philm
24 September 2020 06:59
1
Hello community,
Another testing branch update with some interesting updates for you!
There is something in the works… #stayhome , #staysafe , #stayhealthy
We updated some of our KDE-git packages plus most of our Kernels
More Deepin updates
Coding-language Gambas is now at 3.15.2
Mhwd got a fix for Intel-Nvidia Prime cards
Systemd got renewed to 246.6
Firefox is now at 81.0
Mesa added some more fixes with 20.1.8
Usual Python and Haskell package updates and rebuilds
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev , which we build on a regular basis against kde-git master packages. Also check out our latest Manjaro Mikah 20.1 release! XFCE , KDE and Gnome
sudo pacman -Syy
sudo pacman -S pacman-static
sudo pacman-static -Syyu
Our current supported kernels
linux44 4.4.237
linux49 4.9.237
linux414 4.14.199
linux419 4.19.147
linux54 5.4.67
linux57 5.7.19 [EOL]
linux58 5.8.11
linux59 5.9-rc6
linux54-rt 5.4.66_rt38
linux56-rt 5.6.19_rt12
Packages Changes (Thu Sep 24 08:24:11 CEST 2020)
testing community x86_64: 1113 new and 1080 removed package(s)
testing core x86_64: 31 new and 35 removed package(s)
testing extra x86_64: 310 new and 311 removed package(s)
testing multilib x86_64: 25 new and 27 removed package(s)
A list of package changes may be found here
No issue, everything went smoothly
Yes there was an issue. I was able to resolve it myself.(Please post your solution)
Yes i am currently experiencing an issue due to the update. (Please post about it)
philm
2
Known issues and solutions
PAM and PAMBASE got updated, which might prevent you from login
Due to updates from pambase and pam you might take care about any .pacnew files in /etc/pam.d as for example pam_tally , pam_tally2 and pam_cracklib got deprecated . Read in the ArchWiki about managing those files.
Typical issue:
For recovery, it is enough to boot with kernel option “systemd.unit=rescue.target”, then proceed into /etc/pam.d and merge “system-auth” and “system-auth.pacnew”
Older Issues
System takes a long time to boot
If you’ve got errors like Failed to start Network Manager Wait Online. you can try removing systemd from passwd and group in /etc/nsswitch.conf as described here
Update: If you can see the line
dbus-daemon[1453]: [system] Connection has not authenticated soon enough, closing it (auth_timeout=30000ms, elapsed: 45146ms)
in in your dbus log ( journalctl -b -u dbus ), the new/better workaround is to switch cups from service to socket as described here :
systemctl disable org.cups.cupsd.service
systemctl enable org.cups.cupsd.socket
I think I’ve some font problems
With the update of fontconfig some major rules how fonts get applied changed. Make sure that your system has ttf-dejavu installed. A more in depth explanation can be found here .
Gnome-shell-extension-pop-shell is currently incompatible with wayland
… and causes the system to freeze when the first window is tiled and can render it unbootable. Solution is a hard reset and disabling either pop shell or wayland. If the system becomes unbootable, use a live USB to edit /etc/gdm/custom.conf to disable wayland and reboot.
Update not solved
Error Update
(12/24) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'default'
-> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64.img
==> ERROR: specified kernel image does not exist: `/boot/vmlinuz-5.8-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'fallback'
-> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64-fallback.img -S autodetect
Fehler: Befehl konnte nicht korrekt ausgeführt werden
(13/24) Updating Kernel initcpios for Nvidia-DRM...
(14/24) Updating Grub-Bootmenu
Warning Update
(64/90) Aktualisiere manjaro-zsh-config [------------------------------------------------] 100%
Warnung: Verzeichnis-Berechtigungen unterscheiden sich für /root/
Dateisystem: 750 Paket: 755
(79/90) Aktualisiere samba [------------------------------------------------] 100%
Warnung: Verzeichnis-Berechtigungen unterscheiden sich für /etc/sudoers.d/
Dateisystem: 755 Paket: 750
(80/90) Aktualisiere sudo [------------------------------------------------] 100%
sudo mkinitcpio -P
sudo mkinitcpio -P
currently I do not get fixed the error … no reboot
thx for your tip … rename or copy from /boot/vmlinuz-linux58 to /boot/vmlinuz-5.8-x86_64
Something is not right with the hook, which copies the kernels to /boot, the names are wrong and subsequently mkinitcpio fails to build initramfs:
(12/26) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> ERROR: specified kernel image does not exist: `/boot/vmlinuz-5.4-x86_64'
(13/26) Updating Kernel initcpios for Nvidia-DRM...
