[Testing Update] 2024-11-06 - Kernel 6.12-rc6, Plasma 6.2.3, Bluez 5.79, Cosmic 1.0 Alpha 3
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: Get 4 months extra
Recent News
Previous News
Notable Package Updates
Additional Info
Nvidia driver downgrade
Nvidia drivers got downgraded to 550.100, therefore update with sudo pacman -Syuu. If you want to stay on the 555 driver series you may either switch to unstable or install nvidia-dkms via: sudo pacman -U https://mirror.easyname.at/manjaro/pool/overlay/nvidia-dkms-555.58.02-1-x86_64.pkg.tar.zst. More info about Nvidia drivers here:
555 release feedback & discussion - Linux - NVIDIA Developer Forums
550.78 release feedback & discussion thread - Linux - NVIDIA Developer Forums
Python 3.12 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.11.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.11/ :
pacman -Qoq /usr/lib/python3.11/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.11)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
Our current supported kernels
  • linux419 4.19.322
  • linux54 5.4.284
  • linux510 5.10.228
  • linux515 5.15.170
  • linux61 6.1.115
  • linux66 6.6.59
  • linux610 6.10.14 [EOL]
  • linux611 6.11.6
  • linux612 6.12.0-rc6
  • linux61-rt 6.1.112_rt43
  • linux66-rt 6.6.53_rt44
  • linux610-rt 6.10.2_rt14
Package Changes (Wed Nov 6 02:31:06 CET 2024)
  • testing core x86_64: 9 new and 9 removed package(s)
  • testing extra x86_64: 504 new and 477 removed package(s)
  • testing multilib x86_64: 7 new and 6 removed package(s)
Overlay Changes
  • testing core x86_64: 3 new and 3 removed package(s)
  • testing extra x86_64: 22 new and 24 removed package(s)
A list of all package changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2024-11-06
2024-11-01
KVM default behavior change on module loading in kernel 6.12
In kernel 6.12, KVM initializes virtualization on module loading by default. This prevents VirtualBox VMs from starting. In order to avoid this, either add kvm.enable_virt_at_load=0 parameter into kernel command line or unload the corresponding kvm_XXX module. Initial support for 6.12 kernel series was added with Virtualbox 7.1.4.
More info about that in the Linux mailing list
2024-10-20
Kernel 6.10 has been marked [EOL] on kernel.org
sddm login problems with multiple monitors
  • bug report
  • login only works on secondary monitor
  • switching sddm theme to maldives works around the issue
2024-09-13
:warning: Linux 6.9 is EOL
Linux 6.9 is EOL and has been removed from the repos.
Suggestion is to install latest LTS; i.e.,
sudo mhwd-kernel -i linux66
System freeze on suspend
A feature in systemd 256 freezing a user session when suspending may freeze the system.
The issue is most prominent with Nvidia systems but reports exist that it may affect other systems as well.
System freezes for 60 seconds and then wakes back up or hangs after waking up
Since systemd v256, systemd freezes user.slice before sleeping. This process can fail due to kernel bugs, particularly when KVM is in use.[13][14]
Messages in the logs will contain Failed to freeze unit 'user.slice' before sleep. When such an issue occurs, trying to login (start another session) would fail with pam_systemd(process:session): Failed to create session: Job 9876 for unit 'session-6.scope' failed with 'frozen'.
To temporarily revert back to the old behavior, edit systemd-suspend.service, systemd-hibernate.service, systemd-hybrid-sleep.service, and systemd-suspend-then-hibernate.service with the following drop-in:
[Service]
Environment="SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=false"
Power management/Suspend and hibernate - ArchWiki
KDE Plasma hangs on Shutdown, Restart and Logout
With KDE Plasma 6.1, the session saving feature can make Plasma hang.
A workaround is to disable it in System settings > Session > Desktop Session, by choosing “Start with an empty session”.
KDE Session auto login can't be re-enabled for X11
Once session auto login for X11 gets disabled, it can’t be re-enabled in settings.
