Few days I have been trying manjaro Deepin, Budgie, Gnome editions
There is no crucial problem all about them while booting from external hdd
But, whenever installed PCI express connected internal Disk (probably nvme ssd), system not starting in normally. (I didnt test gnome yet, only external hdd disk) It same on Deepin and Budgie DEs I can able to start with tty2andstartx` command on budgide DE
I need to share initial systemctl report and system hardware.
screenfetch
██████████████████ ████████ test@test-inspiron3585
██████████████████ ████████ OS: Manjaro 21.0.4 Ornara
██████████████████ ████████ Kernel: x86_64 Linux 5.10.34-1-MANJARO
██████████████████ ████████ Uptime: 30m
████████ ████████ Packages: 1057
████████ ████████ ████████ Shell: bash 5.1.4
████████ ████████ ████████ Resolution: 1920x1080
████████ ████████ ████████ DE: GNOME 3.38.5
████████ ████████ ████████ WM: BudgieWM
████████ ████████ ████████ WM Theme: Adwaita
████████ ████████ ████████ GTK Theme: Matcha-sea [GTK2/3]
████████ ████████ ████████ Icon Theme: Papirus-Dark-Maia
████████ ████████ ████████ Font: Cantarell 11
████████ ████████ ████████ Disk: 7,3G / 228G (4%)
CPU: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx @ 8x 2GHz
GPU: AMD Radeon(TM) Vega 8 Graphics (RAVEN, DRM 3.40.0, 5.10.34-1-MANJARO, LLVM 11.1.0)
RAM: 2290MiB / 5898MiB
Systemctl list
journalctl --list-boot
0 86dc60f0dc004ebdbd724bbdc5ee19d4 Sun 2021-05-09 23:27:12 +03—Sun 2021-05-09 23:54:38 +03
Systectl report
journalctl
-- Journal begins at Sun 2021-05-09 23:27:12 +03, ends at Sun 2021-05-09 23:54:38 +03. --
May 09 23:27:12 test-inspiron3585 kernel: Linux version 5.10.34-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP Sun May 2 11:29:56 UTC 2021
May 09 23:27:12 test-inspiron3585 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=3d6060c8-60ca-489c-bcbd-d5b474b05be6 rw quiet apparmor=1 security=apparmor resume=UUID=1c66fe45-57bf-416e-a>
May 09 23:27:12 test-inspiron3585 kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
May 09 23:27:12 test-inspiron3585 kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
May 09 23:27:12 test-inspiron3585 kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
May 09 23:27:12 test-inspiron3585 kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
May 09 23:27:12 test-inspiron3585 kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
May 09 23:27:12 test-inspiron3585 kernel: BIOS-provided physical RAM map:
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000086fff] usable
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x0000000000087000-0x0000000000087fff] reserved
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x0000000000088000-0x000000000009ffff] usable
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000bffff] reserved
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009bfffff] usable
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x0000000009c00000-0x0000000009cfffff] reserved
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x0000000009d00000-0x0000000009efffff] usable
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x0000000009f00000-0x0000000009f09fff] ACPI NVS
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x0000000009f0a000-0x000000002c179fff] usable
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x000000002c17a000-0x000000002d379fff] reserved
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x000000002d37a000-0x000000004b58efff] usable
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x000000004b58f000-0x000000004b78efff] type 20
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x000000004b78f000-0x000000004d78efff] reserved
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x000000004d78f000-0x000000004f78efff] ACPI NVS
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x000000004f78f000-0x000000004f7fefff] ACPI data
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x000000004f7ff000-0x000000004f7fffff] usable
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x000000004f800000-0x00000000cfffffff] reserved
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed80fff] reserved
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffefffff] reserved
May 09 23:27:12 test-inspiron3585 kernel: BIOS-e820: [mem 0x0000000100000000-0x000000022f33ffff] usable
May 09 23:27:12 test-inspiron3585 kernel: NX (Execute Disable) protection: active
May 09 23:27:12 test-inspiron3585 kernel: efi: EFI v2.60 by Dell Inc.
May 09 23:27:12 test-inspiron3585 kernel: efi: ACPI=0x4f7fe000 ACPI 2.0=0x4f7fe014 SMBIOS=0x4c493000 SMBIOS 3.0=0x4c491000 ESRT=0x4c494698 TPMFinalLog=0x4d638000 MEMATTR=0x3a80b018
May 09 23:27:12 test-inspiron3585 kernel: SMBIOS 3.1.1 present.
