4-0
                        ksystemstats                    -              6.2.4-0
                         kwallet-pam                    -              6.2.4-0
                            kwayland                    -              6.2.4-0
                kwayland-integration                    -              6.2.4-0
                                kwin                    -              6.2.4-0
                             kwrited                    -              6.2.4-0
                      layer-shell-qt                    -              6.2.4-0
                          libkscreen                    -              6.2.4-0
                        libksysguard                    -              6.2.4-0
                           libplasma                    -              6.2.4-0
                               milou                    -              6.2.4-0
                   ocean-sound-theme                    -              6.2.4-0
                              oxygen                    -              6.2.4-0
                       oxygen-sounds                    -              6.2.4-0
                             oxygen5                    -              6.2.4-0
                   plasma-activities                    -              6.2.4-0
             plasma-activities-stats                    -              6.2.4-0
          plasma-browser-integration                    -              6.2.4-0
                      plasma-desktop                    -              6.2.4-0
                        plasma-disks                    -              6.2.4-0
                     plasma-firewall                    -              6.2.4-0
                  plasma-integration                    -              6.2.4-0
                           plasma-nm                    -              6.2.4-0
                           plasma-pa                    -              6.2.4-0
                          plasma-sdk                    -              6.2.4-0
                plasma-systemmonitor                    -              6.2.4-0
                  plasma-thunderbolt                    -              6.2.4-0
                        plasma-vault                    -              6.2.4-0
                      plasma-welcome                    -              6.2.4-0
         plasma-workspace-wallpapers                    -              6.2.4-0
                 plasma5-integration                    -              6.2.4-0
                      plasma5support                    -              6.2.4-0
                        plymouth-kcm                    -              6.2.4-0
                    polkit-kde-agent                    -              6.2.4-0
                          powerdevil                    -              6.2.4-0
                       print-manager                    -            1:6.2.4-0
                   qqc2-breeze-style                    -              6.2.4-0
                            sddm-kcm                    -              6.2.4-0
                      systemsettings                    -              6.2.4-0
                         wacomtablet                    -              6.2.4-0
:: Different sync package(s) in repository extra x86_64
                       alsa-ucm-conf             1.2.13-1             1.2.13-2
                            buildkit             0.17.2-1             0.18.0-1
                       cargo-nextest             0.9.84-1             0.9.85-1
                       docker-buildx             0.18.0-1             0.19.0-1
                                 jaq              1.6.0-1              2.0.0-1
               python-softlayer-zeep              5.0.0-5                    -
                              ttysvr              0.3.3-1              0.3.4-1
This update messed up my Bluetooth audio. After the update, two instances of my Bluetooth speaker are visible in my Plasma audio settings, none of them produce any audio.
Device-1: Intel Comet Lake PCH cAVS driver: snd_hda_intel
Device-2: NVIDIA driver: snd_hda_intel
API: ALSA v: k6.12.1-4-MANJARO status: kernel-api
Server-1: PipeWire v: 1.2.6 status: active
Device-1: Intel AX201 Bluetooth driver: btusb type: USB
Note, above is after I restored a working snapshot.
Something messed up Cinnamon.
I get a white/yellow message after Cinnamon login that an applet or plugin failed to start.
First thing I noticed is, the volume icon is missing from the notification area.
Second my volume keyboard controls do not work anymore.
(Logitech keyboard and Lenovo builtin keyboard on T14s G2 AMD)
However sound still works but cannot control volume.
And cannot change input or output devices.
Confirming this. The Cinnamon volume applet no longer works.
forum-manjaro.org - Cinnamon 6.4 sound applet not working after todays update
Audio Applet Disappeared after update [sound@cinnamon.org] · Issue #12522 · linuxmint/cinnamon · GitHub
clefebvre commented 6 hours ago
Don’t upgrade any components until Cinnamon 6.4 is fully available.
clefebvre closed this as completed 6 hours ago
Thanks for the update, @nikgnomic.
My sticky notes applet disappeared on Plasma. When i added it again all my notes were gone.
Fear not! they are still available in the location sticky notes saves it’s text! It just starts a new file when you add it again.
