I’m tired of my laptop taking ages to shutdown whenever a program acts up and won’t stop properly, so I configured /etc/systemd/system.conf like so:
DefaultTimeoutStopSec=05s
(that’s not the whole file, just the relevant setting)
But it seems to be getting ignored, here’s some of the entries from the tail end of journalctl from my last shutdown (it’s a lot)
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopping Accessibility services bus...
mar 19 20:00:29 coomerbox3000 gvfsd[1277]: A connection to the bus can't be made
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopping D-Bus User Message Bus...
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopping User preferences database...
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopping Virtual filesystem service...
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopping Bluetooth OBEX service...
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopping PipeWire PulseAudio...
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopping Portal service...
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopping flatpak document portal service...
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopping sandboxed app permission store...
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopped User preferences database.
mar 19 20:00:29 coomerbox3000 systemd[971]: obex.service: Main process exited, code=exited, status=1/FAILURE
mar 19 20:00:29 coomerbox3000 systemd[971]: obex.service: Failed with result 'exit-code'.
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopped Bluetooth OBEX service.
mar 19 20:00:29 coomerbox3000 systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
mar 19 20:00:29 coomerbox3000 systemd[1]: Unmounted /run/user/1000/doc.
mar 19 20:00:29 coomerbox3000 systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
mar 19 20:00:29 coomerbox3000 systemd[1]: Unmounted /run/user/1000/gvfs.
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopped PipeWire PulseAudio.
mar 19 20:00:29 coomerbox3000 systemd[971]: pipewire-pulse.service: Consumed 37.943s CPU time.
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopped Virtual filesystem service.
mar 19 20:00:29 coomerbox3000 systemd[971]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
mar 19 20:00:29 coomerbox3000 systemd[971]: xdg-document-portal.service: Failed with result 'exit-code'.
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopped flatpak document portal service.
mar 19 20:00:29 coomerbox3000 systemd[971]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
mar 19 20:00:29 coomerbox3000 systemd[971]: xdg-permission-store.service: Failed with result 'exit-code'.
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopped sandboxed app permission store.
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopping PipeWire Media Session Manager...
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopped D-Bus User Message Bus.
mar 19 20:00:29 coomerbox3000 systemd[971]: dbus.service: Consumed 2.106s CPU time.
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopped Portal service.
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopped PipeWire Media Session Manager.
mar 19 20:00:29 coomerbox3000 systemd[971]: pipewire-media-session.service: Consumed 3.693s CPU time.
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopping PipeWire Multimedia Service...
mar 19 20:00:29 coomerbox3000 systemd[971]: Stopped PipeWire Multimedia Service.
mar 19 20:00:29 coomerbox3000 systemd[971]: pipewire.service: Consumed 4.776s CPU time.
mar 19 20:00:29 coomerbox3000 systemd[971]: Removed slice User Core Session Slice.
mar 19 20:00:29 coomerbox3000 systemd[971]: session.slice: Consumed 49.487s CPU time.
mar 19 20:00:29 coomerbox3000 wpa_supplicant[947]: wlo1: CTRL-EVENT-DISCONNECTED bssid=fc:ec:da:15:a8:b0 reason=3 locally_generated=1
mar 19 20:00:29 coomerbox3000 wpa_supplicant[947]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
mar 19 20:00:29 coomerbox3000 NetworkManager[703]: <info> [1647720029.6511] device (wlo1): supplicant interface state: completed -> disconnected
mar 19 20:00:29 coomerbox3000 NetworkManager[703]: <info> [1647720029.6511] device (p2p-dev-wlo1): supplicant management interface state: compl>
mar 19 20:00:29 coomerbox3000 NetworkManager[703]: <info> [1647720029.6513] device (wlo1): state change: deactivating -> disconnected (reason '>
mar 19 20:00:29 coomerbox3000 NetworkManager[703]: <info> [1647720029.6514] dhcp4 (wlo1): canceled DHCP transaction
mar 19 20:00:29 coomerbox3000 NetworkManager[703]: <info> [1647720029.6515] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seco>
mar 19 20:00:29 coomerbox3000 NetworkManager[703]: <info> [1647720029.6515] dhcp4 (wlo1): state changed no lease
mar 19 20:00:29 coomerbox3000 NetworkManager[703]: <info> [1647720029.6526] device (wlo1): set-hw-addr: set MAC address to 2A:BF:26:F3:E5:C5 (s>
mar 19 20:00:29 coomerbox3000 systemd-resolved[668]: wlo1: Bus client set default route setting: no
mar 19 20:00:29 coomerbox3000 systemd-resolved[668]: wlo1: Bus client reset DNS server list.
