After i updated with the last big update ( [Stable Update] 2022-03-14 - Kernels, KDE, LibreOffice, Kodi, Qt5, Mozilla, NetworkManager, Pipewire ) my (wireless usb logitech mx vertical) mouse now takes minutes to start working after I boot, which it didn’t before the update. Touchpad still works though.
After about a full minute or two the mouse works like normal.
Some inxi output:
Kernel: 5.16.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=ade649ba-48e8-4bd1-9e1c-7878c6f77246 rw quiet mitigations=off
nowatchdog pci=noaer cpufreq.default_governor=performance apparmor=1
security=apparmor udev.log_priority=3 acpi_osi=! acpi_osi=Linux
"acpi_osi=Windows 2009" nogpumanager intel_idle.max_cstate=1
i915.enable_gvt=1 i915-enable_fbc=1 pcie_port_pm=off iommu=pt
intel_iommu=on kvm.ignore_msrs=1 rd.driver.pre=vfio-pci
default_hugepagesz=1G hugepagesz=1G hugepages=0 transparent_hugepage=never
Desktop: KDE Plasma 5.24.3 tk: Qt 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: GE75 Raider 8SE v: REV:1.0
Mobo: Micro-Star model: MS-17E2 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E17E2IMS.11A date: 05/19/2020
ID-1: BAT1 charge: 34.9 Wh (90.2%) condition: 38.7/53.4 Wh (72.3%)
volts: 11.6 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A status: N/A
Device-1: hidpp_battery_0
model: Logitech MX Vertical Advanced Ergonomic Mouse serial: <filter>
charge: 10% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 31.19 GiB used: 3.48 GiB (11.2%)
RAM Report:
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 3902 high: 3913 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 3900 2: 3900 3: 3900
4: 3900 5: 3896 6: 3900 7: 3900 8: 3904 9: 3900 10: 3900 11: 3913 12: 3911
bogomips: 52815
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Type: srbds status: Vulnerable
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Acer HD Webcam type: USB driver: N/A bus-ID: 1-13:5
chip-ID: 5986:211c class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: AU Optronics built: 2018 res: 1920x1080 hz: 144
dpi: 128 gamma: 1.2 size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Sound Server-1: ALSA v: k5.16.14-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: no
Sound Server-3: PipeWire v: 0.3.48 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi
vendor: Rivet Networks Killer Wireless-AC 1550i Wireless driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 1969:e0b1 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Local Storage: total: 2.07 TiB used: 1.7 TiB (81.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3256GJ size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: E8FK11.C temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS100T2B0B-00YS70 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: KingSpec model: ACSC4M1TS25
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4H scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 152.97 GiB (65.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: ade649ba-48e8-4bd1-9e1c-7878c6f77246
label: NO_LABEL uuid: B822-64D2
ID-3: /run/media/rabcor/KingSpec raw-size: 953.87 GiB
size: 953.4 GiB (99.95%) used: 768.74 GiB (80.6%) fs: xfs dev: /dev/sdb1
maj-min: 8:17 label: N/A uuid: 7081018e-cce8-4d7d-b093-bb681ff46b8e
ID-4: /run/media/rabcor/WD raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 818.46 GiB (87.9%) fs: f2fs dev: /dev/sda1 maj-min: 8:1
label: Western Digital uuid: ae81d12d-6838-4833-b47b-8dd120364382
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-7:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-3: 1-9:4 info: SteelSeries ApS KLC type: HID
power: 300mA chip-ID: 1038:1122 class-ID: 0300
Device-4: 1-13:5 info: Acer HD Webcam type: Video driver: N/A
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:211c
class-ID: 0e02
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 62.0 C pch: 47.0 C mobo: N/A
Processes: 330 Uptime: 6m wakeups: 3 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1730 lib: 499
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
journalctl -b0 | grep usb
mar 19 02:12:03 coomerbox3000 kernel: usbcore: registered new interface driver usbfs
mar 19 02:12:03 coomerbox3000 kernel: usbcore: registered new interface driver hub
mar 19 02:12:03 coomerbox3000 kernel: usbcore: registered new device driver usb
mar 19 02:12:03 coomerbox3000 kernel: usbcore: registered new interface driver usbserial_generic
mar 19 02:12:03 coomerbox3000 kernel: usbserial: USB Serial support registered for generic
mar 19 02:12:03 coomerbox3000 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16
