System Gets Unresponsive (KDE)
Hi,
My system suddenly got very unresponsive. Had to restart (power button), it is unresponsive immediately after booting.
Luckily I had a Timeshift image I took, restored it and worked fine… then again it happened, and restored the same image. Tried to find a solution, but not really convincing for me it’s about swap as it was unresponsive just after boot!
Here is my system:
    ~  inxi -Fxxx         ✔
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "",
        LC_ALL = (unset),
        LC_ADDRESS = "ar_EG.UTF-8",
        LC_IDENTIFICATION = "ar_EG.UTF-8",
        LC_MEASUREMENT = "ar_EG.UTF-8",
        LC_MONETARY = "ar_EG.UTF-8",
        LC_NAME = "ar_EG.UTF-8",
        LC_NUMERIC = "en_US.UTF-8",
        LC_PAPER = "ar_EG.UTF-8",
        LC_TELEPHONE = "ar_EG.UTF-8",
        LC_TIME = "en_001.UTF-8",
        LANG = "en_US.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
System:    Host: ManjaroLenovo Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
           Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
           base: Arch Linux
Machine:   Type: Laptop System: LENOVO product: 20157 v: Lenovo G580 serial: <superuser required> Chassis:
           type: 10 v: 0.1 serial: <superuser required>
           Mobo: LENOVO model: Emerald Lake 2 v: FAB1 serial: <superuser required> UEFI: LENOVO
           v: 62CN34WW date: 04/26/2012
Battery:   ID-1: BAT0 charge: 24.8 Wh (98.4%) condition: 25.2/42.8 Wh (59.0%) volts: 12.1 min: 10.8
           model: SMP LNV-L11M6Y01 type: Li-ion serial: 6365 status: Unknown
CPU:       Info: Dual Core model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge rev: 9 cache:
           L2: 3 MiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 19961
           Speed: 1197 MHz min/max: 1200/3100 MHz Core speeds (MHz): 1: 1197 2: 1244 3: 1197 4: 1197
Graphics:  Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915 v: kernel
           bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
           Device-2: Acer Lenovo Integrated Webcam type: USB driver: uvcvideo bus-ID: 1-1.5:4
           chip-ID: 5986:0294 class-ID: 0e02
           Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting
           alternate: fbdev,vesa resolution: 1366x768~60Hz s-dpi: 96
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 21.2.1 compat-v: 3.0
           direct render: Yes
Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo driver: snd_hda_intel
           v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
           Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.33 running: yes
Network:   Device-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter driver: wl v: kernel port: efa0
           bus-ID: 02:00.0 chip-ID: 14e4:4727 class-ID: 0280
           IF: wlp2s0 state: up mac: 08:ed:b9:97:27:0f
           Device-2: Qualcomm Atheros AR8162 Fast Ethernet vendor: Lenovo driver: alx v: kernel port: 2000
           bus-ID: 03:00.0 chip-ID: 1969:1090 class-ID: 0200
           IF: enp3s0 state: down mac: f0:de:f1:fd:53:97
Bluetooth: Device-1: Foxconn / Hon Hai Broadcom BCM20702 Bluetooth type: USB driver: btusb v: 0.8
           bus-ID: 1-1.4:3 chip-ID: 0489:e032 class-ID: fe01 serial: 08EDB9972710
           Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives:    Local Storage: total: 465.76 GiB used: 128.37 GiB (27.6%)
           ID-1: /dev/sda vendor: Seagate model: ST9500325AS size: 465.76 GiB speed: 3.0 Gb/s type: HDD
           rpm: 5400 serial: 5VEV48VG rev: LVM1 scheme: GPT
Partition: ID-1: / size: 457.09 GiB used: 128.36 GiB (28.1%) fs: ext4 dev: /dev/sda2
           ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1
Swap:      Alert: No swap data was found.
Sensors:   System Temperatures: cpu: 51.0 C mobo: 46.0 C
Info:      Processes: 200 Uptime: 9m wakeups: 1 Memory: 3.69 GiB used: 1.34 GiB (36.3%) Init: systemd
           v: 248 Compilers: gcc: 11.1.0 Packages: pacman: 1240 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
           running-in: konsole inxi: 3.3.06
    ~          INT ✘
Out of curiosity I noticed something about locale at the beginning and about swap.
It is working fine now after latest Timeshift restore.
NB: I am bilingual and have both languages on keyboard working as expected.
I am keeping all interfaces in English.
What might be the problem? What can be done to avoid having this issue in the future?
Thanks a lot.
