System hangs up too often
Hi.
I’ve been using Manjaro for some years. I worked perfect on my old Lenovo Legion Y540. I had to buy a new laptop and got a Legion slim 7 16APH8 with Ryzen and a nvidia 4600 on October.
With kernels prior to 6.8 speakers didn’t work, so I had to patch the kernel to add some quirks to get some sound. Then since the 6.8 came out and sound works without patching anything, system hangs every now and then. Especially when: using graphics, using HDMI output or updating the system. Also almost always when I shut down the system. And when coming back from suspend.
I’ve tried used 6.8, 6.9 and even the currently unstable 6.10. And I’ve had re-installed the system a bunch of times (after one of the system upgrading hangs, chroot didn’t work…) and still having the same problems. I’ve tried having the system language in British English, American English and Catalan.
These are some of the logs I’ve gotten recently (cabra is my laptop’s name):
21:02:25 cabra kernel: BUG: Bad page map in process khugepaged  pte:00009e9b pmd:10ff4f067
21:02:25 cabra kernel: addr:0000728f221fd000 vm_flags:08000075 anon_vma:0000000000000000 mapping:ffff9a8187575b18 index:23fd
21:02:25 cabra kernel: file:libLLVM-17.so fault:filemap_fault mmap:ext4_file_mmap [ext4] read_folio:ext4_read_folio [ext4]
21:08:59 cabra kernel: BUG: unable to handle page fault for address: ffff9a82d5ffd000
21:08:59 cabra kernel: #PF: supervisor write access in kernel mode
21:08:59 cabra kernel: #PF: error_code(0x0002) - not-present page
13:32:32 cabra kernel: EXT4-fs error (device nvme0n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399058
13:32:32 cabra kernel: ext4_test_bit(bit=401, block=77594640) = 0
13:32:32 cabra systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
16:25:57 cabra pipewire[1263]: spa.alsa: 'front:2': playback open failed: El fitxer o directori no existeix
16:25:57 cabra pipewire[1263]: pw.node: (alsa_output.pci-0000_65_00.6.analog-stereo-59) suspended -> error (Start error: El fitxer o directori no existeix)
16:25:57 cabra dbus-broker-launch[712]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
This is the inxi -Fazy:
  Kernel: 6.10.0-rc3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=75da5fcc-f453-4004-bc96-78d5577de3cf rw udev.log_priority=3
    nvidia-drm.modeset=1 acpi_osi=linux acpi_backlight=native
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
  Type: Laptop System: LENOVO product: 82Y4 v: Legion Slim 7 16APH8
    serial: <superuser required> Chassis: type: 10 v: Legion Slim 7 16APH8
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
    part-nu: LENOVO_MT_82Y4_BU_idea_FM_Legion Slim 7 16APH8
    uuid: <superuser required> UEFI: LENOVO v: M1CN40WW date: 04/24/2024
  ID-1: BAT1 charge: 39.6 Wh (46.0%) condition: 86.0/99.9 Wh (86.1%)
    power: 26.3 W volts: 15.2 min: 15.6 model: Sunwoda L22D4PC3 type: Unknown
    serial: <filter> status: discharging cycles: 154
  Info: model: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics bits: 64 type: MT MCP
    arch: Zen 4 gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x74 (116) stepping: 1 microcode: 0xA704104
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 815 high: 2393 min/max: 400/5137 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 2393
    4: 400 5: 400 6: 400 7: 1397 8: 400 9: 1377 10: 400 11: 2086 12: 400
    13: 1397 14: 400 15: 400 16: 400 bogomips: 121408
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    affected
  Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: Lenovo
    driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-04) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s ports: active: none
    empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 01:00.0 chip-ID: 10de:28e0
    class-ID: 0300
  Device-2: AMD Phoenix1 vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-3
    code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-2 empty: DP-2, DP-3, DP-4, DP-5, DP-6, DP-7,
    DP-8, DP-9, Writeback-1 bus-ID: 65:00.0 chip-ID: 1002:15bf class-ID: 0300
    temp: 41.0 C
  Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 30c9:00ac
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43")
  Monitor-1: eDP-2 mapped: eDP-1 model: BOE Display 0x0bc2 serial: <filter>
    built: 2022 res: 2560x1600 hz: 240 dpi: 188 gamma: 1.2
    size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10 modes:
    max: 2560x1600 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.9-manjaro1.1
    gfx1103_r1 LLVM 17.0.6 DRM 3.57 6.10.0-rc3-1-MANJARO) device-ID: 1002:15bf
    memory: 500 MiB unified: no
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4060 Laptop GPU driver: nvidia v: 550.90.07
    device-ID: 10de:28e0 surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: AMD Radeon Graphics (RADV GFX1103_R1) driver: mesa radv
    v: 24.0.9-manjaro1.1 device-ID: 1002:15bf surfaces: xcb,xlib
  Device-1: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
    bus-ID: 65:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 65:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 65:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.10.0-rc3-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 14c3:0616 class-ID: 0280
  Device-1: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek MT7922]
    driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-4:4 chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
  Local Storage: total: 1.4 TiB used: 271.48 GiB (19.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
    SN810 SDCPNRY-1T00-1101 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 61530001 temp: 37.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Micron model: MTFDHBA512TCK
    lanes: 4 tech: SSD serial: <filter> fw-rev: 005 P1LN temp: 37.9 C
    scheme: GPT
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 16.15 GiB (16.5%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 32.3 MiB (10.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 691.87 GiB size: 679.94 GiB (98.28%)
    used: 255.3 GiB (37.5%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:3
  System Temperatures: cpu: 46.6 C mobo: N/A gpu: amdgpu temp: 41.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 32 GiB note: est. available: 30.54 GiB used: 4.3 GiB (14.1%)
  Processes: 355 Power: uptime: 58m states: freeze,mem,disk suspend: s2idle
    image: 12.15 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 255 default: graphical tool: systemctl
  Packages: 1433 pm: pacman pkgs: 1427 libs: 437 tools: pamac pm: flatpak
    pkgs: 6 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.34
To make the HDMI output work I followed a post in these forums and added “nvidia-drm.modeset=1” to the /etc/default/grub GRUB_CMDLINE_LINUX_DEFAULT
and “nvidia nvidia_modeset nvidia_uvm nvidia_drm” to the MODULES at /etc/mkinitcpio.conf. It was working OK with these configs when on previous kernels.
Also, I get these errors on boot:
de juny 15 16:29:51 cabra kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP18.SATA], AE_NOT_FOUND (20240322/dswload2-162)
de juny 15 16:29:51 cabra kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240322/psobject-220)
de juny 15 16:29:51 cabra kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._S0W], AE_ALREADY_EXISTS (20240322/dswload2-326)
de juny 15 16:29:51 cabra kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240322/psobject-220)
de juny 15 16:29:51 cabra kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP7.DEV0._S0W], AE_ALREADY_EXISTS (20240322/dswload2-326)
de juny 15 16:29:51 cabra kernel: [drm:amdgpu_fill_buffer [amdgpu]] *ERROR* Trying to clear memory with ring turned off.
de juny 15 16:29:51 cabra systemd-backlight[597]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
de juny 15 16:29:51 cabra systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
░░ Subject: A start job for unit systemd-backlight@backlight:nvidia_0.service has failed
░░ Defined-By: systemd
░░ A start job for unit systemd-backlight@backlight:nvidia_0.service has finished with a failure.
░░ The job identifier is 146 and the job result is failed.
de juny 15 16:29:51 cabra systemd-backlight[627]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
░░ The job identifier is 187 and the job result is failed.
de juny 15 16:29:51 cabra systemd-backlight[642]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
░░ The job identifier is 709 and the job result is failed.
de juny 15 16:29:51 cabra systemd-backlight[645]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
░░ The job identifier is 718 and the job result is failed.
de juny 15 16:29:51 cabra systemd-backlight[648]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
I tried installing Kubuntu on another partition, kernel 6.9, plasma too. It worked well, didn’t need to do any extra configuration to make HDMI work and didn’t hang up. I even could shut the system down. And I can pair the Steam Controller. I prefer Manjaro, but if I can’t find a solution for these hangs I’ll have to find another distribution :frowning:
add
fsck.mode=force fsck.repair=yes
to grub commandline
Or boot from Live USB and fsck -a
Use fsck -a NOT in running System
delete it
this is for ?
I already did a force fsck this week, but new FS problems appear as every shutdown is a crash. And I did a fresh reinstall this week again.
The acpi_backlight and acpi_osi are things I’ve been trying lately, as I’m turning crazy and the brightness and backlight errors appear on every boot. I have the same error with or without them :frowning:
OK, removed those options and added the fsck on the command line, this is the output of the journalctl -p 3 -xb
de juny 15 21:11:40 cabra kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP18.SATA], AE_NOT_FOUND (20240322/dswload2-162)
de juny 15 21:11:40 cabra kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240322/psobject-220)
de juny 15 21:11:40 cabra kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._S0W], AE_ALREADY_EXISTS (20240322/dswload2-326)
de juny 15 21:11:40 cabra kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240322/psobject-220)
de juny 15 21:11:40 cabra kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP7.DEV0._S0W], AE_ALREADY_EXISTS (20240322/dswload2-326)
de juny 15 21:11:40 cabra kernel: [drm:amdgpu_fill_buffer [amdgpu]] *ERROR* Trying to clear memory with ring turned off.
de juny 15 21:11:40 cabra systemd-backlight[604]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
de juny 15 21:11:40 cabra systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
de juny 15 21:11:40 cabra systemd-backlight[644]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
de juny 15 21:11:40 cabra systemd-backlight[654]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
de juny 15 21:11:40 cabra systemd-backlight[659]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
de juny 15 21:11:40 cabra systemd-backlight[661]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
and also, I could take a photo of this and converted to text before the system startup:
0.2935423 ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC10.6P18.S ATAJ, AE NOT FOUND (28240322/dswload2-162)
8.2948431 ACPI Error: RE_NOT_FOUND, During name lookup/catalog (28248322/ps object-228)
C 8.3885881 ACPI BIOS Error (bug): Failure creating named object [\_SB.PC18.G PP6.WLAN. SOW), AE ALREADY EXISTS (28248322/dswload2-326) 8.388588) ACPI Error: RE ALREADY_EXISTS, During name lookup/catalog (282483
22/psobject-228)
8.388601] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCIB.G
PP7.DEVB. SBWJ, RE ALREADY EXISTS (28248322/dswload2-326) 8.3886871 RCPI Error: RE ALREADY EXISTS, During name lookup/catalog (282483
22/psobject-228)
:: running early hook [udev]
[ 1.584772]
:: running hook [udev]
:: Triggering uevents...
Hahahah, mamma mia, what’s up with your system?
Look brother, let’s tackle this step-by-step to get your setup running smoothly.
  1. BIOS Settings: First, double-check your BIOS settings. Make sure Secure Boot is disabled – that’s a big one for getting Linux to run right.
  2. Bootloader: What bootloader are you using? Stick to just one to avoid conflicts. And are you running any other operating systems on this machine? That could be part of the problem.
  3. Kernel Version: Which kernel version are you on? Have you tried different ones? Sometimes newer isn’t always better, and it can be a compatibility thing, especially with new non LTE versions.
  4. Drivers: Make sure you’ve got the latest drivers for your hardware, especially for your NVIDIA graphics card. Sometimes the proprietary drivers work better than the open-source ones.
  5. System Overview: Give me a rundown of your setup – BIOS settings, kernel version, drivers, and any other systems you have installed. The more details, the better.
  6. System Logs: Check your system logs for any repeating errors or warnings. Use journalctl -xe and dmesg to dig up that info. Those logs can be super helpful in pinpointing the issue.
And last but not least… whats about your laptop? Is this a new hardware? Can also be that you shoul check for some firmeware and bios updates on your machine. Sound like - especially because its ■■■■■■■ LENOVO - that you just bought crap… lol
Let me know these details, and we can figure this out together. Looking forward to your response!
Edit: Maybe check also here: [External Link] Hardware Linux Check if your hardware fits for linux.
  1. I always have secure boot disabled.
  2. I am using GRUB on the main SSD. I have a secondary SSD I got from my previous laptop and left Windows on it.
  3. With the current laptop I’ve used from 6.6 up to 6.10RC3 right now. With 6.6 and 6.7 sound didn’t work, quirks were added in 6.8 to make speakers work. With 6.6 and 6.7 I didn’t have all those crashes, but I had to patch the kernel to get sound from the speakers.
  4. I always “auto install proprietary drivers” with the mhwd GUI. Right now: video-hybrid-amd-nvidia-prime. Nvidia 550.90.07-1. I have switchable graphics in the BIOS.
  5. I got the FW updated 2 or 3 weeks ago (that’s what windows is useful for, lenovo doesn’t care about linux :sweat_smile: ). This is the laptop:
[type or paste code here](https://pcsupport.lenovo.com/gb/en/products/laptops-and-netbooks/legion-series/legion-s7-16aph8)
Ryzen CPU, nvidia 4600 GPU.
6. journalctl -xe:
de juny 15 22:50:52 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-47 noise=9999 txrate=144400
de juny 15 22:50:55 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=9999 txrate=144400
de juny 15 22:50:58 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=86700
de juny 15 22:51:01 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=9999 txrate=144400
de juny 15 22:51:04 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=144400
de juny 15 22:51:07 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=144400
de juny 15 22:51:10 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-56 noise=9999 txrate=144400
de juny 15 22:51:13 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-56 noise=9999 txrate=144400
de juny 15 22:51:16 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-47 noise=9999 txrate=115600
de juny 15 22:51:19 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-61 noise=9999 txrate=144400
de juny 15 22:51:22 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-50 noise=9999 txrate=144400
de juny 15 22:51:25 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-54 noise=9999 txrate=144400
de juny 15 22:51:28 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-51 noise=9999 txrate=144400
de juny 15 22:51:31 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-47 noise=9999 txrate=144400
de juny 15 22:51:34 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-52 noise=9999 txrate=144400
de juny 15 22:51:37 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-51 noise=9999 txrate=144400
de juny 15 22:51:40 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-47 noise=9999 txrate=115600
de juny 15 22:51:42 cabra rtkit-daemon[1069]: Supervising 8 threads of 6 processes of 1 users.
de juny 15 22:51:43 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-46 noise=9999 txrate=144400
de juny 15 22:51:46 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-45 noise=9999 txrate=144400
de juny 15 22:51:49 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-50 noise=9999 txrate=144400
de juny 15 22:51:52 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-51 noise=9999 txrate=144400
de juny 15 22:51:55 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-51 noise=9999 txrate=144400
de juny 15 22:51:58 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-52 noise=9999 txrate=144400
de juny 15 22:52:01 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-52 noise=9999 txrate=144400
de juny 15 22:52:04 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-51 noise=9999 txrate=144400
de juny 15 22:52:07 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-52 noise=9999 txrate=144400
de juny 15 22:52:10 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-52 noise=9999 txrate=144400
de juny 15 22:52:13 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-47 noise=9999 txrate=144400
de juny 15 22:52:16 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-54 noise=9999 txrate=144400
de juny 15 22:52:19 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-53 noise=9999 txrate=144400
de juny 15 22:52:22 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-52 noise=9999 txrate=144400
de juny 15 22:52:25 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-55 noise=9999 txrate=144400
de juny 15 22:52:25 cabra systemd[980]: app-org.kde.konsole-396403f296a44f3cb77463bb89316093.scope: Consumed 1.372s CPU time.
░░ Subject: Resources consumed by unit runtime
░░ The unit UNIT completed and consumed the indicated resources.
de juny 15 22:52:27 cabra systemd[980]: Started Konsole - Terminal.
