T430 fan doesn't seem to be running
Hi, since the latest stable update (2022-03-14), it seems like the fan on my thinkpad T430 is not running; I cannot hear it and can physically feel how hot my laptop is getting. However, running sensors says that the fan is functioning normally.
Running sensors yields:
coretemp-isa-0000
Adapter: ISA adapter
Package id 0:  +82.0°C  (high = +87.0°C, crit = +105.0°C)
Core 0:        +82.0°C  (high = +87.0°C, crit = +105.0°C)
Core 1:        +77.0°C  (high = +87.0°C, crit = +105.0°C)
BAT0-acpi-0
Adapter: ACPI interface
in0:          12.31 V
nouveau-pci-0100
Adapter: PCI adapter
GPU core:    912.00 mV (min =  +0.84 V, max =  +1.09 V)
temp1:        +75.0°C  (high = +95.0°C, hyst =  +3.0°C)
                       (crit = +105.0°C, hyst =  +5.0°C)
                       (emerg = +135.0°C, hyst =  +5.0°C)
thinkpad-isa-0000
fan1:        4587 RPM
CPU:          +81.0°C
GPU:           +0.0°C
temp3:         +0.0°C
temp4:         +0.0°C
temp5:         +0.0°C
temp6:         +0.0°C
temp7:         +0.0°C
temp8:         +0.0°C
acpitz-acpi-0
temp1:        +81.0°C  (crit = +200.0°C)
Following the arch wiki’s page on fan control I installed thinkfan and have it enabled on level 7 but this did not seem to do anything.
Basic info:
  Kernel: 5.16.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
    root=UUID=4a72765e-c51f-4a44-ac54-7a41652bdee8 rw quiet apparmor=1
  Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.30.0
  Type: Laptop System: LENOVO product: 2344BMU v: ThinkPad T430
  Mobo: LENOVO model: 2344BMU v: Win8 Pro DPK TPG
    serial: <superuser required> UEFI-[Legacy]: LENOVO v: G1ETC1WW (2.81 )
    date: 06/18/2019
  ID-1: BAT0 charge: 40.5 Wh (100.0%) condition: 40.5/86.6 Wh (46.8%)
    volts: 12.3 min: 11.1 model: LGC 45N1011 type: Li-ion serial: <filter>
    status: full
  RAM: total: 7.45 GiB used: 2.87 GiB (38.5%)
  RAM Report:
  Info: model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
    family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2265 high: 2878 min/max: 1200/3300 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1722 2: 1973 3: 2878
    4: 2489 bogomips: 20760
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
    erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
    x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
    v: kernel ports: active: LVDS-1 empty: VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0166 class-ID: 0300
  Device-2: NVIDIA GF108M [NVS 5400M] vendor: Lenovo driver: nouveau
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: none
    empty: DP-1, DP-2, DP-3, LVDS-2, VGA-2 bus-ID: 01:00.0 chip-ID: 10de:0def
    class-ID: 0300
  Device-3: Chicony Thinkpad T430 camera type: USB driver: uvcvideo
    bus-ID: 1-1.6:5 chip-ID: 04f2:b2db class-ID: 0e02
  Display: x11 server: X.Org v: 1.21.1.3 compositor: Picom v: git-7e568
    driver: X: loaded: modesetting alternate: fbdev,vesa gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
    s-diag: 485mm (19.11")
  Monitor-1: LVDS-1 model: Seiko Epson 0x324c built: 2010 res: 1600x900
    hz: 60 dpi: 131 gamma: 1.2 size: 310x174mm (12.2x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1600x900
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
    v: 4.2 Mesa 21.3.7 compat-v: 3.0 direct render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  Device-2: NVIDIA GF108 High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
  Sound Server-1: ALSA v: k5.16.14-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.20 running: no
  Sound Server-4: PulseAudio v: 15.0 running: yes
  Sound Server-5: PipeWire v: 0.3.48 running: no
  Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
    v: kernel port: 7080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
    chip-ID: 8086:0085 class-ID: 0280
  Device-1: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad] type: USB driver: btusb
    v: 0.8 bus-ID: 1-1.4:4 chip-ID: 0a5c:21e6 class-ID: fe01 serial: <filter>
  Local Storage: total: 476.94 GiB used: 166.1 GiB (34.8%)
  ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 476.94 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
    rev: 61.5 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT50N rev: LT20
    dev-links: cdrom
  ID-1: / raw-size: 476.93 GiB size: 468.38 GiB (98.21%)
    used: 166.1 GiB (35.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 4a72765e-c51f-4a44-ac54-7a41652bdee8
  Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.3:3
    info: Upek TouchChip Fingerprint Coprocessor (WBF advanced mode)
    type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 100mA chip-ID: 147e:2020 class-ID: 0000
  Device-2: 1-1.4:4 info: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad]
    type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
  Device-3: 1-1.6:5 info: Chicony Thinkpad T430 camera type: Video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA
  Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 81.0 C mobo: N/A gpu: nouveau temp: 76.0 C
  Fan Speeds (RPM): fan-1: 4106
  Processes: 195 Uptime: 5h 25m wakeups: 2 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1742 apt: 0
  pacman: 1739 lib: 489 snap: 3 Shell: Bash v: 5.1.16 running-in: urxvtd
  inxi: 3.3.14
Hello,
You should honestly switch to proprietary drivers Laptop/Lenovo - ArchWiki as the NVIDIA Optimus - ArchWiki will give better performance and control than nouveau drivers.
Thanks for your input. I updated to proprietydrivers via mhwd (video-hybrid-intel-nvidia-390xx-bumblebee, video-nvidia-390xx) but now I get a classic black screen error; I am bounced back to login after seeing i3 for a split second. Running startx also fails and checking the log at .local/share/xorg/Xorg.1.log yields:
[   101.816]
X.Org X Server 1.21.1.3
[   101.817] Current Operating System: Linux rubeus 5.16.14-1-MANJARO #1 SMP PREEMPT Fri Mar 11 14:12:18 UTC 2022 x86_64
[   101.817] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64 root=UUID=4a72765e-c51f-4a44-ac54-7a41652bdee8 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[   101.818]
[   101.818] Current version of pixman: 0.40.0
[   101.819] 	Before reporting problems, check http://wiki.x.org
[   101.819] Markers: (--) probed, (**) from config file, (==) default setting,
[   101.821] (==) Log file: "/home/xuanzhen/.local/share/xorg/Xorg.1.log", Time: Mon Apr  4 16:19:45 2022
[   101.822] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   101.822] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   101.823] (==) No Layout section.  Using the first Screen section.
