What do we need?
We need people with HDPI screens to test the available scaling options under Gnome settings on GTK and QT apps under Wayland make sure font scaling is switch off under Gnome tweaks and your system packages are upgraded.
Report back your resolution and what scaling works and don’t work, when your report back also please confirm you have disabled font scaling under tweaks as that will result in scaling twice which can cause blurred content.
I have 3000*2000 on a 13" Display. 100% scaling i can’t identify charakters and more scaling is blurry. Intel Graphic on a Surface Book 2. Other Manjaro Gnome Versions make no problem.
Actually there is no need for HDPI display. My laptop has 13 inch screen with 1080p resolution and I setting it to 150% scale, that is comfortable for me. It is blurry on this scale too. ¯_(ツ)_/¯
Because that launches Firefox in Wayland, as it should, actually. Otherwise Firefox runs on xWayland, which cuts off some performance, not able to use VA-API. No reason to use xWayland.
Chromium under ozone-platform: wayland/auto in chrome://flags is not blurry too, by the way, and much smoother.
If all apps would be run on native Wayland, there is shouldn’t be blur at all. It would be perfect fractional scaling and performance everywhere.
Gitlab is recommended to use this cli-command: gsettings set org.gnome.mutter experimental-features '[]'
It turns off fractional scaling (needs relogin), that should be by default in next release.
This issue has being reverted however I would still like that users experiment with it and provide feedback as that is what the QA section is about and it help us making a better distribution.
gsettings set org.gnome.mutter experimental-features “[‘scale-monitor-framebuffer’]” and alternatively gsettings set org.gnome.mutter experimental-features “[‘x11-randr-fractional-scaling’]” for xwayland
If this thread is about Wayland fractional scaling, you should not include this command, as it won’t work out of the box. What the Arch Wiki refers to is my patched mutter package, which is meant for Xorg. This however is not a upstream project, so it won’t help here.
Thanks, i have missed that Xorg patch in the docs, on Wayland it does work on my end on any percentage on 2 test machines, I have no blur issues or font distorcion.