░░ Subject: A start job for unit UNIT has finished successfully
░░ A start job for unit UNIT has finished successfully.
░░ The job identifier is 369.
de juny 15 22:52:27 cabra konsole[9238]: Qt: Session management error: None of the authentication protocols specified are supported
de juny 15 22:52:28 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-52 noise=9999 txrate=144400
de juny 15 22:52:31 cabra wpa_supplicant[872]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-42 noise=9999 txrate=115600
dmesg:
[    3.005739] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.005740] usb usb7: Product: xHCI Host Controller
[    3.005741] usb usb7: Manufacturer: Linux 6.10.0-rc3-1-MANJARO xhci-hcd
[    3.005742] usb usb7: SerialNumber: 0000:67:00.4
[    3.005810] hub 7-0:1.0: USB hub found
[    3.005828] hub 7-0:1.0: 1 port detected
[    3.006606] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.006622] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
[    3.006623] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.006625] usb usb8: Product: xHCI Host Controller
[    3.006625] usb usb8: Manufacturer: Linux 6.10.0-rc3-1-MANJARO xhci-hcd
[    3.006626] usb usb8: SerialNumber: 0000:67:00.4
[    3.006692] hub 8-0:1.0: USB hub found
[    3.006710] hub 8-0:1.0: 1 port detected
[    3.031673] nvme nvme1: 16/0/0 default/read/poll queues
[    3.035270]  nvme1n1: p1 p2 p4
[    3.095636] nvme nvme0: 16/0/0 default/read/poll queues
[    3.105641]  nvme0n1: p1 p2 p3 p4 p5
[    3.117464] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[    3.250458] usb 1-2: new high-speed USB device number 2 using xhci_hcd
[    3.257125] usb 3-1: new full-speed USB device number 2 using xhci_hcd
[    3.406003] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.19
[    3.406006] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.406007] usb 1-2: Product: USB2.1 Hub
[    3.406009] usb 1-2: Manufacturer: Generic
[    3.435918] usb 3-1: New USB device found, idVendor=04f3, idProduct=0c4b, bcdDevice=24.30
[    3.435922] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.435923] usb 3-1: Product: ELAN:Fingerprint
[    3.435925] usb 3-1: Manufacturer: ELAN
[    3.442344] hub 1-2:1.0: USB hub found
[    3.443514] hub 1-2:1.0: 2 ports detected
[    3.521165] usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
[    3.549165] usb 2-2: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.19
[    3.549173] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.549176] usb 2-2: Product: USB3.2 Hub
[    3.549179] usb 2-2: Manufacturer: Generic
[    3.570861] hub 2-2:1.0: USB hub found
[    3.572214] hub 2-2:1.0: 2 ports detected
[    3.667110] usb 1-3: new high-speed USB device number 3 using xhci_hcd
[    3.855390] usb 1-3: New USB device found, idVendor=30c9, idProduct=00ac, bcdDevice= 0.08
[    3.855393] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.855395] usb 1-3: Product: Integrated Camera
[    3.855396] usb 1-3: Manufacturer: 8SSC21K12273V1SR36F281K
[    3.855398] usb 1-3: SerialNumber: 01.00.00
[    4.030443] usb 1-4: new high-speed USB device number 4 using xhci_hcd
[    4.177269] usb 1-4: New USB device found, idVendor=0489, idProduct=e0d8, bcdDevice= 1.00
[    4.177272] usb 1-4: New USB device strings: Mfr=5, Product=6, SerialNumber=7
[    4.177274] usb 1-4: Product: Wireless_Device
[    4.177275] usb 1-4: Manufacturer: MediaTek Inc.
[    4.177276] usb 1-4: SerialNumber: 000000000
[    4.188785] [drm] amdgpu kernel modesetting enabled.
[    4.188799] amdgpu: vga_switcheroo: detected switching method \_SB_.PCI0.GP17.VGA_.ATPX handle
[    4.188916] amdgpu: ATPX version 1, functions 0x00000001
[    4.189013] amdgpu: ATPX Hybrid Graphics
[    4.192243] amdgpu: Virtual CRAT table created for CPU
[    4.192253] amdgpu: Topology: Add CPU node
[    4.192339] amdgpu 0000:65:00.0: enabling device (0006 -> 0007)
[    4.192382] [drm] initializing kernel modesetting (IP DISCOVERY 0x1002:0x15BF 0x17AA:0x3801 0xC2).
[    4.192672] [drm] register mmio base: 0x99700000
[    4.192673] [drm] register mmio size: 524288
[    4.196312] [drm] add ip block number 0 <soc21_common>
[    4.196314] [drm] add ip block number 1 <gmc_v11_0>
[    4.196315] [drm] add ip block number 2 <ih_v6_0>
[    4.196316] [drm] add ip block number 3 <psp>
[    4.196318] [drm] add ip block number 4 <smu>
[    4.196319] [drm] add ip block number 5 <dm>
[    4.196320] [drm] add ip block number 6 <gfx_v11_0>
[    4.196321] [drm] add ip block number 7 <sdma_v6_0>
[    4.196322] [drm] add ip block number 8 <vcn_v4_0>
[    4.196324] [drm] add ip block number 9 <jpeg_v4_0>
[    4.196325] [drm] add ip block number 10 <mes_v11_0>
[    4.196346] amdgpu 0000:65:00.0: amdgpu: Fetched VBIOS from VFCT
[    4.196348] amdgpu: ATOM BIOS: 113-PHXGENERIC-001
[    4.200464] [drm] VCN(0) encode/decode are enabled in VM mode
[    4.201387] amdgpu 0000:65:00.0: [drm:jpeg_v4_0_early_init [amdgpu]] JPEG decode is enabled in VM mode
[    4.214585] Console: switching to colour dummy device 80x25
[    4.248732] amdgpu 0000:65:00.0: vgaarb: deactivate vga console
[    4.248738] amdgpu 0000:65:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
[    4.248815] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[    4.248836] amdgpu 0000:65:00.0: amdgpu: VRAM: 512M 0x0000008000000000 - 0x000000801FFFFFFF (512M used)
[    4.248839] amdgpu 0000:65:00.0: amdgpu: GART: 512M 0x00007FFF00000000 - 0x00007FFF1FFFFFFF
[    4.248852] [drm] Detected VRAM RAM=512M, BAR=512M
[    4.248853] [drm] RAM width 128bits DDR5
[    4.249022] [drm] amdgpu: 512M of VRAM memory ready
[    4.249024] [drm] amdgpu: 15637M of GTT memory ready.
[    4.249038] [drm] GART: num cpu pages 131072, num gpu pages 131072
[    4.249550] [drm] PCIE GART of 512M enabled (table at 0x000000801FD00000).
[    4.249889] [drm] Loading DMUB firmware via PSP: version=0x08003A00
[    4.250197] [drm] Found VCN firmware Version ENC: 1.19 DEC: 7 VEP: 0 Revision: 13
[    4.250202] amdgpu 0000:65:00.0: amdgpu: Will use PSP to load VCN firmware
[    4.275153] amdgpu 0000:65:00.0: amdgpu: reserve 0x4000000 from 0x8018000000 for PSP TMR
[    4.430449] usb 1-5: new full-speed USB device number 5 using xhci_hcd
[    4.593275] usb 1-5: New USB device found, idVendor=048d, idProduct=c987, bcdDevice=14.00
[    4.593280] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.593282] usb 1-5: Product: ITE Device(8258)
[    4.593285] usb 1-5: Manufacturer: ITE Tech. Inc.
[    4.608407] usbcore: registered new interface driver usbhid
[    4.608411] usbhid: USB HID core driver
[    4.611584] input: ITE Tech. Inc. ITE Device(8258) Keyboard as /devices/pci0000:00/0000:00:08.1/0000:65:00.3/usb1/1-5/1-5:1.0/0003:048D:C987.0001/input/input5
[    4.670680] input: ITE Tech. Inc. ITE Device(8258) as /devices/pci0000:00/0000:00:08.1/0000:65:00.3/usb1/1-5/1-5:1.0/0003:048D:C987.0001/input/input6
[    4.670798] input: ITE Tech. Inc. ITE Device(8258) Wireless Radio Control as /devices/pci0000:00/0000:00:08.1/0000:65:00.3/usb1/1-5/1-5:1.0/0003:048D:C987.0001/input/input7
[    4.671044] hid-generic 0003:048D:C987.0001: input,hiddev96,hidraw0: USB HID v1.10 Keyboard [ITE Tech. Inc. ITE Device(8258)] on usb-0000:65:00.3-5/input0
[    4.830553] amdgpu 0000:65:00.0: amdgpu: RAS: optional ras ta ucode is not available
[    4.838672] amdgpu 0000:65:00.0: amdgpu: RAP: optional rap ta ucode is not available
[    4.838675] amdgpu 0000:65:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[    4.868536] amdgpu 0000:65:00.0: amdgpu: SMU is initialized successfully!
[    4.868540] [drm] Seamless boot condition check passed
[    4.869705] [drm:amdgpu_fill_buffer [amdgpu]] *ERROR* Trying to clear memory with ring turned off.
[    4.870098] ------------[ cut here ]------------
[    4.870099] WARNING: CPU: 11 PID: 250 at drivers/gpu/drm/amd/amdgpu/amdgpu_object.c:1382 amdgpu_bo_release_notify+0x1ff/0x220 [amdgpu]
[    4.870224] Modules linked in: hid_generic usbhid amdgpu(+) amdxcp i2c_algo_bit rtsx_pci_sdmmc drm_ttm_helper serio_raw atkbd ttm mmc_core libps2 drm_exec gpu_sched vivaldi_fmap nvme drm_suballoc_helper drm_buddy nvme_core xhci_pci crc32c_intel drm_display_helper i8042 rtsx_pci xhci_pci_renesas nvme_auth serio nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE) video wmi nvidia(POE)
[    4.870248] CPU: 11 PID: 250 Comm: (udev-worker) Tainted: P           OE      6.10.0-rc3-1-MANJARO #1 48aec18d75cf2ff8be45a638398f02cc8fe7b0e4
[    4.870251] Hardware name: LENOVO 82Y4/LNVNB161216, BIOS M1CN40WW 04/24/2024
[    4.870253] RIP: 0010:amdgpu_bo_release_notify+0x1ff/0x220 [amdgpu]
[    4.870372] Code: 0b e9 af fe ff ff 48 ba ff ff ff ff ff ff ff 7f 31 f6 4c 89 e7 e8 11 41 c2 d0 eb 98 e8 ca 37 c2 d0 eb b2 0f 0b e9 58 fe ff ff <0f> 0b eb a7 be 03 00 00 00 e8 e3 63 8f d0 eb 9b e8 dc 38 0b d1 66
[    4.870373] RSP: 0018:ffffadd9474cf578 EFLAGS: 00010282
[    4.870376] RAX: 00000000ffffffea RBX: ffff8f02abb6a848 RCX: 0000000000000003
[    4.870377] RDX: 0000000000000000 RSI: 0000000000000003 RDI: 0000000000000001
[    4.870378] RBP: ffff8f02b000ef58 R08: 0000000000000000 R09: ffffadd9474cf2d8
[    4.870379] R10: ffffffff96cb21e8 R11: 0000000000000003 R12: ffff8f02abb6a800
[    4.870380] R13: ffff8f02abb6a948 R14: ffff8f02b000ef58 R15: 0000000000000008
[    4.870381] FS:  000074c664a7b680(0000) GS:ffff8f09be780000(0000) knlGS:0000000000000000
[    4.870382] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[    4.870383] CR2: 000062e51967d718 CR3: 000000011eedc000 CR4: 0000000000f50ef0
[    4.870385] PKRU: 55555554
[    4.870386] Call Trace:
[    4.870388]  <TASK>
[    4.870390]  ? amdgpu_bo_release_notify+0x1ff/0x220 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.870515]  ? __warn.cold+0x8e/0xe8
[    4.870519]  ? amdgpu_bo_release_notify+0x1ff/0x220 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.870637]  ? report_bug+0xff/0x140
[    4.870642]  ? handle_bug+0x3c/0x80
[    4.870644]  ? exc_invalid_op+0x17/0x70
[    4.870646]  ? asm_exc_invalid_op+0x1a/0x20
[    4.870651]  ? amdgpu_bo_release_notify+0x1ff/0x220 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.870768]  ? amdgpu_bo_release_notify+0x148/0x220 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.870886]  ttm_bo_release+0xfd/0x2e0 [ttm ed8cfe58f97980ee00ecba83db6804d03b2bd61e]
[    4.870892]  ? __pfx_amdgpu_bo_destroy+0x10/0x10 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.871010]  amdgpu_bo_free_kernel+0xcb/0x110 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.871128]  dm_helpers_free_gpu_mem+0x41/0x90 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.871317]  dcn314_clk_mgr_construct+0x29e/0xcd0 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.871505]  dc_clk_mgr_create+0x446/0x5e0 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.871674]  dc_create+0x288/0x650 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.871843]  amdgpu_dm_init.isra.0+0x32f/0x1da0 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.872013]  ? vprintk_emit+0x176/0x2a0
[    4.872023]  dm_hw_init+0x12/0x30 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.872176]  amdgpu_device_init.cold+0x18fe/0x218d [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.872354]  ? srso_alias_return_thunk+0x5/0xfbef5
[    4.872358]  amdgpu_driver_load_kms+0x19/0x70 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.872482]  amdgpu_pci_probe+0x187/0x400 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.872617]  local_pci_probe+0x42/0x90
[    4.872621]  pci_device_probe+0xbd/0x290
[    4.872624]  ? srso_alias_return_thunk+0x5/0xfbef5
[    4.872626]  ? sysfs_do_create_link_sd+0x6e/0xe0
[    4.872629]  really_probe+0xdb/0x340
[    4.872633]  ? pm_runtime_barrier+0x54/0x90
[    4.872637]  ? __pfx___driver_attach+0x10/0x10
[    4.872639]  __driver_probe_device+0x78/0x110
[    4.872641]  driver_probe_device+0x1f/0xa0
[    4.872643]  __driver_attach+0xba/0x1c0
[    4.872646]  bus_for_each_dev+0x8c/0xe0
[    4.872649]  bus_add_driver+0x112/0x1f0
[    4.872651]  driver_register+0x72/0xd0
[    4.872654]  ? __pfx_amdgpu_init+0x10/0x10 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    4.872774]  do_one_initcall+0x58/0x310
[    4.872779]  do_init_module+0x60/0x220
[    4.872782]  init_module_from_file+0x89/0xe0
[    4.872786]  idempotent_init_module+0x121/0x2b0
[    4.872789]  __x64_sys_finit_module+0x5e/0xb0
[    4.872791]  do_syscall_64+0x82/0x160
[    4.872793]  ? srso_alias_return_thunk+0x5/0xfbef5
[    4.872795]  ? srso_alias_return_thunk+0x5/0xfbef5
[    4.872796]  ? syscall_exit_to_user_mode+0x75/0x210
[    4.872799]  ? srso_alias_return_thunk+0x5/0xfbef5
[    4.872800]  ? do_syscall_64+0x8e/0x160
[    4.872801]  ? do_syscall_64+0x8e/0x160
[    4.872802]  ? syscall_exit_to_user_mode+0x75/0x210
[    4.872804]  ? srso_alias_return_thunk+0x5/0xfbef5
[    4.872805]  ? do_syscall_64+0x8e/0x160
[    4.872806]  ? do_syscall_64+0x8e/0x160
[    4.872807]  ? do_syscall_64+0x8e/0x160
[    4.872808]  ? srso_alias_return_thunk+0x5/0xfbef5
[    4.872810]  ? srso_alias_return_thunk+0x5/0xfbef5
[    4.872812]  entry_SYSCALL_64_after_hwframe+0x76/0x7e
[    4.872814] RIP: 0033:0x74c665509e9d
[    4.872823] Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 63 de 0c 00 f7 d8 64 89 01 48
[    4.872824] RSP: 002b:00007ffe7df81f18 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[    4.872826] RAX: ffffffffffffffda RBX: 000062e5196813d0 RCX: 000074c665509e9d
[    4.872827] RDX: 0000000000000004 RSI: 000074c665623376 RDI: 0000000000000027
[    4.872828] RBP: 000074c665623376 R08: 0000000000000001 R09: 00007ffe7df81f60
[    4.872829] R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
[    4.872830] R13: 000062e519677ce0 R14: 0000000000000000 R15: 000062e519695fc0
[    4.872833]  </TASK>
[    4.872834] ---[ end trace 0000000000000000 ]---
[    4.872967] [drm] Display Core v3.2.281 initialized on DCN 3.1.4
[    4.872969] [drm] DP-HDMI FRL PCON supported
[    4.876040] [drm] DMUB hardware initialized: version=0x08003A00
[    5.001324] [drm] PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x2a su_y_granularity 0
[    5.003046] [drm] kiq ring mec 3 pipe 1 q 0
[    5.005572] amdgpu 0000:65:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
[    5.007487] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[    5.007501] kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
[    5.007663] amdgpu: Virtual CRAT table created for GPU
[    5.007801] amdgpu: Topology: Add dGPU node [0x15bf:0x1002]
[    5.007803] kfd kfd: amdgpu: added device 1002:15bf
[    5.007814] amdgpu 0000:65:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 6, active_cu_number 12
[    5.007819] amdgpu 0000:65:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[    5.007821] amdgpu 0000:65:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[    5.007822] amdgpu 0000:65:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[    5.007823] amdgpu 0000:65:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[    5.007824] amdgpu 0000:65:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[    5.007825] amdgpu 0000:65:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[    5.007826] amdgpu 0000:65:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[    5.007827] amdgpu 0000:65:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[    5.007828] amdgpu 0000:65:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[    5.007829] amdgpu 0000:65:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[    5.007830] amdgpu 0000:65:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[    5.007831] amdgpu 0000:65:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
[    5.007832] amdgpu 0000:65:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
[    5.009429] [drm] ring gfx_32768.1.1 was added
[    5.009978] [drm] ring compute_32768.2.2 was added
[    5.010506] [drm] ring sdma_32768.3.3 was added
[    5.010561] [drm] ring gfx_32768.1.1 ib test pass
[    5.010603] [drm] ring compute_32768.2.2 ib test pass
[    5.010693] [drm] ring sdma_32768.3.3 ib test pass
[    5.012731] amdgpu 0000:65:00.0: amdgpu: Runtime PM not available
[    5.013430] [drm] Initialized amdgpu 3.57.0 20150101 for 0000:65:00.0 on minor 2
[    5.017253] fbcon: amdgpudrmfb (fb0) is primary device
[    5.017458] [drm] DSC precompute is not needed.