[   101.823] (==) No screen section available. Using defaults.
[   101.823] (**) |-->Screen "Default Screen Section" (0)
[   101.823] (**) |   |-->Monitor "<default monitor>"
[   101.823] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[   101.823] (**) |   |-->Device "Device0"
[   101.823] (==) No monitor specified for screen "Default Screen Section".
[   101.823] (==) Automatically adding devices
[   101.823] (==) Automatically enabling devices
[   101.823] (==) Automatically adding GPU devices
[   101.823] (==) Automatically binding GPU devices
[   101.823] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   101.823] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   101.823] 	Entry deleted from font path.
[   101.823] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[   101.823] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[   101.823] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF,
	/usr/share/fonts/OTF
[   101.823] (==) ModulePath set to "/usr/lib/xorg/modules"
[   101.823] (**) Extension "Composite" is enabled
[   101.823] (**) Extension "RENDER" is enabled
[   101.824] (II) The server relies on udev to provide the list of input devices.
[   101.824] (II) Module ABI versions:
[   101.824] 	X.Org ANSI C Emulation: 0.4
[   101.824] 	X.Org Video Driver: 25.2
[   101.824] 	X.Org XInput driver : 24.4
[   101.824] 	X.Org Server Extension : 10.0
[   101.825] (++) using VT number 2
[   101.828] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_34
[   101.829] (II) xfree86: Adding drm device (/dev/dri/card0)
[   101.829] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[   101.829] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[   101.832] (--) PCI:*(0@0:2:0) 8086:0166:17aa:21f4 rev 9, Mem @ 0xf1400000/4194304, 0xe0000000/268435456, I/O @ 0x00007000/64, BIOS @ 0x????????/131072
[   101.832] (--) PCI: (1@0:0:0) 10de:0def:17aa:21f4 rev 161, Mem @ 0xf0000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00006000/128, BIOS @ 0x????????/524288
[   101.832] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   101.832] (II) LoadModule: "glx"
[   101.832] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   101.833] (II) Module glx: vendor="X.Org Foundation"
[   101.833] 	compiled for 1.21.1.3, module version = 1.0.0
[   101.833] 	ABI class: X.Org Server Extension, version 10.0
[   101.833] (II) LoadModule: "intel"
[   101.833] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[   101.834] (II) Module intel: vendor="X.Org Foundation"
[   101.834] 	compiled for 1.21.1.1, module version = 2.99.917
[   101.834] 	Module class: X.Org Video Driver
[   101.834] 	ABI class: X.Org Video Driver, version 25.2
[   101.834] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[   101.834] (II) intel: Driver for Intel(R) HD Graphics
[   101.834] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[   101.834] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[   101.834] xf86EnableIO: failed to enable I/O ports 0000-03ff (Operation not permitted)
[   101.834] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20201103
[   101.834] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[   101.848] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[   101.849] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 4000
[   101.849] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx; using a maximum of 2 threads
[   101.849] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[   101.849] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[   101.849] (==) intel(0): RGB weight 888
[   101.849] (==) intel(0): Default visual is TrueColor
[   101.849] (**) intel(0): Option "AccelMethod" "sna"
[   101.849] (**) intel(0): Option "DRI" "true"
[   101.850] (II) intel(0): Output LVDS1 has no monitor section
[   101.851] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output LVDS1
[   101.851] (II) intel(0): Enabled output LVDS1
[   101.851] (II) intel(0): Output VGA1 has no monitor section
[   101.851] (II) intel(0): Enabled output VGA1
[   101.851] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[   101.851] (II) intel(0): Output VIRTUAL1 has no monitor section
[   101.851] (II) intel(0): Enabled output VIRTUAL1
[   101.851] (--) intel(0): Output LVDS1 using initial mode 1600x900 on pipe 0
[   101.851] (==) intel(0): TearFree disabled
[   101.852] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[   101.852] (==) intel(0): DPI set to (96, 96)
[   101.852] (II) Loading sub module "dri3"
[   101.852] (II) LoadModule: "dri3"
[   101.852] (II) Module "dri3" already built-in
[   101.852] (II) Loading sub module "dri2"
[   101.852] (II) LoadModule: "dri2"
[   101.852] (II) Module "dri2" already built-in
[   101.852] (II) Loading sub module "present"
[   101.852] (II) LoadModule: "present"
[   101.852] (II) Module "present" already built-in
[   101.852] (II) intel(0): SNA initialized with Ivybridge (gen7, gt2) backend
[   101.852] (==) intel(0): Backing store enabled
[   101.852] (==) intel(0): Silken mouse enabled
[   101.852] (II) intel(0): HW Cursor enabled
[   101.852] (==) intel(0): DPMS enabled
[   101.852] (==) intel(0): Display hotplug detection enabled
[   101.852] (II) intel(0): [DRI2] Setup complete
[   101.852] (II) intel(0): [DRI2]   DRI driver: i965
[   101.852] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[   101.852] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[   101.852] (II) intel(0): hardware support for Present enabled
[   101.852] (II) Initializing extension Generic Event Extension
[   101.853] (II) Initializing extension SHAPE
[   101.853] (II) Initializing extension MIT-SHM
[   101.853] (II) Initializing extension XInputExtension
[   101.853] (II) Initializing extension XTEST
[   101.853] (II) Initializing extension BIG-REQUESTS
[   101.853] (II) Initializing extension SYNC
[   101.853] (II) Initializing extension XKEYBOARD
[   101.854] (II) Initializing extension XC-MISC
[   101.854] (II) Initializing extension SECURITY
[   101.854] (II) Initializing extension XFIXES
[   101.854] (II) Initializing extension RENDER
[   101.854] (II) Initializing extension RANDR
[   101.854] (II) Initializing extension COMPOSITE
[   101.855] (II) Initializing extension DAMAGE
[   101.855] (II) Initializing extension MIT-SCREEN-SAVER
[   101.855] (II) Initializing extension DOUBLE-BUFFER
[   101.855] (II) Initializing extension RECORD
[   101.855] (II) Initializing extension DPMS
[   101.855] (II) Initializing extension Present
[   101.855] (II) Initializing extension DRI3
[   101.855] (II) Initializing extension X-Resource
[   101.856] (II) Initializing extension XVideo
[   101.856] (II) Initializing extension XVideo-MotionCompensation
[   101.856] (II) Initializing extension GLX
[   101.865] (II) AIGLX: Loaded and initialized i965
[   101.865] (II) GLX: Initialized DRI2 GL provider for screen 0
[   101.865] (II) Initializing extension XFree86-VidModeExtension