mar 19 02:12:03 coomerbox3000 kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
mar 19 02:12:03 coomerbox3000 kernel: usb usb1: Product: xHCI Host Controller
mar 19 02:12:03 coomerbox3000 kernel: usb usb1: Manufacturer: Linux 5.16.14-1-MANJARO xhci-hcd
mar 19 02:12:03 coomerbox3000 kernel: usb usb1: SerialNumber: 0000:00:14.0
mar 19 02:12:03 coomerbox3000 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.16
mar 19 02:12:03 coomerbox3000 kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
mar 19 02:12:03 coomerbox3000 kernel: usb usb2: Product: xHCI Host Controller
mar 19 02:12:03 coomerbox3000 kernel: usb usb2: Manufacturer: Linux 5.16.14-1-MANJARO xhci-hcd
mar 19 02:12:03 coomerbox3000 kernel: usb usb2: SerialNumber: 0000:00:14.0
mar 19 02:12:03 coomerbox3000 kernel: usb: port power management may be unreliable
mar 19 02:12:03 coomerbox3000 kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16
mar 19 02:12:03 coomerbox3000 kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
mar 19 02:12:03 coomerbox3000 kernel: usb usb3: Product: xHCI Host Controller
mar 19 02:12:03 coomerbox3000 kernel: usb usb3: Manufacturer: Linux 5.16.14-1-MANJARO xhci-hcd
mar 19 02:12:03 coomerbox3000 kernel: usb usb3: SerialNumber: 0000:01:00.2
mar 19 02:12:03 coomerbox3000 kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
mar 19 02:12:03 coomerbox3000 kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.16
mar 19 02:12:03 coomerbox3000 kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
mar 19 02:12:03 coomerbox3000 kernel: usb usb4: Product: xHCI Host Controller
mar 19 02:12:03 coomerbox3000 kernel: usb usb4: Manufacturer: Linux 5.16.14-1-MANJARO xhci-hcd
mar 19 02:12:03 coomerbox3000 kernel: usb usb4: SerialNumber: 0000:01:00.2
mar 19 02:12:03 coomerbox3000 kernel: usb 1-2: new full-speed USB device number 2 using xhci_hcd
mar 19 02:12:03 coomerbox3000 kernel: usb 1-2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
mar 19 02:12:03 coomerbox3000 kernel: usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
mar 19 02:12:03 coomerbox3000 kernel: usb 1-2: Product: USB Receiver
mar 19 02:12:03 coomerbox3000 kernel: usb 1-2: Manufacturer: Logitech
mar 19 02:12:03 coomerbox3000 kernel: usb 1-7: new high-speed USB device number 3 using xhci_hcd
mar 19 02:12:03 coomerbox3000 kernel: usb 1-7: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
mar 19 02:12:03 coomerbox3000 kernel: usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
mar 19 02:12:03 coomerbox3000 kernel: usb 1-7: Product: USB2.0-CRW
mar 19 02:12:03 coomerbox3000 kernel: usb 1-7: Manufacturer: Generic
mar 19 02:12:03 coomerbox3000 kernel: usb 1-7: SerialNumber: 20100201396000000
mar 19 02:12:03 coomerbox3000 kernel: usb 1-9: new full-speed USB device number 4 using xhci_hcd
mar 19 02:12:03 coomerbox3000 kernel: usb 1-9: New USB device found, idVendor=1038, idProduct=1122, bcdDevice= 2.30
mar 19 02:12:03 coomerbox3000 kernel: usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
mar 19 02:12:03 coomerbox3000 kernel: usb 1-9: Product: SteelSeries KLC
mar 19 02:12:03 coomerbox3000 kernel: usb 1-9: Manufacturer: SteelSeries
mar 19 02:12:04 coomerbox3000 kernel: usb 1-13: new high-speed USB device number 5 using xhci_hcd
mar 19 02:12:04 coomerbox3000 kernel: usb 1-13: New USB device found, idVendor=5986, idProduct=211c, bcdDevice= 3.01
mar 19 02:12:04 coomerbox3000 kernel: usb 1-13: New USB device strings: Mfr=1, Product=2, SerialNumber=0
mar 19 02:12:04 coomerbox3000 kernel: usb 1-13: Product: HD Webcam
mar 19 02:12:04 coomerbox3000 kernel: usb 1-13: Manufacturer: SunplusIT Inc
mar 19 02:12:04 coomerbox3000 kernel: usb 1-14: new full-speed USB device number 6 using xhci_hcd
mar 19 02:12:04 coomerbox3000 kernel: usb usb4: USB disconnect, device number 1
mar 19 02:12:04 coomerbox3000 kernel: usb usb3: USB disconnect, device number 1
mar 19 02:12:19 coomerbox3000 kernel: usb 1-14: device descriptor read/64, error -110
mar 19 02:12:35 coomerbox3000 kernel: usb 1-14: device descriptor read/64, error -110
mar 19 02:12:35 coomerbox3000 kernel: usb 1-14: new full-speed USB device number 7 using xhci_hcd
mar 19 02:12:51 coomerbox3000 kernel: usb 1-14: device descriptor read/64, error -110
mar 19 02:13:06 coomerbox3000 kernel: usb 1-14: device descriptor read/64, error -110
mar 19 02:13:06 coomerbox3000 kernel: usb usb1-port14: attempt power cycle
mar 19 02:13:07 coomerbox3000 kernel: usb 1-14: new full-speed USB device number 8 using xhci_hcd
mar 19 02:13:12 coomerbox3000 kernel: usb 1-14: Device not responding to setup address.
