System sometimes crashes to login screen after closing VLC
Happens often enough to be an annoyance, but without any obvious pattern to it, aside from the fact that it’s always triggered when VLC is closed. If anyone’s encountered and successfully resolved a problem like this, I’d appreciate your help.
I’m not sure how, if at all, relevant and readable my journalctl log is, so I’ll happily change it or provide other output if necessary.
inxi -Fza output:
System:    Kernel: 5.8.0-2-MANJARO x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=cd849d35-c8c4-4f26-bdc4-002e98527dcd rw quiet apparmor=1
           security=apparmor resume=UUID=7a219f56-7b22-4c13-95b0-edfcebd9ed3d udev.log_priority=3
           Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: PRIME B360-PLUS v: Rev 1.xx serial: <filter> UEFI: American Megatrends v: 1601
           date: 07/30/2019
CPU:       Topology: 6-Core model: Intel Core i5-9400F bits: 64 type: MCP arch: Kaby Lake family: 6 model-id: 9E (158)
           stepping: A (10) microcode: D6 L2 cache: 9216 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 34814
           Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
           Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics:  Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI driver: nvidia v: 440.100
           alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1d01
           Display: x11 server: X.Org 1.20.8 driver: nvidia display ID: :0.0 screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3") s-diag: 583mm (23")
           Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
           OpenGL: renderer: GeForce GT 1030/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
           alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348
           Device-2: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 01:00.1
           chip ID: 10de:0fb8
           Sound Server: ALSA v: k5.8.0-2-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: 3000
           bus ID: 07:00.0 chip ID: 10ec:8168
           IF: enp7s0 state: down mac: <filter>
           Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB driver: r8188eu bus ID: 1-11:3
           chip ID: 0bda:8179 serial: <filter>
           IF: wlp0s20f0u11 state: up mac: <filter>
Drives:    Local Storage: total: 1.84 TiB used: 980.47 GiB (52.0%)
           ID-1: /dev/nvme0n1 vendor: Silicon Power model: SPCC M.2 PCIe SSD size: 953.87 GiB block size: physical: 512 B
           logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: ECFM22.5 scheme: GPT
           ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB block size: physical: 4096 B
           logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A02 scheme: GPT
Partition: ID-1: / raw size: 50.00 GiB size: 48.97 GiB (97.93%) used: 19.05 GiB (38.9%) fs: ext4 dev: /dev/nvme0n1p2
           ID-2: /home raw size: 887.37 GiB size: 872.44 GiB (98.32%) used: 262.85 GiB (30.1%) fs: ext4 dev: /dev/nvme0n1p4
Swap:      Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 16.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors:   System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 37 C
           Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Info:      Processes: 230 Uptime: 4h 06m Memory: 15.55 GiB used: 2.13 GiB (13.7%) Init: systemd v: 245 Compilers: gcc: 10.1.0
           Packages: 1348 pacman: 1342 lib: 401 flatpak: 0 snap: 6 Shell: Bash v: 5.0.18 running in: xfce4-terminal
           inxi: 3.1.05
sudo journalctl -S -1h output:
-- Logs begin at Thu 2020-01-02 21:50:12 EET, end at Sat 2020-08-22 18:06:08 EEST. --
сер 22 17:07:24 vvpc dbus-daemon[928]: [session uid=1000 pid=928] Activating service name='org.freedesktop.thumbnails.Cache1' requested by ':1.16' (uid=1000 pid=997 comm="Thunar --daemon " label="unconfined")
сер 22 17:07:24 vvpc org.freedesktop.thumbnails.Cache1[4320]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
сер 22 17:07:24 vvpc org.freedesktop.thumbnails.Cache1[4320]: Registered thumbnailer comicthumb %i %o %s
сер 22 17:07:24 vvpc org.freedesktop.thumbnails.Cache1[4320]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
сер 22 17:07:24 vvpc org.freedesktop.thumbnails.Cache1[4320]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
сер 22 17:07:24 vvpc org.freedesktop.thumbnails.Cache1[4320]: Registered thumbnailer heif-thumbnailer -s %s %i %o
сер 22 17:07:24 vvpc dbus-daemon[928]: [session uid=1000 pid=928] Successfully activated service 'org.freedesktop.thumbnails.Cache1'
сер 22 17:11:49 vvpc rtkit-daemon[1005]: Supervising 3 threads of 2 processes of 1 users.
сер 22 17:11:53 vvpc rtkit-daemon[1005]: Supervising 3 threads of 2 processes of 1 users.
сер 22 17:11:53 vvpc rtkit-daemon[1005]: Successfully made thread 4586 of process 4260 owned by '1000' RT at priority 10.
сер 22 17:11:53 vvpc rtkit-daemon[1005]: Supervising 4 threads of 3 processes of 1 users.
сер 22 17:14:56 vvpc rtkit-daemon[1005]: Supervising 3 threads of 2 processes of 1 users.
сер 22 17:15:51 vvpc rtkit-daemon[1005]: Supervising 3 threads of 2 processes of 1 users.
сер 22 17:19:10 vvpc dbus-daemon[928]: [session uid=1000 pid=928] Activating service name='org.freedesktop.thumbnails.Thumbnailer1' requested by ':1.16' (uid=1000 pid=997 comm="Thunar --daemon " label="unconfined")
сер 22 17:19:10 vvpc org.freedesktop.thumbnails.Thumbnailer1[4793]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
сер 22 17:19:10 vvpc org.freedesktop.thumbnails.Thumbnailer1[4793]: Registered thumbnailer comicthumb %i %o %s
сер 22 17:19:10 vvpc org.freedesktop.thumbnails.Thumbnailer1[4793]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
сер 22 17:19:10 vvpc org.freedesktop.thumbnails.Thumbnailer1[4793]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
сер 22 17:19:10 vvpc org.freedesktop.thumbnails.Thumbnailer1[4793]: Registered thumbnailer heif-thumbnailer -s %s %i %o
сер 22 17:19:10 vvpc dbus-daemon[928]: [session uid=1000 pid=928] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
сер 22 17:19:38 vvpc vlc[4800]: QObject::startTimer: Timers cannot have negative intervals
сер 22 17:47:56 vvpc dbus-daemon[928]: [session uid=1000 pid=928] Activating service name='org.freedesktop.thumbnails.Thumbnailer1' requested by ':1.16' (uid=1000 pid=997 comm="Thunar --daemon " label="unconfined")
сер 22 17:47:56 vvpc org.freedesktop.thumbnails.Thumbnailer1[4935]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
сер 22 17:47:56 vvpc org.freedesktop.thumbnails.Thumbnailer1[4935]: Registered thumbnailer comicthumb %i %o %s
сер 22 17:47:56 vvpc org.freedesktop.thumbnails.Thumbnailer1[4935]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
сер 22 17:47:56 vvpc org.freedesktop.thumbnails.Thumbnailer1[4935]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
сер 22 17:47:56 vvpc org.freedesktop.thumbnails.Thumbnailer1[4935]: Registered thumbnailer heif-thumbnailer -s %s %i %o
сер 22 17:47:56 vvpc dbus-daemon[928]: [session uid=1000 pid=928] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
сер 22 18:00:01 vvpc CROND[4996]: (root) CMD (timeshift --check --scripted)
сер 22 18:00:01 vvpc CROND[4995]: (root) CMDOUT ((process:4996): GLib-GIO-CRITICAL **: 18:00:01.788: g_file_get_path: assertion 'G_IS_FILE (file)' failed)
сер 22 18:00:01 vvpc CROND[4995]: (root) CMDOUT ()
сер 22 18:00:01 vvpc CROND[4995]: (root) CMDOUT (** (process:4996): CRITICAL **: 18:00:01.789: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed)
сер 22 18:00:01 vvpc CROND[4995]: (root) CMDOUT (** (process:4996): CRITICAL **: 18:00:01.789: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed)
сер 22 18:00:01 vvpc CROND[4995]: (root) CMDOUT (/dev/sda1 is mounted at: /run/timeshift/backup, options: rw,relatime)
сер 22 18:00:01 vvpc CROND[4995]: (root) CMDOUT (Weekly snapshots are enabled)
сер 22 18:00:01 vvpc CROND[4995]: (root) CMDOUT (Last weekly snapshot is 1 days old)
сер 22 18:00:01 vvpc CROND[4995]: (root) CMDOUT (------------------------------------------------------------------------------)
сер 22 18:00:01 vvpc crontab[5029]: (root) LIST (root)
сер 22 18:00:01 vvpc crontab[5030]: (root) LIST (root)
сер 22 18:01:01 vvpc CROND[5038]: (root) CMD (run-parts /etc/cron.hourly)
сер 22 18:05:02 vvpc audit[684]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=684 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
сер 22 18:05:02 vvpc kernel: audit: type=1701 audit(1598108702.467:101): auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=684 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
сер 22 18:05:02 vvpc systemd[1]: Created slice system-systemd\x2dcoredump.slice.