A workaround is to edit the /etc/sddm.conf.d/kde_settings.conf file and replace Session=Plasma (X11) by Session=plasma
2024-08-04
pulseaudio-ctl requires pulseaudio and is not compatible with pipewire
If one is using PipeWire, one will need to remove pulseaudio-ctl if prompted during the update as it’s only compatible with pulseaudio
Previous testing threads:
3 posts were split to a new topic: Feelling a bit adventurous I decided to take a walk on the wild side
I noticed difficulties with exiting the session, rebooting, and shutting down. Session saving has been disabled since the last time, I don’t see anything in the log, just either no reaction, or a black screen(as it was before disabling session saving), and the cursor. I did this, set save session, apply, and then returned do not save. After that, it rebooted normally, we will see what happens next)
Addition, in general, to exit the session, restart, etc. it is impossible to go through the menu, just nothing happens and everything in the log is silent, session saving is disabled. Something can only be done through the terminal, for example, reboot, poweroff, and so on
  Kernel: 6.11.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=b326b8d9-9b77-469c-9ab8-526f002cbfba rw quiet splash
    resume=UUID=0fce9c48-9f96-4bc5-9c34-5ffc0f3c6c62 udev.log_priority=3
    mitigations=off
  Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.7.0
  Type: Laptop System: ASUSTeK product: TP300LDB v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: TP300LDB v: 1.0 serial: <superuser required>
    part-nu: ASUS-NotebookSKU uuid: <superuser required>
    UEFI: American Megatrends v: TP300LDB.211 date: 04/16/2019
  ID-1: BAT0 charge: 40.4 Wh (100.0%) condition: 40.4/50.1 Wh (80.7%)
    volts: 11.3 min: 11.3 model: ASUSTeK UX3-44 type: Li-ion serial: N/A
    status: not charging cycles: 1079
  System RAM: total: 12 GiB available: 11.12 GiB used: 2.87 GiB (25.8%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: N/A serial: N/A
  Device-2: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    manufacturer: 1201 part-no: R538G1601S2SL serial: N/A
  Info: model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell
    gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
    family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2196 min/max: 500/2700 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 2196 2: 2196 3: 2196 4: 2196 bogomips: 17566
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid lahf_lm
    lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat
    pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts
    rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
    tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
  Type: mds status: Vulnerable; SMT vulnerable
  Type: meltdown status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
  Type: srbds status: Vulnerable
  Device-1: Intel HD Graphics 5500 vendor: ASUSTeK driver: i915 v: kernel
    arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
    620M/625M/630M/720M] vendor: ASUSTeK driver: nouveau v: kernel non-free:
    series: 390.xx+ status: legacy (EOL~2022-11-22) last: release: 390.157
    kernel: 6.0 xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm
    built: 2010-2016 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: lanes: 8
    bus-ID: 03:00.0 chip-ID: 10de:1140 class-ID: 0302
  Device-3: Suyin Asus Integrated Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-5:4 chip-ID: 064e:9700
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris,nouveau gpu: i915,nouveau display-ID: 0
  Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
    device: 0 drv: iris device: 1 drv: nouveau device: 2 drv: swrast gbm:
    drv: iris surfaceless: drv: iris wayland: drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 24.2.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
    device-ID: 8086:1616 memory: 5.43 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 5500 (BDW GT2) driver: mesa intel v: 24.2.6-arch1.1
    device-ID: 8086:1616 surfaces: xcb,xlib,wayland
  Device-1: Intel Broadwell-U Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
    class-ID: 0403
  API: ALSA v: k6.11.6-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
  Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:08b1 class-ID: 0280
  IF-ID-1: CloudflareWARP state: unknown speed: 10000 Mbps duplex: full
    mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-4:3 chip-ID: 8087:07dc
    class-ID: e001
  Local Storage: total: 447.13 GiB used: 62.03 GiB (13.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: TR200 size: 447.13 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 13.6 scheme: GPT
  ID-1: / raw-size: 146.48 GiB size: 143.13 GiB (97.71%)
    used: 25.12 GiB (17.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: b326b8d9-9b77-469c-9ab8-526f002cbfba
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: B8A9-BAA4