[   101.865] (II) Initializing extension XFree86-DGA
[   101.865] (II) Initializing extension XFree86-DRI
[   101.865] (II) Initializing extension DRI2
[   101.870] (II) intel(0): switch to mode 1600x900@60.0 on LVDS1 using pipe 0, position (0, 0), rotation normal, reflection none
[   101.877] (II) intel(0): Setting screen physical size to 423 x 238
[   101.929] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[   101.929] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   101.929] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   101.929] (**) Power Button: Applying InputClass "system-keyboard"
[   101.929] (**) Power Button: Applying InputClass "Keyboard Defaults"
[   101.929] (II) LoadModule: "libinput"
[   101.929] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   101.930] (II) Module libinput: vendor="X.Org Foundation"
[   101.930] 	compiled for 1.21.1.3, module version = 1.2.1
[   101.930] 	Module class: X.Org XInput Driver
[   101.930] 	ABI class: X.Org XInput driver, version 24.4
[   101.930] (II) Using input driver 'libinput' for 'Power Button'
[   101.931] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 22 paused 0
[   101.931] (**) Power Button: always reports core events
[   101.931] (**) Option "Device" "/dev/input/event2"
[   101.934] (II) event2  - Power Button: is tagged by udev as: Keyboard
[   101.934] (II) event2  - Power Button: device is a keyboard
[   101.934] (II) event2  - Power Button: device removed
[   101.934] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[   101.934] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   101.934] (**) Option "xkb_layout" "us"
[   101.934] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   101.960] (II) event2  - Power Button: is tagged by udev as: Keyboard
[   101.960] (II) event2  - Power Button: device is a keyboard
[   101.961] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[   101.961] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   101.961] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   101.961] (**) Video Bus: Applying InputClass "system-keyboard"
[   101.961] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[   101.961] (II) Using input driver 'libinput' for 'Video Bus'
[   101.962] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 25 paused 0
[   101.962] (**) Video Bus: always reports core events
[   101.962] (**) Option "Device" "/dev/input/event6"
[   101.963] (II) event6  - Video Bus: is tagged by udev as: Keyboard
[   101.963] (II) event6  - Video Bus: device is a keyboard
[   101.964] (II) event6  - Video Bus: device removed
[   101.964] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8/event6"
[   101.964] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[   101.964] (**) Option "xkb_layout" "us"
[   101.964] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   101.965] (II) event6  - Video Bus: is tagged by udev as: Keyboard
[   101.965] (II) event6  - Video Bus: device is a keyboard
[   101.966] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[   101.966] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   101.966] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   101.966] (**) Video Bus: Applying InputClass "system-keyboard"
[   101.966] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[   101.966] (II) Using input driver 'libinput' for 'Video Bus'
[   101.967] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 26 paused 0
[   101.967] (**) Video Bus: always reports core events
[   101.967] (**) Option "Device" "/dev/input/event7"
[   101.968] (II) event7  - Video Bus: is tagged by udev as: Keyboard
[   101.968] (II) event7  - Video Bus: device is a keyboard
[   101.969] (II) event7  - Video Bus: device removed
[   101.969] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/LNXVIDEO:01/input/input9/event7"
[   101.969] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[   101.969] (**) Option "xkb_layout" "us"
[   101.969] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   101.970] (II) event7  - Video Bus: is tagged by udev as: Keyboard
[   101.970] (II) event7  - Video Bus: device is a keyboard
[   101.970] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[   101.970] (II) No input driver specified, ignoring this device.
[   101.970] (II) This device may have been added with another device file.
[   101.971] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[   101.971] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[   101.971] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[   101.971] (**) Sleep Button: Applying InputClass "system-keyboard"
[   101.971] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[   101.971] (II) Using input driver 'libinput' for 'Sleep Button'
[   101.972] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 27 paused 0
[   101.972] (**) Sleep Button: always reports core events
[   101.972] (**) Option "Device" "/dev/input/event1"
[   101.973] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[   101.973] (II) event1  - Sleep Button: device is a keyboard
[   101.973] (II) event1  - Sleep Button: device removed
[   101.973] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[   101.973] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[   101.973] (**) Option "xkb_layout" "us"
[   101.973] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   101.975] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[   101.975] (II) event1  - Sleep Button: device is a keyboard
[   101.976] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event14)
[   101.976] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[   101.976] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[   101.976] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[   101.976] (**) Integrated Camera: Integrated C: Applying InputClass "Keyboard Defaults"
[   101.976] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[   101.978] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 28 paused 0
[   101.978] (**) Integrated Camera: Integrated C: always reports core events
[   101.978] (**) Option "Device" "/dev/input/event14"
[   101.979] (II) event14 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[   101.979] (II) event14 - Integrated Camera: Integrated C: device is a keyboard
[   101.979] (II) event14 - Integrated Camera: Integrated C: device removed
[   101.979] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.0/input/input15/event14"
[   101.979] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 10)
[   101.979] (**) Option "xkb_layout" "us"
[   101.979] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   101.980] (II) event14 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[   101.980] (II) event14 - Integrated Camera: Integrated C: device is a keyboard
[   101.981] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event9)
[   101.981] (II) No input driver specified, ignoring this device.