сер 22 18:05:02 vvpc audit: BPF prog-id=15 op=LOAD
сер 22 18:05:02 vvpc audit: BPF prog-id=16 op=LOAD
сер 22 18:05:02 vvpc systemd[1]: Started Process Core Dump (PID 5056/UID 0).
сер 22 18:05:02 vvpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-5056-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:02 vvpc kernel: audit: type=1334 audit(1598108702.477:102): prog-id=15 op=LOAD
сер 22 18:05:02 vvpc kernel: audit: type=1334 audit(1598108702.477:103): prog-id=16 op=LOAD
сер 22 18:05:02 vvpc kernel: audit: type=1130 audit(1598108702.477:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-5056-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:02 vvpc vlc[4800]: The X11 connection broke: I/O error (code 1)
сер 22 18:05:02 vvpc msm_notifier[1087]: The X11 connection broke (error 1). Did the X11 server die?
сер 22 18:05:02 vvpc at-spi-bus-launcher[970]: X connection to :0 broken (explicit kill or server shutdown).
сер 22 18:05:02 vvpc pulseaudio[986]: X connection to :0.0 broken (explicit kill or server shutdown).
сер 22 18:05:02 vvpc unknown[1024]: xfce4-notifyd: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
сер 22 18:05:02 vvpc systemd[907]: xfce4-notifyd.service: Main process exited, code=exited, status=1/FAILURE
сер 22 18:05:02 vvpc systemd[907]: xfce4-notifyd.service: Failed with result 'exit-code'.
сер 22 18:05:02 vvpc vlc[4800]: QObject::~QObject: Timers cannot be stopped from another thread
сер 22 18:05:02 vvpc audit[4800]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=4800 comm="vlc" exe="/usr/bin/vlc" sig=11 res=1
сер 22 18:05:02 vvpc kernel: traps: vlc[4807] general protection fault ip:7fc992338c26 sp:7fc96ff47030 error:0 in libc-2.31.so[7fc99231f000+14d000]
сер 22 18:05:02 vvpc kernel: audit: type=1701 audit(1598108702.800:105): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=4800 comm="vlc" exe="/usr/bin/vlc" sig=11 res=1
сер 22 18:05:02 vvpc polkitd[584]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.36, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8) (disconnected from bus)
сер 22 18:05:02 vvpc systemd[907]: pulseaudio.service: Main process exited, code=exited, status=1/FAILURE
сер 22 18:05:02 vvpc audit[896]: USER_LOGOUT pid=896 uid=0 auid=1000 ses=2 subj==unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=vvpc addr=? terminal=/dev/tty7 res=success'
сер 22 18:05:02 vvpc systemd[907]: pulseaudio.service: Failed with result 'exit-code'.
сер 22 18:05:02 vvpc kernel: audit: type=1113 audit(1598108702.807:106): pid=896 uid=0 auid=1000 ses=2 subj==unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=vvpc addr=? terminal=/dev/tty7 res=success'
сер 22 18:05:02 vvpc lightdm[896]: pam_unix(lightdm:session): session closed for user vindicivuoto
сер 22 18:05:02 vvpc audit[896]: USER_END pid=896 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="vindicivuoto" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:02 vvpc audit[896]: CRED_DISP pid=896 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="vindicivuoto" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:02 vvpc systemd-logind[587]: Session 2 logged out. Waiting for processes to exit.
сер 22 18:05:02 vvpc NetworkManager[581]: <info>  [1598108702.8161] device (wlp0s20f0u11): state change: activated -> deactivating (reason 'connection-removed', sys-iface-state: 'managed')
сер 22 18:05:02 vvpc kernel: audit: type=1106 audit(1598108702.810:107): pid=896 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="vindicivuoto" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:02 vvpc kernel: audit: type=1104 audit(1598108702.810:108): pid=896 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="vindicivuoto" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:02 vvpc NetworkManager[581]: <info>  [1598108702.8163] manager: NetworkManager state is now DISCONNECTING
сер 22 18:05:02 vvpc audit: BPF prog-id=17 op=LOAD
сер 22 18:05:02 vvpc audit: BPF prog-id=18 op=LOAD
сер 22 18:05:02 vvpc dbus-daemon[580]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=581 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
сер 22 18:05:02 vvpc systemd[1]: Started Process Core Dump (PID 5059/UID 0).
сер 22 18:05:02 vvpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-5059-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:02 vvpc systemd[1]: Starting Network Manager Script Dispatcher Service...
сер 22 18:05:02 vvpc kernel: audit: type=1334 audit(1598108702.814:109): prog-id=17 op=LOAD
сер 22 18:05:02 vvpc dbus-daemon[580]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
сер 22 18:05:02 vvpc systemd[1]: Started Network Manager Script Dispatcher Service.
сер 22 18:05:02 vvpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:02 vvpc wpa_supplicant[847]: ioctl[SIOCSIWAP]: Operation not permitted
сер 22 18:05:02 vvpc wpa_supplicant[847]: ioctl[SIOCSIWESSID]: Operation not permitted
сер 22 18:05:02 vvpc wpa_supplicant[847]: wlp0s20f0u11: CTRL-EVENT-DISCONNECTED bssid=78:44:76:da:31:5c reason=3 locally_generated=1
сер 22 18:05:02 vvpc kernel: R8188EU: indicate disassoc
сер 22 18:05:02 vvpc NetworkManager[581]: <info>  [1598108702.8274] device (wlp0s20f0u11): supplicant interface state: completed -> disconnected
сер 22 18:05:02 vvpc NetworkManager[581]: <info>  [1598108702.8275] device (wlp0s20f0u11): state change: deactivating -> disconnected (reason 'connection-removed', sys-iface-state: 'managed')
сер 22 18:05:02 vvpc avahi-daemon[578]: Withdrawing address record for fe80::3581:6e4f:6ccd:60ac on wlp0s20f0u11.
