[Testing Update] 2024-10-24 - Plasma, DKMS, Gitlab, Signal
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: Get 4 months extra
Recent News
Previous News
Notable Package Updates
Additional Info
Nvidia driver downgrade
Nvidia drivers got downgraded to 550.100, therefore update with sudo pacman -Syuu. If you want to stay on the 555 driver series you may either switch to unstable or install nvidia-dkms via: sudo pacman -U https://mirror.easyname.at/manjaro/pool/overlay/nvidia-dkms-555.58.02-1-x86_64.pkg.tar.zst. More info about Nvidia drivers here:
555 release feedback & discussion - Linux - NVIDIA Developer Forums
550.78 release feedback & discussion thread - Linux - NVIDIA Developer Forums
Python 3.12 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.11.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.11/ :
pacman -Qoq /usr/lib/python3.11/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.11)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
Our current supported kernels
  • linux419 4.19.322
  • linux54 5.4.284
  • linux510 5.10.228
  • linux515 5.15.169
  • linux61 6.1.114
  • linux66 6.6.58
  • linux610 6.10.14 [EOL]
  • linux611 6.11.5
  • linux612 6.12.0-rc4
  • linux61-rt 6.1.112_rt43
  • linux66-rt 6.6.53_rt44
  • linux610-rt 6.10.2_rt14
Package Changes (Thu Oct 24 03:54:11 CEST 2024)
  • testing core x86_64: 2 new and 2 removed package(s)
  • testing extra x86_64: 606 new and 607 removed package(s)
  • testing multilib x86_64: 2 new and 2 removed package(s)
A list of all package changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2024-10-20
Kernel 6.10 has been marked [EOL] on kernel.org
sddm login problems with multiple monitors
  • bug report
  • login only works on secondary monitor
  • switching sddm theme to maldives works around the issue
2024-09-13
:warning: Linux 6.9 is EOL
Linux 6.9 is EOL and has been removed from the repos.
Suggestion is to install latest LTS; i.e.,
sudo mhwd-kernel -i linux66
System freeze on suspend
A feature in systemd 256 freezing a user session when suspending may freeze the system.
The issue is most prominent with Nvidia systems but reports exist that it may affect other systems as well.
System freezes for 60 seconds and then wakes back up or hangs after waking up
Since systemd v256, systemd freezes user.slice before sleeping. This process can fail due to kernel bugs, particularly when KVM is in use.[13][14]
Messages in the logs will contain Failed to freeze unit 'user.slice' before sleep. When such an issue occurs, trying to login (start another session) would fail with pam_systemd(process:session): Failed to create session: Job 9876 for unit 'session-6.scope' failed with 'frozen'.
To temporarily revert back to the old behavior, edit systemd-suspend.service, systemd-hibernate.service, systemd-hybrid-sleep.service, and systemd-suspend-then-hibernate.service with the following drop-in:
[Service]
Environment="SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=false"
– Power management/Suspend and hibernate - ArchWiki
KDE Plasma hangs on Shutdown, Restart and Logout
With KDE Plasma 6.1, the session saving feature can make Plasma hang.
A workaround is to disable it in System settings > Session > Desktop Session, by choosing “Start with an empty session”.
KDE Session auto login can't be re-enabled for X11
Once session auto login for X11 gets disabled, it can’t be re-enabled in settings.
A workaround is to edit the /etc/sddm.conf.d/kde_settings.conf file and replace Session=Plasma (X11) by Session=plasma
2024-08-04
pulseaudio-ctl requires pulseaudio and is not compatible with pipewire
If one is using PipeWire, one will need to remove pulseaudio-ctl if prompted during the update as it’s only compatible with pulseaudio
Previous testing threads:
Sadly getting votes but no posts detailling the issues…
I’m not sure, but I have problems with cursor movement in the terminal editor. nano, micro.
I’m not sure if it’s caused by vte.
I’m busy today, so I can’t spend time on manjaro, so I restored it. I’m going out.
removing 'vte4-0.76.4-1' from target list because it conflicts with 'vte4-notification-0.76.4-2'
:: vte4-notification-0.76.4-2 and vte4-0.78.1-1 are in conflict. Remove vte4? [y/N]
@ehhen you can check with @Yochanan why it was dropped: Packages / extra / vte3-notification · GitLab
It was fixed after I restored it.
Issue:
it87 (AUR) and linux6.11.5 (only) ==> ERROR :face_with_hand_over_mouth:
EDIT:
ERROR gone with upgrading dkms (3.0.13-1 → 3.1.1-1)
@Ben
I vote and no issues reported because I have none.
Wait…there’s one, most of the time when I vote, I notice the count does not increment.
apparmor 4.0.3-1 fixed this error:
vte4-notification was dropped from the repos as it is now deprecated. Nothing in the repos depends on it. gnome-terminal-fedora depended on it which was also dropped. If you have that installed, install gnome-terminal to replace it.
battery icon in the system tray remain always visible even if it is fully charged, before it use to disappear
both, wayland or x11
You changed the setting to “Show when relevant”? It may have defaulted to “Always Show.”
Update on the pinebook pro went smoothly. However, after reboot
  • no WLAN. Tries to connect, but doesn’t get credentials right.
  • ksystemstats closes unexpectedly permanently.
  • Desktop sometimes crashes.
already checked, it is on “Show when relevant”, that’s the strange thing…
Bug