(14/26) Updating Grub-Bootmenu
$ ll /boot/
drwxr-xr-x 7 root root 4,0K 24. Sep 09:05 .
drwxr-xr-x 21 root root 4,0K 21. Mai 13:24 ..
drwxr-xr-x 3 root root 512 1. Jan 1970 efi
drwxr-xr-x 6 root root 4,0K 24. Sep 09:05 grub
-rw-r--r-- 1 root root 3,1M 16. Jun 19:50 intel-ucode.img
-rw-r--r-- 1 root root 21 23. Sep 16:19 linux54-x86_64.kver
-rw-r--r-- 1 root root 21 23. Sep 16:34 linux58-x86_64.kver
-rw-r--r-- 1 root root 6,2M 24. Sep 09:05 vmlinuz-linux54
-rw-r--r-- 1 root root 6,5M 24. Sep 09:05 vmlinuz-linux58
Renamed them myself:
$ sudo mv /boot/vmlinuz-linux54 /boot/vmlinuz-5.4-x86_64
$ sudo mv /boot/vmlinuz-linux58 /boot/vmlinuz-5.8-x86_64
and afterwards reran:
$ sudo mkinitcpio -P && sudo update-grub
This results in unbootable systems otherwise!
pivpav
24 September 2020 07:53
5
During sudo mkinitcpio -P I also noticed an error which might causing potential issues
==> Starting build: 5.8.11-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [resume]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.8-x86_64.img
This error doesn’t exist when building initramfs-5.7
Yochanan
Split this topic
24 September 2020 14:53
6
blw
24 September 2020 07:56
7
My system became unbootable as well. I had to revert to the btrfs-snapshot I made before the update.
Yochanan
Split this topic
24 September 2020 14:03
8
Nanook
24 September 2020 08:05
9
Problem with Opera: freezes when clicking Opera button, right-clicking, odd font sizes. Can be partially worked around by enabling HWA (opera://settings/system).See here: Latest Update Broke the Opera UI | Opera forums .
My laptop will not boot after this update on kernel 5.8, not sure why. It is stuck at HP splash screen which always shows up before log in screen. TTY does not work.
Can’t put in inxi
I’ll try to boot from kernel 5.7 and see how that works.
Managed to boot from kernel 5.7
inxi -Fxxxza -no-host on kernel 5.7
~ >>> inxi -Fxxxza -no-host
Host: HP Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=9a466d45-9706-4f31-8e9b-737ed449768e rw quiet apparmor=1
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: HP model: 8478 v: 70.57 serial: <filter> UEFI: Insyde v: F.22
date: 04/21/2020
ID-1: BAT1 charge: 37.7 Wh condition: 37.7/52.8 Wh (71%) volts: 12.8/11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
status: Full
Topology: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10)
microcode: D6 L2 cache: 8192 KiB
bogomips: 36812
Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c8d
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam
type: USB driver: uvcvideo bus ID: 1-5:3 chip ID: 05c8:03bc
Display: x11 server: X.org 1.20.9 compositor: gnome-shell
driver: modesetting,nvidia resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
Sound Server: ALSA v: k5.7.19-2-MANJARO
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_pci v: N/A modules: rtwpci port: 4000
bus ID: 02:00.0 chip ID: 10ec:b822
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 05:00.0
chip ID: 10ec:8168
Local Storage: total: 238.47 GiB used: 102.78 GiB (43.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW256HEHP-000H1
size: 238.47 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: CXB73H1Q scheme: GPT
ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 102.78 GiB (44.0%) fs: ext4 dev: /dev/nvme0n1p2
System Temperatures: cpu: 55.0 C mobo: 29.8 C
Processes: 331 Uptime: 2m Memory: 15.53 GiB used: 1.79 GiB (11.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 8/9 clang: 10.0.1
Packages: 1362 pacman: 1341 lib: 364 flatpak: 12 snap: 9 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05
I am all ears in helping to solve this problem (not sure where to look first).
philm
24 September 2020 08:11
12
I’ve to see about mkinitcpio . I deleted our overlay . Let me see what to fix.
My update showed none of these errors while updating (used terminal) so I wasn’t sure if it applied.