23 posts were split to a new topic: Brightness level not working in Plasma 6.2.4
I added more packages to this one:
                             PACKAGE           2024-11-27           2024-11-28
                          linux61-rt       6.1.112_rt43-1       6.1.119_rt45-1
                  linux61-rt-headers       6.1.112_rt43-1       6.1.119_rt45-1
                         linux611-rt           6.11_rt7-1           6.11_rt7-3
                 linux611-rt-headers           6.11_rt7-1           6.11_rt7-3
                          linux66-rt        6.6.53_rt44-1        6.6.63_rt46-1
                  linux66-rt-headers        6.6.53_rt44-1        6.6.63_rt46-1
                            linux613                    -          6.13.0rc0-1
                    linux613-headers                    -          6.13.0rc0-1
                          alsa-utils           1.2.13-1.1                    -
                           bluedevil            1:6.2.4-0                    -
                              breeze              6.2.4-0                    -
                         breeze-grub              6.2.4-0                    -
                          breeze-gtk              6.2.4-0                    -
                     breeze-plymouth              6.2.4-0                    -
                             breeze5              6.2.4-0                    -
                            discover              6.2.4-0                    -
                             drkonqi              6.2.4-0                    -
                         flatpak-kcm              6.2.4-0                    -
                   kactivitymanagerd              6.2.4-0                    -
                       kde-cli-tools              6.2.4-0                    -
                      kde-gtk-config              6.2.4-0                    -
                         kdecoration              6.2.4-0                    -
                    kdeplasma-addons              6.2.4-0                    -
                              kgamma              6.2.4-0                    -
                       kglobalacceld              6.2.4-0                    -
                         kinfocenter              6.2.4-0                    -
                           kmenuedit              6.2.4-0                    -
                           kpipewire              6.2.4-0                    -
                                krdp              6.2.4-0                    -
                             kscreen              6.2.4-0                    -
                       kscreenlocker              6.2.4-0                    -
                         ksshaskpass              6.2.4-0                    -
                        ksystemstats              6.2.4-0                    -
                         kwallet-pam              6.2.4-0                    -
                            kwayland              6.2.4-0                    -
                kwayland-integration              6.2.4-0                    -
                                kwin              6.2.4-0                    -
                             kwrited              6.2.4-0                    -
                      layer-shell-qt              6.2.4-0                    -
                          libkscreen              6.2.4-0                    -
                        libksysguard              6.2.4-0                    -
                           libplasma              6.2.4-0                    -
                linux61-rt-acpi_call             1.2.2-35             1.2.2-36
                 linux61-rt-bbswitch               0.8-34               0.8-35
              linux61-rt-broadcom-wl      6.30.223.271-34      6.30.223.271-35
             linux61-rt-nvidia-390xx           390.157-34           390.157-35
             linux61-rt-nvidia-470xx        470.256.02-13        470.256.02-14
                   linux61-rt-nvidia            550.135-1            550.135-2
                    linux61-rt-r8168           8.054.00-2           8.054.00-3
                linux61-rt-rtl8723bu          20240303-16          20240303-17
                 linux61-rt-tp_smapi              0.44-28              0.44-29
              linux61-rt-vhba-module           20240917-2           20240917-3
  linux61-rt-virtualbox-host-modules              7.1.4-2              7.1.4-3
                     linux611-nvidia            550.135-3          565.57.01-8
               linux611-rt-acpi_call              1.2.2-3              1.2.2-4
                linux611-rt-bbswitch                0.8-2                0.8-3
             linux611-rt-broadcom-wl       6.30.223.271-2       6.30.223.271-3
            linux611-rt-nvidia-390xx            390.157-2            390.157-3
            linux611-rt-nvidia-470xx         470.256.02-2         470.256.02-3
                  linux611-rt-nvidia            550.135-1            550.135-2
                   linux611-rt-r8168           8.054.00-2           8.054.00-3
               linux611-rt-rtl8723bu           20240303-2           20240303-3