mar 19 20:00:29 coomerbox3000 NetworkManager[703]: <info> [1647720029.6911] manager: NetworkManager state is now DISCONNECTED
mar 19 20:00:29 coomerbox3000 dbus-daemon[676]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.fre>
mar 19 20:00:29 coomerbox3000 dbus-daemon[676]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Re>
mar 19 20:00:29 coomerbox3000 audit: BPF prog-id=0 op=UNLOAD
mar 19 20:00:30 coomerbox3000 systemd[971]: Stopped Accessibility services bus.
mar 19 20:00:30 coomerbox3000 systemd[971]: Stopped target Basic System.
mar 19 20:00:30 coomerbox3000 systemd[971]: Stopped target Paths.
mar 19 20:00:30 coomerbox3000 systemd[971]: Stopped target Sockets.
mar 19 20:00:30 coomerbox3000 systemd[971]: Stopped target Timers.
mar 19 20:00:30 coomerbox3000 systemd[971]: Closed D-Bus User Message Bus Socket.
mar 19 20:00:30 coomerbox3000 systemd[971]: Closed GnuPG network certificate management daemon.
mar 19 20:00:30 coomerbox3000 systemd[971]: Closed GCR ssh-agent wrapper.
mar 19 20:00:30 coomerbox3000 systemd[971]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
mar 19 20:00:30 coomerbox3000 systemd[971]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
mar 19 20:00:30 coomerbox3000 systemd[971]: Closed GnuPG cryptographic agent (ssh-agent emulation).
mar 19 20:00:30 coomerbox3000 systemd[971]: Closed GnuPG cryptographic agent and passphrase cache.
mar 19 20:00:30 coomerbox3000 systemd[971]: Closed p11-kit server.
mar 19 20:00:30 coomerbox3000 systemd[971]: Closed PipeWire PulseAudio.
mar 19 20:00:30 coomerbox3000 systemd[971]: Closed PipeWire Multimedia System Socket.
mar 19 20:00:30 coomerbox3000 sddm[730]: Display server stopped.
mar 19 20:00:30 coomerbox3000 sddm[730]: Running display stop script "/usr/share/sddm/scripts/Xstop"
mar 19 20:00:30 coomerbox3000 sddm[730]: Removing display ":0" ...
mar 19 20:00:30 coomerbox3000 sddm[730]: Adding new display on vt 1 ...
mar 19 20:00:30 coomerbox3000 sddm[730]: Loading theme configuration from ""
mar 19 20:00:30 coomerbox3000 sddm[730]: Display server starting...
mar 19 20:00:30 coomerbox3000 sddm[730]: Adding cookie to "/var/run/sddm/{81891eb6-e7ee-4b7b-97d4-affdc13ffbe1}"
mar 19 20:00:30 coomerbox3000 sddm[730]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{81891eb6-e7ee-4>
mar 19 20:00:31 coomerbox3000 sddm[730]: Setting default cursor
mar 19 20:00:32 coomerbox3000 sddm[730]: Running display setup script "/usr/share/sddm/scripts/Xsetup"
mar 19 20:00:32 coomerbox3000 sddm[730]: Display server started.
mar 19 20:00:32 coomerbox3000 sddm[730]: Socket server starting...
mar 19 20:00:32 coomerbox3000 sddm[730]: Socket server started.
