Failed to start load apparmor profiles
During boot, just before the login screen, screen writes:
[FAILED] Failed to start load apparmor profiles
but sudo aa-status outputs:
apparmor module is loaded.
62 profiles are loaded.
62 profiles are in enforce mode.
   /usr/lib/apache2/mpm-prefork/apache2
   /usr/lib/apache2/mpm-prefork/apache2//DEFAULT_URI
   /usr/lib/apache2/mpm-prefork/apache2//HANDLING_UNTRUSTED_INPUT
   /usr/lib/apache2/mpm-prefork/apache2//phpsysinfo
   /usr/lib/snapd/snap-confine
   /usr/lib/snapd/snap-confine//mount-namespace-capture-helper
   apache2
   apache2//phpsysinfo
   avahi-daemon
   dnsmasq
   dnsmasq//libvirt_leaseshelper
   dovecot
   dovecot-anvil
   dovecot-auth
   dovecot-config
   dovecot-deliver
   dovecot-dict
   dovecot-director
   dovecot-doveadm-server
   dovecot-dovecot-auth
   dovecot-dovecot-lda
   dovecot-dovecot-lda//sendmail
   dovecot-imap
   dovecot-imap-login
   dovecot-lmtp
   dovecot-log
   dovecot-managesieve
   dovecot-managesieve-login
   dovecot-pop3
   dovecot-pop3-login
   dovecot-replicator
   dovecot-script-login
   dovecot-ssl-params
   dovecot-stats
   identd
   klogd
   lsb_release
   mdnsd
   nmbd
   nscd
   ntpd
   nvidia_modprobe
   nvidia_modprobe//kmod
   php-fpm
   ping
   samba-bgqd
   samba-dcerpcd
   samba-rpcd
   samba-rpcd-classic
   samba-rpcd-spoolss
   smbd
   smbldap-useradd
   smbldap-useradd///etc/init.d/nscd
   syslog-ng
   syslogd
   traceroute
   winbindd
   zgrep
   zgrep//helper
   zgrep//sed
0 profiles are in complain mode.
0 profiles are in kill mode.
0 profiles are in unconfined mode.
0 processes have profiles defined.
0 processes are in enforce mode.
0 processes are in complain mode.
0 processes are unconfined but have a profile defined.
0 processes are in mixed mode.
0 processes are in kill mode.
    root=UUID=a9df395f-e33b-4fae-a1b2-6ade974a1b16 rw amd_pstate=guided
    iommu=pt quiet apparmor=1 security=apparmor udev.log_priority=3
It started appearing a few days ago, did i miss some config change or can i ignore that?
That’s just mean that one or more profiles wasn’t loaded for some reason (maybe syntax errors or changes in last update) and these failed profiles aren’t listed by aa-status (because it’s not correct profile).
Fixed with apparmor 4.0.3-1
