System Freeze completly during pacman upgrade of kernel packages
When I do a full update the packages download works fine as well as the installation of “regular” packages. Then the system hangs and becomes unusabale for a few minutes when it upgrade kernel module ( pasted below)
281/416) upgrading linux-firmware        [########################################################################################] 100%
(282/416) upgrading mkinitcpio-busybox        [########################################################################################] 100%
(283/416) upgrading linux414        [########################################################################################] 100%
(284/416) upgrading linux414-r8168        [########################################################################################] 100%
(285/416) upgrading linux419        [########################################################################################] 100%
(286/416) upgrading linux419-r8168        [########################################################################################] 100%
(287/416) upgrading linux54        [########################################################################################] 100%
(288/416) upgrading linux54-r8168        [########################################################################################] 100%
Cpu and ram are low during the freeze so I’m not sure what cause this. I’ve never had that before on any other OS nor Manjaro.
Moreover, I think I’ve had the problem since the installation 2 year ago, I’m not sure. Usually I upgrade when I’m afk.
Thanks,
F.f
You haven’t give us any system information but those are very disk-intensive operations so if you still have spinning rust a 5400 RPM HDD that could be causing the “freeze” as CPU wait time is not taken into account in all CPU monitors and the system is just waiting for disk I/O to finish.
:thinking:
The os is on a a nvme ssd. So that shouldn’t be an issues, isn’t?
  Kernel: 5.4.112-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=30a427ca-5791-4920-aced-f594086744ca rw quiet
  cryptdevice=UUID=5a87230c-02e9-4b45-b42c-bfb1a2e5ad19:luks-5a87230c-02e9-4b45-b42c-bfb1a2e5ad19
  root=/dev/mapper/luks-5a87230c-02e9-4b45-b42c-bfb1a2e5ad19
  resume=/dev/mapper/luks-5a87230c-02e9-4b45-b42c-bfb1a2e5ad19
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
  Type: Desktop Mobo: ASUSTeK model: PRIME H310M-A v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 0803 date: 06/20/2018
  RAM: total: 31.22 GiB used: 5.31 GiB (17.0%)
  Info: 6-Core model: Intel Core i5-8600 bits: 64 type: MCP arch: Kaby Lake
  note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
  cache: L2: 9 MiB bogomips: 37213
  Speed: 800 MHz min/max: 800/4300 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2
  xsaves xtopology xtpr
  Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
  Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0300
  Device-2: ARC Camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3:2
  chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
  Display: x11 server: X.org 1.20.11 driver: loaded: intel
  unloaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.0.2
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
  Sound Server-1: ALSA v: k5.4.112-1-MANJARO running: yes
  Sound Server-3: JACK v: 0.125.0 running: no
  Sound Server-4: PulseAudio v: 14.2 running: yes
  Sound Server-5: PipeWire v: 0.3.25 running: no
  vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI modules: r8169 port: 3000
  bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 10 Mbps duplex: half mac: <filter>
  Device-1: sda1_crypt maj-min: 254:1 type: LUKS dm: dm-1 size: 3.64 TiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 3.64 TiB
  Device-2: luks-5a87230c-02e9-4b45-b42c-bfb1a2e5ad19 maj-min: 254:0
  type: LUKS dm: dm-0 size: 111.5 GiB
  Components:
  p-1: sdb2 maj-min: 8:18 size: 111.5 GiB
  Local Storage: total: 3.75 TiB used: 2.55 TiB (68.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD40EZRZ-22GXCB0
  size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
  model: WDS120G2G0B-00EPW0 size: 111.8 GiB block-size: physical: 512 B
  logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0000
  scheme: GPT
  ID-1: / raw-size: 111.5 GiB size: 109.25 GiB (97.98%)
  used: 84.27 GiB (77.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
  mapped: luks-5a87230c-02e9-4b45-b42c-bfb1a2e5ad19 label: N/A
  uuid: 30a427ca-5791-4920-aced-f594086744ca
  used: 408 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
  uuid: 00A6-59C6
  ID-3: /home/<filter>/thiccboi raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
  used: 2.47 TiB (68.9%) fs: ext4 dev: /dev/dm-1 maj-min: 254:1
  mapped: sda1_crypt label: N/A uuid: N/A
  Kernel: swappiness: 50 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: file size: 5.86 GiB used: 0 KiB (0.0%) priority: 100
  file: /swapfile
  ID-2: swap-2 type: file size: 20 GiB used: 0 KiB (0.0%) priority: 10
  file: /home/<filter>/thiccboi/.swapfile
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-3:2 info: ARC Camera type: Video,Audio
  power: 200mA chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
  Device-2: 1-5:3 info: Microsoft Basic Optical Mouse v2.0 type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
  power: 100mA chip-ID: 045e:00cb class-ID: 0301
  Device-3: 1-6:4 info: Logitech DeLuxe 250 Keyboard type: Keyboard,HID
  power: 100mA chip-ID: 046d:c312 class-ID: 0300
  System Temperatures: cpu: 27.8 C mobo: N/A
  Processes: 249 Uptime: 28m wakeups: 0 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1946 lib: 454
  Shell: Bash v: 5.1.0 running-in: terminator inxi: 3.3.04
I think it’s simply that your hd is full, at that stage shown, pacman needs disc space to extract the package files.
To gain space you might want to delete old packages using
pacman -Sc
No it isn’t:
I.E.
  • The “drives” section of inxi shows the partitions, so if the disk is fully allocated to partitions, it’s 100% (in this case ~2% isn’t actually allocated)
  • The “partitions” section shows the actual disk usage as per df, so the 109 GB / only has 84 GB in use.
:wink:
No, it isn’t: it’s on an M2 SSD…
Well, M2s are much faster than HDDs but even the speed of an M2 isn’t infinite neither, so next time before running a large update, start:
sudo iotop
in another terminal in parallel and then you’ll see it even maxes out a WD M2 green when updating 3 kernels…
:grin: :running_man:
P.S. After you do the above, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
Thanks for both replies,
I’ve already checked with iotop, disk usage is far from saturating the drive.
I’ve never experienced this on another setup, with a graphic environment or headless or with arch or debian based OS. My laptop has worse spec and a sata ssd (and even before a hdd) and update are smooth.
I’m not talking about a slow down of the system, the whole thing freeze for 10 minutes. I guess I could test if a limiter such as ionice fix the issue but this is not a “normal” behaviour.
