System stuck in boot screen
My system is not booting correctly, and seems to be stuck on the booting screen. I have managed to get access to the system by following [HowTo] Reach a minimal system
  Kernel: 6.6.99-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64
    root=UUID=17112bd4-5fab-4b45-be7d-a3d5e93e61ea rw 3
  Console: tty 1 DM: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX B360-F GAMING v: Rev 1.xx
    serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
    UEFI: American Megatrends v: 2301 date: 07/10/2020
  System RAM: total: 32 GiB available: 31.2 GiB used: 1.04 GiB (3.3%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None max-module-size: 16 GiB note: est.
  Device-1: ChannelA-DIMM1 type: no module installed
  Device-2: ChannelA-DIMM2 type: DDR4 detail: synchronous size: 16 GiB speed: 2133 MT/s volts:
    curr: 1 width (bits): data: 64 total: 64 manufacturer: Corsair part-no: CMW32GX4M2A2666C16
    serial: N/A
  Device-3: ChannelB-DIMM1 type: no module installed
  Device-4: ChannelB-DIMM2 type: DDR4 detail: synchronous size: 16 GiB speed: 2133 MT/s volts:
    serial: N/A
  Info: model: Intel Core i3-8350K bits: 64 type: MCP arch: Coffee Lake gen: core 8 level: v3
    note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xB (11)
    microcode: 0xF6
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate governor: powersave
    cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 32013
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art
    avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
    ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
    hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm lm mca mce md_clear
    mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
    pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme
    x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled; RSB filling;
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-4
    empty: HDMI-A-2,HDMI-A-3,HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:3e91 class-ID: 0300
  Device-2: NVIDIA AD104 [GeForce RTX 4070 SUPER] driver: nvidia v: 575.64.03
    alternate: nouveau,nvidia_drm non-free: 550-570.xx+ status: current (as of 2025-04)
    arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none empty: DP-1, DP-2, DP-3,
    HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2783 class-ID: 0300
  Display: unspecified server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8 driver: X:
    loaded: nvidia gpu: i915 tty: 215x45
  Monitor-1: DP-4 model: Samsung S34C65xU serial: <filter> built: 2023 res: 3440x1440 dpi: 109
    gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059
    white: x: 0.314 y: 0.329 size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: 3440x1440,
    2560x1440, 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
    1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0 drv: nvidia device: 1
    drv: iris device: 3 drv: swrast gbm: drv: iris surfaceless: drv: nvidia
    inactive: wayland,x11,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 25.1.6-arch1.1 note: console (EGL sourced)
    renderer: Mesa Intel UHD Graphics 630 (CFL GT2), NVIDIA GeForce RTX 4070 SUPER/PCIe/SSE2,
    llvmpipe (LLVM 20.1.8 256 bits)
  API: Vulkan v: 1.4.321 layers: 6 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 4070
    SUPER driver: nvidia v: 575.64.03 device-ID: 10de:2783 surfaces: N/A device: 1
    type: integrated-gpu name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel
    v: 25.1.6-arch1.1 device-ID: 8086:3e91 surfaces: N/A
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor
    gpu: nvidia-settings,nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA AD104 High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:22bc
    class-ID: 0403
  Device-3: Razer USA Barracuda Pro 2.4 driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14.1:5 chip-ID: 1532:053a class-ID: 0301
    serial: <filter>
  API: ALSA v: k6.6.99-1-MANJARO status: kernel-api with: aoss type: oss-emulator
  Server-2: PipeWire v: 1.4.6 status: off with: 1: pipewire-pulse status: off 2: wireplumber
    status: off 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter vendor: AzureWave
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:7922
    class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
  IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
  IF-ID-1: br-0e108781f2a2 state: down mac: <filter>
  IF-ID-2: br-e71baca079e0 state: down mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-10:2 chip-ID: 13d3:3585 class-ID: e001 serial: <filter>
  Message: Unable to run lvs. Root privileges required.
