System Monitor "grid" freezes kde and makes whole system unusable
Hello,
I was just playing arround with the taskbar on wyndsey because I couldnt get my cpu utilization to work with the vertical bar diagram. It was really small and shifted downward arround 60 pixels so I couldn’t even see it with standard task bar size. Anyways when I tried the “grid” type diagram everything related to KDE froze and system told kde wasn’t responding. After restarting it froze after a second again.
Whole KDE now instantly freezes when I start the system. What can I do?
Log out of Plasma, then log in on a TTY. If you have any backups, then restore ~/.config/plasma-org.kde.plasma.desktop-appletsrc from it.
If you don’t have any backups, then you’ll have to delete it, then reconfigure your desktop from scratch.
You must do this while logged out of Plasma, as otherwise your desktop will over-write your restored file.
Hi @Rusticus,
If you can’t boot into your system, then enter a chroot environment and provide logs from there:
How to chroot
  1. Ensure you’ve got a relatively new ISO or at least one with a still supported LTS kernel.
  2. Write/copy/dd the ISO to a USB thumb drive.
  3. When done, boot with the above mentioned USB thumb drive into the live environment.
  4. Once booted, open a terminal and enter the following command to enter the chroot environment:
manjaro-chroot -a
  1. If you have more than one Linux installation, select the correct one to use from the list provided.
When done, you should now be in the chroot environment.
But, be careful, as you’re now in an actual root environment on your computer, so any changes you make will persist after a restart.
Finding errors for specific boot
journalctl --priority=warning..crit --no-pager --boot=-1
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • and the --no-pager formats the output nicely for use here, on the forum;
  • the --boot=-1 argument limits the output to log messages from the previous boot. This can be adjusted to -2 for the boot before that, -3 to the boot before that, and so on and so forth.
Provide the logs here, if you wish us to take a look:
Providing terminal output
:bangbang: Tip :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
I’ve gathered this from console:
Jun 25 15:20:20 nicholas-manjaro kernel: ata3.00: supports DRM functions and may not be fully accessible
Jun 25 15:20:20 nicholas-manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jun 25 15:20:20 nicholas-manjaro kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
Jun 25 15:20:20 nicholas-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: DF poison setting is inconsistent(1:0:0:0)!
Jun 25 15:20:20 nicholas-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Poison setting is inconsistent in DF/UMC(0:1)!
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41177515
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=4522, block=164626450) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156998
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=389, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156855
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=246, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41163638
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=7029, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41181630
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=445, block=164626451) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41181341
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=156, block=164626451) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156912
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=303, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156977
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=368, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156879
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=270, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156918
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=309, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41177272
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=4279, block=164626450) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156926
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=317, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156934
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=325, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156947
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=338, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156948
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=339, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156951
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=342, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156956
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=347, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41185748
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=4563, block=164626451) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41156792
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=183, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41177255
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=4262, block=164626450) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41157013
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=404, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41157021
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=412, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41158066
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=1457, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41177710
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=4717, block=164626450) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41177729
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=4736, block=164626450) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41179906
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=6913, block=164626450) = 0
Jun 25 15:20:20 nicholas-manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420: comm mount: bad orphan inode 41160570
Jun 25 15:20:20 nicholas-manjaro kernel: ext4_test_bit(bit=3961, block=164626448) = 0
Jun 25 15:20:20 nicholas-manjaro systemd-vconsole-setup[412]: KD_FONT_OP_GET failed while trying to get the font metadata: Das Argument ist ungültig
Jun 25 15:20:20 nicholas-manjaro systemd-vconsole-setup[412]: Fonts will not be copied to remaining consoles
Jun 25 15:20:20 nicholas-manjaro systemd-journald[408]: File /var/log/journal/691a7603ada84e7fb379c9cb54831dac/system.journal corrupted or uncleanly shut down, renaming and replacing.