[    5.139014] ------------[ cut here ]------------
[    5.139015] WARNING: CPU: 2 PID: 250 at drivers/gpu/drm/amd/amdgpu/../display/dc/dsc/dcn20/dcn20_dsc.c:272 dsc2_disable+0x108/0x180 [amdgpu]
[    5.139235] Modules linked in: hid_generic usbhid amdgpu(+) amdxcp i2c_algo_bit rtsx_pci_sdmmc drm_ttm_helper serio_raw atkbd ttm mmc_core libps2 drm_exec gpu_sched vivaldi_fmap nvme drm_suballoc_helper drm_buddy nvme_core xhci_pci crc32c_intel drm_display_helper i8042 rtsx_pci xhci_pci_renesas nvme_auth serio nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE) video wmi nvidia(POE)
[    5.139258] CPU: 2 PID: 250 Comm: (udev-worker) Tainted: P        W  OE      6.10.0-rc3-1-MANJARO #1 48aec18d75cf2ff8be45a638398f02cc8fe7b0e4
[    5.139261] Hardware name: LENOVO 82Y4/LNVNB161216, BIOS M1CN40WW 04/24/2024
[    5.139263] RIP: 0010:dsc2_disable+0x108/0x180 [amdgpu]
[    5.139456] Code: 4c 24 0c 44 8b 43 10 48 8b 40 10 48 8b 30 48 85 f6 74 04 48 8b 76 08 48 c7 c1 30 b9 4d c5 ba 08 00 00 00 31 ff e8 18 22 73 d0 <0f> 0b 48 8b 53 20 48 8b 43 28 45 31 c9 48 8b 7b 08 0f b6 8a b4 00
[    5.139457] RSP: 0018:ffffadd9474cf0a0 EFLAGS: 00010246
[    5.139458] RAX: 0000000000000000 RBX: ffff8f029c9cb400 RCX: ffffffffc54db930
[    5.139460] RDX: 0000000000000008 RSI: ffff8f02821560c8 RDI: 0000000000000000
[    5.139460] RBP: ffff8f02af9002d8 R08: 0000000000000000 R09: 0000000000000000
[    5.139461] R10: 0000000000000000 R11: 0000000000000001 R12: ffff8f0293c00000
[    5.139462] R13: ffff8f0294590000 R14: 0000000000000001 R15: 0000000000000000
[    5.139463] FS:  000074c664a7b680(0000) GS:ffff8f09be300000(0000) knlGS:0000000000000000
[    5.139464] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[    5.139465] CR2: 000062e519699608 CR3: 000000011eedc000 CR4: 0000000000f50ef0
[    5.139466] PKRU: 55555554
[    5.139466] Call Trace:
[    5.139469]  <TASK>
[    5.139470]  ? dsc2_disable+0x108/0x180 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.139732]  ? __warn.cold+0x8e/0xe8
[    5.139737]  ? dsc2_disable+0x108/0x180 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.140048]  ? report_bug+0xff/0x140
[    5.140055]  ? handle_bug+0x3c/0x80
[    5.140059]  ? exc_invalid_op+0x17/0x70
[    5.140062]  ? asm_exc_invalid_op+0x1a/0x20
[    5.140068]  ? dsc2_disable+0x108/0x180 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.140370]  link_set_dsc_on_stream+0x406/0x480 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.140710]  ? drm_dp_dpcd_write+0xc3/0xe0 [drm_display_helper 35c50d42232510c2deeca7367631bd82f956b1df]
[    5.140727]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.140731]  ? dm_helpers_dp_write_dsc_enable+0x28a/0x700 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.141086]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.141089]  link_set_dsc_enable+0x83/0x90 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.141266]  link_set_dpms_off+0x1da/0x760 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.141417]  ? dmub_srv_get_fw_boot_status+0x2a/0x50 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.141573]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.141574]  ? dc_dmub_srv_is_restore_required+0x40/0x80 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.141729]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.141731]  ? dm_read_reg_func+0x38/0xb0 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.141904]  dc_commit_state_no_check+0x84e/0xe10 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.142071]  dc_commit_streams+0x300/0x400 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.142221]  amdgpu_dm_atomic_commit_tail+0x671/0x3d20 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.142386]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.142387]  ? dcn314_validate_bandwidth+0x117/0x330 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.142561]  ? dc_validate_global_state+0x30a/0x3d0 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.142714]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.142716]  ? dma_resv_get_fences+0xb2/0x2a0
[    5.142720]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.142721]  ? dma_resv_get_singleton+0x44/0x150
[    5.142724]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.142725]  ? amdgpu_dm_plane_helper_prepare_fb+0x185/0x2a0 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.142889]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.142891]  ? amdgpu_dm_plane_helper_prepare_fb+0x1c8/0x2a0 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.143043]  commit_tail+0x91/0x130
[    5.143048]  drm_atomic_helper_commit+0x11a/0x140
[    5.143050]  drm_atomic_commit+0x9d/0xd0
[    5.143053]  ? __pfx___drm_printfn_info+0x10/0x10
[    5.143055]  drm_client_modeset_commit_atomic+0x203/0x250
[    5.143059]  drm_client_modeset_commit_locked+0x5a/0x160
[    5.143061]  ? set_inverse_trans_unicode+0xde/0x100
[    5.143064]  drm_client_modeset_commit+0x25/0x40
[    5.143065]  __drm_fb_helper_restore_fbdev_mode_unlocked+0x85/0xd0
[    5.143069]  drm_fb_helper_set_par+0x30/0x40
[    5.143071]  fbcon_init+0x2e6/0x630
[    5.143075]  visual_init+0xcb/0x130
[    5.143077]  do_bind_con_driver.isra.0+0x1d6/0x2c0
[    5.143079]  do_take_over_console+0x157/0x180
[    5.143081]  do_fbcon_takeover+0x5a/0xc0
[    5.143083]  fbcon_fb_registered+0x4d/0x70
[    5.143085]  register_framebuffer+0x180/0x280
[    5.143087]  __drm_fb_helper_initial_config_and_unlock+0x35a/0x480
[    5.143091]  drm_fbdev_generic_client_hotplug+0x6b/0xa0
[    5.143093]  drm_client_register+0x7a/0xb0
[    5.143096]  amdgpu_pci_probe+0x3ee/0x400 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.143215]  local_pci_probe+0x42/0x90
[    5.143218]  pci_device_probe+0xbd/0x290
[    5.143220]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.143221]  ? sysfs_do_create_link_sd+0x6e/0xe0
[    5.143225]  really_probe+0xdb/0x340
[    5.143227]  ? pm_runtime_barrier+0x54/0x90
[    5.143230]  ? __pfx___driver_attach+0x10/0x10
[    5.143231]  __driver_probe_device+0x78/0x110
[    5.143233]  driver_probe_device+0x1f/0xa0
[    5.143235]  __driver_attach+0xba/0x1c0
[    5.143237]  bus_for_each_dev+0x8c/0xe0
[    5.143239]  bus_add_driver+0x112/0x1f0
[    5.143241]  driver_register+0x72/0xd0
[    5.143244]  ? __pfx_amdgpu_init+0x10/0x10 [amdgpu 3e370f0834be0865e75f186fbcc3c7bd658362af]
[    5.143360]  do_one_initcall+0x58/0x310
[    5.143365]  do_init_module+0x60/0x220
[    5.143367]  init_module_from_file+0x89/0xe0
[    5.143371]  idempotent_init_module+0x121/0x2b0
[    5.143374]  __x64_sys_finit_module+0x5e/0xb0
[    5.143376]  do_syscall_64+0x82/0x160
[    5.143377]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.143379]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.143380]  ? syscall_exit_to_user_mode+0x75/0x210
[    5.143383]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.143384]  ? do_syscall_64+0x8e/0x160
[    5.143385]  ? do_syscall_64+0x8e/0x160
[    5.143386]  ? syscall_exit_to_user_mode+0x75/0x210
[    5.143387]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.143388]  ? do_syscall_64+0x8e/0x160
[    5.143389]  ? do_syscall_64+0x8e/0x160
[    5.143390]  ? do_syscall_64+0x8e/0x160
[    5.143391]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.143392]  ? srso_alias_return_thunk+0x5/0xfbef5
[    5.143394]  entry_SYSCALL_64_after_hwframe+0x76/0x7e
[    5.143396] RIP: 0033:0x74c665509e9d
[    5.143407] Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 63 de 0c 00 f7 d8 64 89 01 48
[    5.143407] RSP: 002b:00007ffe7df81f18 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[    5.143409] RAX: ffffffffffffffda RBX: 000062e5196813d0 RCX: 000074c665509e9d
[    5.143410] RDX: 0000000000000004 RSI: 000074c665623376 RDI: 0000000000000027
[    5.143411] RBP: 000074c665623376 R08: 0000000000000001 R09: 00007ffe7df81f60
[    5.143411] R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
[    5.143412] R13: 000062e519677ce0 R14: 0000000000000000 R15: 000062e519695fc0
[    5.143415]  </TASK>
[    5.143415] ---[ end trace 0000000000000000 ]---
[    5.876874] Console: switching to colour frame buffer device 160x50
[    5.883945] amdgpu 0000:65:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[    6.126236] EXT4-fs (nvme1n1p2): recovery complete
[    6.126268] EXT4-fs (nvme1n1p2): mounted filesystem 75da5fcc-f453-4004-bc96-78d5577de3cf r/w with ordered data mode. Quota mode: none.
[    6.192873] systemd[1]: systemd 255.7-1-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    6.192878] systemd[1]: Detected architecture x86-64.
[    6.193626] systemd[1]: Hostname set to <cabra>.
[    6.381008] systemd[1]: bpf-lsm: LSM BPF program attached
[    6.487178] systemd[1]: Queued start job for default target Graphical Interface.
[    6.545621] systemd[1]: Created slice Slice /system/dirmngr.
[    6.545949] systemd[1]: Created slice Slice /system/getty.
[    6.546171] systemd[1]: Created slice Slice /system/gpg-agent.
[    6.546363] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[    6.546552] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[    6.546772] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[    6.546966] systemd[1]: Created slice Slice /system/keyboxd.
[    6.547176] systemd[1]: Created slice Slice /system/modprobe.
[    6.547374] systemd[1]: Created slice Slice /system/systemd-fsck.
[    6.547522] systemd[1]: Created slice User and Session Slice.
[    6.547572] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.547709] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.547776] systemd[1]: Expecting device /dev/disk/by-uuid/A018-926A...
[    6.547811] systemd[1]: Expecting device /dev/disk/by-uuid/a807d0b8-4c5e-45a9-a712-a896c5419a6e...
[    6.547844] systemd[1]: Reached target Login Prompts.
[    6.547878] systemd[1]: Reached target Local Integrity Protected Volumes.
[    6.547909] systemd[1]: Reached target Remote File Systems.
[    6.547930] systemd[1]: Reached target Slice Units.
[    6.547958] systemd[1]: Reached target Swaps.
[    6.547986] systemd[1]: Reached target Local Verity Protected Volumes.
[    6.548038] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    6.548214] systemd[1]: Listening on LVM2 poll daemon socket.
[    6.548913] systemd[1]: Listening on Process Core Dump Socket.
[    6.548991] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.549080] systemd[1]: Listening on Journal Socket.
[    6.549112] systemd[1]: TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    6.549327] systemd[1]: Listening on udev Control Socket.
[    6.549393] systemd[1]: Listening on udev Kernel Socket.
[    6.549477] systemd[1]: Listening on User Database Manager Socket.
[    6.550460] systemd[1]: Mounting Huge Pages File System...
[    6.551012] systemd[1]: Mounting POSIX Message Queue File System...
[    6.551887] systemd[1]: Mounting Kernel Debug File System...
[    6.552901] systemd[1]: Mounting Kernel Trace File System...
[    6.553534] systemd[1]: Starting Create List of Static Device Nodes...
[    6.554157] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    6.554878] systemd[1]: Starting Load Kernel Module configfs...
[    6.555418] systemd[1]: Starting Load Kernel Module dm_mod...
[    6.555957] systemd[1]: Starting Load Kernel Module drm...
[    6.556752] systemd[1]: Starting Load Kernel Module fuse...
[    6.557331] systemd[1]: Starting Load Kernel Module loop...
[    6.557413] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[    6.558509] systemd[1]: Starting Journal Service...
[    6.559214] systemd[1]: Starting Load Kernel Modules...
[    6.559235] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    6.559721] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.560880] systemd[1]: TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    6.561447] systemd[1]: Starting Coldplug All udev Devices...
[    6.562788] systemd[1]: Starting Virtual Console Setup...
[    6.564878] systemd[1]: Mounted Huge Pages File System.
[    6.565142] systemd[1]: Mounted POSIX Message Queue File System.