                linux611-rt-tp_smapi               0.44-2               0.44-3
             linux611-rt-vhba-module           20240917-1           20240917-2
 linux611-rt-virtualbox-host-modules              7.1.4-1              7.1.4-2
                linux66-rt-acpi_call             1.2.2-26             1.2.2-27
                 linux66-rt-bbswitch               0.8-25               0.8-26
              linux66-rt-broadcom-wl      6.30.223.271-25      6.30.223.271-26
             linux66-rt-nvidia-390xx           390.157-25           390.157-26
             linux66-rt-nvidia-470xx        470.256.02-14        470.256.02-15
                   linux66-rt-nvidia            550.135-1            550.135-2
                    linux66-rt-r8168           8.054.00-2           8.054.00-3
                linux66-rt-rtl8723bu          20240303-17          20240303-18
              linux66-rt-vhba-module           20240917-2           20240917-3
  linux66-rt-virtualbox-host-modules              7.1.4-2              7.1.4-3
                         mhwd-nvidia            550.135-1          565.57.01-4
                               milou              6.2.4-0                    -
                   ocean-sound-theme              6.2.4-0                    -
                              oxygen              6.2.4-0                    -
                       oxygen-sounds              6.2.4-0                    -
                             oxygen5              6.2.4-0                    -
                   plasma-activities              6.2.4-0                    -
             plasma-activities-stats              6.2.4-0                    -
          plasma-browser-integration              6.2.4-0                    -
                      plasma-desktop              6.2.4-0                    -
                        plasma-disks              6.2.4-0                    -
                     plasma-firewall              6.2.4-0                    -
                  plasma-integration              6.2.4-0                    -
                           plasma-nm              6.2.4-0                    -
                           plasma-pa              6.2.4-0                    -
                          plasma-sdk              6.2.4-0                    -
                plasma-systemmonitor              6.2.4-0                    -
                  plasma-thunderbolt              6.2.4-0                    -
                        plasma-vault              6.2.4-0                    -
                      plasma-welcome              6.2.4-0                    -
         plasma-workspace-wallpapers              6.2.4-0                    -
                 plasma5-integration              6.2.4-0                    -
                      plasma5support              6.2.4-0                    -
                        plymouth-kcm              6.2.4-0                    -
                    polkit-kde-agent              6.2.4-0                    -
                          powerdevil              6.2.4-0                    -
                       print-manager            1:6.2.4-0                    -
                   qqc2-breeze-style              6.2.4-0                    -
                            sddm-kcm              6.2.4-0                    -
                      systemsettings              6.2.4-0                    -
                         wacomtablet              6.2.4-0                    -
                        cinnamon-git                    - 6.2.9+r91+g7a4afa6-1
                  linux613-acpi_call                    -            1.2.2-0.1
                   linux613-bbswitch                    -              0.8-0.2
                linux613-broadcom-wl                    -     6.30.223.271-0.1
               linux613-nvidia-390xx                    -          390.157-0.1
               linux613-nvidia-470xx                    -       470.256.02-0.1
                     linux613-nvidia                    -          550.135-0.1
                      linux613-r8168                    -         8.054.00-0.1
                  linux613-rtl8723bu                    -         20240303-0.1
                   linux613-tp_smapi                    -             0.44-0.1
                linux613-vhba-module                    -         20240917-0.1
    linux613-virtualbox-host-modules                    -            7.1.4-0.1
                              acpica           20240321-1           20240927-1
                          alsa-utils             1.2.13-1             1.2.13-2
                            apitrace               11.1-3               12.0-1
                             archiso                 81-1                 82-1
                           bluedevil            1:6.2.3-1            1:6.2.4-1
                              breeze              6.2.3-1              6.2.4-1
                         breeze-grub              6.2.3-1              6.2.4-1
                          breeze-gtk              6.2.3-1              6.2.4-1
                     breeze-plymouth              6.2.3-1              6.2.4-1