Jun 25 15:20:21 nicholas-manjaro systemd-vconsole-setup[627]: KD_FONT_OP_GET failed while trying to get the font metadata: Das Argument ist ungültig
Jun 25 15:20:21 nicholas-manjaro systemd-vconsole-setup[627]: Fonts will not be copied to remaining consoles
Jun 25 15:20:21 nicholas-manjaro bluetoothd[719]: src/plugin.c:init_plugin() System does not support bap plugin
Jun 25 15:20:21 nicholas-manjaro bluetoothd[719]: src/plugin.c:init_plugin() System does not support bass plugin
Jun 25 15:20:21 nicholas-manjaro bluetoothd[719]: src/plugin.c:init_plugin() System does not support mcp plugin
Jun 25 15:20:21 nicholas-manjaro bluetoothd[719]: src/plugin.c:init_plugin() System does not support vcp plugin
Jun 25 15:20:21 nicholas-manjaro bluetoothd[719]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Jun 25 15:20:21 nicholas-manjaro bluetoothd[719]: src/plugin.c:init_plugin() System does not support micp plugin
Jun 25 15:20:21 nicholas-manjaro bluetoothd[719]: src/plugin.c:init_plugin() System does not support ccp plugin
Jun 25 15:20:21 nicholas-manjaro bluetoothd[719]: src/plugin.c:init_plugin() System does not support csip plugin
Jun 25 15:20:26 nicholas-manjaro dbus-broker-launch[714]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Jun 25 15:20:27 nicholas-manjaro systemd-journald[408]: File /var/log/journal/691a7603ada84e7fb379c9cb54831dac/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Jun 25 15:20:27 nicholas-manjaro dbus-broker-launch[869]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jun 25 15:20:27 nicholas-manjaro dbus-broker-launch[869]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jun 25 15:20:27 nicholas-manjaro dbus-broker-launch[869]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jun 25 15:20:28 nicholas-manjaro kernel: block nvme0n1: No UUID available providing old NGUID
Jun 25 15:20:28 nicholas-manjaro baloo_file[882]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.23'
Jun 25 15:20:28 nicholas-manjaro baloo_file[882]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.26'
Jun 25 15:20:29 nicholas-manjaro kwin_wayland[883]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 25 15:20:29 nicholas-manjaro ksplashqml[886]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Jun 25 15:20:29 nicholas-manjaro kded6[1037]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Jun 25 15:20:29 nicholas-manjaro kded6[1037]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Jun 25 15:20:29 nicholas-manjaro kded6[1037]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Jun 25 15:20:29 nicholas-manjaro ksmserver[1032]: Failed to write ice auth file entry
Jun 25 15:20:29 nicholas-manjaro ksmserver[1032]: Failed to write xsmp ice auth file entry
Jun 25 15:20:29 nicholas-manjaro ksplashqml[886]: Texture 0x7714803297f0 () used with different accesses within the same pass, this is not allowed.
Jun 25 15:20:29 nicholas-manjaro ksplashqml[886]: Texture 0x5d811afa70e0 () used with different accesses within the same pass, this is not allowed.
Jun 25 15:20:29 nicholas-manjaro kconf_update[1140]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Jun 25 15:20:29 nicholas-manjaro kconf_update[1140]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Jun 25 15:20:29 nicholas-manjaro kconf_update[1140]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
Jun 25 15:20:29 nicholas-manjaro kconf_update[1140]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Jun 25 15:20:29 nicholas-manjaro kconf_update[1140]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Jun 25 15:20:29 nicholas-manjaro kconf_update[1140]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Jun 25 15:20:29 nicholas-manjaro kconf_update[1140]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Jun 25 15:20:29 nicholas-manjaro kded6[1037]: kf.coreaddons: "Could not load plugin from /usr/lib/qt6/plugins/plasma5support/geolocationprovider/plasma-geolocation-gps.so: Die Bibliothek /usr/lib/qt6/plugins/plasma5support/geolocationprovider/plasma-geolocation-gps.so kann nicht geladen werden: libgps.so.30: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden"