[    6.565815] systemd[1]: Mounted Kernel Debug File System.
[    6.566322] systemd[1]: Mounted Kernel Trace File System.
[    6.566856] systemd[1]: Finished Create List of Static Device Nodes.
[    6.566959] loop: module loaded
[    6.566967] device-mapper: uevent: version 1.0.3
[    6.567121] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
[    6.567390] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    6.567481] systemd[1]: Finished Load Kernel Module configfs.
[    6.567720] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[    6.567807] systemd[1]: Finished Load Kernel Module dm_mod.
[    6.568097] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    6.568180] systemd[1]: Finished Load Kernel Module drm.
[    6.568386] systemd-journald[439]: Collecting audit messages is disabled.
[    6.568497] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    6.568607] systemd[1]: Finished Load Kernel Module fuse.
[    6.568933] systemd[1]: modprobe@loop.service: Deactivated successfully.
[    6.569057] systemd[1]: Finished Load Kernel Module loop.
[    6.570014] systemd[1]: Mounting FUSE Control File System...
[    6.570465] systemd[1]: Mounting Kernel Configuration File System...
[    6.570618] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[    6.570957] i2c_dev: i2c /dev entries driver
[    6.571148] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    6.574092] systemd[1]: Mounted FUSE Control File System.
[    6.574184] systemd[1]: Mounted Kernel Configuration File System.
[    6.576623] systemd[1]: Finished Load Kernel Modules.
[    6.577827] systemd[1]: Starting Apply Kernel Variables...
[    6.579309] systemd[1]: Finished Virtual Console Setup.
[    6.581642] systemd[1]: Starting User Database Manager...
[    6.585445] systemd[1]: Finished Apply Kernel Variables.
[    6.600798] EXT4-fs (nvme1n1p2): re-mounted 75da5fcc-f453-4004-bc96-78d5577de3cf r/w. Quota mode: none.
[    6.601882] systemd[1]: Finished Remount Root and Kernel File Systems.
[    6.602347] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[    6.602898] systemd[1]: Starting Load/Save OS Random Seed...
[    6.602919] systemd[1]: TPM2 SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    6.607995] systemd[1]: Started Journal Service.
[    6.619763] systemd-journald[439]: Received client request to flush runtime journal.
[    6.621107] systemd-journald[439]: File /var/log/journal/7c8261220c8e4cd0822280fcb619d5b8/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    6.738121] Serial bus multi instantiate pseudo device driver CSC3551:00: Instantiated 2 I2C devices.
[    6.757447] ccp 0000:65:00.2: enabling device (0000 -> 0002)
[    6.758564] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[    6.758570] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[    6.761025] ccp 0000:65:00.2: tee enabled
[    6.761202] mc: Linux media interface: v0.10
[    6.762623] ccp 0000:65:00.2: psp enabled
[    6.762633] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[    6.787270] input: PC Speaker as /devices/platform/pcspkr/input/input8
[    6.787332] ACPI: bus type thunderbolt registered
[    6.787779] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.787887] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.787976] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    6.794050] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[    6.794053] RAPL PMU: hw unit of domain package 2^-16 Joules
[    6.802576] cryptd: max_cpu_qlen set to 1000
[    6.802739] Bluetooth: Core ver 2.22
[    6.802755] NET: Registered PF_BLUETOOTH protocol family
[    6.802756] Bluetooth: HCI device and connection manager initialized
[    6.802759] Bluetooth: HCI socket layer initialized
[    6.802760] Bluetooth: L2CAP socket layer initialized
[    6.802764] Bluetooth: SCO socket layer initialized
[    6.832584] input: ELAN06FA:00 04F3:3280 Mouse as /devices/platform/AMDI0010:00/i2c-0/i2c-ELAN06FA:00/0018:04F3:3280.0002/input/input9
[    6.832641] input: ELAN06FA:00 04F3:3280 Touchpad as /devices/platform/AMDI0010:00/i2c-0/i2c-ELAN06FA:00/0018:04F3:3280.0002/input/input11
[    6.832683] hid-generic 0018:04F3:3280.0002: input,hidraw1: I2C HID v1.00 Mouse [ELAN06FA:00 04F3:3280] on i2c-ELAN06FA:00
[    6.872182] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[    6.872954] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[    6.873047] AVX2 version of gcm_enc/dec engaged.
[    6.873116] AES CTR mode by8 optimization enabled
[    6.873341] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[    6.879656] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input12
[    6.955302] videodev: Linux video capture interface: v2.00
[    6.963324] usbcore: registered new interface driver btusb
[    6.966479] Bluetooth: hci0: HW/SW Version: 0x008a008a, Build Time: 20240409163648
[    6.969313] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: Adding DSD properties for 17AA38B6
[    6.969555] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: Using extra _DSD properties, bypassing _DSD in ACPI
[    6.974308] ideapad_acpi VPC2004:00: DYTC interface is not available
[    6.979049] usb 1-3: Found UVC 1.50 device Integrated Camera (30c9:00ac)
[    6.991151] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[    6.991247] snd_hda_intel 0000:01:00.1: Disabling MSI
[    6.991255] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    6.991749] snd_hda_intel 0000:65:00.1: enabling device (0000 -> 0002)
[    6.991853] snd_hda_intel 0000:65:00.1: Handle vga_switcheroo audio client
[    6.991927] snd_hda_intel 0000:65:00.6: enabling device (0000 -> 0002)
[    7.006882] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: Cirrus Logic CS35L41 (35a40), Revision: B2
[    7.007146] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: Adding DSD properties for 17AA38B6
[    7.007259] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: Using extra _DSD properties, bypassing _DSD in ACPI
[    7.007262] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: Reset line busy, assuming shared reset
[    7.028980] usbcore: registered new interface driver uvcvideo
[    7.041865] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: Cirrus Logic CS35L41 (35a40), Revision: B2
[    7.045247] snd_hda_intel 0000:65:00.1: bound 0000:65:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[    7.050622] kvm_amd: TSC scaling supported
[    7.050624] kvm_amd: Nested Virtualization enabled
[    7.050625] kvm_amd: Nested Paging enabled
[    7.050626] kvm_amd: LBR virtualization supported
[    7.050633] kvm_amd: Virtual VMLOAD VMSAVE supported
[    7.050633] kvm_amd: Virtual GIF supported
[    7.050633] kvm_amd: Virtual NMI enabled
[    7.054376] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:65:00.1/sound/card1/input13
[    7.054416] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input17
[    7.058869] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: DSP1: Firmware version: 3
[    7.058872] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: DSP1: cirrus/cs35l41-dsp1-spk-prot-17aa38b6.wmfw: Fri 27 Aug 2021 14:58:19 W. Europe Daylight Time
[    7.061715] snd_pci_ps 0000:65:00.5: enabling device (0000 -> 0002)
[    7.070650] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input18
[    7.070653] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:65:00.1/sound/card1/input14
[    7.070707] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input19
[    7.070775] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:65:00.1/sound/card1/input15
[    7.070874] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input20
[    7.070874] input: HD-Audio Generic HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:08.1/0000:65:00.1/sound/card1/input16
[    7.080223] input: ELAN06FA:00 04F3:3280 Mouse as /devices/platform/AMDI0010:00/i2c-0/i2c-ELAN06FA:00/0018:04F3:3280.0002/input/input21
[    7.080287] input: ELAN06FA:00 04F3:3280 Touchpad as /devices/platform/AMDI0010:00/i2c-0/i2c-ELAN06FA:00/0018:04F3:3280.0002/input/input23
[    7.080343] hid-multitouch 0018:04F3:3280.0002: input,hidraw1: I2C HID v1.00 Mouse [ELAN06FA:00 04F3:3280] on i2c-ELAN06FA:00
[    7.085205] mousedev: PS/2 mouse device common for all mice
[    7.087271] mt7921e 0000:03:00.0: enabling device (0000 -> 0002)
[    7.089129] Bluetooth: hci0: Device setup in 122845 usecs
[    7.089132] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[    7.092509] mt7921e 0000:03:00.0: ASIC revision: 79220010
[    7.147879] Bluetooth: hci0: AOSP extensions version v1.00
[    7.147884] Bluetooth: hci0: AOSP quality report is supported
[    7.175372] mt7921e 0000:03:00.0: HW/SW Version: 0x8a108a10, Build Time: 20240409163301a
[    7.189923] mt7921e 0000:03:00.0: WM Firmware Version: ____000000, Build Time: 20240409163347
[    7.190833] intel_rapl_common: Found RAPL domain package
[    7.190835] intel_rapl_common: Found RAPL domain core
[    7.191189] AMD Address Translation Library initialized
[    7.538051] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: DSP1: Firmware: 400a4 vendor: 0x2 v0.43.1, 2 algorithms
[    7.539299] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: DSP1: cirrus/cs35l41-dsp1-spk-prot-17aa38b6-spkid0-l0.bin: v0.43.1
[    7.539307] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: DSP1: spk-prot: C:\Users\Administrator\Desktop\Y780S_PDL18-left.bin
[    7.620176] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: Calibration applied: R0=5954
[    7.633561] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: Firmware Loaded - Type: spk-prot, Gain: 17
[    7.633631] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: CS35L41 Bound - SSID: 17AA38B6, BST: 1, VSPK: 1, CH: L, FW EN: 1, SPKID: 0
[    7.633636] snd_hda_codec_realtek hdaudioC2D0: bound i2c-CSC3551:00-cs35l41-hda.0 (ops cs35l41_hda_comp_ops [snd_hda_scodec_cs35l41])
[    7.634539] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: DSP1: Firmware version: 3
[    7.634541] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: DSP1: cirrus/cs35l41-dsp1-spk-prot-17aa38b6.wmfw: Fri 27 Aug 2021 14:58:19 W. Europe Daylight Time
[    7.634928] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19398987
[    7.636132] ext4_test_bit(bit=330, block=77594640) = 0
[    7.636811] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399012
[    7.637453] ext4_test_bit(bit=355, block=77594640) = 0
[    7.638264] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399013
[    7.639433] ext4_test_bit(bit=356, block=77594640) = 0
[    7.640637] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399014
[    7.641341] ext4_test_bit(bit=357, block=77594640) = 0
[    7.642010] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399009
[    7.642659] ext4_test_bit(bit=352, block=77594640) = 0
[    7.643318] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19398986
[    7.644042] ext4_test_bit(bit=329, block=77594640) = 0
[    7.645350] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19398994
[    7.646213] ext4_test_bit(bit=337, block=77594640) = 0
[    7.646982] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19398995
[    7.647756] ext4_test_bit(bit=338, block=77594640) = 0
[    7.648509] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399000
[    7.650823] ext4_test_bit(bit=343, block=77594640) = 0
[    7.651707] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399001
[    7.652542] ext4_test_bit(bit=344, block=77594640) = 0
[    7.653347] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19398989
[    7.655661] ext4_test_bit(bit=332, block=77594640) = 0
[    7.656641] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19398990
[    7.657610] ext4_test_bit(bit=333, block=77594640) = 0
[    7.659874] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19398991
[    7.660820] ext4_test_bit(bit=334, block=77594640) = 0
[    7.661728] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399002
[    7.664192] ext4_test_bit(bit=345, block=77594640) = 0
[    7.665214] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19398988
[    7.667535] ext4_test_bit(bit=331, block=77594640) = 0
[    7.668340] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19398981
[    7.669204] ext4_test_bit(bit=324, block=77594640) = 0
[    7.672005] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19398983
[    7.673135] ext4_test_bit(bit=326, block=77594640) = 0
[    7.674534] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19398985
[    7.676648] ext4_test_bit(bit=328, block=77594640) = 0
[    7.677767] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399004
[    7.679157] ext4_test_bit(bit=347, block=77594640) = 0
[    7.681235] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399005
[    7.684235] ext4_test_bit(bit=348, block=77594640) = 0
[    7.685862] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399283
[    7.688317] ext4_test_bit(bit=626, block=77594640) = 0
[    7.689880] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399294
[    7.692558] ext4_test_bit(bit=637, block=77594640) = 0
[    7.694265] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399295
[    7.696834] ext4_test_bit(bit=638, block=77594640) = 0
[    7.698544] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399296
[    7.700910] ext4_test_bit(bit=639, block=77594640) = 0
[    7.702024] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399297
[    7.703412] ext4_test_bit(bit=640, block=77594640) = 0
[    7.704402] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399298
[    7.705499] ext4_test_bit(bit=641, block=77594640) = 0
[    7.707118] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19401000
[    7.709565] ext4_test_bit(bit=2343, block=77594640) = 0
[    7.711356] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399333
[    7.713797] ext4_test_bit(bit=676, block=77594640) = 0
[    7.715639] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399334
[    7.718065] ext4_test_bit(bit=677, block=77594640) = 0
[    7.719927] EXT4-fs error (device nvme1n1p4): ext4_orphan_get:1420: comm mount: bad orphan inode 19399335
[    7.722027] ext4_test_bit(bit=678, block=77594640) = 0
[    7.724073] EXT4-fs (nvme1n1p4): recovery complete
[    7.725360] EXT4-fs (nvme1n1p4): mounted filesystem a807d0b8-4c5e-45a9-a712-a896c5419a6e r/w with ordered data mode. Quota mode: none.