philm
24 September 2020 08:17
14
Pushed some more updates …
:: Different overlay package(s) in repository community x86_64
PACKAGE testing unstable
breeze-gtk-git5.20.80.r394.ga37192d-15.20.80.r395.g25b81e3-1
deepin-desktop-base 3:2019.07.10-1 -
deepin-kwin-dev 5.0.0-2 -
deepin-live 3.2-1 -
deepin-wallpapers 2:1.7.7-1 -
discover-git5.20.80.r7837.gb294c93f-15.20.80.r7839.g76b562c6-1
kde-cli-tools-git5.20.80.r1806.gede4ba5-15.20.80.r1807.gcbab4f0-1
kdeplasma-addons-git5.20.80.r8388.gfe86cf62f-15.20.80.r8389.geda917ebe-1
kio-git5.75.0.r4211.gd8fc059a-15.75.0.r4212.g5da32a17-1
kirigami2-git5.75.0.r2418.g7575cc3d-15.75.0.r2425.g95781e80-1
kquickcharts-git r380.geeb4ab0-1 r381.gb231ab0-1
krunner-git5.75.0.r503.g57ae6f4-15.75.0.r505.g635e11f-1
kwayland-integration-git5.20.80.r153.g43ba980-15.20.80.r154.g00ae501-1
plasma-framework-git5.75.0.r15573.gc0ebacfa6-15.75.0.r15576.g16f852ea4-1
plasma-wayland-session-git5.20.80.r9431.g811d85cbd-15.20.80.r9435.g665836f56-1
plasma-workspace-git5.20.80.r9431.g811d85cbd-15.20.80.r9435.g665836f56-1
systemsettings-git5.20.80.r2269.g14529229-15.20.80.r2270.g2e82e4fc-1
xdg-desktop-portal-kde-git5.20.80.r316.g0cd7a9d-15.20.80.r317.g8f488ca-1
:: Different overlay package(s) in repository core x86_64
mkinitcpio - 28-1.0
also same error on unstable for mkinitcpio
My issue solved by post 2
philm
24 September 2020 08:30
21
Updated mkinitcpio fixes the issue:
==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'default'
-> -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64.img
==> Starting build: 4.14.199-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'fallback'
-> -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
-> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64.img
==> Starting build: 4.19.147-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
-> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux44.preset: 'default'
-> -k /boot/vmlinuz-4.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.4-x86_64.img
==> Starting build: 4.4.237-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux44.preset: 'fallback'
-> -k /boot/vmlinuz-4.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.4-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.4-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux49.preset: 'default'
-> -k /boot/vmlinuz-4.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.9-x86_64.img
==> Starting build: 4.9.237-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.9-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux49.preset: 'fallback'
-> -k /boot/vmlinuz-4.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.9-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.9-x86_64-fallback.img
==> Starting build: 5.4.67-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'default'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64.img
==> Starting build: 5.7.19-2-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.7-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'fallback'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.7-x86_64-fallback.img
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.8-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'default'
-> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
==> Starting build: 5.9.0-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'fallback'
-> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.8-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.8-x86_64.img
Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.7-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.7-x86_64.img
Found initrd fallback image: /boot/initramfs-5.7-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.19-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-4.19-x86_64.img
Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.14-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-4.14-x86_64.img
Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.9-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-4.9-x86_64.img
Found initrd fallback image: /boot/initramfs-4.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.4-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-4.4-x86_64.img
Found initrd fallback image: /boot/initramfs-4.4-x86_64-fallback.img
Found Manjaro Linux (18.0-alpha-1) on /dev/sda5
Found Manjaro Linux (19.0.2) on /dev/sda6
done
something wrong here , i have update mirrors to get update mkinitcpio
is it this error " `/" that should be " '/" ?
update : error name come from old mkinitcpio
sudo mkinitcpio -P
==> ERROR: specified kernel image does not exist: `/boot/vmlinuz-4.19-x86_64'
==> WARNING: Possibly missing firmware for module: wd719x
==> WARNING: Possibly missing firmware for module: aic94xx
mbod
24 September 2020 09:08
24
May be I am wrong, but I believe the mkinitcpio update is not fixing the initial problem.
The initial problem is that the new kernel packages linux54-5.4.67-1-x86_64.pkg.tar.zst and linux58-5.8.11-1-x86_64.pkg.tar.zst install kernel images with wrong names:
/boot/vmlinuz-5.4
/boot/vmlinuz-5.8
It is my understanding that they are not found even by the new mkinitcpio.
They should be renamed to
this come form /etc/mkinitcpio.d/linuxXY.preset
i have this 4.14 , 5.4 also 5.8
# mkinitcpio preset file for the 'linux54' package
ALL_config="/etc/mkinitcpio.conf"
ALL_kver="/boot/vmlinuz-5.4-x86_64"
PRESETS=('default' 'fallback')
#default_config="/etc/mkinitcpio.conf"
default_image="/boot/initramfs-5.4-x86_64.img"
#default_options=""
#fallback_config="/etc/mkinitcpio.conf"
fallback_image="/boot/initramfs-5.4-x86_64-fallback.img"
fallback_options="-S autodetect"
and if you have bad name vmlinuz
ls -lha vmlinuz*
-rw-r--r-- 1 root root 5,8M 24 sept. 10:34 vmlinuz-419-x86_64
-rw-r--r-- 1 root root 6,2M 24 sept. 10:34 vmlinuz-54-x86_64
-rw-r--r-- 1 root root 6,5M 24 sept. 10:34 vmlinuz-58-x86_64
soluce :
suppress vmlinuz ( name bad )
redo
sudo pacman -S linuxNM
it’s ok for result mkinitcpio