Jun 25 15:20:29 nicholas-manjaro gmenudbusmenuproxy[1164]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 25 15:20:29 nicholas-manjaro xembedsniproxy[1168]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 25 15:20:29 nicholas-manjaro kded6[1037]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Jun 25 15:20:29 nicholas-manjaro kactivitymanagerd[1161]: kf.windowsystem: virtual void KX11Extras::connectNotify(const QMetaMethod&) may only be used on X11
Jun 25 15:20:29 nicholas-manjaro plasmashell[1119]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jun 25 15:20:29 nicholas-manjaro plasmashell[1119]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jun 25 15:20:29 nicholas-manjaro xdg-desktop-por[892]: Choosing kwallet.portal for org.freedesktop.impl.portal.Secret via the deprecated UseIn key
Jun 25 15:20:29 nicholas-manjaro xdg-desktop-por[892]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Jun 25 15:20:29 nicholas-manjaro backlighthelper[1296]: org.kde.powerdevil: no kernel backlight interface found
Jun 25 15:20:29 nicholas-manjaro plasmashell[1119]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jun 25 15:20:29 nicholas-manjaro org_kde_powerdevil[1166]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jun 25 15:20:29 nicholas-manjaro org_kde_powerdevil[1166]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Jun 25 15:20:30 nicholas-manjaro plasmashell[1119]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jun 25 15:20:30 nicholas-manjaro plasmashell[1119]: Path override failed for key base::DIR_APP_DICTIONARIES and path '/usr/bin/qtwebengine_dictionaries'
Jun 25 15:20:30 nicholas-manjaro QtWebEngineProcess[1327]: Path override failed for key base::DIR_APP_DICTIONARIES and path '/usr/lib/qt6/qtwebengine_dictionaries'
Jun 25 15:20:30 nicholas-manjaro QtWebEngineProcess[1326]: Path override failed for key base::DIR_APP_DICTIONARIES and path '/usr/lib/qt6/qtwebengine_dictionaries'
Jun 25 15:20:30 nicholas-manjaro plasmashell[1119]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:114: ReferenceError: updateZoomTimer is not defined
Jun 25 15:20:30 nicholas-manjaro plasmashell[1119]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:57: ReferenceError: PlasmaCore is not defined
Jun 25 15:20:30 nicholas-manjaro plasmashell[1119]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:81: ReferenceError: getUserAgent is not defined
Jun 25 15:20:30 nicholas-manjaro plasmashell[1119]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Jun 25 15:20:30 nicholas-manjaro plasmashell[1119]: The cached device pixel ratio value was stale on window expose.  Please file a QTBUG which explains how to reproduce.
Jun 25 15:20:30 nicholas-manjaro plasmashell[1119]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:140: ReferenceError: infoButton is not defined
Jun 25 15:20:30 nicholas-manjaro plasmashell[1119]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:120: ReferenceError: infoButton is not defined
Jun 25 15:20:30 nicholas-manjaro plasmashell[1119]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Jun 25 15:20:30 nicholas-manjaro plasmashell[1119]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
Jun 25 15:20:30 nicholas-manjaro plasmashell[1119]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Jun 25 15:20:31 nicholas-manjaro org_kde_powerdevil[1166]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jun 25 15:20:31 nicholas-manjaro org_kde_powerdevil[1166]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jun 25 15:20:31 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:20:31 default: Error sending UDP packet: QAbstractSocket::NetworkError
Jun 25 15:20:31 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:20:31 kdeconnect.core: Failed to open any MDNS client sockets
Jun 25 15:20:31 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:20:31 kdeconnect.core: Failed to open any MDNS server sockets
Jun 25 15:20:31 nicholas-manjaro plasmashell[1119]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:57: ReferenceError: PlasmaCore is not defined
Jun 25 15:20:31 nicholas-manjaro plasmashell[1119]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:81: ReferenceError: getUserAgent is not defined
Jun 25 15:20:32 nicholas-manjaro plasmashell[1119]: js: crbug/1173575, non-JS module files deprecated.