сер 22 18:05:02 vvpc avahi-daemon[578]: Leaving mDNS multicast group on interface wlp0s20f0u11.IPv6 with address fe80::3581:6e4f:6ccd:60ac.
сер 22 18:05:02 vvpc avahi-daemon[578]: Interface wlp0s20f0u11.IPv6 no longer relevant for mDNS.
сер 22 18:05:02 vvpc NetworkManager[581]: <info>  [1598108702.8398] dhcp4 (wlp0s20f0u11): canceled DHCP transaction
сер 22 18:05:02 vvpc NetworkManager[581]: <info>  [1598108702.8398] dhcp4 (wlp0s20f0u11): state changed bound -> done
сер 22 18:05:02 vvpc avahi-daemon[578]: Interface wlp0s20f0u11.IPv4 no longer relevant for mDNS.
сер 22 18:05:02 vvpc avahi-daemon[578]: Leaving mDNS multicast group on interface wlp0s20f0u11.IPv4 with address 192.168.1.15.
сер 22 18:05:02 vvpc avahi-daemon[578]: Withdrawing address record for 192.168.1.15 on wlp0s20f0u11.
сер 22 18:05:02 vvpc NetworkManager[581]: <warn>  [1598108702.9424] device (wlp0s20f0u11): set-hw-addr: new MAC address D2:34:48:0A:22:A0 not successfully set (scanning)
сер 22 18:05:02 vvpc avahi-daemon[578]: Joining mDNS multicast group on interface wlp0s20f0u11.IPv4 with address 192.168.1.15.
сер 22 18:05:02 vvpc avahi-daemon[578]: New relevant interface wlp0s20f0u11.IPv4 for mDNS.
сер 22 18:05:02 vvpc avahi-daemon[578]: Registering new address record for 192.168.1.15 on wlp0s20f0u11.IPv4.
сер 22 18:05:02 vvpc NetworkManager[581]: <info>  [1598108702.9432] manager: NetworkManager state is now DISCONNECTED
сер 22 18:05:02 vvpc NetworkManager[581]: <info>  [1598108702.9439] device (wlp0s20f0u11): supplicant interface state: disconnected -> interface_disabled
сер 22 18:05:02 vvpc systemd[907]: pulseaudio.service: Scheduled restart job, restart counter is at 1.
сер 22 18:05:02 vvpc systemd[907]: Stopped Sound Service.
сер 22 18:05:02 vvpc systemd[907]: Starting Sound Service...
сер 22 18:05:03 vvpc systemd-coredump[5057]: Process 684 (Xorg) of user 0 dumped core.
                                                Stack trace of thread 684:
                                                #0  0x00007f6e30b0f355 raise (libc.so.6 + 0x3c355)
                                                #1  0x00007f6e30af8853 abort (libc.so.6 + 0x25853)
                                                #2  0x000055b39876924a OsAbort (Xorg + 0x14a24a)
                                                #3  0x000055b39876ad11 FatalError (Xorg + 0x14bd11)
                                                #4  0x000055b398770969 n/a (Xorg + 0x151969)
                                                #5  0x00007f6e30b0f3e0 __restore_rt (libc.so.6 + 0x3c3e0)
                                                #6  0x00007f6e2ed12d4d n/a (libglxserver_nvidia.so + 0x8f7d4d)
сер 22 18:05:03 vvpc rtkit-daemon[1005]: Successfully made thread 5067 of process 5067 owned by '1000' high priority at nice level -11.
сер 22 18:05:03 vvpc rtkit-daemon[1005]: Supervising 1 threads of 1 processes of 1 users.
сер 22 18:05:03 vvpc pulseaudio[5067]: W: [pulseaudio] pid.c: Stale PID file, overwriting.
сер 22 18:05:03 vvpc systemd[1]: systemd-coredump@0-5056-0.service: Succeeded.
сер 22 18:05:03 vvpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-5056-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:03 vvpc audit: BPF prog-id=16 op=UNLOAD
сер 22 18:05:03 vvpc audit: BPF prog-id=15 op=UNLOAD
сер 22 18:05:03 vvpc rtkit-daemon[1005]: Successfully made thread 5077 of process 5067 owned by '1000' RT at priority 5.
сер 22 18:05:03 vvpc rtkit-daemon[1005]: Supervising 2 threads of 1 processes of 1 users.
сер 22 18:05:03 vvpc dbus-daemon[580]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.829' (uid=1000 pid=5067 comm="/usr/bin/pulseaudio --daemonize=no " label="unconfined")
сер 22 18:05:03 vvpc systemd[1]: Condition check resulted in Bluetooth service being skipped.
сер 22 18:05:03 vvpc systemd[907]: Started Sound Service.
сер 22 18:05:03 vvpc audit[5081]: CRED_ACQ pid=5081 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:03 vvpc lightdm[5081]: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
сер 22 18:05:03 vvpc systemd[1]: Created slice User Slice of UID 970.
сер 22 18:05:03 vvpc systemd[1]: Starting User Runtime Directory /run/user/970...
сер 22 18:05:03 vvpc systemd-logind[587]: New session c2 of user lightdm.
сер 22 18:05:03 vvpc systemd-coredump[5060]: Process 4800 (vlc) of user 1000 dumped core.
