yes thats what im telling you, that this libGL.so.1 library is the issue, which we tried to fix yesterday … do you have a manjaro usb? it would be better to fix it via chroot
Hold I got the ISO, just need to flash it.
hopefully you are not using btrfs? if yes dont bother, i dont know how to chroot into it, and following the manjaro wiki guide on how to do it doesnt work …
No I don’t. Ok so I’m in the chroot environment. I didn’t bother manually mounting and chrooting so I simply executed manjaro-chroot -a and it works fine, but it does say something about grub-probe not being able to find a GRUB drive for /dev/sdb1 and that I have to check my device.map. Is that something to worry about?
no the grub error is for the usb, nothing to worry about … ok, so now run these commands and post output:
pacman -F libGL.so.1
pacman -Qo /**/libGL.so.1
pacman -F libGL.so.304.132
pacman -Qo /**/libGL.so.304.132
[manjaro /]# pacman -F libGL.so.1
extra/libglvnd 1.4.0-3 [installed]
usr/lib/libGL.so.1
community/cuda-tools 11.7.1-1
opt/cuda/nsight_compute/host/linux-desktop-glibc_2_11_3-x64/Mesa/libGL.so.1
opt/cuda/nsight_systems/host-linux-x64/Mesa/libGL.so.1
community/nvidia-cg-toolkit 3.1-6
usr/share/Cg/examples/Trace/libGL.so.1
community/primus 20151110-9
usr/lib/primus/libGL.so.1
multilib/lib32-libglvnd 1.4.0-3 [installed]
usr/lib32/libGL.so.1
multilib/lib32-primus 20151110-4
usr/lib32/primus/libGL.so.1
[manjaro /]# pacman -Qo /**/libGL.so.1
/usr/lib/libGL.so.1 is owned by libglvnd 1.4.0-3
[manjaro /]# pacman -F libGL.so.304.132
[manjaro /]# pacman -Qo /**/libGL.so.304.132
error: No package owns /lib/libGL.so.304.132
error: No package owns /lib64/libGL.so.304.132
[manjaro /]#
i would just remove those 304 libraries … i have nvidia and i dont have them … how did you installed the nvidia?
I don’t exactly remember. I installed the non-free drivers from Manjaro Settings then I installed GWE to try and overclock my GPU and it didn’t work (greyed out). So I searched on Google, pasted some commands and download some nvidia library from Pamac GUI. I also remember I did mess with the X config and changed few stuff but I don’t remember much. It was just me blindly following instructions lol.
you messed up …
post output from:
cat /var/log/pacman.log | grep install | tail -30
grep: (standard input): binary file matches
and this:
cat /var/log/pacman.log | grep -a install | tail -30
[manjaro /]# cat /var/log/pacman.log | grep -a install | tail -30
[2022-09-01T01:47:55+0400] [ALPM] installed telepathy-kde-common-internals (22.04.3-1)
[2022-09-01T01:47:55+0400] [ALPM] installed telepathy-kde-auth-handler (22.04.3-1)
[2022-09-01T01:47:55+0400] [ALPM] installed qt-gstreamer (1.2.0-4)
[2022-09-01T01:47:55+0400] [ALPM] installed telepathy-kde-call-ui (22.04.3-1)
[2022-09-01T01:47:56+0400] [ALPM] installed telepathy-kde-contact-list (22.04.3-1)
[2022-09-01T01:47:56+0400] [ALPM] installed telepathy-kde-contact-runner (22.04.3-1)
[2022-09-01T01:47:56+0400] [ALPM] installed telepathy-kde-desktop-applets (22.04.3-1)
[2022-09-01T01:47:56+0400] [ALPM] installed telepathy-kde-filetransfer-handler (22.04.3-1)
[2022-09-01T01:47:56+0400] [ALPM] installed telepathy-kde-send-file (22.04.3-1)
[2022-09-01T01:47:56+0400] [ALPM] installed telepathy-kde-text-ui (22.04.3-1)
[2022-09-01T01:47:56+0400] [ALPM] installed umbrello (22.04.3-1)
[2022-09-01T01:47:57+0400] [ALPM] reinstalled yakuake (22.04.3-1)
[2022-09-01T01:47:57+0400] [ALPM] installed zanshin (22.04.3-1)
[2022-09-01T01:47:57+0400] [ALPM] installed zeroconf-ioslave (22.04.3-1)
[2022-09-01T01:48:08+0400] [ALPM] running 'texinfo-install.hook'...