[   101.981] (II) This device may have been added with another device file.
[   101.981] (II) config/udev: Adding input device HDA Intel PCH Dock Mic (/dev/input/event10)
[   101.982] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event11)
[   101.982] (II) No input driver specified, ignoring this device.
[   101.982] (II) This device may have been added with another device file.
[   101.982] (II) config/udev: Adding input device HDA Intel PCH Dock Headphone (/dev/input/event12)
[   101.982] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[   101.982] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[   101.982] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[   101.982] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[   101.982] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[   101.982] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[   101.983] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 29 paused 0
[   101.983] (**) AT Translated Set 2 keyboard: always reports core events
[   101.983] (**) Option "Device" "/dev/input/event3"
[   101.984] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   101.984] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[   101.985] (II) event3  - AT Translated Set 2 keyboard: device removed
[   101.985] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[   101.985] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
[   101.985] (**) Option "xkb_layout" "us"
[   101.985] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   101.985] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   101.986] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[   101.987] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event8)
[   101.987] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[   101.987] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[   101.987] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad"
[   101.987] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[   101.987] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 30 paused 0
[   101.987] (**) SynPS/2 Synaptics TouchPad: always reports core events
[   101.987] (**) Option "Device" "/dev/input/event8"
[   101.988] (II) event8  - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[   101.989] (II) event8  - SynPS/2 Synaptics TouchPad: device is a touchpad
[   101.989] (II) event8  - SynPS/2 Synaptics TouchPad: device removed
[   101.989] (**) Option "Tapping" "on"
[   101.990] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event8"
[   101.990] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 12)
[   101.990] (**) Option "AccelerationScheme" "none"
[   101.990] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[   101.990] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[   101.990] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[   101.991] (II) event8  - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[   101.992] (II) event8  - SynPS/2 Synaptics TouchPad: device is a touchpad
[   101.993] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[   101.993] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad"
[   101.993] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[   101.993] (**) SynPS/2 Synaptics TouchPad: always reports core events
[   101.993] (**) Option "Device" "/dev/input/mouse0"
[   101.993] (EE) xf86OpenSerial: Cannot open device /dev/input/mouse0
	Permission denied.
[   101.993] (II) mouse0: opening input device '/dev/input/mouse0' failed (Permission denied).
[   101.993] (II) mouse0  - failed to create input device '/dev/input/mouse0'.
[   101.993] (EE) libinput: SynPS/2 Synaptics TouchPad: Failed to create a device for /dev/input/mouse0
[   101.993] (EE) PreInit returned 2 for "SynPS/2 Synaptics TouchPad"
[   101.993] (II) UnloadModule: "libinput"
[   101.993] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/event13)
[   101.993] (**) TPPS/2 IBM TrackPoint: Applying InputClass "evdev pointer catchall"
[   101.993] (**) TPPS/2 IBM TrackPoint: Applying InputClass "libinput pointer catchall"
[   101.993] (II) Using input driver 'libinput' for 'TPPS/2 IBM TrackPoint'
[   101.994] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 31 paused 0
[   101.994] (**) TPPS/2 IBM TrackPoint: always reports core events
[   101.994] (**) Option "Device" "/dev/input/event13"
[   101.996] (II) event13 - TPPS/2 IBM TrackPoint: is tagged by udev as: Mouse Pointingstick
[   101.996] (II) event13 - TPPS/2 IBM TrackPoint: device is a pointer
[   101.997] (II) event13 - TPPS/2 IBM TrackPoint: device removed
[   101.997] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/serio2/input/input10/event13"
[   101.997] (II) XINPUT: Adding extended input device "TPPS/2 IBM TrackPoint" (type: MOUSE, id 13)
[   101.997] (**) Option "AccelerationScheme" "none"
[   101.997] (**) TPPS/2 IBM TrackPoint: (accel) selected scheme none/0
[   101.997] (**) TPPS/2 IBM TrackPoint: (accel) acceleration factor: 2.000
[   101.997] (**) TPPS/2 IBM TrackPoint: (accel) acceleration threshold: 4
[   101.998] (II) event13 - TPPS/2 IBM TrackPoint: is tagged by udev as: Mouse Pointingstick
[   101.999] (II) event13 - TPPS/2 IBM TrackPoint: device is a pointer
[   102.000] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/mouse1)
[   102.001] (II) No input driver specified, ignoring this device.
[   102.001] (II) This device may have been added with another device file.
