[Testing Update] 2023-01-04 - Kernels, Plasma 5.26., Deepin
Hello community,
Another testing branch update with some usual package updates for you. We hope that you had a good start into 2023 and some great days over the holidays …
Recent News:
Notable Package Updates:
  • Some Kernels got updated. This is also the start of the 6.2 kernel series
  • Pipewire got some fixes added
  • Plasma 5.26 ends out with its last point-release
  • Deepin got a lot of updated packages
  • Beside the usual upstream updates like Firefox-Beta, python, haskell and others we added our KDE-git packages as usual
Additional Info
Info about AUR packages
:warning: AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
Info about GNOME 43
GNOME 43 is here! :partying_face:
New in Manjaro GNOME:
Lonely leftover orphan packages that have been removed from the Arch / Manjaro repositories:
  • adwaita-maia
  • dynamic-wallpaper-editor
  • firefox-gnome-theme-maia
  • gtkhash-nautilus
    (Not compatible with Nautilus 43)
  • manjaro-dynamic-wallpaper
  • manjaro-gdm-tweak
  • nautilus-terminal
    (Not compatible with Nautilus 43 & EOL)
Our current supported kernels
  • linux419 4.19.269
  • linux54 5.4.228
  • linux510 5.10.161
  • linux515 5.15.86
  • linux60 6.0.16
  • linux61 6.1.2
  • linux515-rt 5.15.85_rt55
  • linux60-rt 6.0.5_rt14
Package changes (Wed Jan 4 06:46:46 CET 2023)
  • testing community x86_64: 1499 new and 1468 removed package(s)
  • testing core x86_64: 25 new and 23 removed package(s)
  • testing extra x86_64: 268 new and 258 removed package(s)
  • testing kde-unstable x86_64: 359 new and 359 removed package(s)
  • testing multilib x86_64: 14 new and 13 removed package(s)
A list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2023-01-04
VLC crashes when playing a video file
It looks like there has been a regression introduced with the new version of libva (2.17.0), which is used by VLC media player. If you get the following error when executing vlc in a terminal:
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
you may try to change the Output option in Preferences > Video to VDPAU output instead of Automatic (or whatever value it had been set to before).
Downgrading the libva package from 2.17.0-1 to 2.16.0-1 may also work, but it is a more short-term workaround that should not be kept for too long, as sooner or later, the older package won’t be compatible with the other packages. Consider to do the solution above first.
2022-12-22
pacman-mirrors was temporarily renamed to manjaro-mirrors (the changes were reverted)
This was done to avoid confusion with an AUR / WSL package with the same name and avoid possible breakage. It should be a seamless transition.
Rename project (#183) · Issues · Applications / pacman-mirrors · GitLab
2022-12-19
KDE Wayland sometimes hangs with mesa 22.3.1 and AMD GPU
2022-12-16
dbus-x11 demoted to AUR
dbus-x11 was installed out of the box on some flavors of Manjaro as of a year ago, but is no longer needed. If you have it installed, please replace it with dbus using the following:
sudo pacman -Syu dbus
XFCE becomes unusable if libxfce4ui-nocsd is still installed
So far XFCE Classic project hasn’t updated yet to 4.18 series. We pushed 4.17.0 version of the package, but don’t know if that helps in that situation. It is recommended to install the regular libxfce4ui package to avoid issues and comment on this issue: libxfce4ui 4.18.0 released · Issue #15 · Xfce-Classic/libxfce4ui-nocsd · GitHub
2022-12-04
python-cairo 1.23.0-2 update requires manual intervention
The python-cairo package prior to version 1.23.0-2 was missing the compiled python module. This has been fixed in 1.23.0-2, so the upgrade will need to overwrite the untracked pyc file that was created. If you receive this error
python-cairo: /usr/lib/python3.10/site-packages/cairo/__pycache__/__init__.cpython-310.pyc exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/python3.10/site-packages/cairo/__pycache__/\*
to perform the upgrade.
2022-11-08
Pop Shell issues with Xorg session with Mutter 43.1 (fixed with mutter 43.1-1.0)
Gnome 43 (X11) GTK4 windows failed to render · Issue #1541 · pop-os/shell · GitHub
Making sure you're not a bot!