                             breeze5              6.2.3-1              6.2.4-1
                    cinnamon-session              6.2.1-1              6.4.0-1
            cinnamon-settings-daemon              6.2.0-2              6.4.0-1
                            discover              6.2.3-1              6.2.4-1
                       docker-buildx             0.19.0-1             0.19.1-1
                             drkonqi              6.2.3-1              6.2.4-1
                         flatpak-kcm              6.2.3-1              6.2.4-1
                           git-evtag             2022.1-3             2022.1-4
                             haproxy              3.0.6-1              3.1.0-1
                             jenkins              2.485-1              2.487-1
                               js115           115.17.0-1           115.18.0-1
                               js128            128.4.0-1            128.5.0-1
                             jwt-cli              6.1.1-1              6.2.0-1
                   kactivitymanagerd              6.2.3-1              6.2.4-1
                       kde-cli-tools              6.2.3-1              6.2.4-1
                      kde-gtk-config              6.2.3-1              6.2.4-1
                         kdecoration              6.2.3-1              6.2.4-1
                    kdeplasma-addons              6.2.3-1              6.2.4-1
                              kgamma              6.2.3-1              6.2.4-1
                       kglobalacceld              6.2.3-1              6.2.4-1
                         kinfocenter              6.2.3-1              6.2.4-1
                           kmenuedit              6.2.3-1              6.2.4-1
                           kpipewire              6.2.3-2              6.2.4-1
                                krdp              6.2.3-1              6.2.4-1
                             kscreen              6.2.3-1              6.2.4-1
                       kscreenlocker              6.2.3-1              6.2.4-1
                         ksshaskpass              6.2.3-1              6.2.4-1
                        ksystemstats              6.2.3-1              6.2.4-1
                         kwallet-pam              6.2.3-1              6.2.4-1
                            kwayland              6.2.3-1              6.2.4-1
                kwayland-integration              6.2.3-1              6.2.4-1
                                kwin              6.2.3-1              6.2.4-1
                             kwrited              6.2.3-1              6.2.4-1
                      layer-shell-qt              6.2.3-1              6.2.4-1
                          libkscreen              6.2.3-1              6.2.4-1
                        libksysguard              6.2.3-1              6.2.4-1
                           libplasma              6.2.3-1              6.2.4-1
                        libqalculate              5.4.0-1            5.4.0.1-1
                              libzip             1.11.1-1             1.11.2-1
                               milou              6.2.3-1              6.2.4-1
                                nemo              6.2.8-1              6.4.0-1
                      nemo-audio-tab              6.2.0-1              6.4.0-1
                        nemo-emblems              6.2.0-1              6.4.0-1
                     nemo-fileroller              6.2.0-1              6.4.0-1
                nemo-image-converter              6.2.0-1              6.4.0-1
                       nemo-pastebin              6.2.0-1              6.4.0-1
                        nemo-preview              6.2.0-1              6.4.0-1
                         nemo-python              6.2.0-1              6.4.0-1
                       nemo-seahorse              6.2.0-1              6.4.0-1
                          nemo-share              6.2.0-1              6.4.0-1
                       nemo-terminal              6.2.0-1              6.4.0-1
                          nethsm-cli              0.4.0-1              0.4.1-1
                   ocean-sound-theme              6.2.3-1              6.2.4-1
                              opencv            4.10.0-14            4.10.0-15
                         opencv-cuda            4.10.0-14            4.10.0-15
                      opencv-samples            4.10.0-14            4.10.0-15
                              oxygen              6.2.3-1              6.2.4-1
                       oxygen-sounds              6.2.3-1              6.2.4-1
                             oxygen5              6.2.3-1              6.2.4-1
                               passt 2024_11_21.238c69f-1 2024_11_27.c0fbc7e-1
                  php-legacy-mongodb             1.20.0-1             1.20.1-1
                         php-mongodb             1.20.0-1             1.20.1-1
                   plasma-activities              6.2.3-1              6.2.4-1
             plasma-activities-stats              6.2.3-1              6.2.4-1
          plasma-browser-integration              6.2.3-1              6.2.4-1