[   102.001] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[   102.004] (II) config/udev: Adding input device ThinkPad Extra Buttons (/dev/input/event5)
[   102.004] (**) ThinkPad Extra Buttons: Applying InputClass "evdev keyboard catchall"
[   102.004] (**) ThinkPad Extra Buttons: Applying InputClass "libinput keyboard catchall"
[   102.004] (**) ThinkPad Extra Buttons: Applying InputClass "system-keyboard"
[   102.004] (**) ThinkPad Extra Buttons: Applying InputClass "Keyboard Defaults"
[   102.004] (II) Using input driver 'libinput' for 'ThinkPad Extra Buttons'
[   102.005] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 32 paused 0
[   102.005] (**) ThinkPad Extra Buttons: always reports core events
[   102.005] (**) Option "Device" "/dev/input/event5"
[   102.006] (II) event5  - ThinkPad Extra Buttons: is tagged by udev as: Keyboard Switch
[   102.006] (II) event5  - ThinkPad Extra Buttons: device is a keyboard
[   102.006] (II) event5  - ThinkPad Extra Buttons: device removed
[   102.007] (**) Option "config_info" "udev:/sys/devices/platform/thinkpad_acpi/input/input6/event5"
[   102.007] (II) XINPUT: Adding extended input device "ThinkPad Extra Buttons" (type: KEYBOARD, id 14)
[   102.007] (**) Option "xkb_layout" "us"
[   102.007] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   102.007] (II) event5  - ThinkPad Extra Buttons: is tagged by udev as: Keyboard Switch
[   102.008] (II) event5  - ThinkPad Extra Buttons: device is a keyboard
[   103.772] (EE)
[   103.772] (EE) Backtrace:
[   103.772] (EE) 0: /usr/lib/Xorg (xorg_backtrace+0x89) [0x563d5300b0d9]
[   103.772] (EE) 1: /usr/lib/Xorg (0x563d52ebb000+0x15aef9) [0x563d53015ef9]
[   103.772] (EE) 2: /usr/lib/libc.so.6 (0x7f8beef14000+0x42560) [0x7f8beef56560]
[   103.772] (EE) 3: /usr/lib/Xorg (0x563d52ebb000+0xc8f46) [0x563d52f83f46]
[   103.772] (EE) 4: /usr/lib/Xorg (0x563d52ebb000+0x1d5dd5) [0x563d53090dd5]
[   103.772] (EE) 5: /usr/lib/Xorg (0x563d52ebb000+0xdb1f2) [0x563d52f961f2]
[   103.772] (EE) 6: /usr/lib/Xorg (0x563d52ebb000+0xdfc2c) [0x563d52f9ac2c]
[   103.772] (EE) 7: /usr/lib/Xorg (0x563d52ebb000+0xe19fa) [0x563d52f9c9fa]
[   103.772] (EE) 8: /usr/lib/Xorg (0x563d52ebb000+0xe0b86) [0x563d52f9bb86]
[   103.772] (EE) 9: /usr/lib/Xorg (0x563d52ebb000+0x3d38a) [0x563d52ef838a]
[   103.772] (EE) 10: /usr/lib/libc.so.6 (0x7f8beef14000+0x2d310) [0x7f8beef41310]
[   103.772] (EE) 11: /usr/lib/libc.so.6 (__libc_start_main+0x81) [0x7f8beef413c1]
[   103.772] (EE) 12: /usr/lib/Xorg (_start+0x25) [0x563d52ef87d5]
[   103.772] (EE)
[   103.772] (EE) Segmentation fault at address 0x20
[   103.772] (EE)
Fatal server error:
[   103.772] (EE) Caught signal 11 (Segmentation fault). Server aborting
[   103.772] (EE)
[   103.772] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[   103.772] (EE) Please also check the log file at "/home/xuanzhen/.local/share/xorg/Xorg.1.log" for additional information.
[   103.772] (EE)
[   103.773] (II) AIGLX: Suspending AIGLX clients for VT switch
[   103.839] (EE) Server terminated with error (1). Closing log file.
I do not know enough to ascertain exactly what is failing. I followed arch wiki’s page on enabling bumblebee as well and that did not help
Nope, bad call, you only need the video-hybrid-intel-nvidia-390xx-bumblebee
Removing all propiety drivers and then manually only reinstalling bumblebee results in the same issue:
[   176.111]
[   176.112] Current Operating System: Linux rubeus 5.16.14-1-MANJARO #1 SMP PREEMPT Fri Mar 11 14:12:18 UTC 2022 x86_64
[   176.112] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64 root=UUID=4a72765e-c51f-4a44-ac54-7a41652bdee8 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[   176.113]
[   176.114] Current version of pixman: 0.40.0
[   176.115] 	Before reporting problems, check http://wiki.x.org
[   176.115] Markers: (--) probed, (**) from config file, (==) default setting,
[   176.118] (==) Log file: "/home/xuanzhen/.local/share/xorg/Xorg.1.log", Time: Tue Apr  5 14:02:05 2022
[   176.119] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   176.120] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   176.120] (==) No Layout section.  Using the first Screen section.
[   176.120] (==) No screen section available. Using defaults.
[   176.120] (**) |-->Screen "Default Screen Section" (0)
[   176.120] (**) |   |-->Monitor "<default monitor>"
[   176.121] (==) No device specified for screen "Default Screen Section".
[   176.121] (**) |   |-->Device "Device0"
[   176.121] (==) No monitor specified for screen "Default Screen Section".
[   176.121] (==) Automatically adding devices
[   176.121] (==) Automatically enabling devices
[   176.121] (==) Automatically adding GPU devices
[   176.121] (==) Automatically binding GPU devices
[   176.121] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   176.121] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   176.121] 	Entry deleted from font path.
[   176.121] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[   176.121] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[   176.121] (==) FontPath set to:
[   176.121] (==) ModulePath set to "/usr/lib/xorg/modules"
[   176.121] (**) Extension "Composite" is enabled
[   176.121] (**) Extension "RENDER" is enabled
[   176.122] (II) The server relies on udev to provide the list of input devices.
