Hi guys,
when I using any aurorae theme (aka Window decoration) other than default ones (which are based on Breeze) e.g. Monochrome KDE, or Nordic, I can’t smoothly maximize / restore to original size, it little bit expands horizontally and then jumps to maximized window. With Breeze it works fine.
Since I have Nvidia card with proprietary driver, I already tried set nvidia.conf and kwin.sh based on Choppy Plasma with nvidia, but it didn’t help.
I also tried turn off Vsync 433094 – No way to disable tearing prevention and https://invent.kde.org/plasma/kwin/-/commit/6d20d19fec29509103062a0f8606f7d54fd952a8, but no luck either.
System info
Kernel: 5.14.7-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=a7090548-38ac-4ce2-8524-0ad1c32ac187 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop System: Gigabyte product: Z390 AORUS MASTER v: N/A
serial: <filter>
Mobo: Gigabyte model: Z390 AORUS MASTER-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F11n date: 01/19/2021
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
status: Discharging
Device-2: hidpp_battery_1
model: Logitech Wireless Mobile Mouse MX Anywhere 2S serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 31.29 GiB used: 6.79 GiB (21.7%)
Info: 8-Core model: Intel Core i9-9900K bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: C (12)
microcode: EA cache: L2: 16 MiB bogomips: 115232
Speed: 900 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 900 2: 900 3: 892
4: 900 5: 900 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900 13: 900
14: 900 15: 900 16: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: NVIDIA TU104 [GeForce RTX 2080 Rev. A] vendor: Gigabyte
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1e87 class-ID: 0300
Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.7x13.4")
s-diag: 692mm (27.2")
Monitor-1: USB-C-0 res: 3840x2160 hz: 60 dpi: 163
size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 2080/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
Device-2: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.7-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:7 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 2.75 TiB used: 25.14 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 26.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2KW480H6
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 043C scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-00BN5A0
type: HDD rpm: 7200 serial: <filter> rev: 1A01 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 28.88 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 15.19 GiB (15.5%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2 label: N/A
uuid: a7090548-38ac-4ce2-8524-0ad1c32ac187
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
label: NO_LABEL uuid: D9B3-D417
ID-3: /home raw-size: 831.22 GiB size: 817.1 GiB (98.30%)
used: 9.95 GiB (1.2%) fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:3 label: N/A
uuid: 684ba19f-1347-4749-9a61-c3c5d3489cfe
ID-1: /dev/nvme0n1p1 maj-min: 259:5 size: 100 MiB fs: vfat label: N/A
uuid: DC16-B70B
ID-2: /dev/nvme0n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:7 size: 476.33 GiB fs: ntfs label: N/A
uuid: 0006175606174C52
ID-4: /dev/nvme0n1p4 maj-min: 259:8 size: 507 MiB fs: ntfs label: N/A
uuid: 3274759874755F91
ID-5: /dev/sda1 maj-min: 8:1 size: 446.82 GiB fs: ntfs label: N/A
uuid: 01D59A6271F19D30
ID-6: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: btrfs label: Data
uuid: b9f269d2-c977-45c3-bedf-ce61b021cbe1
ID-7: /dev/sdc1 maj-min: 8:33 size: 3.22 GiB fs: iso9660
ID-8: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: E363-7F8B
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-8:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s power: 300mA chip-ID: 0951:1666 class-ID: 0806
serial: <filter>
Device-2: 1-10:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-2: 1-11:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-12:5 info: Integrated Express IT8297 RGB LED Controller
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
Hub-3: 1-13:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-14:7 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 3-2:2 info: Hitachi ports: 4 rev: 2.0 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Device-1: 3-2.1:3 info: Cypress Billboard Device type: Billboard,HID
chip-ID: 04b4:5210 class-ID: 0300 serial: <filter>
Device-2: 3-2.2:4 info: EIZO FlexScan EV2785 type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
chip-ID: 056d:4036 class-ID: 0300
Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 53.0 C mobo: N/A gpu: nvidia temp: 51 C
Processes: 339 Uptime: 18h 0m wakeups: 111 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1285 lib: 341
flatpak: 0 Shell: Zsh v: 5.8 running-in: yakuake inxi: 3.3.06
Can anyone please throw a bit of light?