[    7.948553] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.948560] Bluetooth: BNEP filters: protocol multicast
[    7.948569] Bluetooth: BNEP socket layer initialized
[    7.949513] Bluetooth: MGMT ver 1.22
[    7.953245] NET: Registered PF_ALG protocol family
[    7.992866] NET: Registered PF_QIPCRTR protocol family
[    8.112675] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: DSP1: Firmware: 400a4 vendor: 0x2 v0.43.1, 2 algorithms
[    8.113869] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: DSP1: cirrus/cs35l41-dsp1-spk-prot-17aa38b6-spkid0-r0.bin: v0.43.1
[    8.113888] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: DSP1: spk-prot: C:\Users\Administrator\Desktop\Y780S_PDL18-right.bin
[    8.193930] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: Calibration applied: R0=6256
[    8.207809] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: Firmware Loaded - Type: spk-prot, Gain: 17
[    8.207859] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: CS35L41 Bound - SSID: 17AA38B6, BST: 1, VSPK: 1, CH: R, FW EN: 1, SPKID: 0
[    8.207865] snd_hda_codec_realtek hdaudioC2D0: bound i2c-CSC3551:00-cs35l41-hda.1 (ops cs35l41_hda_comp_ops [snd_hda_scodec_cs35l41])
[    8.208494] snd_hda_codec_realtek hdaudioC2D0: autoconfig for ALC287: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[    8.208499] snd_hda_codec_realtek hdaudioC2D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    8.208502] snd_hda_codec_realtek hdaudioC2D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    8.208505] snd_hda_codec_realtek hdaudioC2D0:    mono: mono_out=0x0
[    8.208507] snd_hda_codec_realtek hdaudioC2D0:    inputs:
[    8.208511] snd_hda_codec_realtek hdaudioC2D0:      Mic=0x19
[    8.208514] snd_hda_codec_realtek hdaudioC2D0:      Internal Mic=0x12
[    8.256502] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:65:00.6/sound/card2/input24
[    8.256591] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:65:00.6/sound/card2/input25
[    8.317552] mt7921e 0000:03:00.0 wlo1: renamed from wlan0
[   10.346807] block nvme0n1: No UUID available providing old NGUID
[   11.524622] wlo1: authenticate with 82:fb:34:01:ba:f2 (local address=14:ac:60:33:15:99)
[   11.674501] wlo1: send auth to 82:fb:34:01:ba:f2 (try 1/3)
[   11.777243] wlo1: send auth to 82:fb:34:01:ba:f2 (try 2/3)
[   11.782954] wlo1: authenticated
[   11.783835] wlo1: associate with 82:fb:34:01:ba:f2 (try 1/3)
[   11.803730] wlo1: RX AssocResp from 82:fb:34:01:ba:f2 (capab=0x1431 status=0 aid=8)
[   11.833970] wlo1: associated
[   14.424435] systemd-journald[439]: File /var/log/journal/7c8261220c8e4cd0822280fcb619d5b8/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[   15.331726] Bluetooth: RFCOMM TTY layer initialized
[   15.331747] Bluetooth: RFCOMM socket layer initialized
[   15.331751] Bluetooth: RFCOMM ver 1.11
[   15.670620] warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[   23.387232] ------------[ cut here ]------------
[   23.387241] WARNING: CPU: 4 PID: 231 at include/linux/rwsem.h:80 follow_pte+0x1de/0x200
[   23.387256] Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm ccm qrtr cmac algif_hash algif_skcipher af_alg bnep amd_atl intel_rapl_msr intel_rapl_common snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir mousedev snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_pci_ps snd_amd_sdw_acpi soundwire_amd snd_hda_codec_realtek soundwire_generic_allocation snd_hda_codec_generic kvm_amd soundwire_bus snd_hda_scodec_cs35l41_spi snd_hda_scodec_component snd_hda_codec_hdmi snd_soc_core snd_hda_intel snd_compress kvm ac97_bus snd_intel_dspcfg mt7921e snd_pcm_dmaengine snd_intel_sdw_acpi mt7921_common uvcvideo snd_rpl_pci_acp6x hid_multitouch crct10dif_pclmul snd_hda_codec mt792x_lib snd_acp_pci crc32_pclmul videobuf2_vmalloc mt76_connac_lib snd_hda_scodec_cs35l41_i2c snd_acp_legacy_common uvc polyval_clmulni snd_hda_core btusb snd_pci_acp6x polyval_generic videobuf2_memops snd_hda_scodec_cs35l41 snd_hwdep mt76 btrtl gf128mul snd_pci_acp5x videobuf2_v4l2
[   23.387398]  snd_hda_cs_dsp_ctls ghash_clmulni_intel snd_rn_pci_acp3x snd_pcm videodev btintel sha512_ssse3 snd_soc_cs_amp_lib sha256_ssse3 snd_acp_config cs_dsp btbcm ucsi_acpi mac80211 videobuf2_common sha1_ssse3 snd_soc_acpi snd_timer btmtk snd_soc_cs35l41_lib sp5100_tco typec_ucsi ideapad_laptop vfat libarc4 aesni_intel crypto_simd fat cryptd bluetooth rapl pcspkr wmi_bmof platform_profile nvidia_wmi_ec_backlight typec thunderbolt snd sparse_keymap cfg80211 mc i2c_piix4 k10temp snd_pci_acp3x ccp soundcore joydev roles rfkill i2c_hid_acpi serial_multi_instantiate i2c_hid amd_pmc mac_hid uinput i2c_dev crypto_user loop dm_mod nfnetlink ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid amdgpu amdxcp i2c_algo_bit rtsx_pci_sdmmc drm_ttm_helper serio_raw atkbd ttm mmc_core libps2 drm_exec gpu_sched vivaldi_fmap nvme drm_suballoc_helper drm_buddy nvme_core xhci_pci crc32c_intel drm_display_helper i8042 rtsx_pci xhci_pci_renesas nvme_auth serio nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE)
[   23.387582]  video wmi nvidia(POE)
[   23.387592] CPU: 4 PID: 231 Comm: nv_queue Tainted: P        W  OE      6.10.0-rc3-1-MANJARO #1 48aec18d75cf2ff8be45a638398f02cc8fe7b0e4
[   23.387599] Hardware name: LENOVO 82Y4/LNVNB161216, BIOS M1CN40WW 04/24/2024
[   23.387603] RIP: 0010:follow_pte+0x1de/0x200
[   23.387609] Code: ba da 00 48 81 e2 00 00 00 c0 48 09 c2 48 f7 d2 48 85 fa 75 20 e8 d2 f5 ff ff 48 8b 35 fb 99 5d 01 48 81 e6 00 00 00 c0 eb 8d <0f> 0b 48 3b 1f 0f 83 50 fe ff ff bd ea ff ff ff eb b6 49 8b 3c 24
[   23.387613] RSP: 0018:ffffadd945823b60 EFLAGS: 00010246
[   23.387619] RAX: 0000000000000000 RBX: 00007cfaa7890000 RCX: ffffadd945823ba0
[   23.387623] RDX: ffffadd945823b98 RSI: 00007cfaa7890000 RDI: ffff8f0285971590
[   23.387626] RBP: ffffadd945823be0 R08: ffffadd945823d38 R09: 0000000000000000
[   23.387629] R10: 0000000000000001 R11: 0000000000000003 R12: ffffadd945823ba0
[   23.387632] R13: ffffadd945823b98 R14: ffff8f029ad03180 R15: 0000000000000000
[   23.387636] FS:  0000000000000000(0000) GS:ffff8f09be400000(0000) knlGS:0000000000000000
[   23.387640] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   23.387644] CR2: 00005ae2af214000 CR3: 00000002f4420000 CR4: 0000000000f50ef0
[   23.387648] PKRU: 55555554
[   23.387651] Call Trace:
[   23.387655]  <TASK>
[   23.387658]  ? follow_pte+0x1de/0x200
[   23.387663]  ? __warn.cold+0x8e/0xe8
[   23.387670]  ? follow_pte+0x1de/0x200
[   23.387680]  ? report_bug+0xff/0x140
[   23.387690]  ? handle_bug+0x3c/0x80
[   23.387698]  ? exc_invalid_op+0x17/0x70
[   23.387704]  ? asm_exc_invalid_op+0x1a/0x20
[   23.387715]  ? follow_pte+0x1de/0x200
[   23.387723]  follow_phys+0x49/0x110
[   23.387733]  untrack_pfn+0x55/0x120
[   23.387742]  unmap_single_vma+0xa6/0xe0
[   23.387750]  zap_page_range_single+0x122/0x1d0
[   23.387764]  unmap_mapping_range+0x116/0x140
[   23.387774]  ? __pfx__main_loop+0x10/0x10 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.388125]  nv_revoke_gpu_mappings+0x67/0xb0 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.388477]  _nv000708rm+0x35/0x100 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.388834]  rm_execute_work_item+0xea/0x130 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.389064]  os_execute_work_item+0x5e/0x80 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.389217]  _main_loop+0x95/0x150 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.389362]  kthread+0xcf/0x100
[   23.389365]  ? __pfx_kthread+0x10/0x10
[   23.389368]  ret_from_fork+0x31/0x50
[   23.389372]  ? __pfx_kthread+0x10/0x10
[   23.389374]  ret_from_fork_asm+0x1a/0x30
[   23.389381]  </TASK>
[   23.389382] ---[ end trace 0000000000000000 ]---
[   23.389399] ------------[ cut here ]------------
[   23.389400] WARNING: CPU: 4 PID: 231 at include/linux/rwsem.h:80 follow_pte+0x1de/0x200
[   23.389403] Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm ccm qrtr cmac algif_hash algif_skcipher af_alg bnep amd_atl intel_rapl_msr intel_rapl_common snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir mousedev snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_pci_ps snd_amd_sdw_acpi soundwire_amd snd_hda_codec_realtek soundwire_generic_allocation snd_hda_codec_generic kvm_amd soundwire_bus snd_hda_scodec_cs35l41_spi snd_hda_scodec_component snd_hda_codec_hdmi snd_soc_core snd_hda_intel snd_compress kvm ac97_bus snd_intel_dspcfg mt7921e snd_pcm_dmaengine snd_intel_sdw_acpi mt7921_common uvcvideo snd_rpl_pci_acp6x hid_multitouch crct10dif_pclmul snd_hda_codec mt792x_lib snd_acp_pci crc32_pclmul videobuf2_vmalloc mt76_connac_lib snd_hda_scodec_cs35l41_i2c snd_acp_legacy_common uvc polyval_clmulni snd_hda_core btusb snd_pci_acp6x polyval_generic videobuf2_memops snd_hda_scodec_cs35l41 snd_hwdep mt76 btrtl gf128mul snd_pci_acp5x videobuf2_v4l2
[   23.389452]  snd_hda_cs_dsp_ctls ghash_clmulni_intel snd_rn_pci_acp3x snd_pcm videodev btintel sha512_ssse3 snd_soc_cs_amp_lib sha256_ssse3 snd_acp_config cs_dsp btbcm ucsi_acpi mac80211 videobuf2_common sha1_ssse3 snd_soc_acpi snd_timer btmtk snd_soc_cs35l41_lib sp5100_tco typec_ucsi ideapad_laptop vfat libarc4 aesni_intel crypto_simd fat cryptd bluetooth rapl pcspkr wmi_bmof platform_profile nvidia_wmi_ec_backlight typec thunderbolt snd sparse_keymap cfg80211 mc i2c_piix4 k10temp snd_pci_acp3x ccp soundcore joydev roles rfkill i2c_hid_acpi serial_multi_instantiate i2c_hid amd_pmc mac_hid uinput i2c_dev crypto_user loop dm_mod nfnetlink ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid amdgpu amdxcp i2c_algo_bit rtsx_pci_sdmmc drm_ttm_helper serio_raw atkbd ttm mmc_core libps2 drm_exec gpu_sched vivaldi_fmap nvme drm_suballoc_helper drm_buddy nvme_core xhci_pci crc32c_intel drm_display_helper i8042 rtsx_pci xhci_pci_renesas nvme_auth serio nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE)
[   23.389516]  video wmi nvidia(POE)
[   23.389519] CPU: 4 PID: 231 Comm: nv_queue Tainted: P        W  OE      6.10.0-rc3-1-MANJARO #1 48aec18d75cf2ff8be45a638398f02cc8fe7b0e4
[   23.389522] Hardware name: LENOVO 82Y4/LNVNB161216, BIOS M1CN40WW 04/24/2024
[   23.389523] RIP: 0010:follow_pte+0x1de/0x200
[   23.389525] Code: ba da 00 48 81 e2 00 00 00 c0 48 09 c2 48 f7 d2 48 85 fa 75 20 e8 d2 f5 ff ff 48 8b 35 fb 99 5d 01 48 81 e6 00 00 00 c0 eb 8d <0f> 0b 48 3b 1f 0f 83 50 fe ff ff bd ea ff ff ff eb b6 49 8b 3c 24
[   23.389527] RSP: 0018:ffffadd945823b60 EFLAGS: 00010246
[   23.389529] RAX: 0000000000000000 RBX: 00007cfab27a2000 RCX: ffffadd945823ba0
[   23.389531] RDX: ffffadd945823b98 RSI: 00007cfab27a2000 RDI: ffff8f028a3d0e60
[   23.389532] RBP: ffffadd945823be0 R08: ffffadd945823d38 R09: 0000000000000000
[   23.389533] R10: 0000000000000200 R11: 0000000000000003 R12: ffffadd945823ba0
[   23.389535] R13: ffffadd945823b98 R14: ffff8f029ad03180 R15: 0000000000000000
[   23.389536] FS:  0000000000000000(0000) GS:ffff8f09be400000(0000) knlGS:0000000000000000
[   23.389538] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   23.389539] CR2: 00005ae2af214000 CR3: 00000002f4420000 CR4: 0000000000f50ef0
[   23.389541] PKRU: 55555554
[   23.389542] Call Trace:
[   23.389543]  <TASK>
[   23.389544]  ? follow_pte+0x1de/0x200
[   23.389546]  ? __warn.cold+0x8e/0xe8
[   23.389549]  ? follow_pte+0x1de/0x200
[   23.389551]  ? report_bug+0xff/0x140
[   23.389555]  ? handle_bug+0x3c/0x80
[   23.389557]  ? exc_invalid_op+0x17/0x70
[   23.389560]  ? asm_exc_invalid_op+0x1a/0x20
[   23.389565]  ? follow_pte+0x1de/0x200
[   23.389568]  follow_phys+0x49/0x110
[   23.389572]  untrack_pfn+0x55/0x120
[   23.389576]  unmap_single_vma+0xa6/0xe0
[   23.389579]  zap_page_range_single+0x122/0x1d0
[   23.389585]  unmap_mapping_range+0x116/0x140
[   23.389588]  ? __pfx__main_loop+0x10/0x10 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.389727]  nv_revoke_gpu_mappings+0x67/0xb0 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.389869]  _nv000708rm+0x35/0x100 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.390092]  rm_execute_work_item+0xea/0x130 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.390312]  os_execute_work_item+0x5e/0x80 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.390467]  _main_loop+0x95/0x150 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.390635]  kthread+0xcf/0x100
[   23.390638]  ? __pfx_kthread+0x10/0x10
[   23.390640]  ret_from_fork+0x31/0x50
[   23.390643]  ? __pfx_kthread+0x10/0x10
[   23.390645]  ret_from_fork_asm+0x1a/0x30
[   23.390650]  </TASK>
[   23.390651] ---[ end trace 0000000000000000 ]---
[   23.390671] ------------[ cut here ]------------
[   23.390672] WARNING: CPU: 4 PID: 231 at include/linux/rwsem.h:80 follow_pte+0x1de/0x200
[   23.390674] Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm ccm qrtr cmac algif_hash algif_skcipher af_alg bnep amd_atl intel_rapl_msr intel_rapl_common snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir mousedev snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_pci_ps snd_amd_sdw_acpi soundwire_amd snd_hda_codec_realtek soundwire_generic_allocation snd_hda_codec_generic kvm_amd soundwire_bus snd_hda_scodec_cs35l41_spi snd_hda_scodec_component snd_hda_codec_hdmi snd_soc_core snd_hda_intel snd_compress kvm ac97_bus snd_intel_dspcfg mt7921e snd_pcm_dmaengine snd_intel_sdw_acpi mt7921_common uvcvideo snd_rpl_pci_acp6x hid_multitouch crct10dif_pclmul snd_hda_codec mt792x_lib snd_acp_pci crc32_pclmul videobuf2_vmalloc mt76_connac_lib snd_hda_scodec_cs35l41_i2c snd_acp_legacy_common uvc polyval_clmulni snd_hda_core btusb snd_pci_acp6x polyval_generic videobuf2_memops snd_hda_scodec_cs35l41 snd_hwdep mt76 btrtl gf128mul snd_pci_acp5x videobuf2_v4l2