May 09 23:27:12 test-inspiron3585 kernel: DMI: Dell Inc. Inspiron 3585/0CNMRV, BIOS 1.4.0 05/29/2019
May 09 23:27:12 test-inspiron3585 kernel: tsc: Fast TSC calibration using PIT
May 09 23:27:12 test-inspiron3585 kernel: tsc: Detected 1996.134 MHz processor
May 09 23:27:12 test-inspiron3585 kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
May 09 23:27:12 test-inspiron3585 kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
May 09 23:27:12 test-inspiron3585 kernel: last_pfn = 0x22f340 max_arch_pfn = 0x400000000
May 09 23:27:12 test-inspiron3585 kernel: MTRR default type: uncachable
May 09 23:27:12 test-inspiron3585 kernel: MTRR fixed ranges enabled:
May 09 23:27:12 test-inspiron3585 kernel: 00000-9FFFF write-back
May 09 23:27:12 test-inspiron3585 kernel: A0000-BFFFF uncachable
May 09 23:27:12 test-inspiron3585 kernel: C0000-DFFFF write-through
May 09 23:27:12 test-inspiron3585 kernel: E0000-FFFFF uncachable
May 09 23:27:12 test-inspiron3585 kernel: MTRR variable ranges enabled:
May 09 23:27:12 test-inspiron3585 kernel: 0 base 000000000000 mask FFFF80000000 write-back
May 09 23:27:12 test-inspiron3585 kernel: 1 base 000080000000 mask FFFFC0000000 write-back
May 09 23:27:12 test-inspiron3585 kernel: 2 base 0000C0000000 mask FFFFF0000000 write-back
...skipping...
May 09 23:48:22 test-inspiron3585 dbus-daemon[369]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.99' (uid=0 pid=3678 comm="/us>
May 09 23:48:22 test-inspiron3585 dbus-daemon[369]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
May 09 23:48:22 test-inspiron3585 polkit-agent-helper-1[3678]: pam_systemd_home(polkit-1:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 09 23:48:22 test-inspiron3585 audit[3678]: USER_ACCT pid=3678 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="test" exe="/usr/lib/polkit-1/polkit>
May 09 23:48:22 test-inspiron3585 kernel: audit: type=1100 audit(1620593302.426:126): pid=3678 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock >
May 09 23:48:22 test-inspiron3585 kernel: audit: type=1101 audit(1620593302.426:127): pid=3678 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="test" >
May 09 23:48:22 test-inspiron3585 polkitd[373]: Operator of unix-session:1 successfully authenticated as unix-user:test to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1>
May 09 23:48:29 test-inspiron3585 pamac-tray[1322]: updates_checker.vala:71: check updates
May 09 23:48:29 test-inspiron3585 pamac-tray[1322]: updates_checker.vala:101: 1 updates found
May 09 23:49:49 test-inspiron3585 dbus-daemon[1037]: [session uid=1000 pid=1035] Activating service name='org.freedesktop.Tracker3.Miner.Extract' requested by ':1.45' (uid=1000 pid=1351 comm="/usr/lib/tracker-m>
May 09 23:49:49 test-inspiron3585 dbus-daemon[1032]: [session uid=1000 pid=1032] Reloaded configuration
May 09 23:49:49 test-inspiron3585 dbus-daemon[1037]: [session uid=1000 pid=1035] Reloaded configuration
May 09 23:49:49 test-inspiron3585 dbus-daemon[1037]: [session uid=1000 pid=1035] Successfully activated service 'org.freedesktop.Tracker3.Miner.Extract'
May 09 23:49:49 test-inspiron3585 pamac-manager[3660]: pamac_database_custom_db_search: assertion 'needles != NULL' failed
May 09 23:49:54 test-inspiron3585 pamac-tray[1322]: updates_checker.vala:71: check updates
May 09 23:49:54 test-inspiron3585 nemo[3850]: Current gtk theme is not known to have nemo support (Matcha-sea) - checking...
May 09 23:49:54 test-inspiron3585 pamac-tray[1322]: updates_checker.vala:101: 0 updates found
May 09 23:51:27 test-inspiron3585 budgie-wm.desktop[1268]: Window manager warning: WM_TRANSIENT_FOR window 0x4e01a2c for 0x4e01a9c window override-redirect is an override-redirect window and this is not correct>
May 09 23:51:28 test-inspiron3585 budgie-wm.desktop[1268]: Window manager warning: WM_TRANSIENT_FOR window 0x4e01a2c for 0x4e01afa window override-redirect is an override-redirect window and this is not correct>
May 09 23:51:29 test-inspiron3585 budgie-wm.desktop[1268]: Window manager warning: WM_TRANSIENT_FOR window 0x4e01a2c for 0x4e01afa window override-redirect is an override-redirect window and this is not correct>
May 09 23:51:31 test-inspiron3585 dbus-daemon[1037]: [session uid=1000 pid=1035] Activating service name='org.freedesktop.Tracker3.Miner.Extract' requested by ':1.45' (uid=1000 pid=1351 comm="/usr/lib/tracker-m>
May 09 23:51:31 test-inspiron3585 dbus-daemon[1037]: [session uid=1000 pid=1035] Successfully activated service 'org.freedesktop.Tracker3.Miner.Extract'
May 09 23:52:34 test-inspiron3585 dbus-daemon[1037]: [session uid=1000 pid=1035] Activating service name='org.gnome.gedit' requested by ':1.132' (uid=1000 pid=3850 comm="nemo ")
