omano
8 November 2021 14:50
22
That never happens this way. If new Plasma is released, then it goes first to Arch Linux, then when it gets to Arch Stable, it goes to Manjaro Unstable, then Testing, then Stable when/if no issue is holding back the release to Stable.
It is not like you’re new here…
Why do you need libzim6?
$ pactree -ro libzim6
Remove one of the packages to resolve the conflict…
pega2k
8 November 2021 15:17
24
I don’t know:
error: package 'libzim6' not found
libzim
├─kiwix-lib
│ └─kiwix-desktop
└─zim-tools
Are nvidia-suspend and nvidia-resume systemd services enabled?
settings manager no longer works in Plasma desktop,
akya
9 November 2021 05:43
33
anyone tried the new ntfs3 driver?
dva20
9 November 2021 07:13
35
$ zgrep NTFS /proc/config.gz
# CONFIG_NTFS_FS is not set
# CONFIG_NTFS3_FS is not set
akya
9 November 2021 09:09
36
ohh damn hope that gets enabled when the 5.15 hits stable release
After this update, wayland stopped launching. See:
Since Plasma 23.2 there is GBM support and since Nvidia 495 version it also has GBM support added. So I wanted to try Wayland and see it if finally works so well as non-nvidia users claimed.
The problem is: Wayland doesn’t start at all…
After I give my password, I get black screen, then it goes back to SDDM login screen.
It worked earlier. There were many small quirks but at the first glance all was well, only after longer usage many small issues were visible, which showed how lacking wayland…
Can other Plasma users on testing check if they have the same problem? Thanks
I checked on my side and both processes are dead - hybrid session. Is that normal or not? Should I activate them or configure in optimus-manager to enable them once in hybrid mode?
I thought it could help in case of broken suspend with Nvidia cards.
It is normal to have them disabled by default, it’s up to user to decide whether to try them or not.
What would dkms say then when building for that kernel I wonder…
I think it might fail but dkms error are not critical and other modules will still compile so in theory nothing to worry about.
pobrn
9 November 2021 18:05
43
If I recall correctly: if the one compiled with dkms is newer than the one found in the kernel, and the one in the kernel is not built-in, then it will be replaced.
philm
9 November 2021 18:13
44
is there?
[phil@development ~]$ pacman -Ql mhwd-db | grep 470
mhwd-db /var/lib/mhwd/db/pci/graphic_drivers/hybrid-amd-nvidia-470xx-prime/
mhwd-db /var/lib/mhwd/db/pci/graphic_drivers/hybrid-amd-nvidia-470xx-prime/MHWDCONFIG
mhwd-db /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-470xx-prime/
mhwd-db /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-470xx-prime/MHWDCONFIG
mhwd-db /var/lib/mhwd/db/pci/graphic_drivers/nvidia-470xx/
mhwd-db /var/lib/mhwd/db/pci/graphic_drivers/nvidia-470xx/MHWDCONFIG
XRaTiX
9 November 2021 20:30
45
I have those files,but it doesn’t appear to install,neither on the GUI.
philm
10 November 2021 01:09
46
update your system with the new mhwd-db package. Most likely fixed …
alven
10 November 2021 01:16
47
A non-nvidia, unstable user here just to make fast report.
Looks like fixed now
Two days ago was for me:
$ mhwd -la
> All PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2021.11.04 false PCI
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-nvidia-390xx 2021.11.04 false PCI
video-nvidia 2021.11.04 false PCI
video-modesetting 2020.01.13 true PCI
video-virtualmachine 2021.07.26 true PCI
video-openchrome 2020.01.18 true PCI
video-rendition 2020.01.18 true PCI
video-s3 2020.01.18 true PCI
video-sisusb 2020.01.18 true PCI
video-vesa 2017.03.12 true PCI
video-voodoo 2017.03.12 true PCI
video-nvidia-470xx 2021.11.04 false PCI
network-broadcom-wl 2018.10.07 false PCI
network-r8168 2016.04.20 true PCI
network-rt3562sta 2013.12.07 true PCI
network-slmodem 2013.12.07 true PCI
Warning: No USB configs found!
And now:
$ sudo pacman -Qi mhwd-db | grep Ver
Version : 0.6.5-16
$ sudo pacman -Sy
$ sudo pacman -S mhwd-db
Package (1) Old Version New Version Net Change Download Size
extra/mhwd-db 0.6.5-16 0.6.5-17 0.00 MiB 0.03 MiB
Version : 0.6.5-17
$ mhwd -la
> All PCI configs:
video-hybrid-amd-nvidia-470xx-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