                                                Stack trace of thread 4807:
                                                #0  0x00007fc992338c26 __run_exit_handlers (libc.so.6 + 0x3ec26)
                                                #1  0x00007fc992338dfe exit (libc.so.6 + 0x3edfe)
                                                #2  0x00007fc98c4f4652 _XDefaultIOError (libX11.so.6 + 0x43652)
                                                #3  0x00007fc98c4f48fe _XIOError (libX11.so.6 + 0x438fe)
                                                #4  0x00007fc98c4f290a _XReply (libX11.so.6 + 0x4190a)
                                                #5  0x00007fc98c4d83a1 XGetSelectionOwner (libX11.so.6 + 0x273a1)
                                                #6  0x00007fc96ef96abd _ZN7Kvantum11ThemeConfig16getCompositeSpecEv (libkvantum.so + 0xc2abd)
                                                #7  0x00007fc96ef0753d _ZNK7Kvantum5Style16setSurfaceFormatEP7QWidget (libkvantum.so + 0x3353d)
                                                #8  0x00007fc96ef2d28c _ZNK7Kvantum5Style9styleHintEN6QStyle9StyleHintEPK12QStyleOptionPK7QWidgetP16QStyleHintReturn (libkvantum.so + 0x5928c)
                                                #9  0x00007fc98d4f18f4 n/a (libQt5Widgets.so.5 + 0x2da8f4)
                                                #10 0x00007fc98d4f1ca5 _ZN5QMenuC1ERK7QStringP7QWidget (libQt5Widgets.so.5 + 0x2daca5)
                                                #11 0x00007fc98d943eab n/a (libqt_plugin.so + 0x96eab)
                                                #12 0x00007fc98d944c1c n/a (libqt_plugin.so + 0x97c1c)
                                                #13 0x00007fc98c8dca60 n/a (libQt5Core.so.5 + 0x2eaa60)
                                                #14 0x00007fc98da9a242 n/a (libqt_plugin.so + 0x1ed242)
                                                #15 0x00007fc98c8d210f _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2e010f)
                                                #16 0x00007fc98d373702 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x15c702)
                                                #17 0x00007fc98c8a57ba _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x2b37ba)
                                                #18 0x00007fc98c8a82a3 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5 + 0x2b62a3)
                                                #19 0x00007fc98c8fecf4 n/a (libQt5Core.so.5 + 0x30ccf4)
                                                #20 0x00007fc98f38643c g_main_context_dispatch (libglib-2.0.so.0 + 0x5243c)
                                                #21 0x00007fc98f3d41d9 n/a (libglib-2.0.so.0 + 0xa01d9)
                                                #22 0x00007fc98f385221 g_main_context_iteration (libglib-2.0.so.0 + 0x51221)
                                                #23 0x00007fc98c8fe331 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30c331)
                                                #24 0x00007fc98c8a413c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b213c)
                                                #25 0x00007fc98c8ac5c4 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2ba5c4)
                                                #26 0x00007fc98d93df22 n/a (libqt_plugin.so + 0x90f22)
                                                #27 0x00007fc98d93e846 n/a (libqt_plugin.so + 0x91846)
                                                #28 0x00007fc9924d0422 start_thread (libpthread.so.0 + 0x9422)
                                                #29 0x00007fc9923f9bf3 __clone (libc.so.6 + 0xffbf3)
                                                Stack trace of thread 4803:
                                                #0  0x00007fc9924d1a17 __pthread_clockjoin_ex (libpthread.so.0 + 0xaa17)
                                                #1  0x00007fc99226c17a vout_Close (libvlccore.so.9 + 0x8717a)
                                                #2  0x00007fc992252a5e input_resource_TerminateVout (libvlccore.so.9 + 0x6da5e)
                                                #3  0x00007fc99221d7f3 n/a (libvlccore.so.9 + 0x387f3)
                                                #4  0x00007fc9924d0422 start_thread (libpthread.so.0 + 0x9422)
                                                #5  0x00007fc9923f9bf3 __clone (libc.so.6 + 0xffbf3)
                                                Stack trace of thread 4802:
                                                #0  0x00007fc9923ef05f __poll (libc.so.6 + 0xf505f)
                                                #1  0x00007fc98f1cbc14 n/a (libpulse.so.0 + 0xdc14)
                                                #2  0x00007fc98f1d9059 pa_mainloop_poll (libpulse.so.0 + 0x1b059)
                                                #3  0x00007fc98f1e3301 pa_mainloop_iterate (libpulse.so.0 + 0x25301)
                                                #4  0x00007fc98f1e33b1 pa_mainloop_run (libpulse.so.0 + 0x253b1)
                                                #5  0x00007fc98f1d361e n/a (libpulse.so.0 + 0x1561e)
                                                #6  0x00007fc98f157d1c n/a (libpulsecommon-13.0.so + 0x1dd1c)
                                                #7  0x00007fc9924d0422 start_thread (libpthread.so.0 + 0x9422)
                                                #8  0x00007fc9923f9bf3 __clone (libc.so.6 + 0xffbf3)
                                                Stack trace of thread 4817:
                                                #0  0x00007fc992048ef3 dbus_watch_get_unix_fd (libdbus-1.so.3 + 0x2aef3)
                                                #1  0x00007fc96fcb28bc n/a (libQt5DBus.so.5 + 0x228bc)
                                                #2  0x00007fc992049094 _dbus_watch_list_remove_watch (libdbus-1.so.3 + 0x2b094)
                                                #3  0x00007fc992047555 n/a (libdbus-1.so.3 + 0x29555)
                                                #4  0x00007fc9920475d9 n/a (libdbus-1.so.3 + 0x295d9)
                                                #5  0x00007fc992046d44 n/a (libdbus-1.so.3 + 0x28d44)
                                                #6  0x00007fc992033771 dbus_connection_close (libdbus-1.so.3 + 0x15771)
                                                #7  0x00007fc96fcb2fac n/a (libQt5DBus.so.5 + 0x22fac)
                                                #8  0x00007fc96fca7117 n/a (libQt5DBus.so.5 + 0x17117)
                                                #9  0x00007fc98c6c0e0f n/a (libQt5Core.so.5 + 0xcee0f)
                                                #10 0x00007fc9924d0422 start_thread (libpthread.so.0 + 0x9422)
                                                #11 0x00007fc9923f9bf3 __clone (libc.so.6 + 0xffbf3)
                                                Stack trace of thread 4804:
                                                #1  0x00007fc98f248dad n/a (libdbus_plugin.so + 0xadad)
                                                #2  0x00007fc9924d0422 start_thread (libpthread.so.0 + 0x9422)
                                                #3  0x00007fc9923f9bf3 __clone (libc.so.6 + 0xffbf3)
                                                Stack trace of thread 4800:
                                                #1  0x00007fc98d93d1db n/a (libqt_plugin.so + 0x901db)
                                                #2  0x00007fc9922144ce vlc_module_unload (libvlccore.so.9 + 0x2f4ce)
                                                #3  0x00007fc99221b572 n/a (libvlccore.so.9 + 0x36572)
                                                #4  0x00007fc9921fd3b0 libvlc_InternalCleanup (libvlccore.so.9 + 0x183b0)
                                                #5  0x00007fc9924f231d libvlc_release (libvlc.so.5 + 0x931d)
                                                #6  0x0000556d23649342 n/a (vlc + 0x1342)
                                                #7  0x00007fc992321002 __libc_start_main (libc.so.6 + 0x27002)
                                                #8  0x0000556d2364942e n/a (vlc + 0x142e)
                                                Stack trace of thread 4818:
                                                #0  0x00007fc9924d6e32 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xfe32)
                                                #1  0x00007fc9922a073f n/a (libvlccore.so.9 + 0xbb73f)
                                                Stack trace of thread 4827:
                                                #1  0x00007fc98c6c6e84 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xd4e84)
                                                #2  0x00007fc98c6c0aba _ZN7QThread4waitE14QDeadlineTimer (libQt5Core.so.5 + 0xceaba)
                                                #3  0x00007fc96fca6fe5 n/a (libQt5DBus.so.5 + 0x16fe5)
                                                #4  0x00007fc96fca7049 n/a (libQt5DBus.so.5 + 0x17049)
                                                #5  0x00007fc992338c57 __run_exit_handlers (libc.so.6 + 0x3ec57)
                                                #6  0x00007fc992338dfe exit (libc.so.6 + 0x3edfe)
                                                #7  0x00007fc98c4f4652 _XDefaultIOError (libX11.so.6 + 0x43652)
                                                #8  0x00007fc98c4f48fe _XIOError (libX11.so.6 + 0x438fe)
                                                #9  0x00007fc98c4f290a _XReply (libX11.so.6 + 0x4190a)
                                                #10 0x00007fc94f593206 n/a (libGLX_nvidia.so.0 + 0xa6206)
                                                #11 0x00007fc94f53c6bb n/a (libGLX_nvidia.so.0 + 0x4f6bb)
                                                #12 0x00007fc94f53a90a n/a (libGLX_nvidia.so.0 + 0x4d90a)
                                                #13 0x00007fc94f568633 n/a (libGLX_nvidia.so.0 + 0x7b633)
                                                #14 0x00007fc98e58de32 n/a (libGLX.so.0 + 0x13e32)
                                                #15 0x00007fc98e590811 n/a (libGLX.so.0 + 0x16811)
                                                #16 0x00007fc98e5937ed n/a (libGLX.so.0 + 0x197ed)
                                                #17 0x00007fc93873418c n/a (libglx_plugin.so + 0x118c)
                                                #18 0x00007fc9380642f3 n/a (libgl_plugin.so + 0xc2f3)
                                                #19 0x00007fc9922144ce vlc_module_unload (libvlccore.so.9 + 0x2f4ce)
                                                #20 0x00007fc992266c4d n/a (libvlccore.so.9 + 0x81c4d)
                                                #21 0x00007fc992277c1d n/a (libvlccore.so.9 + 0x92c1d)
                                                #22 0x00007fc99226a4cb n/a (libvlccore.so.9 + 0x854cb)
                                                #23 0x00007fc99226beca n/a (libvlccore.so.9 + 0x86eca)
                                                #24 0x00007fc9924d0422 start_thread (libpthread.so.0 + 0x9422)
                                                #25 0x00007fc9923f9bf3 __clone (libc.so.6 + 0xffbf3)
сер 22 18:05:03 vvpc systemd[1]: Finished User Runtime Directory /run/user/970.
