Hello, I’m new to Linux in general and I’m trying out different distros as VMs.
I’ve tried to update Manjaro in CLI using "sudo pacman -Syu kmail’ I included kmail because i want to try it out. It does fine until it gets to the signatures. Then it says " error signature from <about 400 different people> is unknown pkg.tar.zst is unknown trust. file /var/cache/pacman/pkg/libsysprof-capture- 47.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)). Do you want to delete it Y/n? I say yes to all of them, it doesn’t update a lot of packages. What’s wrong with this?
Try to update your mirrors first:
sudo pacman-mirrors -c Global
Then update again:
sudo pacman -Syyu kmail
Nope. No difference. I ran them both and it did the same thing. It says all the file are corrupted. Do you want to delete them? this time I said not to delete them. Does that mean the files are corrupted or have invalid signatures?
Then I tried the regular updates and it says it can’t. Invalid PGP signatures.
Maybe the wiki contains some helpful ideas:
Also, check this thread:
I’ll try it. Thanks!
If you want a scripted fix;
bash <(curl -s https://gitlab.com/cscs/mapare/-/raw/main/mapare) -K
I ran this. I tried an update after. Same thing. I’m just learning to use Linux, so not much computer common sense.
The item(s) you want to say “yes” to for sure are probably:
Download current keyring packages (y/N)? y
and the logical next steps:
Install the downloaded keyring packages (y/N)? y
and
Initialize and populate keys (y/N)? y
Great, fixed the issue for me!