Jun 25 15:20:32 nicholas-manjaro plasmashell[1119]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1719321632084: Dieser Typ von Bilddaten wird nicht unterstützt
Jun 25 15:20:32 nicholas-manjaro plasmashell[1119]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Jun 25 15:20:32 nicholas-manjaro plasmashell[1119]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jun 25 15:20:32 nicholas-manjaro plasmashell[1119]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:62:17: Unable to assign [undefined] to int
Jun 25 15:20:34 nicholas-manjaro plasmashell[1119]: file:///usr/lib/qt6/qml/org/kde/kirigami/Dialog.qml:334:18: QML ScrollView: Binding loop detected for property "calculatedImplicitWidth"
Jun 25 15:20:34 nicholas-manjaro plasmashell[1119]: file:///usr/lib/qt6/qml/org/kde/kirigami/Dialog.qml:386:33: QML Binding: Binding loop detected for property "target"
Jun 25 15:20:37 nicholas-manjaro dbus-broker-launch[714]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Jun 25 15:21:01 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:21:01 default: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jun 25 15:21:01 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:21:01 kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
Jun 25 15:21:01 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:21:01 kdeconnect.plugin.battery: Total quantity of batteries found:  1
Jun 25 15:21:01 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:21:01 kdeconnect.plugin.battery: Primary Battery seems to have been removed. Suspending packets until it is reconnected.
Jun 25 15:21:02 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:21:02 default: DataControlOffer: timeout reading from pipe
Jun 25 15:21:03 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:21:03 default: DataControlOffer: timeout reading from pipe
Jun 25 15:25:34 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:25:34 kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
Jun 25 15:25:34 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:25:34 kdeconnect.plugin.battery: Total quantity of batteries found:  1
Jun 25 15:25:34 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:25:34 kdeconnect.plugin.battery: Primary Battery seems to have been removed. Suspending packets until it is reconnected.
Jun 25 15:32:02 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:02 org.kde.pulseaudio: No object for name "alsa_output.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH115302MKL1MQA4-00.analog-stereo"
Jun 25 15:32:02 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:02 org.kde.pulseaudio: No object for name "alsa_input.usb-046d_0809_9B06D9AB-02.mono-fallback"
Jun 25 15:32:02 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:02 org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Jun 25 15:32:02 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:02 org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jun 25 15:32:02 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:02 org.kde.pulseaudio: No object for name "auto_null.monitor"
Jun 25 15:32:13 nicholas-manjaro wireplumber[973]: spa.bluez5.midi: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.AlreadyExists: Already Exists
Jun 25 15:32:13 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:13 org.kde.pulseaudio: No object for name "auto_null"
Jun 25 15:32:13 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:13 org.kde.pulseaudio: No object for name "auto_null.monitor"
Jun 25 15:32:13 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:13 org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Jun 25 15:32:13 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:13 org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jun 25 15:32:13 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:13 org.kde.pulseaudio: No object for name "alsa_output.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH01570774L1MQAM-00.pro-output-0"
Jun 25 15:32:13 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:13 org.kde.pulseaudio: No object for name "alsa_input.usb-046d_0809_9B06D9AB-02.pro-input-0"
Jun 25 15:32:13 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:13 org.kde.pulseaudio: No object for name "alsa_output.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH115302MKL1MQA4-00.pro-output-0.monitor"
Jun 25 15:32:13 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:13 org.kde.pulseaudio: No object for name "alsa_output.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH115302MKL1MQA4-00.pro-output-0"
Jun 25 15:32:13 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:13 org.kde.pulseaudio: No object for name "alsa_output.pci-0000_12_00.1.pro-output-3"
Jun 25 15:32:19 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:19 org.kde.pulseaudio: No object for name "alsa_output.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH115302MKL1MQA4-00.analog-stereo"
Jun 25 15:32:19 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:19 org.kde.pulseaudio: No object for name "alsa_input.usb-046d_0809_9B06D9AB-02.mono-fallback"
Jun 25 15:32:19 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:19 org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Jun 25 15:32:19 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:19 org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jun 25 15:32:19 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:19 org.kde.pulseaudio: No object for name "auto_null.monitor"
Jun 25 15:32:19 nicholas-manjaro agetty[1780]: failed to open credentials directory
Jun 25 15:32:33 nicholas-manjaro wireplumber[973]: spa.bluez5.midi: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.AlreadyExists: Already Exists
Jun 25 15:32:33 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:33 org.kde.pulseaudio: No object for name "auto_null"
Jun 25 15:32:33 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:33 org.kde.pulseaudio: No object for name "auto_null.monitor"
Jun 25 15:32:33 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:33 org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Jun 25 15:32:33 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:33 org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jun 25 15:32:33 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:33 org.kde.pulseaudio: No object for name "alsa_output.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH01570774L1MQAM-00.pro-output-0"
Jun 25 15:32:33 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:33 org.kde.pulseaudio: No object for name "alsa_input.usb-046d_0809_9B06D9AB-02.pro-input-0"
Jun 25 15:32:33 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:33 org.kde.pulseaudio: No object for name "alsa_output.pci-0000_12_00.6.pro-output-0"
Jun 25 15:32:33 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:33 org.kde.pulseaudio: No object for name "alsa_input.pci-0000_12_00.6.pro-input-0"
Jun 25 15:32:33 nicholas-manjaro kdeconnectd[1458]: 2024-06-25T15:32:33 org.kde.pulseaudio: No object for name "alsa_output.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH115302MKL1MQA4-00.pro-output-0"
Jun 25 15:50:07 nicholas-manjaro kernel: FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Thank you!