2022-10-28
signature from "Manjaro Build Server <build_at_manjaro_dot_org>" is unknown trust
Seems our signing key for our Build Server had the 2022-10-28 as expire date set when generated. This is now fixed for chroot builds and fresh as also current existing installs via manjaro-keyring 20221028-4 Simply update your system to get that package, which got pushed to all our branches.
2022-10-27
Kernel 6.1-rc# might break backlight control on old/weird laptops
2022-10-18
Firefox 106.0 may have issues with screen sharing on GNOME with Wayland
2022-09-23
Nvidia 3060RTX cards may have issues with the 515.76 driver (fixed with 520.56.06)
Removing python2 from the repositories
2022-09-23 - Jelle van der Waa
Python 2 went end of life January 2020. Since then we have been actively cutting down the number of projects depending on python2 in our repositories, and we have finally been able to drop it from our distribution. If you still have python2 installed on your system consider removing it and any python2 package.
If you still require the python2 package you can keep it around, but please be aware that there will be no security updates. If you need a patched package please consult the AUR, or use an unofficial user repository.*
– Arch Linux - News: Removing python2 from the repositories
* Note: Unofficial user repositories are not supported
2022-08-27
Changes with Back In Time packages
  • backintime has been renamed to backintime-qt
  • backintime-cli has been renamed to backintime
After replacing backintime-cli with backintime, you will need to install backintime-qt manually if you want the Qt frontend installed again.
2022-08-23
electron12, electron13, electron14 & electron16 have been dropped to the AUR
Unsupported Electron packages have been dropped from the official repos to the AUR. They no longer receive security updates and nothing in the repos depend on them.
If you have AUR packages depending on those versions, install the binary version from the AUR to replace them; i.e., electron16-bin.
See FS#75490 - electron12, electron13, electron14, electron16 are unsupported and vulnerable packages
End of Support for 15.x.y and 16.x.y
Electron 15.x.y and 16.x.y has reached end-of-support. As per Electron’s new 8-week cadence, we were supporting the latest four versions of Electron until May 2022. With this Electron 19 release, we’ll return to supporting the latest three major versions, as well as the alpha, beta, and nightly releases.
– This is due to an AUR / WSL package to avoid confusion and possible breakage. It should be a seamless transition.Release electron v19.0.0 · electron/electron · GitHub
2022-08-12
element-desktop dependency error (fixed with 1.11.4)
:: installing electron (20.0.0-1) breaks dependency 'electron19' required by element-desktop
```[details=pacman-mirrors has been renamed to manjaro-mirrors]
https://gitlab.manjaro.org/applications/pacman-mirrors/-/issues/183
The upstream package was already flagged out of date (it needs to be rebuilt against latest electron).
Workaround for now:
sudo pacman -Syy electron electron19 --asdeps
sudo pacman -Su
[/details]
2022-08-04
Glibc 2.36 update will break EasyAntiCheat within Proton (should be fixed with glibc 2.36-2)
Temporary workaround for now is to use the flatpak version of steam:
sudo pacman -S flatpak --needed --noconfirm
sudo flatpak install com.valvesoftware.Steam -y
You can use flatseal (another flatpak app) to grant it access to your existing game library so you don’t have to re-download your games (add the game library install path under “Other files” under “Filesystem”).
sudo flatpak install com.github.tchx84.Flatseal -y
For advanced users (not recommended by us): patched glibc and lib32-glibc are available here. They remove the commit that broke EAC.
2022-07-27
Fixed: Pamac shows archlinux-keyring (20220713-2) and manjaro-keyring (20220514-2) as orphans
sudo pacman -D --asexplicit archlinux-keyring manjaro-keyring
Resolved: w/ base 3-2 Revert changes:
sudo pacman -D --asdeps archlinux-keyring manjaro-keyring
2022-07-16
wxWidgets 3.2 update may need manual intervention
Packages have been renamed from wxgtk- to wxwidgets-. The GTK2 frontend is no longer provided. If you have wxgtk2 installed, the upgrade will fail with:
In such case, uninstall wxgtk2 first and then proceed with the upgrade.
2022-07-13
Linux518: could not insert 'amd_pstate': No such device
With Kernel 5.18.11 there was added a regression to AMD P-State driver preventing it from loading.