mar 19 20:00:32 coomerbox3000 sddm[730]: Loading theme configuration from "/usr/share/sddm/themes/breath/theme.conf"
mar 19 20:00:32 coomerbox3000 sddm[730]: Greeter starting...
mar 19 20:00:32 coomerbox3000 sddm[730]: Signal received: SIGTERM
mar 19 20:00:32 coomerbox3000 sddm[730]: Socket server stopping...
mar 19 20:00:32 coomerbox3000 sddm[730]: Socket server stopped.
mar 19 20:00:32 coomerbox3000 sddm[730]: Display server stopping...
mar 19 20:00:32 coomerbox3000 sddm-helper[798878]: [PAM] Starting...
mar 19 20:00:32 coomerbox3000 audit[798878]: USER_AUTH pid=798878 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authenticati>
mar 19 20:00:32 coomerbox3000 audit[798878]: USER_ACCT pid=798878 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting g>
mar 19 20:00:32 coomerbox3000 sddm-helper[798878]: [PAM] Authenticating...
mar 19 20:00:32 coomerbox3000 sddm-helper[798878]: [PAM] returning.
mar 19 20:00:32 coomerbox3000 sddm[730]: Display server stopped.
mar 19 20:00:32 coomerbox3000 sddm[730]: Running display stop script "/usr/share/sddm/scripts/Xstop"
mar 19 20:00:32 coomerbox3000 sddm[730]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
mar 19 20:00:32 coomerbox3000 systemd[1]: sddm.service: Deactivated successfully.
mar 19 20:00:32 coomerbox3000 systemd[1]: Stopped Simple Desktop Display Manager.
mar 19 20:00:32 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" e>
mar 19 20:00:32 coomerbox3000 systemd[1]: sddm.service: Consumed 6min 11.846s CPU time.
mar 19 20:00:32 coomerbox3000 systemd[1]: Stopping User Login Management...
mar 19 20:00:32 coomerbox3000 systemd[1]: systemd-logind.service: Deactivated successfully.
mar 19 20:00:32 coomerbox3000 systemd[1]: Stopped User Login Management.
mar 19 20:00:32 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm=">
mar 19 20:00:32 coomerbox3000 audit: BPF prog-id=0 op=UNLOAD
mar 19 20:01:59 coomerbox3000 systemd[971]: app-net.lutris.Lutris-b37e6bf7c0d5465fb22832c3704b2812.scope: Stopping timed out. Killing.
mar 19 20:01:59 coomerbox3000 systemd[971]: app-net.lutris.Lutris-b37e6bf7c0d5465fb22832c3704b2812.scope: Killing process 798441 (winedevice.exe>
mar 19 20:01:59 coomerbox3000 systemd[971]: app-net.lutris.Lutris-b37e6bf7c0d5465fb22832c3704b2812.scope: Killing process 798447 (winedevice.exe>
mar 19 20:01:59 coomerbox3000 systemd[971]: app-net.lutris.Lutris-b37e6bf7c0d5465fb22832c3704b2812.scope: Failed with result 'timeout'.
mar 19 20:01:59 coomerbox3000 systemd[971]: Stopped Lutris.
mar 19 20:01:59 coomerbox3000 systemd[971]: app-net.lutris.Lutris-b37e6bf7c0d5465fb22832c3704b2812.scope: Consumed 1min 4.310s CPU time.
mar 19 20:01:59 coomerbox3000 systemd[971]: Removed slice User Application Slice.
mar 19 20:01:59 coomerbox3000 systemd[971]: app.slice: Consumed 12min 19.531s CPU time.
mar 19 20:01:59 coomerbox3000 systemd[971]: Reached target Shutdown.
mar 19 20:01:59 coomerbox3000 systemd[971]: Finished Exit the Session.
mar 19 20:01:59 coomerbox3000 systemd[971]: Reached target Exit the Session.