That shows that your nvme drive’s partition 2 has a file system error. While this might be the reason for the problem you’re facing, it might also not, I don’t know enough to be sure.
But, you might be able to fix this from a Live environment. So boot into a live environment, and run the fsck tool on the partition, and see if it can fix any errors. From the live environment, run:
sudo fsck.ext4 nvme0n1p2 -p
If there are no errors, it should be safe to try and reboot. But be careful that there aren’t errors.
Hope this helps!
Thanks @Mirdarthos
Sorry the nvme problem seems to have disappeared after reboot.
Here’s a new log:
Jun 25 16:46:20 nicholas-manjaro kernel: ata3.00: supports DRM functions and may not be fully accessible
Jun 25 16:46:20 nicholas-manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jun 25 16:46:20 nicholas-manjaro kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
Jun 25 16:46:20 nicholas-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: DF poison setting is inconsistent(1:0:0:0)!
Jun 25 16:46:20 nicholas-manjaro kernel: amdgpu 0000:03:00.0: amdgpu: Poison setting is inconsistent in DF/UMC(0:1)!
Jun 25 16:46:20 nicholas-manjaro systemd-vconsole-setup[419]: KD_FONT_OP_GET failed while trying to get the font metadata: Das Argument ist ungültig
Jun 25 16:46:20 nicholas-manjaro systemd-vconsole-setup[419]: Fonts will not be copied to remaining consoles
Jun 25 16:46:20 nicholas-manjaro systemd-journald[415]: File /var/log/journal/691a7603ada84e7fb379c9cb54831dac/system.journal corrupted or uncleanly shut down, renaming and replacing.
Jun 25 16:46:20 nicholas-manjaro systemd-vconsole-setup[640]: KD_FONT_OP_GET failed while trying to get the font metadata: Das Argument ist ungültig
Jun 25 16:46:20 nicholas-manjaro systemd-vconsole-setup[640]: Fonts will not be copied to remaining consoles
Jun 25 16:46:21 nicholas-manjaro bluetoothd[738]: src/plugin.c:init_plugin() System does not support bap plugin
Jun 25 16:46:21 nicholas-manjaro bluetoothd[738]: src/plugin.c:init_plugin() System does not support bass plugin
Jun 25 16:46:21 nicholas-manjaro bluetoothd[738]: src/plugin.c:init_plugin() System does not support mcp plugin
Jun 25 16:46:21 nicholas-manjaro bluetoothd[738]: src/plugin.c:init_plugin() System does not support vcp plugin
Jun 25 16:46:21 nicholas-manjaro bluetoothd[738]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Jun 25 16:46:21 nicholas-manjaro bluetoothd[738]: src/plugin.c:init_plugin() System does not support micp plugin
Jun 25 16:46:21 nicholas-manjaro bluetoothd[738]: src/plugin.c:init_plugin() System does not support ccp plugin
Jun 25 16:46:21 nicholas-manjaro bluetoothd[738]: src/plugin.c:init_plugin() System does not support csip plugin
Jun 25 16:46:24 nicholas-manjaro dbus-broker-launch[734]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Jun 25 16:46:27 nicholas-manjaro dbus-broker-launch[734]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Jun 25 16:46:27 nicholas-manjaro systemd-journald[415]: File /var/log/journal/691a7603ada84e7fb379c9cb54831dac/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Jun 25 16:46:28 nicholas-manjaro dbus-broker-launch[893]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jun 25 16:46:28 nicholas-manjaro dbus-broker-launch[893]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jun 25 16:46:28 nicholas-manjaro dbus-broker-launch[893]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jun 25 16:46:28 nicholas-manjaro kernel: block nvme0n1: No UUID available providing old NGUID
Jun 25 16:46:29 nicholas-manjaro baloo_file[905]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.24'
Jun 25 16:46:29 nicholas-manjaro baloo_file[905]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.27'
Jun 25 16:46:30 nicholas-manjaro kwin_wayland[907]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 25 16:46:30 nicholas-manjaro ksplashqml[910]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Jun 25 16:46:30 nicholas-manjaro ksplashqml[910]: Texture 0x78c54c341b40 () used with different accesses within the same pass, this is not allowed.