2022-07-08
Wireplumber 0.4.11 may crash for GDM users
Currently there is an issue with 0.4.11 and GDM crashing on boot-up. More in the upstream bugtracker issue: Making sure you're not a bot!
2022-06-07
Locale file changes
C.UTF8 locale is now included in glibc:
Credits @diabonas for this change. Systemd wants us to include C.UTF8 by default and it seems the locale may be in included by glibc upstream in the future. To fix building and avoid nasty fixing in devtools, we include the locale in the package. See systemd/systemd#23252 (comment) FS#74864 : [systemd] >= 251 breaks devtools' locale
There is a pacsave for /etc/locale.conf as it has been removed from the filesystem package.
UPDATE: With filesystem 2022.06.08-2, it will automatically restore /etc/locale.conf if it did not already exist.
Uploading: image.png…
There is a pacnew for /etc/locale.gen. Please review it and regenerate your locale if necessary.
the last version of mesa 22.3.2 still has this issue. There is the bugfix, but it hasn’t been merged yet.
Or you can add this patch to Mesa and build it yourself for AMD GPU. But downgrade mesa is simple solution without some new features of mesa.
Weird system freezes with caps lock button switching on and off on my t16 amd. Kernel: 6.0.16
pacsave file found for /usr/share/icons/default/index.theme
pamac search --files  /usr/share/icons/default/index.theme
/usr/share/icons/default/index.theme is owned by default-cursors
I’ve chosen to set the value in the file to Adwaita
My AMD laptop cpu temp is down to 31° from 41° in idle. This is with kernel 6.2. compared to 6.1.
It’s on par now with what I use to get with intel cpus.
And though it’s early rc of 6.2 the kernel log is clean.
Mh, it looks like something weird happened with these set of updates with VLC. I get a segfault when I try to read a video file in VLC. It’s fine on mpv though.
VLC didn’t get updated with this update set, so I guess we got a crappy version of one of its dependency (libva perhaps?).
    ~  vlc         ✔
VLC media player 3.0.18 Vetinari (revision 3.0.13-8-g41878ff4f2)
[000055b3d0f96550] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[000055b3d1032b40] main playlist: playlist is empty
kf.kio.core: Invalid URL: QUrl("/home/frog")
kf.jobwidgets: Cannot register a job with KUiServerV2JobTracker without QGuiApplication::desktopFileName
uint DBusMenuExporterDBus::GetLayout(int, int, const QStringList&, DBusMenuLayoutItem&): Condition failed: menu
[00007f832c007a70] gl gl: Initialized libplacebo v4.208.0 (API v208)
[00007f832c007a70] glconv_vaapi_x11 gl error: vaInitialize: unknown libva error
zsh: segmentation fault (core dumped)  vlc
    ~  vlc         SEGV ✘  14s 
[00005574e5239550] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00005574e52d5b40] main playlist: playlist is empty
[00007f95ec007a70] gl gl: Initialized libplacebo v4.208.0 (API v208)
[00007f95ec007a70] glconv_vaapi_x11 gl error: vaInitialize: unknown libva error
To be investigated, it’s late for me. :slight_smile:
My inxi for people who are interested.
inxi -Fxxxnz         ✔
  Kernel: 5.15.86-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: H170 PRO GAMING v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 0224
    date: 07/17/2015
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
    status: discharging
  Info: quad core model: Intel Core i5-6400 bits: 64 type: MCP
    smt: <unsupported> arch: Skylake-S rev: 3 cache: L1: 256 KiB L2: 1024 KiB
    L3: 6 MiB
  Speed (MHz): avg: 1088 high: 1600 min/max: 800/3300 cores: 1: 800 2: 800
    3: 1155 4: 1600 bogomips: 21607
  Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: ASUSTeK driver: nvidia
    v: 525.60.11 arch: Maxwell pcie: speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:13c2 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: N/A
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
    s-diag: 1102mm (43.38")
  Monitor-1: DVI-D-0 pos: primary,right res: 1920x1080 hz: 60 dpi: 94
    size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
  Monitor-2: HDMI-0 pos: left res: 1920x1080 hz: 60 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX
    970/PCIe/SSE2 direct render: Yes
EDIT: Well, it looks like I am not the only one getting the exact same error.