mar 19 20:01:59 coomerbox3000 systemd[972]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] termin>
mar 19 20:01:59 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="syste>
mar 19 20:01:59 coomerbox3000 systemd[1]: user@1000.service: Deactivated successfully.
mar 19 20:01:59 coomerbox3000 systemd[1]: Stopped User Manager for UID 1000.
mar 19 20:01:59 coomerbox3000 systemd[1]: user@1000.service: Consumed 13min 11.413s CPU time.
mar 19 20:01:59 coomerbox3000 systemd[1]: Stopping User Runtime Directory /run/user/1000...
mar 19 20:01:59 coomerbox3000 kernel: kauditd_printk_skb: 13 callbacks suppressed
mar 19 20:01:59 coomerbox3000 kernel: audit: type=1131 audit(1647720119.617:264): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined ms>
mar 19 20:01:59 coomerbox3000 systemd[1]: run-user-1000.mount: Deactivated successfully.
mar 19 20:01:59 coomerbox3000 systemd[1]: Unmounted /run/user/1000.
mar 19 20:01:59 coomerbox3000 systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
mar 19 20:01:59 coomerbox3000 systemd[1]: Stopped User Runtime Directory /run/user/1000.
mar 19 20:01:59 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000>
mar 19 20:01:59 coomerbox3000 systemd[1]: Removed slice User Slice of UID 1000.
mar 19 20:01:59 coomerbox3000 systemd[1]: user-1000.slice: Consumed 2h 32min 38.025s CPU time.
mar 19 20:01:59 coomerbox3000 systemd[1]: Stopping Permit User Sessions...
mar 19 20:01:59 coomerbox3000 kernel: audit: type=1131 audit(1647720119.620:265): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined ms>
mar 19 20:01:59 coomerbox3000 systemd[1]: systemd-user-sessions.service: Deactivated successfully.
mar 19 20:01:59 coomerbox3000 systemd[1]: Stopped Permit User Sessions.
mar 19 20:01:59 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions>
mar 19 20:01:59 coomerbox3000 systemd[1]: Stopped target Network.
mar 19 20:01:59 coomerbox3000 systemd[1]: Stopped target Remote File Systems.
mar 19 20:01:59 coomerbox3000 systemd[1]: Stopping Network Manager...
mar 19 20:01:59 coomerbox3000 NetworkManager[703]: <info> [1647720119.6243] caught SIGTERM, shutting down normally.
mar 19 20:01:59 coomerbox3000 systemd[1]: Stopping Network Name Resolution...
mar 19 20:01:59 coomerbox3000 wpa_supplicant[947]: p2p-dev-wlo1: CTRL-EVENT-DSCP-POLICY clear_all
mar 19 20:01:59 coomerbox3000 wpa_supplicant[947]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
mar 19 20:01:59 coomerbox3000 systemd[1]: Stopping WPA supplicant...
mar 19 20:01:59 coomerbox3000 kernel: audit: type=1131 audit(1647720119.623:266): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined ms>
mar 19 20:01:59 coomerbox3000 systemd[1]: systemd-resolved.service: Deactivated successfully.
mar 19 20:01:59 coomerbox3000 systemd[1]: Stopped Network Name Resolution.
