System upgrade breaks dependency
Hello, trying to do a full system upgrade and it breaks dependencys
tryed removing lib32-libcanberra-gstreamer but i can not find it.
Can someone help me please.
Here is output
Thanks Dian fron the Netherlands
[dian@dian-pc ~]$ sudo pacman -Syu
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
:: Replace jack with extra/jack2? [Y/n]
:: Replace lib32-jack with multilib/lib32-jack2? [Y/n]
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n]
:: Replace pamac-common with extra/libpamac? [Y/n]
:: Replace python-dbus with extra/dbus-python? [Y/n]
:: Replace python-dbus-common with extra/dbus-python? [Y/n]
:: Replace qca with extra/qca-qt5? [Y/n]
warning: sndio: local (20180120-1) is newer than community (1.7.0-3)
resolving dependencies...
:: dbus-python and python2-dbus are in conflict. Remove python2-dbus? [y/N] y
:: installing lib32-libcanberra (0.30+2+gc0620e4-5) breaks dependency 'lib32-libcanberra=0.30+2+gc0620e4-3' required by lib32-libcanberra-gstreamer
:: installing pacman (6.0.0-2) breaks dependency 'pacman<5.3' required by package-query
Please check update announcements:
If you do the upgrade with pamac instead of pacman it will resolve the dependency issue for you without manual intervention. But like posted above its ab obsolete package
Thanks for your concern cjean and sawdoctor
Updated with pamac worked well for me.
What do you mean by
’ ab obsolete package’ sawdoctor
There was a known problem with updating these packages
[Stable Update] 2021-06-14 - Kernels, Browsers, Mesa, Deepin, Systemd, Gnome Apps 40.2, Pipewire, Haskell
  • You might be blocked updating when using pacman due to some libcanberra packages. Simply remove those packages: sudo pacman -Rdd lib32-libcanberra-pulse lib32-libcanberra-gstreamer libcanberra-pulse libcanberra-gstreamer. We recommend to use pamac anyway, which does this automatically: pamac update
The packages that you removed with pamac when you upgraded are no longer needed and have been replaced with a different package. So nothing will break removing them
Thanks for the explenation.
And i will now always use pamac to update.
Dian