EDIT2: It think it might be caused by NVIDIA drivers actually. libva and many packages related to hardware acceleration got updated, but we got no update for nvidia utils which provides software for hardware acceleration for NVIDIA GPUs. I would try to rebuild nvidia-utils and the NVIDIA drivers and release it in repos to see if it fixes the issue.
EDIT3: Made some progress with this issue. It looks like VLC doesn’t like the new version of libva that we got. If I downgrade libva from 2.17.0 to 2.16.0, VLC works properly again. Weird.
EDIT4: VLC works properly with libva at version 2.17.0 if I set the Output option in Preferences > Video at VDPAU output instead of Automatic (the latter being the default setting).
Have you considered to update to the next stable kernel (6.1.x)?
Yeah, I am currently using the 6.1.2 Kernel. It does not happen using this kernel. But 6.0.15 was fine for me as well
inxi -Fxxxnz
  Kernel: 6.1.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
    base: Arch Linux
  Type: Laptop System: LENOVO product: 21CHCTO1WW v: ThinkPad T16 Gen 1
  Mobo: LENOVO model: 21CHCTO1WW v: ThinkPad serial: <superuser required>
    UEFI: LENOVO v: R23ET62W (1.32 ) date: 11/11/2022
  ID-1: BAT0 charge: 79.6 Wh (89.4%) condition: 89.0/86.0 Wh (103.5%)
    volts: 17.0 min: 15.4 model: SMP LNV-5B10W51871�� type: Li-poly
    serial: <filter> status: not charging cycles: 26
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M560
    status: discharging
  Info: 8-core model: AMD Ryzen 7 PRO 6850U with Radeon Graphics bits: 64
    type: MT MCP smt: enabled arch: Zen 3+ rev: 1 cache: L1: 512 KiB L2: 4 MiB
    L3: 16 MiB
  Speed (MHz): avg: 576 high: 1644 min/max: 400/4768 boost: enabled cores:
    1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 1186 10: 1644
    11: 400 12: 400 13: 400 14: 400 15: 400 16: 1186 bogomips: 86279
  Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
    v: kernel arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1 bus-ID: 04:00.0
    chip-ID: 1002:1681 class-ID: 0300 temp: 43.0 C
  Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
    bus-ID: 5-1:2 chip-ID: 174f:1812 class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 21.1.6 compositor: xfwm v: 4.18.0 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43")
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0aa7 res: 2560x1600
    hz: 60 dpi: 188 size: 345x215mm (13.58x8.46") diag: 407mm (16") modes:
    max: 2560x1600 min: 640x480
  API: OpenGL v: 4.6 Mesa 23.0.0-devel (git-ff928d9567) renderer: AMD
    Radeon Graphics (rembrandt LLVM 14.0.6 DRM 3.49 6.1.2-1-MANJARO)
    direct render: Yes
  Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
    bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    driver: snd_pci_acp6x v: kernel pcie: speed: 16 GT/s lanes: 16
    bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Sound API: ALSA v: k6.1.2-1-MANJARO running: yes
  Sound Interface: sndio v: N/A running: no
  Sound Server-3: PipeWire v: 0.3.63 running: yes
    vendor: Lenovo driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0f0 state: down mac: <filter>
  Device-2: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
    driver: ath11k_pci v: kernel pcie: speed: 5 GT/s lanes: 1 bus-ID: 02:00.0
    chip-ID: 17cb:1103 class-ID: 0280
  Device-1: USI type: USB driver: btusb v: 0.8 bus-ID: 1-3.1:3
    chip-ID: 10ab:9309 class-ID: e001
  Local Storage: total: 476.94 GiB used: 87.34 GiB (18.3%)
  ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFS512GDE9X081N
    size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
    rev: 41730C20 temp: 38.9 C scheme: GPT
  ID-1: / size: 435.47 GiB used: 87.31 GiB (20.1%) fs: ext4
    dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 299.4 MiB used: 33.3 MiB (11.1%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-1: swap-1 type: partition size: 33.14 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p3
  System Temperatures: cpu: 49.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
  Fan Speeds (RPM): fan-1: 0
  Processes: 344 Uptime: 3h 54m wakeups: 20286 Memory: 30.13 GiB
  used: 4.51 GiB (15.0%) Init: systemd v: 252 default: graphical Compilers:
  gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1487 Shell: Zsh v: 5.9
  running-in: xfce4-terminal inxi: 3.3.24
mesa 22.3.2-4 update appears to have gotten rid of KDE UI hangs with amdgpu. Every notify-send "test" is also smooth. Thank you.