  Local Storage: total: 43.89 TiB used: 20.66 TiB (47.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB size: 3.64 TiB
    block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: 4B2QJXD7 temp: 39.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST22000NT001-3LS101 size: 20.01 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: EN01
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST22000NT001-3LS101 size: 20.01 TiB
    fw-rev: EN01
  ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: USB 3.2Gen1 size: 232.88 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A
    serial: <filter> fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 1.73 TiB size: 1.7 TiB (98.37%) used: 619.79 GiB (35.5%) fs: ext4
    dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A uuid: 17112bd4-5fab-4b45-be7d-a3d5e93e61ea
  ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 31 MiB (32.2%) fs: vfat
    dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A uuid: E8F2-6C8D
  ID-3: /data raw-size: 40.02 TiB size: 39.39 TiB (98.43%) used: 20.05 TiB (50.9%) fs: ext4
    dev: /dev/dm-0 maj-min: 254:0 mapped: data-data label: N/A uuid: N/A
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 1.91 TiB fs: ntfs label: N/A uuid: F002F4E202F4AF2A
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 651 MiB fs: ntfs label: N/A uuid: DAD68761D6873D2F
  ID-4: /dev/sdc1 maj-min: 8:33 size: 32 GiB fs: vfat label: ESD-USB uuid: 10E0-CCBC
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 16 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
  Device-1: 1-10:2 info: IMC Networks Wireless_Device type: bluetooth driver: btusb
    interfaces: 3 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
  Device-2: 1-11:3 info: SanDisk Ultra Flair type: mass storage driver: usb-storage
    interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 224mA
    chip-ID: 0781:5591 class-ID: 0806 serial: <filter>
  Hub-2: 1-14:4 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-14.1:5 info: Razer USA Barracuda Pro 2.4 type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1532:053a class-ID: 0301 serial: <filter>
  Device-2: 1-14.2:6 info: Razer USA BlackWidow V4 Pro type: keyboard,mouse,HID
    driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 1532:028d class-ID: 0300
  Device-3: 1-14.3:7 info: Razer USA Goliathus Extended type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 1532:0c02 class-ID: 0300
  Device-4: 1-14.4:8 info: Razer USA RC30-0315 Gaming Mouse [Basilisk X HyperSpeed]
    type: mouse,keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0083 class-ID: 0300
  Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 chip-ID: 1d6b:0003 class-ID: 0900
  System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 38 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1508 libs: 448 tools: pamac,yay pm: flatpak pkgs: 0
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    4: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    8: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 179
  1: cpu: 20.9% command: rsync pid: 719 mem: 33.5 MiB (0.1%)
  2: cpu: 3.3% command: [ext4lazyinit] pid: 555 mem: 0.00 MiB (0.0%)
  3: cpu: 1.5% command: rsync pid: 981 mem: 34.0 MiB (0.1%)
  4: cpu: 1.0% command: init pid: 1 mem: 13.5 MiB (0.0%)
  5: cpu: 0.8% command: dockerd pid: 711 mem: 84.2 MiB (0.2%)
  Memory top: 5 of 179
  1: mem: 84.2 MiB (0.2%) command: dockerd pid: 711 cpu: 0.8%
  2: mem: 42.9 MiB (0.1%) command: containerd pid: 666 cpu: 0.1%
  3: mem: 34.0 MiB (0.1%) command: rsync pid: 981 cpu: 1.5%
  4: mem: 33.5 MiB (0.1%) command: rsync pid: 719 cpu: 20.9%
  5: mem: 27.2 MiB (0.0%) command: NetworkManager pid: 571 cpu: 0.3%
  Processes: 179 Power: uptime: 1m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.4 GiB Init: systemd
    v: 257 default: graphical tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: Bash (login) v: 5.3.0 running-in: tty 1
    inxi: 3.3.38
> Installed PCI configs:
          video-nvidia            2025.01.13               false            PCI
           video-linux            2024.05.06                true            PCI
Any help would be appreciated, thanks
what were you doing prior to this? updating/installing/uninstalling etc…?
from chroot rerun update:
pacman-mirrors -f 5 && pacman -Syyu
if there are errors post the output here, if there are no errors and you are up to date, post output from:
ldconfig - (this should return nothing, if there are more than lets say 20 lines, dont bother to post, just let me know)
ls /etc/X11/* /etc/modprobe.d
pacman -Qm
So a couple days before this I was updating my Nvidia drivers and had some issues with this, however this all went well and has been working for just under a week with no issues.