mar 19 20:01:59 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-resolved comm>
mar 19 20:01:59 coomerbox3000 audit: BPF prog-id=0 op=UNLOAD
mar 19 20:01:59 coomerbox3000 kernel: audit: type=1131 audit(1647720119.650:267): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined ms>
mar 19 20:01:59 coomerbox3000 kernel: audit: type=1334 audit(1647720119.650:268): prog-id=0 op=UNLOAD
mar 19 20:01:59 coomerbox3000 kernel: audit: type=1334 audit(1647720119.650:269): prog-id=0 op=UNLOAD
mar 19 20:01:59 coomerbox3000 wpa_supplicant[947]: p2p-dev-wlo1: CTRL-EVENT-TERMINATING
mar 19 20:01:59 coomerbox3000 wpa_supplicant[947]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
mar 19 20:01:59 coomerbox3000 NetworkManager[703]: <info> [1647720119.6814] device (wlo1): state change: disconnected -> unmanaged (reason 'unm>
mar 19 20:01:59 coomerbox3000 NetworkManager[703]: <info> [1647720119.6960] device (wlo1): set-hw-addr: reset MAC address to 64:5D:86:5A:06:13 >
mar 19 20:01:59 coomerbox3000 kernel: audit: type=1334 audit(1647720119.797:270): prog-id=0 op=UNLOAD
mar 19 20:01:59 coomerbox3000 NetworkManager[703]: <info> [1647720119.8928] device (p2p-dev-wlo1): state change: disconnected -> unmanaged (rea>
mar 19 20:01:59 coomerbox3000 dbus-daemon[676]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.fre>
mar 19 20:01:59 coomerbox3000 dbus-daemon[676]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Re>
mar 19 20:01:59 coomerbox3000 NetworkManager[703]: <info> [1647720119.9312] exiting (success)
mar 19 20:01:59 coomerbox3000 systemd[1]: NetworkManager.service: Deactivated successfully.
mar 19 20:01:59 coomerbox3000 systemd[1]: Stopped Network Manager.
mar 19 20:01:59 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm=">
mar 19 20:01:59 coomerbox3000 systemd[1]: NetworkManager.service: Consumed 6.100s CPU time.
mar 19 20:01:59 coomerbox3000 kernel: audit: type=1131 audit(1647720119.937:271): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined ms>
mar 19 20:02:00 coomerbox3000 wpa_supplicant[947]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
mar 19 20:02:00 coomerbox3000 wpa_supplicant[947]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
mar 19 20:02:00 coomerbox3000 wpa_supplicant[947]: wlo1: CTRL-EVENT-TERMINATING
mar 19 20:02:00 coomerbox3000 systemd[1]: wpa_supplicant.service: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped WPA supplicant.
mar 19 20:02:00 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm=">
mar 19 20:02:00 coomerbox3000 systemd[1]: wpa_supplicant.service: Consumed 1.322s CPU time.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopping D-Bus System Message Bus...
mar 19 20:02:00 coomerbox3000 kernel: audit: type=1131 audit(1647720120.063:272): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined ms>
mar 19 20:02:00 coomerbox3000 systemd[1]: dbus.service: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped D-Bus System Message Bus.
mar 19 20:02:00 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" e>
mar 19 20:02:00 coomerbox3000 systemd[1]: dbus.service: Consumed 41.966s CPU time.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped target Basic System.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped target Path Units.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped target Slice Units.
mar 19 20:02:00 coomerbox3000 systemd[1]: Removed slice User and Session Slice.
mar 19 20:02:00 coomerbox3000 systemd[1]: user.slice: Consumed 2h 32min 38.025s CPU time.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped target Socket Units.
mar 19 20:02:00 coomerbox3000 systemd[1]: avahi-daemon.socket: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
mar 19 20:02:00 coomerbox3000 systemd[1]: dbus.socket: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Closed D-Bus System Message Bus Socket.
mar 19 20:02:00 coomerbox3000 systemd[1]: nordvpnd.socket: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Closed NordVPN Daemon Socket.
mar 19 20:02:00 coomerbox3000 systemd[1]: snapd.socket: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Closed Socket activation for snappy daemon.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped target System Initialization.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped target Local Encrypted Volumes.
mar 19 20:02:00 coomerbox3000 systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 kernel: audit: type=1131 audit(1647720120.077:273): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined ms>
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
mar 19 20:02:00 coomerbox3000 systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped target Local Integrity Protected Volumes.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped target Local Verity Protected Volumes.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:acpi_video0...
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:intel_backlight...
