Telegram panel icon theme
Hi,
telegram
Ever since the last upgrade to gnome 42 my Telegram panel icon has been incorrect.
It also looses its position every now and then, moving over the icons to the right.
Any ideas how to fix this?
Thanks
Pieter
Hello
Maybe this topic will help you: Telegram tray icon is no longer displayed since 2.5.7
Thanks, I tried that but no change.
Also, it mentions, "Change icon style from “Papirus-Dark to Mate” only there is no “Mate” theme.
I just thought, that you need use the same approach - change icon theme to something more suitable for your desktop environment.
Ok, I tried a few but so far no change.