[   23.390722]  snd_hda_cs_dsp_ctls ghash_clmulni_intel snd_rn_pci_acp3x snd_pcm videodev btintel sha512_ssse3 snd_soc_cs_amp_lib sha256_ssse3 snd_acp_config cs_dsp btbcm ucsi_acpi mac80211 videobuf2_common sha1_ssse3 snd_soc_acpi snd_timer btmtk snd_soc_cs35l41_lib sp5100_tco typec_ucsi ideapad_laptop vfat libarc4 aesni_intel crypto_simd fat cryptd bluetooth rapl pcspkr wmi_bmof platform_profile nvidia_wmi_ec_backlight typec thunderbolt snd sparse_keymap cfg80211 mc i2c_piix4 k10temp snd_pci_acp3x ccp soundcore joydev roles rfkill i2c_hid_acpi serial_multi_instantiate i2c_hid amd_pmc mac_hid uinput i2c_dev crypto_user loop dm_mod nfnetlink ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid amdgpu amdxcp i2c_algo_bit rtsx_pci_sdmmc drm_ttm_helper serio_raw atkbd ttm mmc_core libps2 drm_exec gpu_sched vivaldi_fmap nvme drm_suballoc_helper drm_buddy nvme_core xhci_pci crc32c_intel drm_display_helper i8042 rtsx_pci xhci_pci_renesas nvme_auth serio nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE)
[   23.390785]  video wmi nvidia(POE)
[   23.390788] CPU: 4 PID: 231 Comm: nv_queue Tainted: P        W  OE      6.10.0-rc3-1-MANJARO #1 48aec18d75cf2ff8be45a638398f02cc8fe7b0e4
[   23.390790] Hardware name: LENOVO 82Y4/LNVNB161216, BIOS M1CN40WW 04/24/2024
[   23.390792] RIP: 0010:follow_pte+0x1de/0x200
[   23.390794] Code: ba da 00 48 81 e2 00 00 00 c0 48 09 c2 48 f7 d2 48 85 fa 75 20 e8 d2 f5 ff ff 48 8b 35 fb 99 5d 01 48 81 e6 00 00 00 c0 eb 8d <0f> 0b 48 3b 1f 0f 83 50 fe ff ff bd ea ff ff ff eb b6 49 8b 3c 24
[   23.390795] RSP: 0018:ffffadd945823b60 EFLAGS: 00010246
[   23.390797] RAX: 0000000000000000 RBX: 00007cfab26f9000 RCX: ffffadd945823ba0
[   23.390798] RDX: ffffadd945823b98 RSI: 00007cfab26f9000 RDI: ffff8f028a3d1368
[   23.390800] RBP: ffffadd945823be0 R08: ffffadd945823d38 R09: 0000000000000000
[   23.390801] R10: 0000000000000200 R11: 0000000000000003 R12: ffffadd945823ba0
[   23.390802] R13: ffffadd945823b98 R14: ffff8f029ad03180 R15: 0000000000000000
[   23.390804] FS:  0000000000000000(0000) GS:ffff8f09be400000(0000) knlGS:0000000000000000
[   23.390805] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   23.390807] CR2: 00005ae2af214000 CR3: 00000002f4420000 CR4: 0000000000f50ef0
[   23.390808] PKRU: 55555554
[   23.390809] Call Trace:
[   23.390811]  <TASK>
[   23.390812]  ? follow_pte+0x1de/0x200
[   23.390813]  ? __warn.cold+0x8e/0xe8
[   23.390816]  ? follow_pte+0x1de/0x200
[   23.390818]  ? report_bug+0xff/0x140
[   23.390822]  ? handle_bug+0x3c/0x80
[   23.390825]  ? exc_invalid_op+0x17/0x70
[   23.390827]  ? asm_exc_invalid_op+0x1a/0x20
[   23.390832]  ? follow_pte+0x1de/0x200
[   23.390835]  follow_phys+0x49/0x110
[   23.390839]  untrack_pfn+0x55/0x120
[   23.390842]  unmap_single_vma+0xa6/0xe0
[   23.390845]  zap_page_range_single+0x122/0x1d0
[   23.390851]  unmap_mapping_range+0x116/0x140
[   23.390855]  ? __pfx__main_loop+0x10/0x10 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.390993]  nv_revoke_gpu_mappings+0x67/0xb0 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.391134]  _nv000708rm+0x35/0x100 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.391351]  rm_execute_work_item+0xea/0x130 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.391571]  os_execute_work_item+0x5e/0x80 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.391711]  _main_loop+0x95/0x150 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.391852]  kthread+0xcf/0x100
[   23.391854]  ? __pfx_kthread+0x10/0x10
[   23.391857]  ret_from_fork+0x31/0x50
[   23.391859]  ? __pfx_kthread+0x10/0x10
[   23.391861]  ret_from_fork_asm+0x1a/0x30
[   23.391867]  </TASK>
[   23.391868] ---[ end trace 0000000000000000 ]---
[   23.391874] ------------[ cut here ]------------
[   23.391875] WARNING: CPU: 4 PID: 231 at include/linux/rwsem.h:80 follow_pte+0x1de/0x200
[   23.391877] Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm ccm qrtr cmac algif_hash algif_skcipher af_alg bnep amd_atl intel_rapl_msr intel_rapl_common snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir mousedev snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_pci_ps snd_amd_sdw_acpi soundwire_amd snd_hda_codec_realtek soundwire_generic_allocation snd_hda_codec_generic kvm_amd soundwire_bus snd_hda_scodec_cs35l41_spi snd_hda_scodec_component snd_hda_codec_hdmi snd_soc_core snd_hda_intel snd_compress kvm ac97_bus snd_intel_dspcfg mt7921e snd_pcm_dmaengine snd_intel_sdw_acpi mt7921_common uvcvideo snd_rpl_pci_acp6x hid_multitouch crct10dif_pclmul snd_hda_codec mt792x_lib snd_acp_pci crc32_pclmul videobuf2_vmalloc mt76_connac_lib snd_hda_scodec_cs35l41_i2c snd_acp_legacy_common uvc polyval_clmulni snd_hda_core btusb snd_pci_acp6x polyval_generic videobuf2_memops snd_hda_scodec_cs35l41 snd_hwdep mt76 btrtl gf128mul snd_pci_acp5x videobuf2_v4l2
[   23.391925]  snd_hda_cs_dsp_ctls ghash_clmulni_intel snd_rn_pci_acp3x snd_pcm videodev btintel sha512_ssse3 snd_soc_cs_amp_lib sha256_ssse3 snd_acp_config cs_dsp btbcm ucsi_acpi mac80211 videobuf2_common sha1_ssse3 snd_soc_acpi snd_timer btmtk snd_soc_cs35l41_lib sp5100_tco typec_ucsi ideapad_laptop vfat libarc4 aesni_intel crypto_simd fat cryptd bluetooth rapl pcspkr wmi_bmof platform_profile nvidia_wmi_ec_backlight typec thunderbolt snd sparse_keymap cfg80211 mc i2c_piix4 k10temp snd_pci_acp3x ccp soundcore joydev roles rfkill i2c_hid_acpi serial_multi_instantiate i2c_hid amd_pmc mac_hid uinput i2c_dev crypto_user loop dm_mod nfnetlink ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid amdgpu amdxcp i2c_algo_bit rtsx_pci_sdmmc drm_ttm_helper serio_raw atkbd ttm mmc_core libps2 drm_exec gpu_sched vivaldi_fmap nvme drm_suballoc_helper drm_buddy nvme_core xhci_pci crc32c_intel drm_display_helper i8042 rtsx_pci xhci_pci_renesas nvme_auth serio nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE)
[   23.391988]  video wmi nvidia(POE)
[   23.391992] CPU: 4 PID: 231 Comm: nv_queue Tainted: P        W  OE      6.10.0-rc3-1-MANJARO #1 48aec18d75cf2ff8be45a638398f02cc8fe7b0e4
[   23.391994] Hardware name: LENOVO 82Y4/LNVNB161216, BIOS M1CN40WW 04/24/2024
[   23.391995] RIP: 0010:follow_pte+0x1de/0x200
[   23.391997] Code: ba da 00 48 81 e2 00 00 00 c0 48 09 c2 48 f7 d2 48 85 fa 75 20 e8 d2 f5 ff ff 48 8b 35 fb 99 5d 01 48 81 e6 00 00 00 c0 eb 8d <0f> 0b 48 3b 1f 0f 83 50 fe ff ff bd ea ff ff ff eb b6 49 8b 3c 24
[   23.391998] RSP: 0018:ffffadd945823b60 EFLAGS: 00010246
[   23.392000] RAX: 0000000000000000 RBX: 00007cfab27a3000 RCX: ffffadd945823ba0
[   23.392001] RDX: ffffadd945823b98 RSI: 00007cfab27a3000 RDI: ffff8f028a3d1b50
[   23.392003] RBP: ffffadd945823be0 R08: ffffadd945823d38 R09: 0000000000000000
[   23.392004] R10: 0000000000000200 R11: 0000000000000003 R12: ffffadd945823ba0
[   23.392005] R13: ffffadd945823b98 R14: ffff8f029ad03180 R15: 0000000000000000
[   23.392007] FS:  0000000000000000(0000) GS:ffff8f09be400000(0000) knlGS:0000000000000000
[   23.392008] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   23.392010] CR2: 00005ae2af214000 CR3: 00000002f4420000 CR4: 0000000000f50ef0
[   23.392011] PKRU: 55555554
[   23.392012] Call Trace:
[   23.392013]  <TASK>
[   23.392014]  ? follow_pte+0x1de/0x200
[   23.392016]  ? __warn.cold+0x8e/0xe8
[   23.392018]  ? follow_pte+0x1de/0x200
[   23.392021]  ? report_bug+0xff/0x140
[   23.392024]  ? handle_bug+0x3c/0x80
[   23.392027]  ? exc_invalid_op+0x17/0x70
[   23.392029]  ? asm_exc_invalid_op+0x1a/0x20
[   23.392034]  ? follow_pte+0x1de/0x200
[   23.392037]  follow_phys+0x49/0x110
[   23.392041]  untrack_pfn+0x55/0x120
[   23.392044]  unmap_single_vma+0xa6/0xe0
[   23.392047]  zap_page_range_single+0x122/0x1d0
[   23.392053]  unmap_mapping_range+0x116/0x140
[   23.392057]  ? __pfx__main_loop+0x10/0x10 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.392200]  nv_revoke_gpu_mappings+0x67/0xb0 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.392342]  _nv000708rm+0x35/0x100 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.392561]  rm_execute_work_item+0xea/0x130 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.392774]  os_execute_work_item+0x5e/0x80 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.392916]  _main_loop+0x95/0x150 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.393060]  kthread+0xcf/0x100
[   23.393062]  ? __pfx_kthread+0x10/0x10
[   23.393065]  ret_from_fork+0x31/0x50
[   23.393067]  ? __pfx_kthread+0x10/0x10
[   23.393070]  ret_from_fork_asm+0x1a/0x30
[   23.393075]  </TASK>
[   23.393076] ---[ end trace 0000000000000000 ]---
[   23.393085] ------------[ cut here ]------------
[   23.393086] WARNING: CPU: 4 PID: 231 at include/linux/rwsem.h:80 follow_pte+0x1de/0x200
[   23.393088] Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm ccm qrtr cmac algif_hash algif_skcipher af_alg bnep amd_atl intel_rapl_msr intel_rapl_common snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir mousedev snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_pci_ps snd_amd_sdw_acpi soundwire_amd snd_hda_codec_realtek soundwire_generic_allocation snd_hda_codec_generic kvm_amd soundwire_bus snd_hda_scodec_cs35l41_spi snd_hda_scodec_component snd_hda_codec_hdmi snd_soc_core snd_hda_intel snd_compress kvm ac97_bus snd_intel_dspcfg mt7921e snd_pcm_dmaengine snd_intel_sdw_acpi mt7921_common uvcvideo snd_rpl_pci_acp6x hid_multitouch crct10dif_pclmul snd_hda_codec mt792x_lib snd_acp_pci crc32_pclmul videobuf2_vmalloc mt76_connac_lib snd_hda_scodec_cs35l41_i2c snd_acp_legacy_common uvc polyval_clmulni snd_hda_core btusb snd_pci_acp6x polyval_generic videobuf2_memops snd_hda_scodec_cs35l41 snd_hwdep mt76 btrtl gf128mul snd_pci_acp5x videobuf2_v4l2
[   23.393136]  snd_hda_cs_dsp_ctls ghash_clmulni_intel snd_rn_pci_acp3x snd_pcm videodev btintel sha512_ssse3 snd_soc_cs_amp_lib sha256_ssse3 snd_acp_config cs_dsp btbcm ucsi_acpi mac80211 videobuf2_common sha1_ssse3 snd_soc_acpi snd_timer btmtk snd_soc_cs35l41_lib sp5100_tco typec_ucsi ideapad_laptop vfat libarc4 aesni_intel crypto_simd fat cryptd bluetooth rapl pcspkr wmi_bmof platform_profile nvidia_wmi_ec_backlight typec thunderbolt snd sparse_keymap cfg80211 mc i2c_piix4 k10temp snd_pci_acp3x ccp soundcore joydev roles rfkill i2c_hid_acpi serial_multi_instantiate i2c_hid amd_pmc mac_hid uinput i2c_dev crypto_user loop dm_mod nfnetlink ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid amdgpu amdxcp i2c_algo_bit rtsx_pci_sdmmc drm_ttm_helper serio_raw atkbd ttm mmc_core libps2 drm_exec gpu_sched vivaldi_fmap nvme drm_suballoc_helper drm_buddy nvme_core xhci_pci crc32c_intel drm_display_helper i8042 rtsx_pci xhci_pci_renesas nvme_auth serio nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE)
[   23.393199]  video wmi nvidia(POE)
[   23.393202] CPU: 4 PID: 231 Comm: nv_queue Tainted: P        W  OE      6.10.0-rc3-1-MANJARO #1 48aec18d75cf2ff8be45a638398f02cc8fe7b0e4
[   23.393204] Hardware name: LENOVO 82Y4/LNVNB161216, BIOS M1CN40WW 04/24/2024
[   23.393205] RIP: 0010:follow_pte+0x1de/0x200
[   23.393207] Code: ba da 00 48 81 e2 00 00 00 c0 48 09 c2 48 f7 d2 48 85 fa 75 20 e8 d2 f5 ff ff 48 8b 35 fb 99 5d 01 48 81 e6 00 00 00 c0 eb 8d <0f> 0b 48 3b 1f 0f 83 50 fe ff ff bd ea ff ff ff eb b6 49 8b 3c 24
[   23.393209] RSP: 0018:ffffadd945823b60 EFLAGS: 00010246
[   23.393211] RAX: 0000000000000000 RBX: 00007cfab27b8000 RCX: ffffadd945823ba0
[   23.393212] RDX: ffffadd945823b98 RSI: 00007cfab27b8000 RDI: ffff8f02ae174170
[   23.393213] RBP: ffffadd945823be0 R08: ffffadd945823d38 R09: 0000000000000000
[   23.393215] R10: 0000000000000200 R11: 0000000000000003 R12: ffffadd945823ba0
[   23.393216] R13: ffffadd945823b98 R14: ffff8f029ad03180 R15: 0000000000000000
[   23.393217] FS:  0000000000000000(0000) GS:ffff8f09be400000(0000) knlGS:0000000000000000
[   23.393219] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   23.393220] CR2: 00005ae2af214000 CR3: 00000002f4420000 CR4: 0000000000f50ef0
[   23.393222] PKRU: 55555554
[   23.393223] Call Trace:
[   23.393224]  <TASK>
[   23.393225]  ? follow_pte+0x1de/0x200
[   23.393226]  ? __warn.cold+0x8e/0xe8
[   23.393229]  ? follow_pte+0x1de/0x200
[   23.393231]  ? report_bug+0xff/0x140
[   23.393235]  ? handle_bug+0x3c/0x80
[   23.393238]  ? exc_invalid_op+0x17/0x70
[   23.393240]  ? asm_exc_invalid_op+0x1a/0x20
[   23.393245]  ? follow_pte+0x1de/0x200
[   23.393248]  follow_phys+0x49/0x110
[   23.393251]  untrack_pfn+0x55/0x120
[   23.393255]  unmap_single_vma+0xa6/0xe0
[   23.393258]  zap_page_range_single+0x122/0x1d0
[   23.393264]  unmap_mapping_range+0x116/0x140