After the update, no selection of the refresh rate above 30Hz on secend monitor?! (miss <30Hz, 50HZ and 60Hz(default before the update))
[ALPM] upgraded libva-mesa-driver (22.3.2-2 -> 22.3.2-4)
[ALPM] upgraded mesa (22.3.2-2 -> 22.3.2-4)
  Device-1: NVIDIA GM204M [GeForce GTX 980M] vendor: Micro-Star MSI
    driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
    status: current (as of 2022-12) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:13d7
    class-ID: 0300
    driver: N/A display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 5760x2160 s-dpi: 96 s-size: 1524x572mm (60.00x22.52")
    s-diag: 1628mm (64.09")
  Monitor-1: DP-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 128
    size: 382x215mm (15.04x8.46") diag: 438mm (17.26") modes: N/A
  Monitor-2: DP-1 pos: right res: 3840x2160 hz: 30 dpi: 157
    size: 621x341mm (24.45x13.43") diag: 708mm (27.89") modes: N/A
    980M/PCIe/SSE2 direct render: Yes
DP-1 causes problems no 4k 60Hz
xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x1b7 cap: 0x1, Source Output crtcs: 4 outputs: 6 associated providers: 0 name:NVIDIA-0
xrandr --listactivemonitors
Monitors: 2
 0: +DP-0 1920/382x1080/215+0+0  DP-0
 1: +DP-1 3840/621x2160/341+1920+0  DP-1
xrandr
Screen 0: minimum 8 x 8, current 5760 x 2160, maximum 16384 x 16384
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 382mm x 215mm
   1920x1080     60.01*+
DP-1 connected 3840x2160+1920+0 (normal left inverted right x axis y axis) 621mm x 341mm
   3840x2160     29.98*+  29.97    25.00    23.98
   1920x2160     59.99
   1920x1080     60.00    59.94    50.00
   1680x1050     59.95
   1440x900      59.89
   1280x1024     75.02    60.02
   1280x960      60.00
   1280x720      60.00    59.94    50.00
   1024x768      75.03    70.07    60.00
   800x600       75.00    72.19    60.32    56.25
   720x576       50.00
   720x480       59.94
   640x480       75.00    72.81    59.94    59.93
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-0 also only has 60.01Hz selection :interrobang: hmmm…
There were no changes made in revision 3: [pkg-upd] 22.3.2-3 (efe6a4fb) · Commits · Packages / Extra / mesa · GitLab
Revision 4 added a workaround for AMDGpu: [pkg-upd] 22.3.2-4 (3ee9e9a1) · Commits · Packages / Extra / mesa · GitLab
Do you mean the old version of mesa 22.3.2-2 has no issue?
But you are using XFCE in your profile?
XFCE has nothing to do with the bugfix of mesa 22.3.2-4 that is for KDE Plasma Wayland and AMD GPU only.
I’m currently trying to figure out what’s wrong…
  • downgrade kernel and nvidia drivers
Yes, I don’t really understand that either… was it a quick shot of me to push it onto mesa? :frowning:
I am also experiencing an(or multiple) issues however I wasnt able to track them down to an update or anything, but maybe someone here has an idea.
  1. First Steam or X/XWayland to be precise crashes when I try to open the systeminfromations from within steam,
    this was not the case 3-6days ago though I think I already had the issue but X crashed with a delay a little while afterwards.
  2. And also another error also related to steam though it could have a different cause,
    the game Halo Infinite on Steam doesnt work, according to ProtonDB it worked 2 or even 1 month ago on Manjaro so I am curious if it could be related to the codec changes or indeed be the same or a related issue to the first one I described.
It is current not big of a deal but I really dont know where this is coming from only “strange” think I did was temporarily installing mesa-git from the AUR but that was after the issues had appeared.
Otherwise I am obviously on the testing branch and also using the 6.1.2-1 Kernel.