[   176.122] (II) Module ABI versions:
[   176.122] 	X.Org ANSI C Emulation: 0.4
[   176.122] 	X.Org Video Driver: 25.2
[   176.122] 	X.Org XInput driver : 24.4
[   176.122] 	X.Org Server Extension : 10.0
[   176.123] (++) using VT number 2
[   176.126] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_34
[   176.127] (II) xfree86: Adding drm device (/dev/dri/card0)
[   176.127] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[   176.128] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[   176.132] (--) PCI:*(0@0:2:0) 8086:0166:17aa:21f4 rev 9, Mem @ 0xf1400000/4194304, 0xe0000000/268435456, I/O @ 0x00007000/64, BIOS @ 0x????????/131072
[   176.132] (--) PCI: (1@0:0:0) 10de:0def:17aa:21f4 rev 161, Mem @ 0xf0000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00006000/128, BIOS @ 0x????????/524288
[   176.132] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   176.132] (II) LoadModule: "glx"
[   176.132] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   176.134] (II) Module glx: vendor="X.Org Foundation"
[   176.134] 	compiled for 1.21.1.3, module version = 1.0.0
[   176.134] 	ABI class: X.Org Server Extension, version 10.0
[   176.134] (II) LoadModule: "intel"
[   176.134] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[   176.135] (II) Module intel: vendor="X.Org Foundation"
[   176.135] 	compiled for 1.21.1.1, module version = 2.99.917
[   176.135] 	Module class: X.Org Video Driver
[   176.135] 	ABI class: X.Org Video Driver, version 25.2
[   176.135] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[   176.135] (II) intel: Driver for Intel(R) HD Graphics
[   176.135] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[   176.135] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[   176.135] xf86EnableIO: failed to enable I/O ports 0000-03ff (Operation not permitted)
[   176.135] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20201103
[   176.135] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[   176.152] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[   176.152] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 4000
[   176.152] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx; using a maximum of 2 threads
[   176.152] (II) intel(0): Creating default Display subsection in Screen section
[   176.152] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[   176.152] (==) intel(0): RGB weight 888
[   176.152] (==) intel(0): Default visual is TrueColor
[   176.152] (**) intel(0): Option "AccelMethod" "sna"
[   176.152] (**) intel(0): Option "DRI" "true"
[   176.153] (II) intel(0): Output LVDS1 has no monitor section
[   176.154] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output LVDS1
[   176.154] (II) intel(0): Enabled output LVDS1
[   176.154] (II) intel(0): Output VGA1 has no monitor section
[   176.154] (II) intel(0): Enabled output VGA1
[   176.154] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[   176.154] (II) intel(0): Output VIRTUAL1 has no monitor section
[   176.154] (II) intel(0): Enabled output VIRTUAL1
[   176.154] (--) intel(0): Output LVDS1 using initial mode 1600x900 on pipe 0
[   176.154] (==) intel(0): TearFree disabled
[   176.154] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[   176.154] (==) intel(0): DPI set to (96, 96)
[   176.154] (II) Loading sub module "dri3"
[   176.154] (II) LoadModule: "dri3"
[   176.154] (II) Module "dri3" already built-in
[   176.154] (II) Loading sub module "dri2"
[   176.154] (II) LoadModule: "dri2"
[   176.154] (II) Module "dri2" already built-in
[   176.154] (II) Loading sub module "present"
[   176.154] (II) LoadModule: "present"
[   176.154] (II) Module "present" already built-in
[   176.154] (II) intel(0): SNA initialized with Ivybridge (gen7, gt2) backend
[   176.154] (==) intel(0): Backing store enabled
[   176.154] (==) intel(0): Silken mouse enabled
[   176.154] (II) intel(0): HW Cursor enabled
[   176.155] (==) intel(0): DPMS enabled
[   176.155] (==) intel(0): Display hotplug detection enabled
[   176.155] (II) intel(0): [DRI2] Setup complete
[   176.155] (II) intel(0): [DRI2]   DRI driver: i965
[   176.155] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[   176.155] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[   176.155] (II) intel(0): hardware support for Present enabled
[   176.155] (II) Initializing extension Generic Event Extension
[   176.155] (II) Initializing extension SHAPE
[   176.155] (II) Initializing extension MIT-SHM
[   176.155] (II) Initializing extension XInputExtension
[   176.155] (II) Initializing extension XTEST
[   176.155] (II) Initializing extension BIG-REQUESTS
[   176.156] (II) Initializing extension SYNC
[   176.156] (II) Initializing extension XKEYBOARD
[   176.156] (II) Initializing extension XC-MISC
[   176.156] (II) Initializing extension SECURITY
[   176.156] (II) Initializing extension XFIXES
[   176.156] (II) Initializing extension RENDER
[   176.156] (II) Initializing extension RANDR
[   176.156] (II) Initializing extension COMPOSITE
[   176.156] (II) Initializing extension DAMAGE
[   176.157] (II) Initializing extension MIT-SCREEN-SAVER
[   176.157] (II) Initializing extension DOUBLE-BUFFER
[   176.157] (II) Initializing extension RECORD
[   176.157] (II) Initializing extension DPMS
[   176.157] (II) Initializing extension Present
[   176.157] (II) Initializing extension DRI3
[   176.157] (II) Initializing extension X-Resource
[   176.157] (II) Initializing extension XVideo
[   176.157] (II) Initializing extension XVideo-MotionCompensation
[   176.157] (II) Initializing extension GLX
[   176.165] (II) AIGLX: Loaded and initialized i965
[   176.165] (II) GLX: Initialized DRI2 GL provider for screen 0
[   176.165] (II) Initializing extension XFree86-VidModeExtension
[   176.165] (II) Initializing extension XFree86-DGA
[   176.165] (II) Initializing extension XFree86-DRI
[   176.165] (II) Initializing extension DRI2
[   176.169] (II) intel(0): switch to mode 1600x900@60.0 on LVDS1 using pipe 0, position (0, 0), rotation normal, reflection none
[   176.171] (II) intel(0): Setting screen physical size to 423 x 238
[   176.215] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[   176.215] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   176.215] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   176.215] (**) Power Button: Applying InputClass "system-keyboard"
[   176.215] (**) Power Button: Applying InputClass "Keyboard Defaults"
[   176.215] (II) LoadModule: "libinput"
[   176.215] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   176.217] (II) Module libinput: vendor="X.Org Foundation"
[   176.217] 	compiled for 1.21.1.3, module version = 1.2.1
[   176.217] 	Module class: X.Org XInput Driver
[   176.217] 	ABI class: X.Org XInput driver, version 24.4
[   176.217] (II) Using input driver 'libinput' for 'Power Button'
[   176.217] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 22 paused 0
[   176.218] (**) Power Button: always reports core events
[   176.218] (**) Option "Device" "/dev/input/event2"
[   176.220] (II) event2  - Power Button: is tagged by udev as: Keyboard
[   176.220] (II) event2  - Power Button: device is a keyboard
[   176.220] (II) event2  - Power Button: device removed
[   176.220] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[   176.220] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   176.220] (**) Option "xkb_layout" "us"
[   176.220] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   176.247] (II) event2  - Power Button: is tagged by udev as: Keyboard
[   176.247] (II) event2  - Power Button: device is a keyboard
[   176.248] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[   176.248] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   176.248] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   176.248] (**) Video Bus: Applying InputClass "system-keyboard"
[   176.248] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[   176.248] (II) Using input driver 'libinput' for 'Video Bus'
[   176.249] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 25 paused 0
[   176.249] (**) Video Bus: always reports core events
[   176.249] (**) Option "Device" "/dev/input/event6"
[   176.250] (II) event6  - Video Bus: is tagged by udev as: Keyboard
[   176.250] (II) event6  - Video Bus: device is a keyboard
[   176.251] (II) event6  - Video Bus: device removed
[   176.251] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8/event6"
[   176.251] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[   176.251] (**) Option "xkb_layout" "us"
[   176.251] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   176.252] (II) event6  - Video Bus: is tagged by udev as: Keyboard
[   176.252] (II) event6  - Video Bus: device is a keyboard
[   176.253] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[   176.253] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   176.253] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   176.253] (**) Video Bus: Applying InputClass "system-keyboard"
[   176.253] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[   176.253] (II) Using input driver 'libinput' for 'Video Bus'
[   176.254] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 26 paused 0
[   176.254] (**) Video Bus: always reports core events
[   176.254] (**) Option "Device" "/dev/input/event7"
[   176.255] (II) event7  - Video Bus: is tagged by udev as: Keyboard
[   176.255] (II) event7  - Video Bus: device is a keyboard
[   176.255] (II) event7  - Video Bus: device removed
[   176.255] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/LNXVIDEO:01/input/input9/event7"
[   176.255] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[   176.255] (**) Option "xkb_layout" "us"
[   176.255] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   176.257] (II) event7  - Video Bus: is tagged by udev as: Keyboard
[   176.257] (II) event7  - Video Bus: device is a keyboard
[   176.258] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[   176.258] (II) No input driver specified, ignoring this device.
