We currently have a flashsale with our partner MINISFORUM on the UM790Pro featuring the Manjaro Linux GamingEdition. Use the device either as a MiniPC or Gaming Console! Use our link to get yours. Note: US Market only!
Find out all about our current Gaming Laptop the Hero with Manjaro pre-installed from Spain!
Protect your personal data, keep yourself safe with Surfshark VPN: 79% OFF + 2 mo. FREE
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
As you might have seen some of our team were able to attend FOSDEM 2023 and the conference proved to be incredibly productive for us. See our blog post for more.
Finding information easier about Manjaro always has been a topic that needed to be solved. With our new search we have put all Manjaro data accessible in one place and divided by sections so it makes it easier to digest: New Manjaro search engine is available | Blog
AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcements topics are off-topic and will be flagged, moved or removed without warning.
For help with AUR packages, please create a new topic in AUR and a helpful volunteer may be able to assist you.
pacman-contrib is now split out from pacman. If you have anything installed that depends on pacman-contrib, update with:
sudo pacman -Syu pacman-contrib
2024-01-11
Making dbus-broker our default D-Bus daemon
2024-01-09 - Jan Alexander Steffens
We are making dbus-broker our default implementation of D-Bus, for improved performance, reliability and integration with systemd.
For the foreseeable future we will still support the use of dbus-daemon, the previous implementation. Pacman will ask you whether to install dbus-broker-units or dbus-daemon-units. We recommend picking the default.
For a more detailed rationale, please see our RFC 25.
Due to various issues including non working backlights on some machines, the NVIDIA 545 series feature branch drivers have been downgraded to the 535 series production branch drivers.
If you are having no issues with the 545 series, there is nothing to do. If you are, you can downgrade to the 535 series with pamac update --enable-downgrade or sudo pacman -Syuu.
So far we know about these issues the Nvidia 545 driver series has:
Backlight control might not work on certain laptop configurations. Reported also here
If you experience similar or new issues please run sudo usr/bin/nvidia-bug-report.sh and post either in an already given post or create a new one, including your generated nvidia-bug-report.log.gz for Nvidia to fix the issue: Linux - NVIDIA Developer Forums
Changes in JDK / JRE 21 packages may require manual intervention
2023-11-02 - Frederik Schwan
We are introducing a change in JDK/JRE packages of our distro. This is triggered from the way a JRE is build in modern versions of Java (>9). We are introducing this change in Java 21.
To sum it up instead of having JDK and JRE packages coexist in the same system we will be making them conflict. The JDK variant package includes the runtime environment to execute Java applications so if one needs compilation and runtime of Java they need only the JDK package in the future. If, on the other hand, they need just runtime of Java then JRE (or jre-headless) will work.
This will (potentially) require a manual user action during upgrade:
If you have both JDK and JRE installed you can manually install the JDK with pacman -Sy jdk-openjdk && pacman -Su and this removes the JRE related packages.
If you have both JRE and JRE-headless you will need to choose one of them and install it manually since they would conflict each other now.
If you only have one of the JDK/JRE/JRE-headless pacman should resolve dependencies normally and no action is needed.
At the moment this is only valid for the upcoming JDK 21 release.
all is ok for kernel 6.7.6 + nvidia 550.54.14
video avc1 1080p x 60 fps is ok
steam + opengl ok
and resume xfce screen ( wait few minutes to see login appears ) , no more restart ligtdm
there is also some option with current drive nvidia
for HDMI 10 bits can be test with hdmi_deepcolor=1
I want to try the deepcolor mode. Do you know how it can be activated and how I can verify that it is in use?
I tried to use the kernel parameter “nvidia-modeset.hdmi_deepcolor=1” in grub to activate it, but have the impression that this does not work. I use two Eizo ColorEdge CS2731 monitors connected via displayport and believe that they should be able to display 10 bit colors.