[   23.393268]  ? __pfx__main_loop+0x10/0x10 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.393415]  nv_revoke_gpu_mappings+0x67/0xb0 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.393555]  _nv000708rm+0x35/0x100 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.393775]  rm_execute_work_item+0xea/0x130 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.393996]  os_execute_work_item+0x5e/0x80 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.394141]  _main_loop+0x95/0x150 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.394283]  kthread+0xcf/0x100
[   23.394285]  ? __pfx_kthread+0x10/0x10
[   23.394288]  ret_from_fork+0x31/0x50
[   23.394290]  ? __pfx_kthread+0x10/0x10
[   23.394292]  ret_from_fork_asm+0x1a/0x30
[   23.394297]  </TASK>
[   23.394298] ---[ end trace 0000000000000000 ]---
[   23.394341] ------------[ cut here ]------------
[   23.394343] WARNING: CPU: 8 PID: 231 at include/linux/rwsem.h:80 follow_pte+0x1de/0x200
[   23.394348] Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm ccm qrtr cmac algif_hash algif_skcipher af_alg bnep amd_atl intel_rapl_msr intel_rapl_common snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir mousedev snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_pci_ps snd_amd_sdw_acpi soundwire_amd snd_hda_codec_realtek soundwire_generic_allocation snd_hda_codec_generic kvm_amd soundwire_bus snd_hda_scodec_cs35l41_spi snd_hda_scodec_component snd_hda_codec_hdmi snd_soc_core snd_hda_intel snd_compress kvm ac97_bus snd_intel_dspcfg mt7921e snd_pcm_dmaengine snd_intel_sdw_acpi mt7921_common uvcvideo snd_rpl_pci_acp6x hid_multitouch crct10dif_pclmul snd_hda_codec mt792x_lib snd_acp_pci crc32_pclmul videobuf2_vmalloc mt76_connac_lib snd_hda_scodec_cs35l41_i2c snd_acp_legacy_common uvc polyval_clmulni snd_hda_core btusb snd_pci_acp6x polyval_generic videobuf2_memops snd_hda_scodec_cs35l41 snd_hwdep mt76 btrtl gf128mul snd_pci_acp5x videobuf2_v4l2
[   23.394399]  snd_hda_cs_dsp_ctls ghash_clmulni_intel snd_rn_pci_acp3x snd_pcm videodev btintel sha512_ssse3 snd_soc_cs_amp_lib sha256_ssse3 snd_acp_config cs_dsp btbcm ucsi_acpi mac80211 videobuf2_common sha1_ssse3 snd_soc_acpi snd_timer btmtk snd_soc_cs35l41_lib sp5100_tco typec_ucsi ideapad_laptop vfat libarc4 aesni_intel crypto_simd fat cryptd bluetooth rapl pcspkr wmi_bmof platform_profile nvidia_wmi_ec_backlight typec thunderbolt snd sparse_keymap cfg80211 mc i2c_piix4 k10temp snd_pci_acp3x ccp soundcore joydev roles rfkill i2c_hid_acpi serial_multi_instantiate i2c_hid amd_pmc mac_hid uinput i2c_dev crypto_user loop dm_mod nfnetlink ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid amdgpu amdxcp i2c_algo_bit rtsx_pci_sdmmc drm_ttm_helper serio_raw atkbd ttm mmc_core libps2 drm_exec gpu_sched vivaldi_fmap nvme drm_suballoc_helper drm_buddy nvme_core xhci_pci crc32c_intel drm_display_helper i8042 rtsx_pci xhci_pci_renesas nvme_auth serio nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE)
[   23.394465]  video wmi nvidia(POE)
[   23.394468] CPU: 8 PID: 231 Comm: nv_queue Tainted: P        W  OE      6.10.0-rc3-1-MANJARO #1 48aec18d75cf2ff8be45a638398f02cc8fe7b0e4
[   23.394471] Hardware name: LENOVO 82Y4/LNVNB161216, BIOS M1CN40WW 04/24/2024
[   23.394473] RIP: 0010:follow_pte+0x1de/0x200
[   23.394475] Code: ba da 00 48 81 e2 00 00 00 c0 48 09 c2 48 f7 d2 48 85 fa 75 20 e8 d2 f5 ff ff 48 8b 35 fb 99 5d 01 48 81 e6 00 00 00 c0 eb 8d <0f> 0b 48 3b 1f 0f 83 50 fe ff ff bd ea ff ff ff eb b6 49 8b 3c 24
[   23.394477] RSP: 0018:ffffadd945823b60 EFLAGS: 00010246
[   23.394480] RAX: 0000000000000000 RBX: 00007cfab2697000 RCX: ffffadd945823ba0
[   23.394481] RDX: ffffadd945823b98 RSI: 00007cfab2697000 RDI: ffff8f02859ce958
[   23.394483] RBP: ffffadd945823be0 R08: ffffadd945823d38 R09: 0000000000000000
[   23.394484] R10: 0000000000000001 R11: 0000000000000003 R12: ffffadd945823ba0
[   23.394485] R13: ffffadd945823b98 R14: ffff8f029ad03180 R15: 0000000000000000
[   23.394487] FS:  0000000000000000(0000) GS:ffff8f09be600000(0000) knlGS:0000000000000000
[   23.394488] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   23.394490] CR2: 00007141aa4c8000 CR3: 00000002f4420000 CR4: 0000000000f50ef0
[   23.394492] PKRU: 55555554
[   23.394493] Call Trace:
[   23.394494]  <TASK>
[   23.394495]  ? follow_pte+0x1de/0x200
[   23.394497]  ? __warn.cold+0x8e/0xe8
[   23.394500]  ? follow_pte+0x1de/0x200
[   23.394503]  ? report_bug+0xff/0x140
[   23.394507]  ? handle_bug+0x3c/0x80
[   23.394510]  ? exc_invalid_op+0x17/0x70
[   23.394512]  ? asm_exc_invalid_op+0x1a/0x20
[   23.394517]  ? follow_pte+0x1de/0x200
[   23.394520]  follow_phys+0x49/0x110
[   23.394524]  untrack_pfn+0x55/0x120
[   23.394528]  unmap_single_vma+0xa6/0xe0
[   23.394531]  zap_page_range_single+0x122/0x1d0
[   23.394537]  unmap_mapping_range+0x116/0x140
[   23.394541]  ? __pfx__main_loop+0x10/0x10 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.394690]  nv_revoke_gpu_mappings+0x67/0xb0 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.394833]  _nv000708rm+0x35/0x100 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.395059]  rm_execute_work_item+0xea/0x130 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.395297]  os_execute_work_item+0x5e/0x80 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.395441]  _main_loop+0x95/0x150 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.395587]  kthread+0xcf/0x100
[   23.395589]  ? __pfx_kthread+0x10/0x10
[   23.395592]  ret_from_fork+0x31/0x50
[   23.395595]  ? __pfx_kthread+0x10/0x10
[   23.395597]  ret_from_fork_asm+0x1a/0x30
[   23.395602]  </TASK>
[   23.395603] ---[ end trace 0000000000000000 ]---
[   23.395610] ------------[ cut here ]------------
[   23.395611] WARNING: CPU: 8 PID: 231 at include/linux/rwsem.h:80 follow_pte+0x1de/0x200
[   23.395614] Modules linked in: snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm ccm qrtr cmac algif_hash algif_skcipher af_alg bnep amd_atl intel_rapl_msr intel_rapl_common snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir mousedev snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_pci_ps snd_amd_sdw_acpi soundwire_amd snd_hda_codec_realtek soundwire_generic_allocation snd_hda_codec_generic kvm_amd soundwire_bus snd_hda_scodec_cs35l41_spi snd_hda_scodec_component snd_hda_codec_hdmi snd_soc_core snd_hda_intel snd_compress kvm ac97_bus snd_intel_dspcfg mt7921e snd_pcm_dmaengine snd_intel_sdw_acpi mt7921_common uvcvideo snd_rpl_pci_acp6x hid_multitouch crct10dif_pclmul snd_hda_codec mt792x_lib snd_acp_pci crc32_pclmul videobuf2_vmalloc mt76_connac_lib snd_hda_scodec_cs35l41_i2c snd_acp_legacy_common uvc polyval_clmulni snd_hda_core btusb snd_pci_acp6x polyval_generic videobuf2_memops snd_hda_scodec_cs35l41 snd_hwdep mt76 btrtl gf128mul snd_pci_acp5x videobuf2_v4l2
[   23.395662]  snd_hda_cs_dsp_ctls ghash_clmulni_intel snd_rn_pci_acp3x snd_pcm videodev btintel sha512_ssse3 snd_soc_cs_amp_lib sha256_ssse3 snd_acp_config cs_dsp btbcm ucsi_acpi mac80211 videobuf2_common sha1_ssse3 snd_soc_acpi snd_timer btmtk snd_soc_cs35l41_lib sp5100_tco typec_ucsi ideapad_laptop vfat libarc4 aesni_intel crypto_simd fat cryptd bluetooth rapl pcspkr wmi_bmof platform_profile nvidia_wmi_ec_backlight typec thunderbolt snd sparse_keymap cfg80211 mc i2c_piix4 k10temp snd_pci_acp3x ccp soundcore joydev roles rfkill i2c_hid_acpi serial_multi_instantiate i2c_hid amd_pmc mac_hid uinput i2c_dev crypto_user loop dm_mod nfnetlink ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid amdgpu amdxcp i2c_algo_bit rtsx_pci_sdmmc drm_ttm_helper serio_raw atkbd ttm mmc_core libps2 drm_exec gpu_sched vivaldi_fmap nvme drm_suballoc_helper drm_buddy nvme_core xhci_pci crc32c_intel drm_display_helper i8042 rtsx_pci xhci_pci_renesas nvme_auth serio nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE)
[   23.395725]  video wmi nvidia(POE)
[   23.395729] CPU: 8 PID: 231 Comm: nv_queue Tainted: P        W  OE      6.10.0-rc3-1-MANJARO #1 48aec18d75cf2ff8be45a638398f02cc8fe7b0e4
[   23.395731] Hardware name: LENOVO 82Y4/LNVNB161216, BIOS M1CN40WW 04/24/2024
[   23.395732] RIP: 0010:follow_pte+0x1de/0x200
[   23.395734] Code: ba da 00 48 81 e2 00 00 00 c0 48 09 c2 48 f7 d2 48 85 fa 75 20 e8 d2 f5 ff ff 48 8b 35 fb 99 5d 01 48 81 e6 00 00 00 c0 eb 8d <0f> 0b 48 3b 1f 0f 83 50 fe ff ff bd ea ff ff ff eb b6 49 8b 3c 24
[   23.395736] RSP: 0018:ffffadd945823b60 EFLAGS: 00010246
[   23.395738] RAX: 0000000000000000 RBX: 00007cfab2a68000 RCX: ffffadd945823ba0
[   23.395739] RDX: ffffadd945823b98 RSI: 00007cfab2a68000 RDI: ffff8f02859cecf0
[   23.395741] RBP: ffffadd945823be0 R08: ffffadd945823d38 R09: 0000000000000000
[   23.395742] R10: 0000000000000200 R11: 0000000000000003 R12: ffffadd945823ba0
[   23.395744] R13: ffffadd945823b98 R14: ffff8f029ad03180 R15: 0000000000000000
[   23.395745] FS:  0000000000000000(0000) GS:ffff8f09be600000(0000) knlGS:0000000000000000
[   23.395747] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   23.395748] CR2: 00007141aa4c8000 CR3: 00000002f4420000 CR4: 0000000000f50ef0
[   23.395750] PKRU: 55555554
[   23.395751] Call Trace:
[   23.395752]  <TASK>
[   23.395753]  ? follow_pte+0x1de/0x200
[   23.395755]  ? __warn.cold+0x8e/0xe8
[   23.395757]  ? follow_pte+0x1de/0x200
[   23.395760]  ? report_bug+0xff/0x140
[   23.395763]  ? handle_bug+0x3c/0x80
[   23.395766]  ? exc_invalid_op+0x17/0x70
[   23.395769]  ? asm_exc_invalid_op+0x1a/0x20
[   23.395773]  ? follow_pte+0x1de/0x200
[   23.395776]  follow_phys+0x49/0x110
[   23.395780]  untrack_pfn+0x55/0x120
[   23.395784]  unmap_single_vma+0xa6/0xe0
[   23.395787]  zap_page_range_single+0x122/0x1d0
[   23.395793]  unmap_mapping_range+0x116/0x140
[   23.395797]  ? __pfx__main_loop+0x10/0x10 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.395941]  nv_revoke_gpu_mappings+0x67/0xb0 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.396084]  _nv000708rm+0x35/0x100 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.396306]  rm_execute_work_item+0xea/0x130 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.396525]  os_execute_work_item+0x5e/0x80 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.396670]  _main_loop+0x95/0x150 [nvidia d9b1cbf3dbb9acc211f5bcab9926fb6dceed2a37]
[   23.396814]  kthread+0xcf/0x100
[   23.396816]  ? __pfx_kthread+0x10/0x10
[   23.396819]  ret_from_fork+0x31/0x50
[   23.396822]  ? __pfx_kthread+0x10/0x10
[   23.396824]  ret_from_fork_asm+0x1a/0x30
[   23.396829]  </TASK>
[   23.396830] ---[ end trace 0000000000000000 ]---
[  313.711704] EXT4-fs (nvme1n1p4): error count since last fsck: 30
[  313.711747] EXT4-fs (nvme1n1p4): initial error at time 1718482488: ext4_orphan_get:1420
[  313.711760] EXT4-fs (nvme1n1p4): last error at time 1718482488: ext4_orphan_get:1420
There are FS errors again, as it crashed again after the fsck…
I just hw-probed the system:
https://linux-hardware.org/?probe=6b0cc29b90
The fingerprint failed :thinking: I always use the power button to shutdown, where the fingerprint is located. But that doesn’t explain the crashes while pacman upgrade, while steam playing or after HDMI is disconnected.
Thats the problem… you need to make a new partition map.
My main SSD was new (the laptop didn’t have any OS installed) and I created new partitions on it. The secondary SSD has just Windows now. What was the problem?
The issue is with the partition map. Even though you created new partitions on the main SSD, it might not have a proper partition map.
You need to create a new partition map to ensure the system can properly recognize and use the partitions. This can often solve the problem you’re experiencing. (At least I think that that is the issue) - But it all looks like it, because of the errors in your first post.
You need to create a new partition map for your SSD. Here’s a concise outline of the steps:
  1. Boot from a live system (using a USB or CD).
  2. Open a partition tool like GParted, fdisk, or parted.
  3. Create a new partition map/table.
  4. Repartition the drive as needed.
  5. Format the new partitions with the desired file systems.
  6. Reinstall the operating system on the newly created partitions.
Normally you can do that just in your installation process of the System BEFORE you make the new partitions.
Edit: Use GPT as Table Option!
Its also worth to disable “fast boot” in your bios and create a Bootstick with Ventoy.
When you don’t have sound with Kernel 6.9, 6.10 or LTS Kernel 6.6, then maybe try LTS 6.1 then.
Also… I’d recommend don’t use GRUB but UFEI BECUSE Lenovo dose not give a ■■■■ on Linux!
Kobold
I already had that disabled.
Sound is not working with kernels below 6.8.
In 6.8, 6.9 and 6.10 it is working because there were some quirks added to the kernel for this model.
And actually… I tried with 6.6 (with no sound) and it hangs up at shutdown too. I think it began to fail when the system upgraded to dynsdale with the new plasma along 6.8 (and new wallpaper). Maybe the wallpaper it’s the cause :crazy_face:
what i found
So your new system doesn’t had problem’s for a short periode of time?
But how long exactly?
But you reinstalled Manjaro KDE already and the stability problem is still there.
Do you know what plasma version are you using in Kubuntu? For Manjaro its 6.0.5
Maybe there is a bug at KDE in relation to your hardware that lead to your system freeze? Does it also freeze in the live environment?
Did you maybe restored a few settings from your old install after you reinstalled your system?