сер 22 18:05:03 vvpc systemd[1]: Starting User Manager for UID 970...
сер 22 18:05:03 vvpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:03 vvpc audit[5090]: USER_ACCT pid=5090 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:03 vvpc audit[5090]: CRED_ACQ pid=5090 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
сер 22 18:05:03 vvpc systemd[5090]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
сер 22 18:05:03 vvpc systemd[5090]: pam_unix(systemd-user:session): session opened for user lightdm by (uid=0)
сер 22 18:05:03 vvpc audit[5090]: USER_START pid=5090 uid=0 auid=970 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:03 vvpc audit: BPF prog-id=19 op=LOAD
сер 22 18:05:03 vvpc audit: BPF prog-id=19 op=UNLOAD
сер 22 18:05:03 vvpc systemd[1]: systemd-coredump@1-5059-0.service: Succeeded.
сер 22 18:05:03 vvpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-5059-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:03 vvpc systemd[5090]: Reached target Paths.
сер 22 18:05:03 vvpc systemd[5090]: Reached target Timers.
сер 22 18:05:03 vvpc systemd[5090]: Starting D-Bus User Message Bus Socket.
сер 22 18:05:03 vvpc systemd[5090]: Listening on GnuPG network certificate management daemon.
сер 22 18:05:03 vvpc systemd[5090]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
сер 22 18:05:03 vvpc systemd[5090]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
сер 22 18:05:03 vvpc systemd[5090]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
сер 22 18:05:03 vvpc systemd[5090]: Listening on GnuPG cryptographic agent and passphrase cache.
сер 22 18:05:03 vvpc systemd[5090]: Listening on p11-kit server.
сер 22 18:05:03 vvpc systemd[5090]: Listening on Multimedia System.
сер 22 18:05:03 vvpc systemd[5090]: Listening on Sound System.
сер 22 18:05:03 vvpc systemd[5090]: Listening on D-Bus User Message Bus Socket.
сер 22 18:05:03 vvpc systemd[5090]: Reached target Sockets.
сер 22 18:05:03 vvpc systemd[5090]: Reached target Basic System.
сер 22 18:05:03 vvpc systemd[1]: Started User Manager for UID 970.
сер 22 18:05:03 vvpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:03 vvpc systemd[5090]: Starting Update XDG user dir configuration...
сер 22 18:05:03 vvpc systemd[1]: Started Session c2 of user lightdm.
сер 22 18:05:03 vvpc systemd[5090]: xdg-user-dirs-update.service: Succeeded.
сер 22 18:05:03 vvpc systemd[5090]: Finished Update XDG user dir configuration.
сер 22 18:05:03 vvpc systemd[5090]: Reached target Main User Target.
сер 22 18:05:03 vvpc systemd[5090]: Startup finished in 57ms.
сер 22 18:05:03 vvpc audit[5081]: USER_START pid=5081 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:03 vvpc audit: BPF prog-id=18 op=UNLOAD
сер 22 18:05:03 vvpc audit: BPF prog-id=17 op=UNLOAD
сер 22 18:05:03 vvpc systemd[5090]: Started D-Bus User Message Bus.
сер 22 18:05:03 vvpc dbus-daemon[5106]: [session uid=970 pid=5106] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=970 pid=5104 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
сер 22 18:05:03 vvpc systemd[5090]: Starting Accessibility services bus...
сер 22 18:05:03 vvpc dbus-daemon[5106]: [session uid=970 pid=5106] Successfully activated service 'org.a11y.Bus'
сер 22 18:05:03 vvpc systemd[5090]: Started Accessibility services bus.
сер 22 18:05:03 vvpc dbus-daemon[5106]: [session uid=970 pid=5106] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=970 pid=5104 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
сер 22 18:05:03 vvpc systemd[5090]: Starting Virtual filesystem service...
сер 22 18:05:03 vvpc dbus-daemon[5106]: [session uid=970 pid=5106] Successfully activated service 'org.gtk.vfs.Daemon'
сер 22 18:05:03 vvpc systemd[5090]: Started Virtual filesystem service.
сер 22 18:05:03 vvpc polkitd[584]: /usr/share/polkit-1/rules.d/lightdm.rules:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
сер 22 18:05:03 vvpc polkitd[584]: /usr/share/polkit-1/rules.d/lightdm.rules:4: subject=[Subject pid=5104 user='lightdm' groups=lightdm seat='seat0' session='c2' local=true active=true]
сер 22 18:05:03 vvpc at-spi-bus-launcher[5113]: dbus-daemon[5113]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=970 pid=5104 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
сер 22 18:05:03 vvpc at-spi-bus-launcher[5113]: dbus-daemon[5113]: Successfully activated service 'org.a11y.atspi.Registry'
сер 22 18:05:03 vvpc at-spi-bus-launcher[5136]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
сер 22 18:05:07 vvpc NetworkManager[581]: <info>  [1598108707.8261] device (wlp0s20f0u11): supplicant interface state: interface_disabled -> disconnected
сер 22 18:05:12 vvpc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
сер 22 18:05:12 vvpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:12 vvpc kernel: kauditd_printk_skb: 19 callbacks suppressed
сер 22 18:05:12 vvpc kernel: audit: type=1131 audit(1598108712.944:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:17 vvpc lightdm[5133]: gkr-pam: unable to locate daemon control file
сер 22 18:05:17 vvpc audit[5133]: USER_AUTH pid=5133 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="vindicivuoto" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:17 vvpc lightdm[5133]: gkr-pam: stashed password to try later in open session
сер 22 18:05:17 vvpc kernel: audit: type=1100 audit(1598108717.777:130): pid=5133 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="vindicivuoto" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:17 vvpc audit[5133]: USER_ACCT pid=5133 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="vindicivuoto" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:17 vvpc kernel: audit: type=1101 audit(1598108717.780:131): pid=5133 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="vindicivuoto" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:17 vvpc systemd[1]: Stopping Session c2 of user lightdm.
