System won't boot after update
Yesterday there were a whole lot of new updates in pamac, so I installed them all before shutting down for the night. Today, the system gets stuck on boot. I hear my HDD loading for a while, then nothing.
A second issue I have, which was never a problem before now, is that I don’t get any boot menu when booting from the HDD, and only one line of information while loading the system, before it goes to the login screen (it shows up fine when booting from USB.) This means that I can’t see if there’s any error message when the boot fails.
edit:
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=se
  tz=Europe/Stockholm misobasedir=manjaro misolabel=MANJARO_KDE_2115 quiet
  systemd.show_status=1 apparmor=1 security=apparmor driver=free
  nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: P8H67-M PRO v: Rev 1.xx serial: <filter>
  UEFI: American Megatrends v: 1004 date: 06/08/2011
  RAM: total: 7.75 GiB used: 2.41 GiB (31.1%)
  Info: Quad Core model: Intel Core i5-2400 bits: 64 type: MCP
  arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
  cache: L2: 6 MiB bogomips: 25553
  Speed: 1648 MHz min/max: 1600/3400 MHz Core speeds (MHz): 1: 1648 2: 1648
  3: 1648 4: 1734
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
  constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb est flush_l1d
  fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr
  nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt
  pse pse36 pti pts rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3
  stibp syscall tm tm2 tsc tsc_deadline_timer vme x2apic xsave xsaveopt
  xtopology xtpr
  Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
  Device-1: NVIDIA GK107 [GeForce GTX 650] vendor: ASUSTeK driver: nouveau
  v: kernel bus-ID: 01:00.0 chip-ID: 10de:0fc6 class-ID: 0300
  loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.5x10.9")
  s-diag: 523mm (20.6")
  Monitor-1: DVI-D-1 res: 1680x1050 hz: 60 dpi: 90
  size: 474x296mm (18.7x11.7") diag: 559mm (22")
  OpenGL: renderer: NVE7 v: 4.3 Mesa 21.2.3 direct render: Yes
  vendor: ASUSTeK P8H67 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  chip-ID: 8086:1c20 class-ID: 0403
  Device-2: NVIDIA GK107 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: yes
  vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
  port: c000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  Local Storage: total: 1.61 TiB used: 696.84 GiB (42.4%)
  ID-1: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: USB 3.2Gen1
  size: 14.32 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: N/A serial: <filter> rev: 1.00 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
  model: WD7502AAEX-00Z3A0 size: 698.64 GiB block-size: physical: 512 B
  logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1D05
  scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HDS721010CLA332
  size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  type: HDD rpm: 7200 serial: <filter> rev: A3MA scheme: MBR
  Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7203S rev: 1.06
  dev-links: cdrom
  ID-1: /mnt raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
  used: 113.74 GiB (12.4%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
  uuid: 3deb6435-3750-4dec-bf85-5817d3d734e4
  ID-2: /run/media/manjaro/127C22497C2227C5 raw-size: 698.63 GiB
  size: 698.63 GiB (100.00%) used: 583.1 GiB (83.5%) fs: ntfs dev: /dev/sdb1
  maj-min: 8:17 label: N/A uuid: 127C22497C2227C5
  ID-1: /dev/sda1 maj-min: 8:1 size: 3.24 GiB fs: iso9660
  ID-2: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
  uuid: C5CD-B119
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.3:3 info: SanDisk Ultra type: Mass Storage driver: usb-storage
  interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 224mA chip-ID: 0781:5581
  class-ID: 0806 serial: <filter>
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Device-1: 3-2:2 info: SteelSeries ApS Rival Gaming Mouse
  type: HID,Mouse,Keyboard driver: hid-generic,usbhid interfaces: 4 rev: 1.1
  speed: 12 Mb/s power: 200mA chip-ID: 1038:1384 class-ID: 0300
  Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 38.0 C mobo: N/A gpu: nouveau temp: 31.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 1140
  Processes: 217 Uptime: 1h 28m wakeups: 0 Init: systemd v: 249
  tool: systemctl Compilers: gcc: N/A Packages: pacman: 1234 lib: 333
  flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06 ```
Press ESC during boot to bring up the grub menu.
Also please read:
If your machine uses nvidia graphics, please do a forum search: there are plenty of driver related problems (and solutions!) already posted.
have you try to login in TTY ?
try with Ctrl+Alt +F2 to F7
if not you will use USB live manjaro for chroot to check in journal logs and X11 logs
Thank you, this helped a lot. I managed to resolve the problem by reinstalling the nvidia drivers.
I checked Xorg.0.log and it shows this:
[   165.310] (WW) NVIDIA(0):     supported through the NVIDIA 470.xx Legacy drivers. Please
[   165.310] (WW) NVIDIA(0):     visit http://www.nvidia.com/object/unix.html for more
[   165.310] (WW) NVIDIA(0):     information.  The 495.44 NVIDIA driver will ignore this
[   165.310] (WW) NVIDIA(0):     GPU.  Continuing probe...
[   165.310] (EE) No devices detected.
[   165.310] (EE)
Fatal server error:
[   165.310] (EE) no screens found(EE)
[   165.310] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[   165.310] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   165.310] (EE)
[   165.334] (EE) Server terminated with error (1). Closing log file.
However, what confused me is that when running mhwd -l it doesn’t say anything about 495.44 drivers
> 0000:01:00.0 (0300:10de:0fc6) Display controller nVidia Corporation:
    video-nvidia-470xx            2021.11.04               false            PCI
    video-nvidia-390xx            2021.11.04               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:05:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI ```
You should probably give some thought into upgrading the kernel since your running 5.13 which has been end of life for some time now.You can try 5.14 or 5.15.
It doesn’t show the latest one video-nvidia as it’s not supported by your GPU.