May 09 23:52:34 test-inspiron3585 dbus-daemon[1037]: [session uid=1000 pid=1035] Successfully activated service 'org.gnome.gedit'
May 09 23:52:34 test-inspiron3585 gedit[4164]: Error loading plugin: libaspell.so.15: cannot open shared object file: No such file or directory
May 09 23:52:34 test-inspiron3585 gedit[4164]: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
May 09 23:52:34 test-inspiron3585 gedit[4164]: Error loading plugin: libvoikko.so.1: cannot open shared object file: No such file or directory
May 09 23:52:34 test-inspiron3585 gedit[4164]: Error loading plugin: libnuspell.so.4: cannot open shared object file: No such file or directory
May 09 23:53:00 test-inspiron3585 dbus-daemon[1037]: [session uid=1000 pid=1035] Activating service name='org.gnome.gedit' requested by ':1.132' (uid=1000 pid=3850 comm="nemo ")
May 09 23:53:00 test-inspiron3585 dbus-daemon[1037]: [session uid=1000 pid=1035] Successfully activated service 'org.gnome.gedit'
May 09 23:53:00 test-inspiron3585 gedit[4187]: Error loading plugin: libaspell.so.15: cannot open shared object file: No such file or directory
May 09 23:53:00 test-inspiron3585 gedit[4187]: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
May 09 23:53:00 test-inspiron3585 gedit[4187]: Error loading plugin: libvoikko.so.1: cannot open shared object file: No such file or directory
May 09 23:53:00 test-inspiron3585 gedit[4187]: Error loading plugin: libnuspell.so.4: cannot open shared object file: No such file or directory
May 09 23:54:38 test-inspiron3585 NetworkManager[371]: <info> [1620593678.5901] device (wlp3s0): set-hw-addr: set MAC address to 4A:57:B0:DA:32:B3 (scanning)
May 09 23:54:38 test-inspiron3585 NetworkManager[371]: <info> [1620593678.5966] device (wlp3s0): supplicant interface state: inactive -> interface_disabled
May 09 23:54:38 test-inspiron3585 NetworkManager[371]: <info> [1620593678.5966] device (p2p-dev-wlp3s0): supplicant management interface state: inactive -> interface_disabled
May 09 23:54:38 test-inspiron3585 NetworkManager[371]: <info> [1620593678.7082] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
May 09 23:54:38 test-inspiron3585 NetworkManager[371]: <info> [1620593678.7083] device (p2p-dev-wlp3s0): supplicant management interface state: interface_disabled -> inactive
...skipping...
...skipping...
...skipping...
Hardware
lshw -short
WARNING: you should run this program as super-user.
H/W path Device Class Description
system Computer
/0 bus Motherboard
/0/0 memory 6GiB System memory
/0/1 processor AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
/0/100 bridge Raven/Raven2 Root Complex
/0/100/0.2 generic Raven/Raven2 IOMMU
/0/100/1.2 bridge Raven/Raven2 PCIe GPP Bridge [6:0]
/0/100/1.2/0 /dev/nvme0 storage KBG30ZMS256G NVMe TOSHIBA 256GB
/0/100/1.2/0/1 /dev/nvme0n1 disk NVMe disk
/0/100/1.6 bridge Raven/Raven2 PCIe GPP Bridge [6:0]
/0/100/1.6/0 enp2s0 network RTL810xE PCI Express Fast Ethernet controller
/0/100/1.7 bridge Raven/Raven2 PCIe GPP Bridge [6:0]
/0/100/1.7/0 wlp3s0 network QCA9377 802.11ac Wireless Network Adapter
/0/100/8.1 bridge Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
/0/100/8.1/0 display Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
/0/100/8.1/0.1 multimedia Raven/Raven2/Fenghuang HDMI/DP Audio Controller
/0/100/8.1/0.2 generic Family 17h (Models 10h-1fh) Platform Security Processor
/0/100/8.1/0.3 bus Raven USB 3.1
/0/100/8.1/0.4 bus Raven USB 3.1
/0/100/8.1/0.6 multimedia Family 17h (Models 10h-1fh) HD Audio Controller
/0/100/8.2 bridge Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B
/0/100/8.2/0 storage FCH SATA Controller [AHCI mode]
/0/100/14 bus FCH SMBus Controller
/0/100/14.3 bridge FCH LPC Bridge
/0/101 bridge Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
/0/102 bridge Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
/0/103 bridge Raven/Raven2 Device 24: Function 0
/0/104 bridge Raven/Raven2 Device 24: Function 1
/0/105 bridge Raven/Raven2 Device 24: Function 2
/0/106 bridge Raven/Raven2 Device 24: Function 3
/0/107 bridge Raven/Raven2 Device 24: Function 4
/0/108 bridge Raven/Raven2 Device 24: Function 5
/0/109 bridge Raven/Raven2 Device 24: Function 6
/0/10a bridge Raven/Raven2 Device 24: Function 7
/0/2 system Motherboard registers
/0/3 system AT Real-Time Clock
/0/4 input IBM Enhanced keyboard controller (101/2-key)
/0/5 generic PnP device DLL08d7
/0/6 system Motherboard registers
/0/7 system System Board
/1 scsi1 storage
/2 mmc0 bus MMC Host
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
