Hi
I am pretty new at Linux. Manjaro is my first distributive. Thank you very much for it.
I am getting one annoying problem. I guees 1 per 7 click closes my tabs on browsers (Chrome, Brave), VS Code, File manager and in tray. Sometimes it closes even if I use touchpad (previously I mistakenly call it touch bar). Sometimes it paste copied text.
I couldn’t find anything related to this problem in settings and have noone to ask.
Is there is a way to fix this problem or at least to understand the reason of this behaviour?
UPD:
Thank you, Nachlese for topic
My system:
Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f39d9866-5be6-4713-b625-36fb4ec289a4 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: ASUSTeK product: N552VW v: 1.0 serial: <filter>
Mobo: ASUSTeK model: N552VW v: 1.0 serial: <filter>
UEFI: American Megatrends v: N552VW.300 date: 08/31/2016
ID-1: BAT0 charge: 26.4 Wh (76.3%) condition: 34.6/48.2 Wh (71.7%)
volts: 14.4 min: 14.4 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Charging cycles: 354
RAM: total: 15.53 GiB used: 2.77 GiB (17.9%)
Info: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: EA cache:
L2: 6 MiB bogomips: 41621
Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 802
4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: ASUSTeK driver: nvidia
v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:139b class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 13d3:5666 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting,nvidia unloaded: intel,nouveau alternate: fbdev,nv,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5")
s-diag: 1165mm (45.9")
Monitor-1: eDP-1 res: 3840x2160 hz: 60 dpi: 284 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.1.6
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: Sennheiser Headset [PC 8] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:4 chip-ID: 1395:0025
class-ID: 0300
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: e000
bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 03:00.1
IF: enp3s0f1 state: down mac: <filter>
bus-ID: 1-9:5 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.29 TiB used: 71.69 GiB (3.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS512G39MND-3510A
size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0P00 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000LM003 HN-M201RAD
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE1N rev: AS00
dev-links: cdrom
ID-1: / raw-size: 98.81 GiB size: 96.7 GiB (97.86%) used: 71.66 GiB (74.1%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: f39d9866-5be6-4713-b625-36fb4ec289a4
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 7E48-4C5B
ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: ntfs
label: \xd0\x92\xd0\xbe\xd1\x81\xd1\x81\xd1\x82\xd0\xb0\xd0\xbd\xd0\xbe\xd0\xb2\xd0\xb8\xd1\x82\xd1\x8c
uuid: CCBA479BBA478146
ID-2: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda4 maj-min: 8:4 size: 377.53 GiB fs: ntfs label: N/A
uuid: 0434816F34816490
ID-4: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-5: /dev/sdb2 maj-min: 8:18 size: 878.89 GiB fs: ntfs label: N/A
uuid: 447C577C7C5767A6
ID-6: /dev/sdb3 maj-min: 8:19 size: 984.11 GiB fs: ntfs label: N/A
uuid: 1024636424634BB2
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-1:2 info: A4Tech XL-730K / XL-750BK / XL-755BK Mice
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 09da:9090 class-ID: 0301
Device-2: 1-4:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Device-3: 1-6:4 info: Sennheiser Headset [PC 8] type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1395:0025 class-ID: 0300
Device-4: 1-9:5 info: Intel Bluetooth wireless interface type: Bluetooth
Device-5: 1-12:6 info: Atmel type: HID
driver: hid-generic,hid-multitouch,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 03eb:8a9c class-ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2000
Processes: 259 Uptime: 5m wakeups: 91 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages: 1311 pacman: 1307
lib: 345 flatpak: 0 snap: 4 Shell: Zsh v: 5.8 running-in: xfce4-terminal
inxi: 3.3.06