Jun 25 16:46:30 nicholas-manjaro ksplashqml[910]: Texture 0x59681a955c10 () used with different accesses within the same pass, this is not allowed.
Jun 25 16:46:30 nicholas-manjaro kded6[1061]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Jun 25 16:46:30 nicholas-manjaro kded6[1061]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Jun 25 16:46:30 nicholas-manjaro ksmserver[1056]: Failed to write ice auth file entry
Jun 25 16:46:30 nicholas-manjaro ksmserver[1056]: Failed to write xsmp ice auth file entry
Jun 25 16:46:30 nicholas-manjaro kded6[1061]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Jun 25 16:46:30 nicholas-manjaro kconf_update[1165]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Jun 25 16:46:30 nicholas-manjaro kconf_update[1165]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Jun 25 16:46:30 nicholas-manjaro kconf_update[1165]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
Jun 25 16:46:30 nicholas-manjaro kconf_update[1165]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Jun 25 16:46:30 nicholas-manjaro kconf_update[1165]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Jun 25 16:46:30 nicholas-manjaro kconf_update[1165]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Jun 25 16:46:30 nicholas-manjaro kconf_update[1165]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Jun 25 16:46:30 nicholas-manjaro kded6[1061]: kf.coreaddons: "Could not load plugin from /usr/lib/qt6/plugins/plasma5support/geolocationprovider/plasma-geolocation-gps.so: Die Bibliothek /usr/lib/qt6/plugins/plasma5support/geolocationprovider/plasma-geolocation-gps.so kann nicht geladen werden: libgps.so.30: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden"
Jun 25 16:46:30 nicholas-manjaro gmenudbusmenuproxy[1193]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 25 16:46:30 nicholas-manjaro xembedsniproxy[1197]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 25 16:46:30 nicholas-manjaro kded6[1061]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Jun 25 16:46:30 nicholas-manjaro kactivitymanagerd[1187]: kf.windowsystem: virtual void KX11Extras::connectNotify(const QMetaMethod&) may only be used on X11
Jun 25 16:46:30 nicholas-manjaro plasmashell[1142]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jun 25 16:46:30 nicholas-manjaro plasmashell[1142]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jun 25 16:46:30 nicholas-manjaro xdg-desktop-por[916]: Choosing kwallet.portal for org.freedesktop.impl.portal.Secret via the deprecated UseIn key
Jun 25 16:46:30 nicholas-manjaro xdg-desktop-por[916]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Jun 25 16:46:30 nicholas-manjaro plasmashell[1142]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jun 25 16:46:30 nicholas-manjaro backlighthelper[1322]: org.kde.powerdevil: no kernel backlight interface found
Jun 25 16:46:30 nicholas-manjaro org_kde_powerdevil[1195]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jun 25 16:46:30 nicholas-manjaro org_kde_powerdevil[1195]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Jun 25 16:46:30 nicholas-manjaro plasmashell[1142]: Path override failed for key base::DIR_APP_DICTIONARIES and path '/usr/bin/qtwebengine_dictionaries'
Jun 25 16:46:30 nicholas-manjaro QtWebEngineProcess[1353]: Path override failed for key base::DIR_APP_DICTIONARIES and path '/usr/lib/qt6/qtwebengine_dictionaries'
Jun 25 16:46:30 nicholas-manjaro QtWebEngineProcess[1352]: Path override failed for key base::DIR_APP_DICTIONARIES and path '/usr/lib/qt6/qtwebengine_dictionaries'
Jun 25 16:46:31 nicholas-manjaro plasmashell[1142]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:114: ReferenceError: updateZoomTimer is not defined
Jun 25 16:46:31 nicholas-manjaro plasmashell[1142]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:57: ReferenceError: PlasmaCore is not defined
Jun 25 16:46:31 nicholas-manjaro plasmashell[1142]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:81: ReferenceError: getUserAgent is not defined
Jun 25 16:46:31 nicholas-manjaro plasmashell[1142]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Jun 25 16:46:31 nicholas-manjaro plasmashell[1142]: The cached device pixel ratio value was stale on window expose.  Please file a QTBUG which explains how to reproduce.