From → Laptop/Lenovo - ArchWiki it appears the only issue with this specific model is sound is only partially supported (what ever that means)
Audio through headphone jack works, but not through speakers due to missing quirks for amplifier chipset (6.1.9-1 kernel). Fan control with LenovoLegionLinux.
linux-aarhus
The speakers sound was fixed in 6.8.
And now, 6.8 has reached EOL… 6.9 is probably better for you, considering the sound worked as expected (noted earlier).
I had a quick look earlier to see if you have an updated BIOS available; I couldn’t find any information on the manufacturer site, but you might have better luck; assuming you have the relevant details of your machine available.
An updated BIOS can often cure unforeseen issues; it’s worth following up. Cheers.
Well, I created a new partition table, GPT (like the previous one) and created new partitions and installed Manjaro again. I configured the nvidia drm to enable HDMI and installed Steam, connected the HDMI. Opened sc-controller and an emulator (sudachi), well until now (but there were errors in the logs). Closed them and opened Steam. Before any download finished, laptop screen went white (it happened sometimes too in the old installations) and after that I closed everything and tried to shutdown: it failed miserably.
journalctl -p 3 -b-1:
de juny 16 10:31:12 cabra kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP18.SATA], AE_NOT_FOUND (20230628/dswload2-162)
de juny 16 10:31:12 cabra kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230628/psobject-220)
de juny 16 10:31:12 cabra kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._S0W], AE_ALREADY_EXISTS (20230628/dswload2-326)
de juny 16 10:31:12 cabra kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
de juny 16 10:31:12 cabra kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP7.DEV0._S0W], AE_ALREADY_EXISTS (20230628/dswload2-326)
de juny 16 10:31:13 cabra systemd-backlight[587]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
de juny 16 10:31:13 cabra systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
de juny 16 10:31:13 cabra systemd-backlight[633]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
de juny 16 10:31:13 cabra systemd-backlight[642]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
de juny 16 10:31:13 cabra systemd-backlight[649]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
de juny 16 10:31:13 cabra systemd-backlight[652]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
de juny 16 10:31:14 cabra systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
de juny 16 10:32:37 cabra wpa_supplicant[1829]: bgscan simple: Failed to enable signal strength monitoring
de juny 16 11:59:43 cabra bluetoothd[680]: src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters
de juny 16 12:00:16 cabra scc-daemon[30790]: scc-daemon: [Errno 5] Input/output error
de juny 16 12:00:18 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:20 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:22 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:24 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:26 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:28 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:30 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:32 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:34 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:36 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:38 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:40 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:42 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:44 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:46 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:48 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:50 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:52 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:54 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:55 cabra systemd-coredump[31029]: [🡕] Process 30854 (sudachi) of user 1000 dumped core.
                                                   Stack trace of thread 30973:
                                                   #0  0x0000754173caa434 pthread_mutex_lock (libc.so.6 + 0x96434)
                                                   #1  0x00005ec2f4ef5dc1 n/a (sudachi + 0x573dc1)
                                                   #2  0x00005ec2f52a0a34 n/a (sudachi + 0x91ea34)
                                                   #3  0x00005ec2f4f2398b n/a (sudachi + 0x5a198b)
                                                   #4  0x00005ec2f4f0ccf7 n/a (sudachi + 0x58acf7)
                                                   #5  0x00005ec2f533e07b n/a (sudachi + 0x9bc07b)
                                                   #6  0x00005ec2f4f218a9 n/a (sudachi + 0x59f8a9)
                                                   #7  0x00005ec2f4f21975 n/a (sudachi + 0x59f975)
                                                   #8  0x00005ec2f4fc3c61 n/a (sudachi + 0x641c61)
                                                   #9  0x00005ec2f4ecb0d3 n/a (sudachi + 0x5490d3)
                                                   #10 0x00005ec2f5ef4674 n/a (sudachi + 0x1572674)
                                                   #11 0x00005ec2f5ef46fb n/a (sudachi + 0x15726fb)
                                                   #12 0x00005ec2f5f2742f n/a (sudachi + 0x15a542f)
de juny 16 12:00:57 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:00:59 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:01 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:03 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:05 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:07 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:09 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:11 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:13 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:15 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:17 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:19 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:21 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:23 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:25 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:27 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:29 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:31 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:33 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:35 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:37 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:39 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:41 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:43 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:45 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:47 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:49 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:51 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:53 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:55 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:57 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:01:59 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:01 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:03 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:05 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:07 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:09 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:11 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:13 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:15 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:17 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:19 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:21 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:23 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:25 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:27 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:29 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:31 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:33 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:35 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:37 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:39 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:41 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:43 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:45 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:47 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:49 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:51 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:53 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:55 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:57 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:02:59 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:01 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:03 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:05 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:07 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:09 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:11 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:13 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:15 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:17 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:19 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:21 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:23 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:25 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:27 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:29 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:31 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:33 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:35 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:37 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:39 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:41 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:43 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:45 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:47 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:49 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:51 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:53 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:55 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:57 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:03:59 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:01 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:03 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:05 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:07 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:09 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:11 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:13 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:15 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:17 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:19 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:21 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:23 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:25 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:27 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:29 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:31 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:33 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:35 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:37 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:39 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:41 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:43 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:45 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:47 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:49 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:51 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:53 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:55 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:57 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:04:59 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:05:01 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:05:03 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:05:05 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:05:07 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:05:09 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:05:11 cabra scc-daemon[30790]: scc-daemon:
de juny 16 12:05:27 cabra scc-daemon[34454]: scc-daemon: [Errno 5] Input/output error
de juny 16 12:05:29 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:31 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:33 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:35 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:37 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:39 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:41 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:43 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:45 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:47 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:49 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:51 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:53 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:55 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:57 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:05:59 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:06:01 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:06:03 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:06:05 cabra scc-daemon[34454]: scc-daemon:
de juny 16 12:21:16 cabra kernel: hid-steam 0003:28DE:1102.0008: steam_send_report: error -19 (85)
de juny 16 12:21:16 cabra kernel: hid-steam 0003:28DE:1102.0008: steam_send_report: error -19 (8e)
de juny 16 12:21:16 cabra kernel: hid-steam 0003:28DE:1102.0008: steam_send_report: error -19 (81)
de juny 16 12:21:16 cabra kernel: hid-steam 0003:28DE:1102.0008: steam_send_report: error -19 (87 06 07 07 00 08 07 00)
de juny 16 12:21:21 cabra kernel: hid-steam 0003:28DE:1102.000C: steam_send_report: error -19 (85)
de juny 16 12:21:21 cabra kernel: hid-steam 0003:28DE:1102.000C: steam_send_report: error -19 (8e)
de juny 16 12:21:21 cabra kernel: hid-steam 0003:28DE:1102.000C: steam_send_report: error -19 (81)
de juny 16 12:21:21 cabra kernel: hid-steam 0003:28DE:1102.000C: steam_send_report: error -19 (87 06 07 07 00 08 07 00)
de juny 16 12:27:29 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6a0000 flags=0x0000]
de juny 16 12:27:29 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6a1000 flags=0x0000]
de juny 16 12:27:29 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6a2000 flags=0x0000]
de juny 16 12:27:29 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6a3000 flags=0x0000]
de juny 16 12:27:29 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6a4000 flags=0x0000]
de juny 16 12:27:29 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6a5000 flags=0x0000]
de juny 16 12:27:29 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6a6000 flags=0x0000]
de juny 16 12:27:29 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6a7000 flags=0x0000]
de juny 16 12:27:29 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6b0000 flags=0x0000]
de juny 16 12:27:29 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6ac000 flags=0x0000]
de juny 16 12:27:34 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdfc80000 flags=0x0000]
de juny 16 12:27:34 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdfc81000 flags=0x0000]
de juny 16 12:27:34 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdfc82000 flags=0x0000]
de juny 16 12:27:34 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdfc83000 flags=0x0000]
de juny 16 12:27:34 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdfc84000 flags=0x0000]
de juny 16 12:27:34 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdfc85000 flags=0x0000]
de juny 16 12:27:34 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdfc86000 flags=0x0000]
de juny 16 12:27:34 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdfc87000 flags=0x0000]
de juny 16 12:27:34 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdfc90000 flags=0x0000]
de juny 16 12:27:34 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdfc8c000 flags=0x0000]
de juny 16 12:27:39 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6c0000 flags=0x0000]
de juny 16 12:27:39 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6c1000 flags=0x0000]
de juny 16 12:27:39 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6c2000 flags=0x0000]
de juny 16 12:27:39 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6c3000 flags=0x0000]
de juny 16 12:27:39 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6c4000 flags=0x0000]
de juny 16 12:27:39 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6c5000 flags=0x0000]
de juny 16 12:27:39 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6c6000 flags=0x0000]
de juny 16 12:27:39 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6c7000 flags=0x0000]
de juny 16 12:27:39 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6a0000 flags=0x0000]
de juny 16 12:27:39 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdd6a8000 flags=0x0000]
de juny 16 12:27:44 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffff76a0000 flags=0x0000]
de juny 16 12:27:44 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffff76a1000 flags=0x0000]
de juny 16 12:27:44 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffff76a2000 flags=0x0000]
de juny 16 12:27:44 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffff76a3000 flags=0x0000]
de juny 16 12:27:44 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffff76a4000 flags=0x0000]
de juny 16 12:27:44 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffff76a5000 flags=0x0000]
de juny 16 12:27:44 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffff76a6000 flags=0x0000]
de juny 16 12:27:44 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffff76a7000 flags=0x0000]
de juny 16 12:27:44 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffff76b0000 flags=0x0000]
de juny 16 12:27:44 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffff76c4000 flags=0x0000]
de juny 16 12:27:49 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdbb45000 flags=0x0000]
de juny 16 12:27:49 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdbb46000 flags=0x0000]
de juny 16 12:27:49 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdbb47000 flags=0x0000]
de juny 16 12:27:49 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdbb48000 flags=0x0000]
de juny 16 12:27:49 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdbb54000 flags=0x0000]
de juny 16 12:27:49 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdbb66000 flags=0x0000]
de juny 16 12:27:49 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdbb78000 flags=0x0000]
de juny 16 12:27:49 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdbbca000 flags=0x0000]
de juny 16 12:27:49 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdbba4000 flags=0x0000]
de juny 16 12:27:49 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffdbbae000 flags=0x0000]
de juny 16 12:28:21 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffec800000 flags=0x0000]
de juny 16 12:28:21 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffec801000 flags=0x0000]
de juny 16 12:28:21 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffec802000 flags=0x0000]
de juny 16 12:28:21 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffec803000 flags=0x0000]
de juny 16 12:28:21 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffec804000 flags=0x0000]
de juny 16 12:28:21 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffec805000 flags=0x0000]
de juny 16 12:28:21 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffec806000 flags=0x0000]
de juny 16 12:28:21 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffec807000 flags=0x0000]
de juny 16 12:28:21 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffec808000 flags=0x0000]
de juny 16 12:28:21 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xfffec814000 flags=0x0000]
de juny 16 12:28:26 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffffc150000 flags=0x0000]
de juny 16 12:28:26 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffffc14c000 flags=0x0000]
de juny 16 12:28:26 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffffc166000 flags=0x0000]
de juny 16 12:28:26 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffffc178000 flags=0x0000]
de juny 16 12:28:26 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffffc180000 flags=0x0000]
de juny 16 12:28:26 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffffc181000 flags=0x0000]
de juny 16 12:28:26 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffffc182000 flags=0x0000]
de juny 16 12:28:26 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffffc183000 flags=0x0000]
de juny 16 12:28:26 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffffc184000 flags=0x0000]
de juny 16 12:28:26 cabra kernel: amdgpu 0000:65:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0005 address=0xffffc185000 flags=0x0000]
journalctl -p 3 -xb
de juny 16 14:10:09 cabra kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP18.SATA], AE_N>
de juny 16 14:10:09 cabra kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230628/psobject-220)
de juny 16 14:10:09 cabra kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._>
de juny 16 14:10:09 cabra kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobjec>
de juny 16 14:10:09 cabra kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP7.DEV0._>
de juny 16 14:10:09 cabra systemd-backlight[598]: nvidia_0: Failed to write system 'brightness' attribute: In>
de juny 16 14:10:09 cabra systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvid>
░░ Subject: A start job for unit systemd-backlight@backlight:nvidia_0.service has failed
░░ Defined-By: systemd
░░ A start job for unit systemd-backlight@backlight:nvidia_0.service has finished with a failure.
░░ The job identifier is 146 and the job result is failed.
de juny 16 14:10:09 cabra systemd-backlight[638]: nvidia_0: Failed to write system 'brightness' attribute: In>
░░ The job identifier is 177 and the job result is failed.
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orp>
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=613, block=41943056) = 0
lines 1-27...skipping...
de juny 16 14:10:09 cabra kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP18.SATA], AE_NOT_FOUND (20230628/dswload2-162)
de juny 16 14:10:09 cabra kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._S0W], AE_ALREADY_EXISTS (20230628/dswload2-326)
de juny 16 14:10:09 cabra kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
de juny 16 14:10:09 cabra kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP7.DEV0._S0W], AE_ALREADY_EXISTS (20230628/dswload2-326)
de juny 16 14:10:09 cabra systemd-backlight[598]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
de juny 16 14:10:09 cabra systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
de juny 16 14:10:09 cabra systemd-backlight[638]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486374
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486375
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=614, block=41943056) = 0
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486376
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=615, block=41943056) = 0
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486377
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=616, block=41943056) = 0
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486117
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=356, block=41943056) = 0
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486340
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=579, block=41943056) = 0
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486371
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=610, block=41943056) = 0
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486414
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=653, block=41943056) = 0
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486383
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=622, block=41943056) = 0
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486384
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=623, block=41943056) = 0
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486385
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=624, block=41943056) = 0
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486378
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=617, block=41943056) = 0
de juny 16 14:10:10 cabra kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 10486380
de juny 16 14:10:10 cabra kernel: ext4_test_bit(bit=619, block=41943056) = 0
I’m not sure, but I feel like having the wifi off, or the fans not active, it’s more likely to have a clean shutdown. And having used graphic intensive apps or hdmi more likely to fail.
Has anything important changed in wynsdey? Manjaro 23 worked quite well, I think (or I like to think).
I haven’t mentioned yet, but I’m always on X11. Wayland is buggy as hell with my computer, full screen apps and videos go blurry and a lot of apps fail.
Should I disconnect the old SSD?
The combination of Nvidia and Wayland is indeed troublesome. I use amdgpu; without any issue. If Nvidia eventually offer better support for Wayland; or, indeed, Linux in general, perhaps it could be different.
However, I don’t see that happening; especially after recent headlines that Nvidia is moving away from graphics chips.
Okay, other question. Do you use encryption for your partitions? As what I experienced with my system is, when I used different encrypted partitions I had a lot of errors with my hardware laptop (Dell) as it sadly is also a little bit ■■■■■■ concerning running a linux machine on it smoothly. What I did though then was to completely gave a ■■■■ on partitions … encrypted my complete hardrive at once and let the installer make only one partition and one swap partition with UFEI Boot Loader and not GRUB. And more the less all of my problems where gone.
What I think is also, that it could be a reason (in my case) is that on my ■■■■■■ dell machine Watch Dog and this ■■■■■■■ surveillance backdoors are installed Bios or even Hardware sided that causes all that troubles within the Kernel.
So I would suggest for you ( as especially on a personal computer and an SDD) to try to install the system without any partitions. AND also to look maybe, that you format the second SSD in an other fileformat than NTFS - maybe ext4 as well as when you have your game files on that machine it also coul be a problem with steam and the file format you use on the external HDD.