mar 19 02:13:12 coomerbox3000 kernel: usb 1-14: device not accepting address 8, error -71
mar 19 02:13:13 coomerbox3000 kernel: usb 1-14: new full-speed USB device number 9 using xhci_hcd
mar 19 02:13:18 coomerbox3000 kernel: usb 1-14: Device not responding to setup address.
mar 19 02:13:18 coomerbox3000 kernel: usb 1-14: device not accepting address 9, error -71
mar 19 02:13:18 coomerbox3000 kernel: usb usb1-port14: unable to enumerate USB device
mar 19 02:13:18 coomerbox3000 mtp-probe[3751]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7"
mar 19 02:13:18 coomerbox3000 mtp-probe[3752]: checking bus 1, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2"
mar 19 02:13:18 coomerbox3000 mtp-probe[3753]: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-13"
mar 19 02:13:18 coomerbox3000 mtp-probe[3750]: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9"
mar 19 02:13:19 coomerbox3000 mtp-probe[3889]: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-13"
mar 19 02:13:19 coomerbox3000 kernel: input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C52B.0001/input/input24
mar 19 02:13:19 coomerbox3000 mtp-probe[3890]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7"
mar 19 02:13:19 coomerbox3000 kernel: usbcore: registered new interface driver rtsx_usb
mar 19 02:13:19 coomerbox3000 kernel: hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-2/input0
mar 19 02:13:19 coomerbox3000 kernel: input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input25
mar 19 02:13:19 coomerbox3000 kernel: input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input26
mar 19 02:13:19 coomerbox3000 kernel: input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input27
mar 19 02:13:19 coomerbox3000 kernel: hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-2/input1
mar 19 02:13:19 coomerbox3000 kernel: hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-2/input2
mar 19 02:13:19 coomerbox3000 kernel: hid-generic 0003:1038:1122.0004: hiddev98,hidraw3: USB HID v1.11 Device [SteelSeries SteelSeries KLC] on usb-0000:00:14.0-9/input0
mar 19 02:13:19 coomerbox3000 kernel: input: SteelSeries SteelSeries KLC as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:1038:1122.0005/input/input29
mar 19 02:13:19 coomerbox3000 mtp-probe[3893]: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9"
mar 19 02:13:19 coomerbox3000 kernel: hid-generic 0003:1038:1122.0005: input,hidraw4: USB HID v1.11 Device [SteelSeries SteelSeries KLC] on usb-0000:00:14.0-9/input1
mar 19 02:13:19 coomerbox3000 kernel: usbcore: registered new interface driver usbhid
mar 19 02:13:19 coomerbox3000 kernel: usbhid: USB HID core driver
mar 19 02:13:20 coomerbox3000 kernel: logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-2/input2
mar 19 02:13:20 coomerbox3000 kernel: input: Logitech Wireless Device PID:407b Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:407B.0006/input/input30
mar 19 02:13:20 coomerbox3000 kernel: input: Logitech Wireless Device PID:407b Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:407B.0006/input/input31
mar 19 02:13:20 coomerbox3000 kernel: hid-generic 0003:046D:407B.0006: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:407b] on usb-0000:00:14.0-2/input2:1
mar 19 02:13:20 coomerbox3000 kernel: input: Logitech MX Vertical as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:407B.0006/input/input35
mar 19 02:13:20 coomerbox3000 kernel: logitech-hidpp-device 0003:046D:407B.0006: input,hidraw1: USB HID v1.11 Keyboard [Logitech MX Vertical] on usb-0000:00:14.0-2/input2:1
mar 19 02:13:20 coomerbox3000 upowerd[1183]: treated changed event as add on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:407B.0006/power_supply/hidpp_battery_0
idk what’s causing it. I also noticed that unplugging it and plugging it back in or turning it on or off seems to have no effect.
Update: I discovered that the issue is related to bluetooth (this is a USB mouse! not a bluetooth mouse!, it should be unaffacted) when bluetooth is enabled when i start my PC this occurs, if I turn it off it’ll usually unfreeze the mouse when this is happening.
I’ve been having problems with getting my bluetooth to connect to devices as well (device is not ready/ br-connection-adapter-not-powered; but sometimes it will just work.)