[   176.258] (II) This device may have been added with another device file.
[   176.258] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[   176.258] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[   176.258] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[   176.258] (**) Sleep Button: Applying InputClass "system-keyboard"
[   176.258] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[   176.258] (II) Using input driver 'libinput' for 'Sleep Button'
[   176.259] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 27 paused 0
[   176.259] (**) Sleep Button: always reports core events
[   176.259] (**) Option "Device" "/dev/input/event1"
[   176.260] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[   176.260] (II) event1  - Sleep Button: device is a keyboard
[   176.261] (II) event1  - Sleep Button: device removed
[   176.261] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[   176.261] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[   176.261] (**) Option "xkb_layout" "us"
[   176.261] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   176.262] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[   176.262] (II) event1  - Sleep Button: device is a keyboard
[   176.263] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event14)
[   176.263] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[   176.263] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[   176.263] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[   176.263] (**) Integrated Camera: Integrated C: Applying InputClass "Keyboard Defaults"
[   176.263] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[   176.265] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 28 paused 0
[   176.265] (**) Integrated Camera: Integrated C: always reports core events
[   176.265] (**) Option "Device" "/dev/input/event14"
[   176.268] (II) event14 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[   176.268] (II) event14 - Integrated Camera: Integrated C: device is a keyboard
[   176.268] (II) event14 - Integrated Camera: Integrated C: device removed
[   176.268] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.0/input/input15/event14"
[   176.268] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 10)
[   176.268] (**) Option "xkb_layout" "us"
[   176.268] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   176.270] (II) event14 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[   176.270] (II) event14 - Integrated Camera: Integrated C: device is a keyboard
[   176.271] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event9)
[   176.271] (II) No input driver specified, ignoring this device.
[   176.271] (II) This device may have been added with another device file.
[   176.271] (II) config/udev: Adding input device HDA Intel PCH Dock Mic (/dev/input/event10)
[   176.272] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event11)
[   176.272] (II) No input driver specified, ignoring this device.
[   176.272] (II) This device may have been added with another device file.
[   176.272] (II) config/udev: Adding input device HDA Intel PCH Dock Headphone (/dev/input/event12)
[   176.279] (II) No input driver specified, ignoring this device.
[   176.279] (II) This device may have been added with another device file.
[   176.280] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[   176.280] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[   176.280] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[   176.280] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[   176.280] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[   176.280] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[   176.281] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 29 paused 0
[   176.281] (**) AT Translated Set 2 keyboard: always reports core events
[   176.281] (**) Option "Device" "/dev/input/event3"
[   176.282] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   176.282] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[   176.283] (II) event3  - AT Translated Set 2 keyboard: device removed
[   176.283] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[   176.283] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
[   176.283] (**) Option "xkb_layout" "us"
[   176.283] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   176.285] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   176.285] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[   176.286] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event8)
[   176.286] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[   176.286] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[   176.286] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad"
[   176.286] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[   176.288] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 30 paused 0
[   176.288] (**) SynPS/2 Synaptics TouchPad: always reports core events
[   176.288] (**) Option "Device" "/dev/input/event8"
[   176.289] (II) event8  - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[   176.290] (II) event8  - SynPS/2 Synaptics TouchPad: device is a touchpad
[   176.290] (II) event8  - SynPS/2 Synaptics TouchPad: device removed
[   176.291] (**) Option "Tapping" "on"
[   176.291] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input6/event8"
[   176.291] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 12)
[   176.292] (**) Option "AccelerationScheme" "none"
[   176.292] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[   176.292] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[   176.292] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[   176.293] (II) event8  - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[   176.295] (II) event8  - SynPS/2 Synaptics TouchPad: device is a touchpad
[   176.295] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[   176.295] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad"
[   176.295] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[   176.295] (**) SynPS/2 Synaptics TouchPad: always reports core events
[   176.295] (**) Option "Device" "/dev/input/mouse0"
[   176.296] (EE) xf86OpenSerial: Cannot open device /dev/input/mouse0
	Permission denied.
[   176.296] (II) mouse0: opening input device '/dev/input/mouse0' failed (Permission denied).
[   176.296] (II) mouse0  - failed to create input device '/dev/input/mouse0'.
