I startup started reinstalling xorg, plasma and kde apps lol
pacman -S xorg plasma plasma-wayland-session kde-applications
if it worked haha
Yeah but it didn’t lol
So do I still execute your commands?
i thought it did haha… yes run those commands and recheck if it looks like in the post above
The first command returned the following error: failed to create symbolic link '/usr/lib64/libGL.so.1.7.0': File exists
ok so proceed to the second command, and then recheck them
Just did that. Now ls -l /usr/lib32/libGL.so* outputs the same result as ls -l /usr/lib/libGL.so* in the above screenshot.
that 32 was linked correctly, but these 2 were not:
ls -l /usr/lib64/libGL.so*
these libGL.so.1 should not point to the 340.132
I see. They still point though.
so run it with sudo:
sudo ln -s /usr/lib/libGL.so.1 /usr/lib/libGL.so.1.7.0
and then check with:
I was executing all the commands in superuser mode all this time. Is there any difference?
well they worked they changed the correct lib32 symlink to the nvidia ones haha …
try this:
ln -s /usr/lib/libGL.so /usr/lib/libGL.so.1
then check with:
First one failed, again saying that file already exists. The output of the last command seems to be the same as before.
i dont know why it doesnt work …
lets reinstall mesa, post output from:
pacman -Qs mesa
yes, its to check what you have installed, since im on intel and you are amd, dont know if they both use the same packages …
sudo pacman -S glu lib32-glu lib32-libva-mesa-driver lib32-mesa lib32-mesa-demos lib32-mesa-vdpau lib32-vulkan-radeon libva-mesa-driver mesa mesa-demos mesa-utils mesa-vdpau vulkan-radeon
reboot
Still the same. Anyways, I am really tried and it’s late here I should go sleep. We will continue tomorrow alright? Thanks for the help too. Good day or good night to you friend.
ok, we will continue tomorrow, but theres not much i can think off, except removing the 304.132 libs
Hey, good day. So today I decided to try and launch an application from TTY just for curiosity and it threw an interesting error konsole: error while loading shared libraries: libGL.so.1: wrong ELF class: ELFCLASS32 I am assuming the problem is with these opengl libs. What do you think?
