[Testing Update] 2022-12-04 - Kernels, Systemd, Mesa, GNOME
Luckily I have no AMD hardware.
And I have some experience of turning Manjaro into Arch, so in case of emergency … :joy:
My systemd package did NOT get downgraded to version 251.8 and it currently on 252.2-2 manjaro. Did something fail during the update for me?
Thanks in advance to everyone for your time and help, it is greatly appreciated!
You need to “downgrade” using pacman -Syyuu command, or set enable downgrade in pamac gui settings and then update.
Or you can update adding the systemd packages after the -Suy, in my case:
pacman -Syu systemd systemd-libs systemd-sysvcompat
What are the specifics on the systemd v252 issues? I’m anxious to get this fix included: https://github.com/systemd/systemd/pull/23348
That PR was merged back in June. The shutdown script mentioned does not actually work. We used to include it, but haven’t for several months.
I recognize that the nVidia up/down situation is a mess of failures, especially from the suspend state, and that their shutdown script does nothing to fix the situation. I just don’t want the “umount oldroot” warning messages that show up on every reboot.
This was working for me
Will that shutdown script get executed on suspend as well as shutdown? I have issues where my laptop commonly won’t wake up after suspend, getting stuck somewhere in the early initialization. I’m sure it’s nvidia-related.
3 posts were merged into an existing topic: [Unstable Update] 2022-11-25 - Mkinitcpio, NVIDIA, Qt, Gtk, SDL, LibreOffice, Cinnamon
A post was merged into an existing topic: [Unstable Update] 2022-11-25 - Mkinitcpio, NVIDIA, Qt, Gtk, SDL, LibreOffice, Cinnamon
I’m not sure. It worked for me, then I started seeing these oldroot messages again, now I know why:
Adding
#!/bin/sh
# remove nvidia modules
/usr/bin/modprobe -r nvidia_drm nvidia_modeset nvidia_uvm && /usr/bin/modprobe -r nvidia
as /usr/lib/systemd/system-shutdown/nvidia.shutdown and making it executable resolved it again.
Indeed, as I said it was working. But I think some people said it wasn’t working with their laptop or whatever and the fix was promptly removed soon after. I re-added it manually back then as it was definitely working on my side…
