When i click on system setting it doesnot launch…
Also no luck from terminal
inxi -fazy
Info: Dual Core model: Intel Core i3-4150 bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
L2: 3 MiB bogomips: 28010
Speed: 3070 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3070 2: 3203
3: 3156 4: 3183
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
ibpb ibrs invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology
xtpr
Type: l1tf
Strit
27 May 2021 08:01
2
Can you give the outpout of this command from terminal:
systemsettings5
When providing the output, please wrap in triple backticks, (```), like this:
terminal output
text
That will make it to show like this:
terminal output
text
making it easier for us, those trying to help, read and process it.
Also, please see How to provide good information
L2: 3 MiB bogomips: 28009
Speed: 3500 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3500 2: 3500
3: 3501 4: 3501
xtpr
Type: l1tf
file:///usr/share/kpackage/genericqml/org.kde.systemsettings.sidebar/contents/ui/SubCategoryPage.qml:158:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
file:///usr/share/kpackage/genericqml/org.kde.systemsettings.sidebar/contents/ui/SubCategoryPage.qml:148:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
QQmlEngine::setContextForObject(): Object already has a QQmlContext
qt.qpa.xcb: QXcbConnection: XCB error: 5 (BadAtom), sequence: 637, resource id: 0, major code: 20 (GetProperty), minor code: 0