                      plasma-desktop              6.2.3-1              6.2.4-1
                        plasma-disks              6.2.3-1              6.2.4-1
                     plasma-firewall              6.2.3-1              6.2.4-1
                  plasma-integration              6.2.3-1              6.2.4-1
                           plasma-nm              6.2.3-1              6.2.4-1
                           plasma-pa              6.2.3-1              6.2.4-1
                          plasma-sdk              6.2.3-1              6.2.4-1
                plasma-systemmonitor              6.2.3-1              6.2.4-1
                  plasma-thunderbolt              6.2.3-1              6.2.4-1
                        plasma-vault              6.2.3-1              6.2.4-1
                      plasma-welcome              6.2.3-1              6.2.4-1
         plasma-workspace-wallpapers              6.2.3-1              6.2.4-1
                 plasma5-integration              6.2.3-1              6.2.4-1
                      plasma5support              6.2.3-1              6.2.4-1
                             plocate             1.1.22-3             1.1.23-1
                        plymouth-kcm              6.2.3-1              6.2.4-1
                    polkit-kde-agent              6.2.3-1              6.2.4-1
                          powerdevil              6.2.3-1              6.2.4-1
                       print-manager            1:6.2.3-1            1:6.2.4-1
                       python-opencv            4.10.0-14            4.10.0-15
                        python-pooch              1.8.2-1              1.8.2-3
                   qqc2-breeze-style              6.2.3-1              6.2.4-1
                           qxmpp-qt5              1.9.0-1              1.9.1-1
                           qxmpp-qt6              1.9.0-1              1.9.1-1
                                rsop              0.4.2-1              0.4.3-1
                            sddm-kcm              6.2.3-1              6.2.4-1
            signstar-configure-build              0.1.0-1              0.1.1-1
                      systemsettings              6.2.3-1              6.2.4-1
                           virtiofsd             1.12.0-1             1.13.0-1
                         wacomtablet              6.2.3-1              6.2.4-1
                          webkit2gtk             2.46.3-1             2.46.4-1
                      webkit2gtk-4.1             2.46.3-1             2.46.4-1
                 webkit2gtk-4.1-docs             2.46.3-1             2.46.4-1
                     webkit2gtk-docs             2.46.3-1             2.46.4-1
                       webkitgtk-6.0             2.46.3-1             2.46.4-1
                  webkitgtk-6.0-docs             2.46.3-1             2.46.4-1
                           wpewebkit             2.46.3-1             2.46.4-1
                      wpewebkit-docs             2.46.3-1             2.46.4-1
                                 zed            0.162.5-1            0.163.2-1
                         clairvoyant                    -              3.1.8-2
                              gaphor                    -             2.27.0-1
                              luanti                    -             5.10.0-1
                       luanti-common                    -             5.10.0-1
                       luanti-server                    -             5.10.0-1
            python-better-exceptions                    -              0.3.3-1
                       python-gaphas                    -              4.1.1-2
                      python-generic                    -              1.1.3-2
                  python-opencv-cuda                    -            4.10.0-15
                python-pyperformance                    -             1.11.0-1
:: Different sync package(s) in repository multilib x86_64
                      lib32-apitrace               11.1-2               12.0-1
Those who have issues with Cinnamon can try the cinnamon-git package.
I encountered zero issues when I switched to the release candidate for kernel 6.12 (I think it was 6.12.0rc4 when I made the change), so I’ve just installed & rebooted into 6.13.0rc0-1. No issues so far.
This fixed my Bluetooth problem, thanks!
Pretty funny that Manjaro (and ArchLinux maybe) decided to go forward nonetheless.
Welp, as long as it stays in Testing I guess, we like to live dangerously. :slight_smile:
Cinnamon 6.4.0 got tagged today. We will see when @Yochanan finds time to update it. USA has thanks giving this week. Those who want to test it out can install cinnamon-git package I updated already to that version.
Installing cinnamon-git fixes the sound applet here. Thx.
cinnamon 6.4.0-1 is now available. If one had temporarily installed cinnamon-git, one will need to manually install cinnamon again to replace it.
Is the Branch compare for Manjaro working ?
It is a very practice tool.
plasma 6.2.4 is available on the servers but not on the Branch compare for Manjaro…
x86 && ARM
https://manjaristas.org/branch_compare?q=plasma