сер 22 18:05:17 vvpc lightdm[5081]: pam_unix(lightdm-greeter:session): session closed for user lightdm
сер 22 18:05:17 vvpc kernel: audit: type=1106 audit(1598108717.837:132): pid=5081 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:17 vvpc kernel: audit: type=1104 audit(1598108717.840:133): pid=5081 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:17 vvpc audit[5081]: USER_END pid=5081 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:17 vvpc audit[5081]: CRED_DISP pid=5081 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:17 vvpc systemd[1]: session-c2.scope: Succeeded.
сер 22 18:05:17 vvpc systemd[1]: Stopped Session c2 of user lightdm.
сер 22 18:05:17 vvpc audit[5133]: CRED_ACQ pid=5133 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="vindicivuoto" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:17 vvpc systemd-logind[587]: Removed session c2.
сер 22 18:05:17 vvpc kernel: audit: type=1103 audit(1598108717.847:134): pid=5133 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="vindicivuoto" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:17 vvpc kernel: audit: type=1006 audit(1598108717.847:135): pid=5133 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=5 res=1
сер 22 18:05:17 vvpc lightdm[5133]: pam_unix(lightdm:session): session opened for user vindicivuoto by (uid=0)
сер 22 18:05:17 vvpc systemd-logind[587]: New session 5 of user vindicivuoto.
сер 22 18:05:17 vvpc systemd[1]: Started Session 5 of user vindicivuoto.
сер 22 18:05:17 vvpc lightdm[5133]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
сер 22 18:05:17 vvpc audit[5133]: USER_START pid=5133 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="vindicivuoto" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:17 vvpc kernel: audit: type=1105 audit(1598108717.867:136): pid=5133 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="vindicivuoto" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
сер 22 18:05:17 vvpc audit[5133]: USER_LOGIN pid=5133 uid=0 auid=1000 ses=5 subj==unconfined msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=vvpc addr=? terminal=/dev/tty7 res=success'
сер 22 18:05:17 vvpc kernel: audit: type=1112 audit(1598108717.870:137): pid=5133 uid=0 auid=1000 ses=5 subj==unconfined msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=vvpc addr=? terminal=/dev/tty7 res=success'
сер 22 18:05:17 vvpc at-spi-bus-launcher[963]: dbus-daemon[963]: Activating service name='org.a11y.atspi.Registry' requested by ':1.40' (uid=1000 pid=5149 comm="xfce4-session " label="unconfined")
сер 22 18:05:17 vvpc at-spi-bus-launcher[963]: dbus-daemon[963]: Successfully activated service 'org.a11y.atspi.Registry'
сер 22 18:05:17 vvpc at-spi-bus-launcher[5172]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
сер 22 18:05:18 vvpc dbus-daemon[928]: [session uid=1000 pid=928] Activating via systemd: service name='org.freedesktop.Notifications' unit='xfce4-notifyd.service' requested by ':1.136' (uid=1000 pid=5196 comm="/usr/lib/xfce4/panel/wrapper-2.0 /usr/lib/xfce4/pa" label="unconfined")
сер 22 18:05:18 vvpc systemd[907]: Starting XFCE notifications service...
сер 22 18:05:18 vvpc dbus-daemon[928]: [session uid=1000 pid=928] Successfully activated service 'org.freedesktop.Notifications'
сер 22 18:05:18 vvpc systemd[907]: Started XFCE notifications service.
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6572] policy: auto-activating connection 'george 2' (fd3eb73f-081c-4e7d-90bd-e053a4147f5c)
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6575] device (wlp0s20f0u11): Activation: starting connection 'george 2' (fd3eb73f-081c-4e7d-90bd-e053a4147f5c)
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6575] device (wlp0s20f0u11): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6577] manager: NetworkManager state is now CONNECTING
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6579] device (wlp0s20f0u11): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6580] device (wlp0s20f0u11): Activation: (wifi) access point 'george 2' has security, but secrets are required.
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6580] device (wlp0s20f0u11): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6592] device (wlp0s20f0u11): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6594] device (wlp0s20f0u11): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6595] device (wlp0s20f0u11): Activation: (wifi) connection 'george 2' has security, and secrets exist.  No new secrets needed.
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6596] Config: added 'ssid' value 'george'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6596] Config: added 'scan_ssid' value '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6596] Config: added 'bgscan' value 'simple:30:-70:86400'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6596] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6596] Config: added 'auth_alg' value 'OPEN'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6596] Config: added 'psk' value '<hidden>'
сер 22 18:05:18 vvpc wpa_supplicant[847]: wlp0s20f0u11: Trying to associate with 78:44:76:da:31:5c (SSID='george' freq=2462 MHz)
сер 22 18:05:18 vvpc wpa_supplicant[847]: Failed to add supported operating classes IE
сер 22 18:05:18 vvpc wpa_supplicant[847]: wlp0s20f0u11: Association request to the driver failed
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.6680] device (wlp0s20f0u11): supplicant interface state: disconnected -> associating
сер 22 18:05:18 vvpc kernel: R8188EU: assoc success
сер 22 18:05:18 vvpc wpa_supplicant[847]: wlp0s20f0u11: Associated with 78:44:76:da:31:5c
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7032] device (wlp0s20f0u11): supplicant interface state: associating -> associated
сер 22 18:05:18 vvpc wpa_supplicant[847]: wlp0s20f0u11: WPA: Key negotiation completed with 78:44:76:da:31:5c [PTK=CCMP GTK=CCMP]
сер 22 18:05:18 vvpc wpa_supplicant[847]: wlp0s20f0u11: CTRL-EVENT-CONNECTED - Connection to 78:44:76:da:31:5c completed [id=0 id_str=]
сер 22 18:05:18 vvpc wpa_supplicant[847]: bgscan simple: Failed to enable signal strength monitoring
сер 22 18:05:18 vvpc kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f0u11: link becomes ready
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7331] device (wlp0s20f0u11): supplicant interface state: associated -> 4way_handshake
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7379] device (wlp0s20f0u11): supplicant interface state: 4way_handshake -> completed
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7379] device (wlp0s20f0u11): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "george"
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7380] device (wlp0s20f0u11): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7382] dhcp4 (wlp0s20f0u11): activation: beginning transaction (timeout in 45 seconds)
сер 22 18:05:18 vvpc avahi-daemon[578]: Joining mDNS multicast group on interface wlp0s20f0u11.IPv6 with address fe80::3581:6e4f:6ccd:60ac.
сер 22 18:05:18 vvpc avahi-daemon[578]: New relevant interface wlp0s20f0u11.IPv6 for mDNS.
