i wish to test MAnjaro on odroid… but i do not have the possibility to use an x86 updated and so i’m asking if it is possible to get testing version for odroid c4 to flash with etcher or dd command on an sd. thanks
curious.
Hello and welcome to the forum,
You can build one from Manjaro-Arm-Tools or Manjaro-Arm-Installer
BTW I just a very old test image which was shared with an OEM for testing.
Manjaro ARM - XFCE - C4
Just uploaded a fresh built image on my server,
Manjaro ARM - XFCE - C4 - 20-12-08
It is quite old and a lot have changed since then.
Try this and let me know about your experience.
I’m using your version
thnks!
it seems that everything is working
usually in other distro I use governor on performance
for the cpu and gpu temperature it is not displayed in htop, looking for an app that is working under Manjaro for those information that i consider important
Hi,
for temperatures, try sensors
at the commandline; it is the default tool from the lm_sensors package. If that shows you output, it is just a matter of choosing a gui tool.
Install cpu-temp-speed
sudo pacman -S cpu-temp-speed
Run it using
cpu-temp-speed
i reply to both
here the image
sensor not found but cpu temp speed found,
but i would like to know if there is a graphical interface to add as an applet?
Make sure you loaded all the kernel drivers you need.
Try sensors-detect to find out which these are.
[root@sbc Scrivania]# sensors-detect
sensors-detect version 3.6.0
DMI data unavailable, please consider installing dmidecode 2.7
or later for better results.
Kernel: 5.9.9-2-MANJARO-ARM aarch64
Cannot show processor info on aarch64 architecture.
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you’re doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): y
modprobe: FATAL: Module cpuid not found in directory /lib/modules/5.9.9-2-MANJARO-ARM
Failed to load module cpuid.
Silicon Integrated Systems SIS5595… No
VIA VT82C686 Integrated Sensors… No
VIA VT8231 Integrated Sensors… No
AMD K8 thermal sensors… No
AMD Family 10h thermal sensors… No
AMD Family 11h thermal sensors… No
AMD Family 12h and 14h thermal sensors… No
AMD Family 15h thermal sensors… No
AMD Family 16h thermal sensors… No
AMD Family 17h thermal sensors… No
AMD Family 15h power sensors… No
AMD Family 16h power sensors… No
Hygon Family 18h thermal sensors… No
Intel digital thermal sensor… No
Intel AMB FB-DIMM thermal sensor… No
Intel 5500/5520/X58 thermal sensor… No
VIA C7 thermal sensor… No
VIA Nano thermal sensor… No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no): y
Sorry, no supported PCI bus adapters found.
Module i2c-dev loaded successfully.
Most ARM boards, do not display temperatures like regular x86 computers do.
Some even use a custom class in /sys for it.
I don’t think there are any graphical applications that display them, except maybe Plasmas KSysGuard, if you create a custom panel for it.
it does work the applet under the armbian but i do not know more about… i can see the temperature in mate
and also change the governor and minimal and maximum speed
Hi,
Nice to meet you.
On my Odroid c4 (Manjaro KDE) I installed (via pamac 10 :-)
sensor viewer no issue, see below more details.
i wish to install it a mean all the kde plasma and also the sensors
where i could get it? also I would like to overclock at more than 2.4ghz the cpu, the temperature under armbian at 2100 is at maximum 53 degrees, and also to overclock about 20% more the gpu… that reaches 54c
thanks
is there a guide to install kde as an update from xfce via terminal?
thanks
i already used it but if I’'m searching a program I can not do a search i have to look under utilty or scroll till i found it …
i must correct myself if I type a name than it start searching, not used to gnome desktop (it seems like that)
for the performance i wish to change the governor and also to arrive at least at 2100mghz thanks.
sensors working now!
happy
Nice that you got it working!
You can search with pamac, the package manager, in the terminal. check https://wiki.manjaro.org/index.php/Pamac
To @Strit and @spikerguy
with the last testing update I can’t access to the display configuration on the odroid c4, kde plasma 5.20.4
No issue like this one on the odroid c2 kde plasma 5.19.5 and odroid n2 kde plasma 5.20.3