[2022-09-01T02:13:28+0400] [ALPM] installed eglexternalplatform (1.1-2)
[2022-09-01T02:13:28+0400] [ALPM] installed egl-wayland (2:1.1.10-1)
[2022-09-01T02:31:41+0400] [ALPM] reinstalled mesa (22.1.6-1)
[2022-09-01T02:31:41+0400] [ALPM] reinstalled glu (9.0.2-3)
[2022-09-01T02:31:41+0400] [ALPM] reinstalled lib32-mesa (22.1.6-1)
[2022-09-01T02:31:41+0400] [ALPM] reinstalled lib32-glu (9.0.2-3)
[2022-09-01T02:31:41+0400] [ALPM] reinstalled lib32-libva-mesa-driver (22.1.6-1)
[2022-09-01T02:31:41+0400] [ALPM] reinstalled mesa-demos (8.5.0-2)
[2022-09-01T02:31:42+0400] [ALPM] reinstalled lib32-mesa-demos (8.5.0-1)
[2022-09-01T02:31:42+0400] [ALPM] reinstalled lib32-mesa-vdpau (22.1.6-1)
[2022-09-01T02:31:42+0400] [ALPM] reinstalled lib32-vulkan-radeon (22.1.6-1)
[2022-09-01T02:31:42+0400] [ALPM] reinstalled libva-mesa-driver (22.1.6-1)
[2022-09-01T02:31:42+0400] [ALPM] reinstalled mesa-utils (8.5.0-2)
[2022-09-01T02:31:42+0400] [ALPM] reinstalled mesa-vdpau (22.1.6-1)
[2022-09-01T02:31:42+0400] [ALPM] reinstalled vulkan-radeon (22.1.6-1)
[manjaro /]#
i forgot that we did installed a lot of things yesterday so post output from:
cat /var/log/pacman.log | grep -a installed | grep -a nvidia | tail -30
[2022-08-12T16:36:14+0400] [ALPM] installed nvidia-cg-toolkit (3.1-6)
[2022-08-30T18:04:26+0400] [ALPM] installed nvidia-390xx-utils (390.154-1)
[2022-08-30T18:04:26+0400] [ALPM] installed lib32-nvidia-390xx-utils (390.154-1)
[2022-08-30T18:04:27+0400] [ALPM] installed linux419-nvidia-390xx (390.154-2)
[2022-08-30T18:04:37+0400] [ALPM] installed linux515-nvidia-390xx (390.154-2)
[2022-08-30T23:00:24+0400] [ALPM] installed nvidia-utils (515.65.01-2)
[2022-08-30T23:00:25+0400] [ALPM] installed lib32-nvidia-utils (515.65.01-1)
[2022-08-30T23:00:25+0400] [ALPM] installed linux419-nvidia (515.65.01-2)
[2022-08-30T23:00:35+0400] [ALPM] installed linux515-nvidia (515.65.01-2)
[2022-08-30T23:55:08+0400] [ALPM] installed nvidia-utils (515.65.01-2)
[2022-08-30T23:55:08+0400] [ALPM] installed lib32-nvidia-utils (515.65.01-1)
[2022-08-30T23:55:08+0400] [ALPM] installed linux419-nvidia (515.65.01-2)
[2022-08-30T23:55:18+0400] [ALPM] installed linux515-nvidia (515.65.01-2)
run this, just to be sure:
pacman -Rns linux515-nvidia linux419-nvidia lib32-nvidia-utils nvidia-utils linux515-nvidia-390xx linux419-nvidia-390xx lib32-nvidia-390xx-utils nvidia-390xx-utils nvidia-cg-toolkit
if it gives you error not found or something like that, then every nvidia is removed and then we remove the libs
error: target not found: linux515-nvidia
error: target not found: linux419-nvidia
error: target not found: lib32-nvidia-utils
error: target not found: nvidia-utils
error: target not found: linux515-nvidia-390xx
error: target not found: linux419-nvidia-390xx
error: target not found: lib32-nvidia-390xx-utils
error: target not found: nvidia-390xx-utils
error: target not found: nvidia-cg-toolkit
so remove the libs:
rm /lib/libGL.so.304.132
rm /lib64/libGL.so.304.132
if there are no errors post output from:
mhwd-kernel -li
rm: cannot remove '/lib64/libGL.so.304.132': No such file or directory
the rm /lib/libGL.so.304.132 worked?
if yes post the output mhwd-kernel -li
Yup
* linux515
* linux519