сер 22 18:05:18 vvpc avahi-daemon[578]: Registering new address record for fe80::3581:6e4f:6ccd:60ac on wlp0s20f0u11.*.
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option dhcp_lease_time      => '28800'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option domain_name          => 'TOTOLINK'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option domain_name_servers  => '192.168.1.1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option expiry               => '1598137518'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option ip_address           => '192.168.1.15'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option requested_broadcast_address => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option requested_domain_name => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option requested_domain_name_servers => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option requested_domain_search => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option requested_host_name  => '1'
сер 22 18:05:18 vvpc avahi-daemon[578]: Joining mDNS multicast group on interface wlp0s20f0u11.IPv4 with address 192.168.1.15.
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option requested_interface_mtu => '1'
сер 22 18:05:18 vvpc avahi-daemon[578]: New relevant interface wlp0s20f0u11.IPv4 for mDNS.
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option requested_ms_classless_static_routes => '1'
сер 22 18:05:18 vvpc avahi-daemon[578]: Registering new address record for 192.168.1.15 on wlp0s20f0u11.IPv4.
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option requested_nis_domain => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option requested_nis_servers => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7525] dhcp4 (wlp0s20f0u11): option requested_ntp_servers => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7526] dhcp4 (wlp0s20f0u11): option requested_rfc3442_classless_static_routes => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7526] dhcp4 (wlp0s20f0u11): option requested_root_path  => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7526] dhcp4 (wlp0s20f0u11): option requested_routers    => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7526] dhcp4 (wlp0s20f0u11): option requested_static_routes => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7526] dhcp4 (wlp0s20f0u11): option requested_subnet_mask => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7526] dhcp4 (wlp0s20f0u11): option requested_time_offset => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7526] dhcp4 (wlp0s20f0u11): option requested_wpad       => '1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7526] dhcp4 (wlp0s20f0u11): option routers              => '192.168.1.1'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7526] dhcp4 (wlp0s20f0u11): option subnet_mask          => '255.255.255.0'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7526] dhcp4 (wlp0s20f0u11): state changed unknown -> bound
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7531] device (wlp0s20f0u11): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
сер 22 18:05:18 vvpc dbus-daemon[580]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=581 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
сер 22 18:05:18 vvpc systemd[1]: Starting Network Manager Script Dispatcher Service...
сер 22 18:05:18 vvpc dbus-daemon[580]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
сер 22 18:05:18 vvpc systemd[1]: Started Network Manager Script Dispatcher Service.
сер 22 18:05:18 vvpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7592] device (wlp0s20f0u11): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7594] device (wlp0s20f0u11): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7596] manager: NetworkManager state is now CONNECTED_LOCAL
сер 22 18:05:18 vvpc kernel: audit: type=1130 audit(1598108718.754:138): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7604] manager: NetworkManager state is now CONNECTED_SITE
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7604] policy: set 'george 2' (wlp0s20f0u11) as default for IPv4 routing and DNS
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.7632] device (wlp0s20f0u11): Activation: successful, device activated.
сер 22 18:05:18 vvpc dbus-daemon[928]: [session uid=1000 pid=928] Activating service name='org.freedesktop.thumbnails.Thumbnailer1' requested by ':1.149' (uid=1000 pid=5219 comm="xfdesktop " label="unconfined")
сер 22 18:05:18 vvpc org.freedesktop.thumbnails.Thumbnailer1[5239]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
сер 22 18:05:18 vvpc org.freedesktop.thumbnails.Thumbnailer1[5239]: Registered thumbnailer comicthumb %i %o %s
сер 22 18:05:18 vvpc org.freedesktop.thumbnails.Thumbnailer1[5239]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
сер 22 18:05:18 vvpc org.freedesktop.thumbnails.Thumbnailer1[5239]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
сер 22 18:05:18 vvpc org.freedesktop.thumbnails.Thumbnailer1[5239]: Registered thumbnailer heif-thumbnailer -s %s %i %o
сер 22 18:05:18 vvpc dbus-daemon[928]: [session uid=1000 pid=928] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
сер 22 18:05:18 vvpc polkitd[584]: Registered Authentication Agent for unix-session:5 (system bus name :1.845 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
сер 22 18:05:18 vvpc NetworkManager[581]: <info>  [1598108718.9244] manager: NetworkManager state is now CONNECTED_GLOBAL
сер 22 18:05:18 vvpc dbus-daemon[580]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.849' (uid=1000 pid=5248 comm="pamac-tray " label="unconfined")
сер 22 18:05:18 vvpc systemd[1]: Starting Pamac Daemon...
сер 22 18:05:18 vvpc dbus-daemon[580]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
сер 22 18:05:18 vvpc systemd[1]: Started Pamac Daemon.
сер 22 18:05:18 vvpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:18 vvpc kernel: audit: type=1130 audit(1598108718.994:139): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:19 vvpc NetworkManager[581]: <info>  [1598108719.0004] agent-manager: agent[d4feef0d903fc886,:1.848/org.freedesktop.nm-applet/1000]: agent registered
сер 22 18:05:19 vvpc systemd[1]: pamac-daemon.service: Succeeded.
сер 22 18:05:18 vvpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:19 vvpc kernel: audit: type=1131 audit(1598108718.997:140): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:19 vvpc dbus-daemon[580]: [system] Activating via systemd: service name='org.blueman.Mechanism' unit='blueman-mechanism.service' requested by ':1.853' (uid=1000 pid=5260 comm="/usr/bin/python /usr/bin/blueman-applet " label="unconfined")
сер 22 18:05:19 vvpc systemd[1]: Starting Bluetooth management mechanism...
сер 22 18:05:19 vvpc blueman-mechanism[5320]: Unable to init server: Could not connect: Connection refused
сер 22 18:05:19 vvpc blueman-mechani[5320]: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
сер 22 18:05:19 vvpc dbus-daemon[580]: [system] Successfully activated service 'org.blueman.Mechanism'
сер 22 18:05:19 vvpc systemd[1]: Started Bluetooth management mechanism.
сер 22 18:05:19 vvpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:19 vvpc kernel: audit: type=1130 audit(1598108719.230:141): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:27 vvpc systemd[1]: Stopping User Manager for UID 970...
сер 22 18:05:27 vvpc systemd[5090]: Stopped target Main User Target.
сер 22 18:05:27 vvpc systemd[5090]: Stopping Accessibility services bus...
сер 22 18:05:27 vvpc systemd[5090]: Stopping D-Bus User Message Bus...
сер 22 18:05:27 vvpc systemd[5090]: Stopping Virtual filesystem service...
сер 22 18:05:27 vvpc systemd[5090]: at-spi-dbus-bus.service: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Stopped Accessibility services bus.
сер 22 18:05:27 vvpc systemd[5090]: dbus.service: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Stopped D-Bus User Message Bus.
сер 22 18:05:27 vvpc systemd[5090]: run-user-970-gvfs.mount: Succeeded.
сер 22 18:05:27 vvpc systemd[1]: run-user-970-gvfs.mount: Succeeded.
сер 22 18:05:27 vvpc systemd[907]: run-user-970-gvfs.mount: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: gvfs-daemon.service: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Stopped Virtual filesystem service.
