My setup takes forever to restart, and it has several issues now. It worked perfectly half a month ago, but it started having several issues after I tried to make a new activity in the activities tab of the system settings. I use a usb internet stick for my internet, so reinstalling requires me to have a usb installation of the driver for it.
Issues include:
Dolphin file manager is super slow, and deleting things can sometimes crash it altogether.
Putting things on my desktop doesn’t actually put them there until I reset, although I can see them in the dolphin desktop folder.
Steam games don’t launch through proton at all.
My system settings crashed after returning a page’s settings to default.
Things I’ve tried:
KDE Plasma Version: 5.24.5
KDE Frameworks Version: 5.95.0
Qt Version: 5.15.5
Kernel Version: 5.15.50-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 16 × 11th Gen Intel® Core™ i7-11700K @ 3.60GHz
Memory: 31.2 GiB of RAM
Graphics Processor: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
Welcome to Manjaro!
Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
Please press the three dots … below your post and then press the
If you give us information about your system, we can see what we’re talking about and make better suggestions.
You can do this by using inxi in a terminal or in console.
Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
Copy the output from inxi (including the command) and paste it into your post.
To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Check Settings > Startup and Shutdown > Desktop Session and see if you use Restore previous saved session…
Kernel: 5.15.50-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=658720fb-113d-4497-bca8-6d52db7e95af rw quiet apparmor=1
security=apparmor udev.log_priority=3 nowatchdog
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: PRIME Z590-P v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 0407 date: 01/14/2021
RAM: total: 31.21 GiB used: 3.1 GiB (9.9%)
RAM Report:
Info: model: 11th Gen Intel Core i7-11700K bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 built: 2021+ process: Intel 14nm family: 6
model-id: 0xA7 (167) stepping: 1 microcode: 0x53
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4449 high: 4706 min/max: 800/4900:5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 4686 2: 4700 3: 4683
4: 4700 5: 4700 6: 2676 7: 4700 8: 4684 9: 4706 10: 4567 11: 4575 12: 4688
13: 3782 14: 4006 15: 4691 16: 4649 bogomips: 115232
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed
rdtscp rep_good sdbg sep sha_ni smap smep smx ss ssbd sse sse2 sse4_1
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2182 class-ID: 0300
Device-2: Generalplus GENERAL WEBCAM type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-3:3 chip-ID: 1b3f:2247
class-ID: 0102
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
s-diag: 1252mm (49.29")
Monitor-1: DP-0 pos: primary,right res: 1920x1080 hz: 144 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-2: DP-5 pos: primary,left res: 1920x1080 hz: 60 dpi: 94
size: 520x290mm (20.47x11.42") diag: 595mm (23.44") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
bus-ID: 1-3:3 v: kernel chip-ID: 1b3f:2247 alternate: snd_sof_pci_intel_tgl
class-ID: 0102 bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-3: Generalplus GENERAL WEBCAM type: USB
Sound Server-1: ALSA v: k5.15.50-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu
bus-ID: 1-2.2:6 chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u2u2 state: up mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Local Storage: total: 960.76 GiB used: 406.18 GiB (42.3%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Dial
size: 29.25 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 701.6 GiB size: 611.17 GiB (87.11%)
used: 406.16 GiB (66.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 658720fb-113d-4497-bca8-6d52db7e95af
used: 14.1 MiB (4.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: C77E-4B8A
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 1024 MiB fs: ext4 label: N/A
uuid: 93632f5d-8fb0-4dd9-bf14-59f2819ca956
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 228.62 GiB fs: btrfs
label: fedora_localhost-live uuid: 3c79958e-7753-422b-bcf3-54cb7caeac9c
ID-3: /dev/sda1 maj-min: 8:1 size: 1.88 GiB fs: iso9660
ID-4: /dev/sda2 maj-min: 8:2 size: 9.9 MiB fs: vfat label: ANACONDA
uuid: 1F4B-F0F7
ID-5: /dev/sda3 maj-min: 8:3 size: 20.8 MiB fs: hfsplus label: ANACONDA
uuid: 28d52925-499c-3a1f-b20d-34e524d3b6ba
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-2.1:4 info: SanDisk Cruzer Dial type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5599 class-ID: 0806 serial: <filter>
Device-2: 1-2.2:6 info: Realtek RTL88x2bu [AC1200 Techkey] type: Network
driver: rtl88x2bu interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
Device-3: 1-2.3:8 info: Corsair H100iRGBPROXT type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1b1c:0c20 class-ID: 0300
Device-4: 1-3:3 info: Generalplus GENERAL WEBCAM type: Video,Audio
power: 100mA chip-ID: 1b3f:2247 class-ID: 0102
Device-5: 1-5:5 info: Logitech Gaming Mouse G300 type: Mouse,Keyboard
power: 200mA chip-ID: 046d:c246 class-ID: 0300
Hub-3: 1-6:7 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0801 class-ID: 0900
Device-1: 1-6.2:10 info: XP-Pen G430S type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 70mA
chip-ID: 28bd:0075 class-ID: 0300
Device-2: 1-6.4:11 info: SINO WEALTH Bluetooth Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 258a:0059 class-ID: 0300
Device-3: 1-13:9 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:19af class-ID: 0300 serial: <filter>
Hub-4: 2-0:1 info: Super-speed hub ports: 9 rev: 3.1 speed: 20 Gb/s
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 60 C
Processes: 337 Uptime: 29m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: pacman: 1407 lib: 405 flatpak: 0 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.19
I don’t, I use manually saved session.
Did you try cleaning the cache? KDE - ArchWiki
this solved exactly one problem: the linking to desktop problem.
woah this made steam games work. I wonder if it also fixed dolphin.
system
Closed
10 July 2022 20:30
10