EDIT:
Just to update you.
sudo locale-gen
export LC_ALL=en_US.UTF-8
Seems to sort out the locale thing
Now, I have:
   ~  inxi -Fxxx  :heavy_check_mark:
base: Arch Linux
EDIT 2: rebooted, same error appears again :roll_eyes:
Please read this:
Execute:
locale-gen
Ah, you already did that! :+1:
Do you have a compelling reason to be on 5.13 Stable? If not, does this also happen on 5.10 LTS?
Read this, please! :rainbow: :unicorn:
After you’ve remedied all of the above, please provide an inxi --admin --verbosity=7 --filter --no-host --width as that provides more detailed information while keeping Personally Identifiable Information private…
Thank you Fabby
Thanks for the hint about REISUB/REISUO, I’ll try.
Execute:
locale-gen
But after reboot the same warning is sill there.
Well, I’m not that techie, and I would never try to play with the kernel on my own (a bit cowardly here :pleading_face:
I just download the iso, install, update and that’s it. This is what Manjaro gave me.
So, there is no “reason” as such, I just installed! :roll_eyes:
I’ll read about the swap you provided.
Thanks a lot. :+1:
Please read this:
especially the section about Linux has multiple kernels…
Then do this:
  • Execute:
     sudo mhwd-kernel --install linux54
     sudo mhwd-kernel --install linux510
  • to ensure grub is showing, execute:
     sudo nano --backup /etc/default/grub
  • Change (or add?) the following 3 lines:
    GRUB_TIMEOUT=3
    #GRUB_HIDDEN_TIMEOUT=0
    #GRUB_TIMEOUT_STYLE=hidden
    (3 or higher is fine, add the # before the lines above if those lines are present)
  • Ctrl+X Y Enter to save if there is anything to save
  • If you did save, execute:
     sudo update-grub
  • Reboot
  • Go to grub’s Advanced options
  • Choose these kernels one by one and try them out one by one and see if that helps.
  • If it does help, remove 5.13.
:+1:
OK!
If you think it’s better start with kernel, (my kernel is 5.13). At https://www.kernel.org/ I see there are:
  • mainline: 5.14
  • stable: 5.13.13 (which I think this is mine)
  • longterm: 5.10.61 (which I believe older - but longterm/more stable than above 2?)
Let me try one kernel at a time.
Which one would be more suitable for my old laptop? The one that might solve the freezing problem?
which version does linux54 and linux510 refer to? (am I getting it right that linux510 refers to the long term above? older than my current kernel? why shouldn’t I go straight to the latest?)
Or should I start with sorting out the swap issue?
Forgive me please for being so “illiterate” :pleading_face:
I really appreciate your patience and understanding.
Whatever you see more convenient, what commands to do?
EDIT:
After reading I assume I should install
longterm: 5.10.61
as the most stable now
How to do it without bricking the system? Make it the default kernel? Remove the current one?
EDIT 2:
Is this Manjaro Kernels - Manjaro
Ok?
Just to update you.
According to Manjaro Kernels - Manjaro
Now:
    ~  uname -r         ✔
5.13.12-1-MANJARO
    ~  mhwd-kernel -li         ✔
Currently running: 5.13.12-1-MANJARO (linux513)
   * linux513
    ~  mhwd-kernel -li         ✔  5s 
   * linux510
   * linux513
I hope I’ll safely reboot to the new kernel :crossed_fingers:
EDIT:
Rebooted, but to the same kernel, so I updated grub as dear Fabby mentioned.
Will reboot again and see.
Update:
Booted and rebooted to same kernel.
So I used Manjaro Settings Manager, and removed the kernel.
I assume it did everything.
linux513
linux513-broadcom-wl
Starting
checking dependencies...
Packages (2) linux513-5.13.12-1  linux513-broadcom-wl-6.30.223.271-16
Total Removed Size:  102.46 MiB
:: Do you want to remove these packages? [Y/n]
(1/1) Removing linux initcpios...
removing linux513-broadcom-wl...
removing linux513...
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating module dependencies...
(3/4) Refreshing PackageKit...
(4/4) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Detecting snapshots ...
Root partition isn't a btrfs filesystem.
This script only supports snapshots of the btrfs filesystem.
If you think an error has occurred , please file a bug report at " https://github.com/Antynea/grub-btrfs "
Nothing to do. Abort.
done
Done ...
:crossed_fingers:
I’m finaly done
Currently running: 5.10.60-1-MANJARO (linux510)
   * linux510
I will try and see if it doesnt freez, hopefully :crossed_fingers:
:+1: :grin: :hugs: Thanks to Fabby
:man_shrugging: :stuck_out_tongue_winking_eye:
For more info, please read this:
(At a minimum the Linux has multiple kernels section, at a maximum, everything except the “What’s this upstream / downstream business?”
:crossed_fingers:
Almost 24 Hrs later.
It seems much better now after taking hints from Fabby
I really appreciate your support.
Thank you.