[   176.296] (EE) libinput: SynPS/2 Synaptics TouchPad: Failed to create a device for /dev/input/mouse0
[   176.296] (EE) PreInit returned 2 for "SynPS/2 Synaptics TouchPad"
[   176.296] (II) UnloadModule: "libinput"
[   176.296] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/event13)
[   176.296] (**) TPPS/2 IBM TrackPoint: Applying InputClass "evdev pointer catchall"
[   176.296] (**) TPPS/2 IBM TrackPoint: Applying InputClass "libinput pointer catchall"
[   176.296] (II) Using input driver 'libinput' for 'TPPS/2 IBM TrackPoint'
[   176.298] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 31 paused 0
[   176.298] (**) TPPS/2 IBM TrackPoint: always reports core events
[   176.298] (**) Option "Device" "/dev/input/event13"
[   176.299] (II) event13 - TPPS/2 IBM TrackPoint: is tagged by udev as: Mouse Pointingstick
[   176.300] (II) event13 - TPPS/2 IBM TrackPoint: device is a pointer
[   176.301] (II) event13 - TPPS/2 IBM TrackPoint: device removed
[   176.301] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/serio2/input/input10/event13"
[   176.301] (II) XINPUT: Adding extended input device "TPPS/2 IBM TrackPoint" (type: MOUSE, id 13)
[   176.301] (**) Option "AccelerationScheme" "none"
[   176.301] (**) TPPS/2 IBM TrackPoint: (accel) selected scheme none/0
[   176.301] (**) TPPS/2 IBM TrackPoint: (accel) acceleration factor: 2.000
[   176.301] (**) TPPS/2 IBM TrackPoint: (accel) acceleration threshold: 4
[   176.302] (II) event13 - TPPS/2 IBM TrackPoint: is tagged by udev as: Mouse Pointingstick
[   176.303] (II) event13 - TPPS/2 IBM TrackPoint: device is a pointer
[   176.304] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/mouse1)
[   176.304] (II) No input driver specified, ignoring this device.
[   176.305] (II) This device may have been added with another device file.
[   176.305] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[   176.305] (II) No input driver specified, ignoring this device.
[   176.308] (II) config/udev: Adding input device ThinkPad Extra Buttons (/dev/input/event5)
[   176.308] (**) ThinkPad Extra Buttons: Applying InputClass "evdev keyboard catchall"
[   176.308] (**) ThinkPad Extra Buttons: Applying InputClass "libinput keyboard catchall"
[   176.308] (**) ThinkPad Extra Buttons: Applying InputClass "system-keyboard"
[   176.308] (**) ThinkPad Extra Buttons: Applying InputClass "Keyboard Defaults"
[   176.308] (II) Using input driver 'libinput' for 'ThinkPad Extra Buttons'
[   176.309] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 32 paused 0
[   176.309] (**) ThinkPad Extra Buttons: always reports core events
[   176.309] (**) Option "Device" "/dev/input/event5"
[   176.310] (II) event5  - ThinkPad Extra Buttons: is tagged by udev as: Keyboard Switch
[   176.310] (II) event5  - ThinkPad Extra Buttons: device is a keyboard
[   176.310] (II) event5  - ThinkPad Extra Buttons: device removed
[   176.310] (**) Option "config_info" "udev:/sys/devices/platform/thinkpad_acpi/input/input7/event5"
[   176.310] (II) XINPUT: Adding extended input device "ThinkPad Extra Buttons" (type: KEYBOARD, id 14)
[   176.310] (**) Option "xkb_layout" "us"
[   176.310] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   176.311] (II) event5  - ThinkPad Extra Buttons: is tagged by udev as: Keyboard Switch
[   176.312] (II) event5  - ThinkPad Extra Buttons: device is a keyboard
[   177.979] (EE)
[   177.979] (EE) Backtrace:
[   177.979] (EE) 0: /usr/lib/Xorg (xorg_backtrace+0x89) [0x5638b1f610d9]
[   177.979] (EE) 1: /usr/lib/Xorg (0x5638b1e11000+0x15aef9) [0x5638b1f6bef9]
[   177.980] (EE) 2: /usr/lib/libc.so.6 (0x7f32f0646000+0x42560) [0x7f32f0688560]
[   177.980] (EE) 3: /usr/lib/Xorg (0x5638b1e11000+0xc8f46) [0x5638b1ed9f46]
[   177.980] (EE) 4: /usr/lib/Xorg (0x5638b1e11000+0x1d5dd5) [0x5638b1fe6dd5]
[   177.980] (EE) 5: /usr/lib/Xorg (0x5638b1e11000+0xdb1f2) [0x5638b1eec1f2]
[   177.980] (EE) 6: /usr/lib/Xorg (0x5638b1e11000+0xdfc2c) [0x5638b1ef0c2c]
[   177.980] (EE) 7: /usr/lib/Xorg (0x5638b1e11000+0xe19fa) [0x5638b1ef29fa]
[   177.980] (EE) 8: /usr/lib/Xorg (0x5638b1e11000+0xe0b86) [0x5638b1ef1b86]
[   177.980] (EE) 9: /usr/lib/Xorg (0x5638b1e11000+0x3d38a) [0x5638b1e4e38a]
[   177.980] (EE) 10: /usr/lib/libc.so.6 (0x7f32f0646000+0x2d310) [0x7f32f0673310]
[   177.980] (EE) 11: /usr/lib/libc.so.6 (__libc_start_main+0x81) [0x7f32f06733c1]
[   177.980] (EE) 12: /usr/lib/Xorg (_start+0x25) [0x5638b1e4e7d5]
[   177.980] (EE)
[   177.980] (EE) Segmentation fault at address 0x20
[   177.980] (EE)
Fatal server error:
[   177.980] (EE) Caught signal 11 (Segmentation fault). Server aborting
[   177.980] (EE)
[   177.980] (EE)
 for help.
[   177.980] (EE) Please also check the log file at "/home/xuanzhen/.local/share/xorg/Xorg.1.log" for additional information.
[   177.980] (EE)
[   177.980] (II) AIGLX: Suspending AIGLX clients for VT switch
[   178.050] (EE) Server terminated with error (1). Closing log file.
mhwd -li currently is:
e[1me[31m> e[mInstalled PCI configs:
           video-linux            2018.05.04                true            PCI
video-hybrid-intel-nvidia-390xx-bumblebee            2021.12.18               false            PCI
e[1me[31mWarning: e[mNo installed USB configs!
I also tried replacing bumblebee with only 390xx, in which case I dont even get a login screen, its straight black screem from the start. Thank you for your patience.
Downgraded all the way down to kernel 5.4 LTS and the fan is working again. Couldn’t get the propiety drivers working though.
