[pi@pi ~]$ journalctl -b -u dashboard.service
-- Journal begins at Fri 2021-10-29 16:07:00 UTC, ends at Tue 2022-04-12 10:59:40 UTC. --
Apr 12 10:58:49 pi systemd[1]: Starting Start scripts...
Apr 12 10:58:50 pi git[434]: No local changes to save
Apr 12 10:58:50 pi git[479]: fatal: unable to access 'https://github.com/caedenph/raspberry-dashboard/': Could not resolve host>
Apr 12 10:58:50 pi systemd[1]: dashboard.service: Control process exited, code=exited, status=1/FAILURE
Apr 12 10:58:50 pi systemd[1]: dashboard.service: Failed with result 'exit-code'.
Apr 12 10:58:50 pi systemd[1]: Failed to start Start scripts.
Indicating that the git pull failed due to what I would assume to be lack of network connectivity. I googled this error and there are also some ideas about proxy’s not ready. However, I have
I have been taking a look at the manuals, but I’m not entirely sure what I am looking for. Is there a target I need to add to the after or requires, or?
Im not sure what to do with this information, I tried googling it but I am a bit lost. Could I have a little more help please?
I know that NetworkManager supplies a NetworkManager-wait-online.service service you can use as a “required/after” target, but our minimal edition does not come with NetworkManager.
“Network Online” does not really mean that a connection has been made, just that the interface has been brought up.
Cut the crap! How do I make sure that my service starts after the network is really online?
Well, that depends on your setup and the services you plan to run after it (see above). If you need to delay you service after the network is up, include
This will ensure that all configured network devices are up and have an IP address assigned before the service is started. network-online.target will time out after 90s. Enabling this might considerably delay your boot even if the timeout is not reached.
The right “wait” service must be enabled too (NetworkManager-wait-online.service if NetworkManager is used to configure the network, systemd-networkd-wait-online.service if systemd-networkd is used, etc.). systemd-networkd.service has Also=systemd-networkd-wait-online.service in its [Install] section, so when systemd-networkd.service is enabled, systemd-networkd-wait-online.service will be enabled too, which means that network-online.target will include systemd-networkd-wait-online.service when and only when systemd-networkd.service is enabled. NetworkManager-wait-online.service is set up similarly. Verify that the right service is enabled (usually only one should be):
This shows a bunch of units with systemd-networkd-wait-online.service enabled disabled being one of the displayed units. This indicates that the systemd-networkd-wait-online service is enabled. I ran the systemctl is-enabled on the systemd-networkd-wait-online to confirm (I cant run it on the NetworkManager because that doesnt exist)
Unfortunately, the After=nss-lookup.target doesnt work I dont think. My current service unit looks like
Have you reloaded the system daemon after changing the units?
systemctl daemon-reload
I don’t think you need Requires because that is inferred from Wants and After and the nss-lookup.target should ensure nameservice is available too which you need to run the git pull.
To quote from above link
Units that strictly require a configured network connection should pull in network-online.target (via a Wants= type dependency) and order themselves after it. This target unit is intended to pull in a service that delays further execution until the network is sufficiently set up. What precisely this requires is left to the implementation of the network managing service.
Note the distinction between this unit and network.target. This unit is an active unit (i.e. pulled in by the consumer rather than the provider of this functionality) and pulls in a service which possibly adds substantial delays to further execution. In contrast, network.target is a passive unit (i.e. pulled in by the provider of the functionality, rather than the consumer) that usually does not delay execution much. Usually, network.target is part of the boot of most systems, while network-online.target is not, except when at least one unit requires it. Also see Running Services After the Network is up for more information.
All mount units for remote network file systems automatically pull in this unit, and order themselves after it. Note that networking daemons that simply provide functionality to other hosts (as opposed to consume functionality of other hosts) generally do not need to pull this in.
systemd automatically adds dependencies of type Wants= and After= for this target unit to all SysV init script service units with an LSB header referring to the “$network” facility.
Note that this unit is only useful during the original system start-up logic. After the system has completed booting up, it will not track the online state of the system anymore. Due to this it cannot be used as a network connection monitor concept, it is purely a one-time system start-up concept.
Everytime I change the unit I always reload the system daemon and reboot the pi.
Unfortunately, even without the Requires= param in the unit it still doesnt work. Any ideas why?