Jun 25 16:46:31 nicholas-manjaro plasmashell[1142]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:140: ReferenceError: infoButton is not defined
Jun 25 16:46:31 nicholas-manjaro plasmashell[1142]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:120: ReferenceError: infoButton is not defined
Jun 25 16:46:31 nicholas-manjaro plasmashell[1142]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Jun 25 16:46:31 nicholas-manjaro plasmashell[1142]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
Jun 25 16:46:31 nicholas-manjaro plasmashell[1142]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Jun 25 16:46:32 nicholas-manjaro org_kde_powerdevil[1195]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jun 25 16:46:32 nicholas-manjaro org_kde_powerdevil[1195]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jun 25 16:46:32 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:32 default: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jun 25 16:46:32 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:32 kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
Jun 25 16:46:32 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:32 kdeconnect.plugin.battery: Total quantity of batteries found:  1
Jun 25 16:46:32 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:32 kdeconnect.plugin.battery: Primary Battery seems to have been removed. Suspending packets until it is reconnected.
Jun 25 16:46:32 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:32 org.kde.pulseaudio: No object for name "alsa_input.usb-046d_0809_9B06D9AB-02.pro-input-0"
Jun 25 16:46:32 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:32 org.kde.pulseaudio: No object for name "alsa_output.pci-0000_12_00.6.pro-output-0"
Jun 25 16:46:32 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:32 org.kde.pulseaudio: No object for name "alsa_input.pci-0000_12_00.6.pro-input-0"
Jun 25 16:46:32 nicholas-manjaro plasmashell[1142]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:57: ReferenceError: PlasmaCore is not defined
Jun 25 16:46:32 nicholas-manjaro plasmashell[1142]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:81: ReferenceError: getUserAgent is not defined
Jun 25 16:46:33 nicholas-manjaro plasmashell[1142]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1719326793003: Dieser Typ von Bilddaten wird nicht unterstützt
Jun 25 16:46:33 nicholas-manjaro plasmashell[1142]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Jun 25 16:46:33 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:33 kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
Jun 25 16:46:33 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:33 kdeconnect.plugin.battery: Total quantity of batteries found:  1
Jun 25 16:46:33 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:33 kdeconnect.plugin.battery: Primary Battery seems to have been removed. Suspending packets until it is reconnected.
Jun 25 16:46:33 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:33 kdeconnect.plugin.clipboard: Ignoring clipboard without timestamp
Jun 25 16:46:33 nicholas-manjaro plasmashell[1142]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jun 25 16:46:33 nicholas-manjaro plasmashell[1142]: file:///home/nicholas/.local/share/plasma/plasmoids/com.samirgaire10.chatgpt-plasma6/contents/ui/main.qml:122: ReferenceError: updateZoomTimer is not defined
Jun 25 16:46:34 nicholas-manjaro plasmashell[1142]: file:///usr/lib/qt6/qml/org/kde/kirigami/Dialog.qml:334:18: QML ScrollView: Binding loop detected for property "calculatedImplicitWidth"
Jun 25 16:46:34 nicholas-manjaro plasmashell[1142]: file:///usr/lib/qt6/qml/org/kde/kirigami/Dialog.qml:386:33: QML Binding: Binding loop detected for property "target"
Jun 25 16:46:52 nicholas-manjaro kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0x87 on isa0060/serio0).
