Hello. Had a strange situation, when I found my laptop, that wasn’t used, was locked and maybe was going to sleep due to Power Management timeout - unresponsive (fans, display were off, no reaction on keyboard)
And pretty warm, like it was still working, but without fans. GPU temperature on reboot was 122’F, which is normal, so, no overheating.
It didn’t reboot, have really long grub timeout and would definately notice it.
So it just was off and heating somehow
Power button didn’t react several times press + press and hold. But then it powered on normally.
Manjaro was just installed a couple of days ago, barely use this PC for meetings. The only errors I’ve seen in dmesg before, since it suddenly rebooted once were connected to iwlwifi such as:
iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
Hardware restart was requested
But I’m not sure that iwlwifi could trigger the above mentioned situation.
Please help
kernel: ioremap error for 0x67eb2000-0x67eb3000, requested 0x2, got 0x0
Sep 03 11:00:20 NetworkManager[723]: <error> [1630656020.7871] device (wlan0): addrconf6: failed to start neighbor discovery: failure creating libndp socket: Address family not supported by protocol (97)
[ 0.142355] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.743076] i8042: Warning: Keylock active
[ 1.229605] usb: port power management may be unreliable
[ 8.701530] nvidia: loading out-of-tree module taints kernel.
[ 8.701546] nvidia: module license 'NVIDIA' taints kernel.
[ 8.701547] Disabling lock debugging due to kernel taint
[ 8.841512] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 8.841594] wmi_bus wmi_bus-PNP0C14:03: WQBC data block query control method not found
[ 8.841596] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 8.864588] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 8.871610] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 8.871762] acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 8.871873] acpi PNP0C14:07: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 8.871972] acpi PNP0C14:08: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 8.895701] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.63.01 Tue Aug 3 20:44:16 UTC 2021
[ 9.141813] i2c_hid i2c-DELL09E1:00: supply vdd not found, using dummy regulator
[ 9.141854] i2c_hid i2c-DELL09E1:00: supply vddl not found, using dummy regulator
[ 9.471878] mtd: partition "BIOS" extends beyond the end of device "0000:00:1f.5" -- size truncated to 0x800000
[ 9.495245] iwlwifi: unknown parameter 'wd_disable' ignored
[ 9.529561] r8169 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 9.561349] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 10.011974] thermal thermal_zone6: failed to read out thermal zone (-61)
[ 11.340633] sof-audio-pci 0000:00:1f.3: warning: unknown sof_ext_man header type 6 size 0x20
[ 11.340638] sof-audio-pci 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 11.340646] sof-audio-pci 0000:00:1f.3: warning: unknown sof_ext_man header type 3 size 0x30
[ 11.340647] sof-audio-pci 0000:00:1f.3: warning: unknown sof_ext_man header type 5 size 0x20
[ 11.458383] sof-audio-pci 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 11.467516] sof-audio-pci 0000:00:1f.3: warn: topology ABI is more recent than kernel
[ 11.487659] sof-audio-pci 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
[ 11.567575] snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
[ 11.567580] snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
[ 11.567730] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
[ 11.567734] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
[ 11.567738] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
[ 11.567743] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
[ 11.567747] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
[ 11.567752] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
[ 11.567757] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
[ 11.567762] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
[ 11.567768] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
[ 11.567773] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
[ 11.567778] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
[ 11.629144] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
[ 13.962817] kauditd_printk_skb: 109 callbacks suppressed
[ 21.024377] kauditd_printk_skb: 8 callbacks suppressed
[ 26.480944] kauditd_printk_skb: 7 callbacks suppressed
[37597.675956] done.
[37598.614999] kauditd_printk_skb: 3 callbacks suppressed
Aug 29 15:36:33 ii kernel: x86/cpu: SGX disabled by BIOS.
Aug 29 15:36:34 ii kernel: ioremap error for 0x67eb2000-0x67eb3000, requested 0x2, got 0x0
Aug 29 15:36:34 ii sddm[664]: Failed to read display number from pipe
Aug 29 15:36:35 ii wpa_supplicant[815]: nl80211: kernel reports: Attribute failed policy validation
Aug 29 15:36:35 ii wpa_supplicant[815]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 29 15:36:35 ii wpa_supplicant[815]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 29 15:37:10 ii pulseaudio[1186]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Aug 29 16:00:51 ii pulseaudio[1186]: Error opening PCM device hdmi:0: No such file or directory
Aug 29 16:00:51 ii pulseaudio[1186]: Error opening PCM device _ucm0003.hw:sofhdadsp,5: No such device
Aug 29 16:00:51 ii pulseaudio[1186]: Error opening PCM device _ucm0003.hw:sofhdadsp,4: No such device
Aug 29 16:00:51 ii pulseaudio[1186]: Error opening PCM device _ucm0003.hw:sofhdadsp,3: No such device
Aug 29 16:00:51 ii pulseaudio[1186]: Error opening PCM device _ucm0003.hw:sofhdadsp: No such device
Aug 29 16:00:51 ii pulseaudio[1186]: Error opening PCM device _ucm0003.hw:sofhdadsp,6: No such device
Aug 29 16:03:57 ii kernel: x86/cpu: SGX disabled by BIOS.