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopping Set Up Additional Binary Formats...
mar 19 20:02:00 coomerbox3000 systemd[1]: systemd-sysctl.service: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped Apply Kernel Variables.
mar 19 20:02:00 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm=">
mar 19 20:02:00 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load >
mar 19 20:02:00 coomerbox3000 systemd[1]: systemd-modules-load.service: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-done c>
mar 19 20:02:00 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ldconfig comm="system>
mar 19 20:02:00 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hwdb-update c>
mar 19 20:02:00 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-catal>
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped Load Kernel Modules.
mar 19 20:02:00 coomerbox3000 systemd[1]: systemd-update-done.service: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped Update is Completed.
mar 19 20:02:00 coomerbox3000 systemd[1]: ldconfig.service: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped Rebuild Dynamic Linker Cache.
mar 19 20:02:00 coomerbox3000 systemd[1]: systemd-hwdb-update.service: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped Rebuild Hardware Database.
mar 19 20:02:00 coomerbox3000 systemd[1]: systemd-journal-catalog-update.service: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped Rebuild Journal Catalog.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
mar 19 20:02:00 coomerbox3000 systemd[1]: systemd-binfmt.service: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped Set Up Additional Binary Formats.
mar 19 20:02:00 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm=">
mar 19 20:02:00 coomerbox3000 systemd[1]: systemd-backlight@backlight:acpi_video0.service: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:acpi_video0.
mar 19 20:02:00 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@bac>
mar 19 20:02:00 coomerbox3000 systemd[1]: systemd-backlight@backlight:intel_backlight.service: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:intel_backlight.
mar 19 20:02:00 coomerbox3000 systemd[1]: Removed slice Slice /system/systemd-backlight.
mar 19 20:02:00 coomerbox3000 systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
mar 19 20:02:00 coomerbox3000 audit[798898]: SYSTEM_SHUTDOWN pid=798898 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="system>
mar 19 20:02:01 coomerbox3000 systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
mar 19 20:02:01 coomerbox3000 systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
mar 19 20:02:01 coomerbox3000 systemd[1]: systemd-update-utmp.service: Deactivated successfully.
mar 19 20:02:01 coomerbox3000 systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
mar 19 20:02:01 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp c>
mar 19 20:02:01 coomerbox3000 systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
mar 19 20:02:01 coomerbox3000 systemd[1]: Stopped Create Volatile Files and Directories.
mar 19 20:02:01 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setu>
mar 19 20:02:01 coomerbox3000 systemd[1]: Stopped target Local File Systems.
mar 19 20:02:01 coomerbox3000 systemd[1]: Unmounting /boot/efi...
mar 19 20:02:01 coomerbox3000 systemd[1]: Unmounting /run/credentials/systemd-sysusers.service...
mar 19 20:02:01 coomerbox3000 systemd[1]: Unmounting /run/media/rabcor/KingSpec...
mar 19 20:02:01 coomerbox3000 systemd[1]: Unmounting /run/media/rabcor/WD...
mar 19 20:02:01 coomerbox3000 systemd[1]: Unmounting Temporary Directory /tmp...
mar 19 20:02:01 coomerbox3000 systemd[1]: boot-efi.mount: Deactivated successfully.
mar 19 20:02:01 coomerbox3000 systemd[1]: Unmounted /boot/efi.
mar 19 20:02:01 coomerbox3000 systemd[1]: systemd-fsck@dev-disk-by\x2duuid-B822\x2d64D2.service: Deactivated successfully.
mar 19 20:02:01 coomerbox3000 systemd[1]: Stopped File System Check on /dev/disk/by-uuid/B822-64D2.
mar 19 20:02:01 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk>
mar 19 20:02:01 coomerbox3000 systemd[1]: Removed slice Slice /system/systemd-fsck.
mar 19 20:02:01 coomerbox3000 systemd[1]: run-credentials-systemd\x2dsysusers.service.mount: Deactivated successfully.
mar 19 20:02:01 coomerbox3000 systemd[1]: Unmounted /run/credentials/systemd-sysusers.service.
mar 19 20:02:01 coomerbox3000 systemd[1]: tmp.mount: Deactivated successfully.