сер 22 18:05:27 vvpc systemd[5090]: Stopped target Basic System.
сер 22 18:05:27 vvpc systemd[5090]: Stopped target Paths.
сер 22 18:05:27 vvpc systemd[5090]: Stopped target Sockets.
сер 22 18:05:27 vvpc systemd[5090]: Stopped target Timers.
сер 22 18:05:27 vvpc systemd[5090]: dbus.socket: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Closed D-Bus User Message Bus Socket.
сер 22 18:05:27 vvpc systemd[5090]: dirmngr.socket: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Closed GnuPG network certificate management daemon.
сер 22 18:05:27 vvpc systemd[5090]: gpg-agent-browser.socket: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
сер 22 18:05:27 vvpc systemd[5090]: gpg-agent-extra.socket: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
сер 22 18:05:27 vvpc systemd[5090]: gpg-agent-ssh.socket: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Closed GnuPG cryptographic agent (ssh-agent emulation).
сер 22 18:05:27 vvpc systemd[5090]: gpg-agent.socket: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Closed GnuPG cryptographic agent and passphrase cache.
сер 22 18:05:27 vvpc systemd[5090]: p11-kit-server.socket: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Closed p11-kit server.
сер 22 18:05:27 vvpc systemd[5090]: pipewire.socket: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Closed Multimedia System.
сер 22 18:05:27 vvpc systemd[5090]: pulseaudio.socket: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Closed Sound System.
сер 22 18:05:27 vvpc systemd[5090]: Reached target Shutdown.
сер 22 18:05:27 vvpc systemd[5090]: systemd-exit.service: Succeeded.
сер 22 18:05:27 vvpc systemd[5090]: Finished Exit the Session.
сер 22 18:05:27 vvpc systemd[5090]: Reached target Exit the Session.
сер 22 18:05:27 vvpc systemd[5091]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
сер 22 18:05:27 vvpc systemd[1]: user@970.service: Succeeded.
сер 22 18:05:27 vvpc systemd[1]: Stopped User Manager for UID 970.
сер 22 18:05:27 vvpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:27 vvpc systemd[1]: Stopping User Runtime Directory /run/user/970...
сер 22 18:05:27 vvpc kernel: audit: type=1131 audit(1598108727.990:142): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:27 vvpc systemd[907]: run-user-970.mount: Succeeded.
сер 22 18:05:27 vvpc systemd[1]: run-user-970.mount: Succeeded.
сер 22 18:05:28 vvpc systemd[1]: user-runtime-dir@970.service: Succeeded.
сер 22 18:05:28 vvpc systemd[1]: Stopped User Runtime Directory /run/user/970.
сер 22 18:05:27 vvpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:28 vvpc systemd[1]: Removed slice User Slice of UID 970.
сер 22 18:05:28 vvpc kernel: audit: type=1131 audit(1598108727.997:143): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:28 vvpc dbus-daemon[580]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
сер 22 18:05:28 vvpc pulseaudio[5067]: E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
сер 22 18:05:28 vvpc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
сер 22 18:05:28 vvpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:28 vvpc kernel: audit: type=1131 audit(1598108728.950:144): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:43 vvpc audit[5382]: USER_AUTH pid=5382 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:authentication grantors=pam_unix,pam_permit acct="vindicivuoto" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:05:43 vvpc audit[5382]: USER_ACCT pid=5382 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="vindicivuoto" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:05:43 vvpc audit[5382]: CRED_REFR pid=5382 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:05:43 vvpc kernel: audit: type=1100 audit(1598108743.917:145): pid=5382 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:authentication grantors=pam_unix,pam_permit acct="vindicivuoto" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:05:43 vvpc kernel: audit: type=1101 audit(1598108743.917:146): pid=5382 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="vindicivuoto" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:05:43 vvpc kernel: audit: type=1110 audit(1598108743.917:147): pid=5382 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:05:43 vvpc kernel: audit: type=1105 audit(1598108743.920:148): pid=5382 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:05:43 vvpc audit[5382]: USER_START pid=5382 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:05:43 vvpc sudo[5382]: vindicivuoto : TTY=pts/0 ; PWD=/home/vindicivuoto ; USER=root ; COMMAND=/usr/bin/journalctl -S -1h
сер 22 18:05:43 vvpc sudo[5382]: pam_unix(sudo:session): session opened for user root by (uid=0)
сер 22 18:05:48 vvpc sudo[5382]: pam_unix(sudo:session): session closed for user root
сер 22 18:05:48 vvpc kernel: audit: type=1106 audit(1598108748.714:149): pid=5382 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:05:48 vvpc kernel: audit: type=1104 audit(1598108748.717:150): pid=5382 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:05:48 vvpc audit[5382]: USER_END pid=5382 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:05:48 vvpc audit[5382]: CRED_DISP pid=5382 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:05:49 vvpc systemd[1]: blueman-mechanism.service: Succeeded.
сер 22 18:05:49 vvpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:05:49 vvpc kernel: audit: type=1131 audit(1598108749.264:151): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
сер 22 18:06:08 vvpc audit[5408]: USER_ACCT pid=5408 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="vindicivuoto" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:06:08 vvpc audit[5408]: CRED_REFR pid=5408 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit,pam_env acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:06:08 vvpc sudo[5408]: vindicivuoto : TTY=pts/0 ; PWD=/home/vindicivuoto ; USER=root ; COMMAND=/usr/bin/journalctl -S -1h
сер 22 18:06:08 vvpc kernel: audit: type=1101 audit(1598108768.520:152): pid=5408 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="vindicivuoto" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:06:08 vvpc kernel: audit: type=1110 audit(1598108768.520:153): pid=5408 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit,pam_env acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:06:08 vvpc sudo[5408]: pam_unix(sudo:session): session opened for user root by (uid=0)
сер 22 18:06:08 vvpc audit[5408]: USER_START pid=5408 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
сер 22 18:06:08 vvpc kernel: audit: type=1105 audit(1598108768.524:154): pid=5408 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
This is an old issue with VLC, I would recommend to replace VLC by an other player such as SMPlayer. In the old forum there was a long discussion about it already:
Welcome to the forum! :slight_smile:
There was another major system update today, including many KDE packages.
Have you updated your system yet?
sudo pacman -Syyu
Wollie, thanks for your reply, I’ve just installed SMPlayer and will give it a try. I haven’t tested other players so far, so hopefully my issue is restricted to VLC. As for other threads with complaints about VLC’s performance, indeed I’ve seen quite a lot of those on the web, but only one with my specific trigger for the problem (closing the program), which made me, well, morbidly curious. Anyway, thanks again.
I appreciate the welcome, Aragorn. I updated my system shortly after posting this thread, but I don’t expect it to make a difference in my particular case as my issue has persisted for months, through a number of major updates, ever since I switched to Manjaro after building a new desktop.
Another decent video player ─ but it’s a Qt application ─ is Dragon Player. :wink:
From preferences =>Input/Codecs
Change hardware-accelerated decoding method to VA-API.
Test and please report.
Thank you…
i have same problem with this VLC, my PC freeze if im close or pause video. must push power shut down computer… lol
but with ur way posting method VA-API…my VLC good now…