Aug 29 16:03:59 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Aug 29 16:03:59 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 29 16:03:59 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 29 16:04:00 ii sddm[716]: Failed to read display number from pipe
Aug 29 16:04:37 ii pulseaudio[1325]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Aug 29 17:23:51 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Aug 29 17:23:51 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 29 17:23:51 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 29 18:52:18 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Aug 29 18:52:19 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Aug 29 19:13:46 ii kernel: iwlwifi 0000:00:14.3: No beacon heard and the session protection is over already...
Aug 29 20:30:34 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Aug 29 20:30:34 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 29 20:30:34 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 30 09:07:47 ii systemd[1]: Failed to start pkgfile database update.
Aug 30 09:07:48 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Aug 30 09:07:48 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 30 09:07:48 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 30 09:49:08 ii spectacle[17217]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "org.freedesktop.DBus.Error.ServiceUnknown")
Aug 30 09:49:09 ii spectacle[17217]: "applications.menu" not found in ()
Aug 30 10:18:34 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Aug 30 10:36:01 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Aug 30 12:08:53 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Aug 30 13:24:15 ii spectacle[31646]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "org.freedesktop.DBus.Error.ServiceUnknown")
Aug 30 13:24:16 ii spectacle[31646]: "applications.menu" not found in ()
Aug 30 13:50:26 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Aug 30 14:59:06 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Aug 30 14:59:07 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Aug 30 15:54:03 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Aug 30 16:21:25 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Aug 30 16:21:25 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 30 16:21:25 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 30 17:10:12 ii spectacle[47769]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "org.freedesktop.DBus.Error.ServiceUnknown")
Aug 30 17:10:13 ii spectacle[47769]: "applications.menu" not found in ()
Aug 30 17:46:29 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Aug 30 17:46:29 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 30 17:46:29 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 30 20:36:59 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Aug 30 20:36:59 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 30 20:36:59 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 30 20:47:26 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Aug 30 21:25:03 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Aug 30 21:25:03 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 30 21:25:03 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 31 09:32:50 ii systemd[1]: Failed to start pkgfile database update.
Aug 31 09:32:51 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Aug 31 09:32:51 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 31 09:32:51 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 31 10:03:31 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Aug 31 13:51:13 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Aug 31 13:51:13 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 31 13:51:13 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 31 16:44:18 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Aug 31 16:44:18 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 31 16:44:18 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 31 18:43:14 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Aug 31 18:43:14 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Aug 31 18:43:14 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Aug 31 19:14:20 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Sep 01 10:33:23 ii systemd[1]: Failed to start pkgfile database update.
Sep 01 10:33:23 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Sep 01 10:33:23 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Sep 01 10:33:23 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Sep 01 10:48:05 ii spectacle[93735]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "org.freedesktop.DBus.Error.ServiceUnknown")
Sep 01 10:48:06 ii spectacle[93735]: "applications.menu" not found in ()
Sep 01 11:33:34 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Sep 01 18:43:31 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Sep 01 18:43:31 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Sep 01 18:43:31 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Sep 02 07:03:28 ii systemd[1]: Failed to start pkgfile database update.
Sep 02 07:03:29 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Sep 02 07:03:29 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Sep 02 07:03:29 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Sep 02 11:23:38 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Sep 02 11:23:38 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Sep 02 11:23:38 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Sep 02 11:30:50 ii kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x3f0707
Sep 02 14:11:49 ii kernel: mei_me 0000:00:16.0: wait hw ready failed
Sep 02 14:11:49 ii kernel: mei_me 0000:00:16.0: hw_start failed ret = -62
Sep 02 14:11:50 ii wpa_supplicant[855]: nl80211: kernel reports: Attribute failed policy validation
Sep 02 14:11:50 ii wpa_supplicant[855]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Sep 02 14:11:50 ii wpa_supplicant[855]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Welcome to Manjaro!
to give us more information so we can see what’s really going on.
this message and I’ll come back and have another look.