Today I got a new monitor, aswell as switched from HDMI to DisplayPort and have had issues since then. Not 100% sure why that would cause an issue though
I ran this, there were no errors and it didnt do much (im already mostly up to date, it updated versions of firefox though)
ldconfig
Litrally returned nothing
/etc/modprobe.d:
mhwd-gpu.conf
/etc/X11/mhwd.d:
nvidia.conf
nvidia.conf.nvidia-xconfig-original
/etc/X11/xinit:
xinitrc
xinitrc.d
xserverrc
/etc/X11/xorg.conf.d:
00-keyboard.conf
30-touchpad.conf
90-mhwd.conf
pacman -Qm
aws-nuke-bin 3.56.0-1
java-openjdk-bin 24.0.1.u9-1
ksanecore5 24.08.3-1
libksane5 24.08.3-1
minecraft-launcher 1:2.1.3-3
neofetch 7.1.0-2
nordvpn-bin 3.20.2-4
opencode-bin 0.1.181-1
postman-bin 11.48.0-1
reiserfsprogs 3.6.27-5
rnp 0.17.1-1
v86d 0.1.10-13
switching the ports is probably the issue…
post also output from:
mhwd -l
since you have dual gpu, dont know what driver is being loaded, either nvidia or intel, or how is the gpu routed through the ports…
> 0000:01:00.0 (0300:10de:2783) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime            2025.01.13               false            PCI
> 0000:00:02.0 (0300:8086:3e91) Display controller Intel Corporation:
my Dual GPU is an inbuilt GPU on my motherboard (Intel), and an actual Graphics Card (Nvidia) which should be the one actually being used
you should have this installed:
or if you only want to use nvidia, disable intel gpu in bios, if you have the option…
so lets try installing the proper drivers, remove these:
mhwd -r pci video-linux
mhwd -r pci video-nvidia
install the proper ones:
mhwd -i pci video-hybrid-intel-nvidia-prime
if no errors, reboot and test…
This did work, but I also realized that when changing my monitor I plugged it into my internal GPU, not my actual GPU which would have been why the drivers wernt working, so if you will excuse me im going to go cry at my own stupidity
so if you are planing on using nvidia on games or other things, so switching completely to it would probably better, if you have the options in bios for switching gpus… if you do want that, you cant use the hybrid drivers that you installed, you will need these drivers video-nvidia
So just so im understanding correctly… mhwd -l now displays
(Because im plugged into the main GPU and not using the inbuilt GPU anymore)
In which case you reccomend going back to what I had before?
mhwd -r pci video-hybrid-intel-nvidia-prime
and
mhwd -i pci video-linux
mhwd -i pci video-nvidia
yes?
mhwd-l now dettects only nvidia, so yes, you should switch to only nvidia… dont need to install video-linux, since intel one is not being detected, only install video-nvidia… however, i dont understand why you are not having a black screen on the hybrid driver…
post output before you reinstall it from:
inxi -G
  Device-1: NVIDIA AD104 [GeForce RTX 4070 SUPER] driver: nvidia v: 575.64.03
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8 driver: X:
    loaded: nvidia unloaded: modesetting gpu: nvidia,nvidia-nvswitch
    resolution: N/A
  API: EGL v: 1.5 drivers: nvidia,swrast
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.03
    renderer: NVIDIA GeForce RTX 4070 SUPER/PCIe/SSE2
  API: Vulkan v: 1.4.321 drivers: nvidia surfaces: N/A
only nvidia is being detected, and the proper driver loaded… post also output from:
mhwd -li
it works also on the hybrid one, so i would just keep it, and not reinstall it…
Ok, sounds good, appreciate your help
Just a quick note here - your font rendering; those dashed lines…