Jun 25 16:46:52 nicholas-manjaro kernel: atkbd serio0: Use 'setkeycodes e007 <keycode>' to make it known.
Jun 25 16:46:52 nicholas-manjaro kernel: atkbd serio0: Unknown key released (translated set 2, code 0x87 on isa0060/serio0).
Jun 25 16:46:55 nicholas-manjaro kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0x87 on isa0060/serio0).
Jun 25 16:46:55 nicholas-manjaro kernel: atkbd serio0: Use 'setkeycodes e007 <keycode>' to make it known.
Jun 25 16:46:55 nicholas-manjaro kernel: atkbd serio0: Unknown key released (translated set 2, code 0x87 on isa0060/serio0).
Jun 25 16:46:57 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:57 org.kde.pulseaudio: No object for name "alsa_output.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH115302MKL1MQA4-00.analog-stereo"
Jun 25 16:46:57 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:57 org.kde.pulseaudio: No object for name "alsa_input.usb-046d_0809_9B06D9AB-02.mono-fallback"
Jun 25 16:46:57 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:57 org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Jun 25 16:46:57 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:57 org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jun 25 16:46:57 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:46:57 org.kde.pulseaudio: No object for name "auto_null.monitor"
Jun 25 16:46:57 nicholas-manjaro agetty[1649]: failed to open credentials directory
Jun 25 16:47:24 nicholas-manjaro wireplumber[997]: spa.bluez5.midi: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.AlreadyExists: Already Exists
Jun 25 16:47:24 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:47:24 org.kde.pulseaudio: No object for name "auto_null"
Jun 25 16:47:24 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:47:24 org.kde.pulseaudio: No object for name "auto_null.monitor"
Jun 25 16:47:24 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:47:24 org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Jun 25 16:47:24 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:47:24 org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Jun 25 16:47:24 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:47:24 org.kde.pulseaudio: No object for name "alsa_output.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH01570774L1MQAM-00.pro-output-0"
Jun 25 16:47:24 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:47:24 org.kde.pulseaudio: No object for name "alsa_input.pci-0000_12_00.6.pro-input-0"
Jun 25 16:47:25 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:47:25 org.kde.pulseaudio: No object for name "alsa_output.pci-0000_12_00.6.pro-output-0"
Jun 25 16:47:25 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:47:25 org.kde.pulseaudio: No object for name "alsa_input.pci-0000_12_00.6.pro-input-0"
Jun 25 16:47:25 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:47:25 org.kde.pulseaudio: No object for name "alsa_output.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH115302MKL1MQA4-00.pro-output-0"
Jun 25 16:47:25 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:47:25 org.kde.pulseaudio: No object for name "alsa_output.pci-0000_12_00.1.pro-output-3"
Jun 25 16:47:25 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:47:25 org.kde.pulseaudio: No object for name "alsa_input.usb-046d_0809_9B06D9AB-02.pro-input-0"
Jun 25 16:47:25 nicholas-manjaro kdeconnectd[1483]: 2024-06-25T16:47:25 org.kde.pulseaudio: No object for name "alsa_output.usb-Apple__Inc._USB-C_to_3.5mm_Headphone_Jack_Adapter_DWH01570774L1MQAM-00.analog-stereo.monitor"
Well, I’m glad it “dissapeared” (or got fixed, or whatever.)
However, to me that log still doesn’t say anything.
I still recommend my previously mentio9ned approach to get the logs to provide. And please don’t just provide what you think is relevant. Provide everything because context is necessary.
Thanks for your help @Mirdarthos.
I managed to fix it by just being quick and deleting the taskbar before the program could load. Was a skill issue after all ;D
Whatever happened to the system monitor widget in plasma 6 is way to buggy. I’m not touching that again.
I don’t have an overall monitor widget, but I do have several individual monitoring widgets. And they are all working perfectly.
So I suggest removing and rebuilding KDEs cache.
rm --recursive --force ~/.cache
kbuildsycoca6  --noincremental
The rest of your applications should rebuild their own cache where necessary.