mar 19 20:02:01 coomerbox3000 systemd[1]: Unmounted Temporary Directory /tmp.
mar 19 20:02:01 coomerbox3000 systemd[1]: Stopped target Swaps.
mar 19 20:02:01 coomerbox3000 systemd[1]: Deactivating swap /swapfile...
mar 19 20:02:01 coomerbox3000 systemd[1]: swapfile.swap: Deactivated successfully.
mar 19 20:02:01 coomerbox3000 systemd[1]: Deactivated swap /swapfile.
mar 19 20:02:01 coomerbox3000 kernel: XFS (sdb1): Unmounting Filesystem
mar 19 20:02:01 coomerbox3000 systemd[1]: run-media-rabcor-KingSpec.mount: Deactivated successfully.
mar 19 20:02:01 coomerbox3000 systemd[1]: Unmounted /run/media/rabcor/KingSpec.
mar 19 20:02:02 coomerbox3000 systemd[1]: run-media-rabcor-WD.mount: Deactivated successfully.
mar 19 20:02:02 coomerbox3000 systemd[1]: Unmounted /run/media/rabcor/WD.
mar 19 20:02:02 coomerbox3000 systemd[1]: run-media-rabcor-WD.mount: Consumed 1.234s CPU time.
mar 19 20:02:02 coomerbox3000 systemd[1]: Stopped target Preparation for Local File Systems.
mar 19 20:02:02 coomerbox3000 systemd[1]: Reached target Unmount All Filesystems.
mar 19 20:02:02 coomerbox3000 systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
mar 19 20:02:02 coomerbox3000 systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
mar 19 20:02:02 coomerbox3000 systemd[1]: Stopped Create Static Device Nodes in /dev.
mar 19 20:02:02 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setu>
mar 19 20:02:02 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysusers comm>
mar 19 20:02:02 coomerbox3000 systemd[1]: systemd-sysusers.service: Deactivated successfully.
mar 19 20:02:02 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-remount-fs co>
mar 19 20:02:02 coomerbox3000 systemd[1]: Stopped Create System Users.
mar 19 20:02:02 coomerbox3000 systemd[1]: systemd-remount-fs.service: Deactivated successfully.
mar 19 20:02:02 coomerbox3000 systemd[1]: Stopped Remount Root and Kernel File Systems.
mar 19 20:02:02 coomerbox3000 systemd[1]: lvm2-monitor.service: Deactivated successfully.
mar 19 20:02:02 coomerbox3000 systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
mar 19 20:02:02 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="sy>
mar 19 20:02:02 coomerbox3000 systemd[1]: Reached target System Shutdown.
mar 19 20:02:02 coomerbox3000 systemd[1]: Reached target Late Shutdown Services.
mar 19 20:02:02 coomerbox3000 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm=>
mar 19 20:02:02 coomerbox3000 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm=">
mar 19 20:02:02 coomerbox3000 systemd[1]: systemd-reboot.service: Deactivated successfully.
mar 19 20:02:02 coomerbox3000 systemd[1]: Finished System Reboot.
mar 19 20:02:02 coomerbox3000 systemd[1]: Reached target System Reboot.
mar 19 20:02:02 coomerbox3000 systemd[1]: Shutting down.
mar 19 20:02:02 coomerbox3000 audit: BPF prog-id=0 op=UNLOAD
mar 19 20:02:02 coomerbox3000 systemd-shutdown[1]: Syncing filesystems and block devices.
mar 19 20:02:02 coomerbox3000 systemd-shutdown[1]: Sending SIGTERM to remaining processes...
mar 19 20:02:02 coomerbox3000 systemd-journald[355]: Journal stopped
It took a bit over 90 seconds to shutdown, and the part where it seemed to hang was shutting down lutris, whose stop job timed out
Am I maybe reading it wrong? is the problem something else? I just want to not have to sit here and stare at a blinking underscore for minutes everytime i need to restart.
