Telegram crashing when i am opening media
Telegram from pacman started crashing when I saw media 2-3 month ago, but I solved this problem via going telegram Flatpak
Yesterday I have updated the flatpak apps and granted GPU acceleration via flatseal
but now I am took of this permission, but nosing is change.
if I type telegram-desktop in terminal, I am getting this output:
QGuiApplication::setDesktopFileName: the specified desktop file name ends with .desktop. For compatibility reasons, the .desktop suffix will be removed. Please specify a desktop file name without .desktop suffix
but 2 months ago, output was like: SVG reading error.
PS: I will try to use snap version of telegram
PS2: I can get logs
    ~  telegram-desktop         ✔
QPainter::begin: Paint device returned engine == 0, type: 2
QWidget::render: Cannot render with an inactive painter
qt.svg: Error while inflating gzip file: SVG format check failed
qt.gui.imageio.jpeg: Corrupt JPEG data: premature end of data segment
zsh: segmentation fault (core dumped)  telegram-desktop
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
If you installed Telegram with flatpak, you have to run flatpak run org.telegram.desktop to start it.
Apparently, you’re starting another installed version.
    ~  flatpak run org.telegram.desktop         SEGV ✘  1m 35s 
Gtk-Message: 18:50:59.742: Failed to load module "xapp-gtk3-module"
Gtk-Message: 18:50:59.742: Failed to load module "canberra-gtk-module"
(telegram-desktop:2): Gtk-WARNING **: 18:51:02.597: Theme parsing error: <data>:1:0: Expected a valid selector
** (telegram-desktop:2): WARNING **: 18:51:25.514: atk-bridge: get_device_events_reply: unknown signature
    ~          SEGV ✘  49s 
Got to love post from people using different Linux distro’s…
If you use Manjaro, then provide system info together with your problem…
Yes i saw the mentioning of pacman, so…? :woman_shrugging:
Always include exact versions of software you post about…
Help others to help you better by:
  1. Providing system info about your hardware by posting program output instead of describing your hardware.
  2. Use new lines when a sentence ends, so it is better readable and followable by others.
  3. If english is not your native language please see:
    • :us: :uk: English [HowTo] Become multi-language on internet
    • :tr: Türkçe [Nasıl] İnternette çok dilli olun
    • :de: Deutsch [Wie man] Werden Sie im Internet mehrsprachig
    • :fr: Français [Comment] Devenir multilingue sur internet
    • :es: Española [Cómo] Conviértete en multilenguaje en Internet
    • :cn: 中文 [如何] 成为互联网上的多语言
    • :it: Italiana [Come] Diventa multilingua su internet
    • :ru: русский язык [Как] Стать многоязычным в Интернете
Please read and follow all advice in this thread:
Especially:
[HowTo] Post command output and file content as preformatted text
If you often have a need to do a “Hard reset” or “Power off” to get back to your system, then avoid that when possible by following:
Info about my system in my profile
Flatpak
Pacman
Another output of telegram
ATTENTION: default value of option mesa_glthread overridden by environment.
That’s only basic info, which can be from a different time when you used those, so up-to-date output of inxi in your post is always better…
I also updated my profile info like 2 years afterwards lol
CPU: quad core Intel Core i5-10300H (-MT MCP-)
speed/min/max: 2960/800/4500 MHz Kernel: 6.1.41-1-MANJARO x86_64 Up: 1h 26m
Mem: 8.59/31.19 GiB (27.5%) Storage: 1.38 TiB (52.0% used) Procs: 337
Shell: Zsh inxi: 3.3.28
Could you try with X instead of Wayland?
However, this looks more like a KDE problem, maybe it needs updating?
Did i mention this link yet?
Plus having those info in the FIRST post is optimal, ppl don’t need to read every reply that way to assist you…
If you can’t be bothered to read what is linked, dont expect ppl to spend time to help YOU either…
    ~  sudo pacman -Suy         ✔
[sudo] password for alexbespik:
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
warning: manjaro-hello: local (0.7.0-6) is newer than extra (0.7.0-5)
 there is nothing to do
If you have enabled High DPI in telegram settings, just disable it and see if you can watch media without crash.
Settings > Advance > Experimental…> Precise High DPI scaling