  ID-3: /home raw-size: 284.73 GiB size: 279.2 GiB (98.06%)
    used: 36.91 GiB (13.2%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: b69511a1-4ed8-4c95-be54-807f86927a04
  Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
    zswap: yes compressor: zstd max-pool: 20%
  ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 0fce9c48-9f96-4bc5-9c34-5ffc0f3c6c62
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8001
  Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 11 rev: 2.0
  Device-1: 2-3:2 info: YICHIP Wireless Device type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:3020 class-ID: 0301
  Device-2: 2-4:3 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:07dc class-ID: e001
  Device-3: 2-5:4 info: Suyin Asus Integrated Webcam type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 064e:9700 class-ID: 0e02 serial: <filter>
  Device-4: 2-7:5 info: Atmel type: HID
    driver: hid-generic,hid-multitouch,usbhid interfaces: 2 rev: 2.0
    chip-ID: 03eb:8b04 class-ID: 0300
  Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 49.0 C pch: 39.5 C mobo: N/A
  Fan Speeds (rpm): cpu: 2700
  Packages: 1420 pm: pacman pkgs: 1382 libs: 377 tools: pamac pm: flatpak
    pkgs: 38
    1: https://ftp.lysator.liu.se/pub/manjaro/unstable/$repo/$arch
    2: https://mirrors.manjaro.org/repo/unstable/$repo/$arch
    3: https://mirrors2.manjaro.org/unstable/$repo/$arch
    4: https://ask4.mm.fcix.net/manjaro/unstable/$repo/$arch
    5: https://ipng.mm.fcix.net/manjaro/unstable/$repo/$arch
    6: https://manjaro.mirrors.lavatech.top/unstable/$repo/$arch
    7: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/unstable/$repo/$arch
    8: https://ftp.gwdg.de/pub/linux/manjaro/unstable/$repo/$arch
    9: https://manjaro.kurdy.org/unstable/$repo/$arch
    10: https://mirror.easyname.at/manjaro/unstable/$repo/$arch
    11: https://mirror.koddos.net/manjaro/unstable/$repo/$arch
    12: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/unstable/$repo/$arch
    13: https://mirror.raiolanetworks.com/manjaro/unstable/$repo/$arch
    14: http://manjaro.mirrors.uk2.net/unstable/$repo/$arch
    15: https://uvermont.mm.fcix.net/manjaro/unstable/$repo/$arch
    16: https://cofractal-ewr.mm.fcix.net/manjaro/unstable/$repo/$arch
    17: https://forksystems.mm.fcix.net/manjaro/unstable/$repo/$arch
    18: https://mirror.math.princeton.edu/pub/manjaro/unstable/$repo/$arch
    19: https://coresite.mm.fcix.net/manjaro/unstable/$repo/$arch
    20: https://mnvoip.mm.fcix.net/manjaro/unstable/$repo/$arch
    21: http://mirror.fcix.net/manjaro/unstable/$repo/$arch
    22: https://mirror.alpix.eu/manjaro/unstable/$repo/$arch
    23: https://volico.mm.fcix.net/manjaro/unstable/$repo/$arch
    24: https://nnenix.mm.fcix.net/manjaro/unstable/$repo/$arch
    25: https://ziply.mm.fcix.net/manjaro/unstable/$repo/$arch
    26: https://irltoolkit.mm.fcix.net/manjaro/unstable/$repo/$arch
    27: https://nocix.mm.fcix.net/manjaro/unstable/$repo/$arch
    28: https://opencolo.mm.fcix.net/manjaro/unstable/$repo/$arch
    29: https://southfront.mm.fcix.net/manjaro/unstable/$repo/$arch
    30: https://codingflyboy.mm.fcix.net/manjaro/unstable/$repo/$arch
    31: https://edgeuno-bog2.mm.fcix.net/manjaro/unstable/$repo/$arch
    32: https://repo.ialab.dsu.edu/manjaro/unstable/$repo/$arch
    33: https://muug.ca/mirror/manjaro/unstable/$repo/$arch
    34: https://mirror.archlinux.tw/Manjaro/unstable/$repo/$arch
    35: https://gsl-syd.mm.fcix.net/manjaro/unstable/$repo/$arch
    36: http://mirror.is.co.za/mirrors/manjaro.org/unstable/$repo/$arch
    37: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/unstable/$repo/$arch
    38: https://mirror.2degrees.nz/manjaro/unstable/$repo/$arch
    39: https://mirror.ufro.cl/manjaro/unstable/$repo/$arch
    40: http://ossmirror.mycloud.services/os/linux/manjaro/unstable/$repo/$arch
    41: https://manjaro.c3sl.ufpr.br/unstable/$repo/$arch
    42: https://ridgewireless.mm.fcix.net/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 235
  1: cpu: 19.7% command: firefox pid: 1549 mem: 471.6 MiB (4.1%)
  2: cpu: 16.6% command: firefox pid: 1774 mem: 289.0 MiB (2.5%)
  3: cpu: 7.8% command: kwin_wayland pid: 808 mem: 204.1 MiB (1.7%)
  4: cpu: 5.6% command: konsole pid: 2003 mem: 150.3 MiB (1.3%)
  5: cpu: 4.0% command: plasmashell pid: 1056 mem: 333.8 MiB (2.9%)
  Memory top: 5 of 235
  1: mem: 471.6 MiB (4.1%) command: firefox pid: 1549 cpu: 19.7%
  2: mem: 333.8 MiB (2.9%) command: plasmashell pid: 1056 cpu: 4.0%
  3: mem: 289.0 MiB (2.5%) command: firefox pid: 1774 cpu: 16.6%
  4: mem: 223.3 MiB (1.9%) command: firefox pid: 1705 cpu: 3.7%
  5: mem: 204.1 MiB (1.7%) command: kwin_wayland pid: 808 cpu: 7.8%
  Processes: 235 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 4.42 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
7 posts were split to a new topic: Tried to switch from stable to testing
