System doesn't boot, gets stuck on '[OK] Reached Graphical Interface' with the mouse cursor
Ok So basically I put my laptop’s SSD in my desktop computer and since my pc had a Nvidia GPU, I tried installing the drivers for it. Somehow I messed up and after rebooting I was presented with a black screen. Then I erased the Nvidia drivers, auto-detected and reinstalled AMD’s drivers with MHWD in TTY from my laptop. And now I’m here. It boots like usual but then gets stuck on ‘[OK] Reached Graphical Interface’, but the cursor is present and I can control it. Actually, it used to get stuck on TLP so I thought deleting it might help, which it obviously didn’t. I am assuming this has to do with the Window Manager or some sort.
I already tried this: [Fix] System doesn’t boot, boots to a black screen, or stops at a message
Didn’t work.
The result of startx is:
And pacman -Syyu says there’s nothing to do.
Result of ‘mhwd’ and mhwd -li are:
My current kernel is linux515.
Any help?
Edit: GRUB just doesn’t show up even though I have set GRUB_TIMEOUT_STYLE=menu GRUB_TIMEOUT=10 GRUB_DISABLE_OS_PROBER=false. Holding down ESC makes the screen black and gets stuck. I am on UEFI boot mode and Secure boot is off. I also don’t have Windows on this SSD, only Manjaro.
maybe some leftover from nvidia… post pic of:
find /etc/X11/ -name "*.conf"
and:
cat /var/log/Xorg.1.log
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/xorg.conf.d/30-touchpad.conf
and the log
[  1049.108]
X.Org X Server 1.21.1.4
[  1049.108] Current Operating System: Linux Node 5.15.60-1-MANJARO #1 SMP PREEMPT Thu Aug 11 13:14:05 UTC 2022 x86_64
[  1049.108] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=c03df553-75df-4f8b-8a8d-ff3c7dab7b90 rw apparmor=1 security=apparmor resume=UUID=c3760056-6644-4450-9adc-7c163254783d udev.log_priority=3
[  1049.108]
[  1049.109] Current version of pixman: 0.40.0
[  1049.109] 	Before reporting problems, check http://wiki.x.org
[  1049.109] Markers: (--) probed, (**) from config file, (==) default setting,
[  1049.110] (==) Log file: "/var/log/Xorg.1.log", Time: Wed Aug 31 23:06:05 2022
[  1049.110] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  1049.110] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  1049.111] (==) No Layout section.  Using the first Screen section.
[  1049.111] (==) No screen section available. Using defaults.
[  1049.111] (**) |-->Screen "Default Screen Section" (0)
[  1049.111] (**) |   |-->Monitor "<default monitor>"
[  1049.111] (==) No monitor specified for screen "Default Screen Section".
[  1049.111] (==) Automatically adding devices
[  1049.111] (==) Automatically enabling devices
[  1049.111] (==) Automatically adding GPU devices
[  1049.111] (==) Automatically binding GPU devices
[  1049.111] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  1049.112] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[  1049.112] 	Entry deleted from font path.
[  1049.112] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[  1049.112] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[  1049.112] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[  1049.112] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[  1049.112] (==) ModulePath set to "/usr/lib/xorg/modules"
[  1049.112] (II) The server relies on udev to provide the list of input devices.
[  1049.112] (II) Module ABI versions:
[  1049.112] 	X.Org ANSI C Emulation: 0.4
[  1049.112] 	X.Org Video Driver: 25.2
[  1049.112] 	X.Org XInput driver : 24.4
[  1049.112] 	X.Org Server Extension : 10.0
[  1049.113] (++) using VT number 3
[  1049.116] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[  1049.118] (II) xfree86: Adding drm device (/dev/dri/card0)
[  1049.118] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/drm/card0
[  1049.120] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[  1049.128] (--) PCI:*(0@0:1:0) 1002:1309:17aa:3988 rev 0, Mem @ 0xe0000000/268435456, 0xf0000000/8388608, 0xf0a00000/262144, I/O @ 0x00002000/256, BIOS @ 0x????????/131072
[  1049.128] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[  1049.128] (II) LoadModule: "glx"
[  1049.128] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  1049.129] (EE) Failed to load /usr/lib/xorg/modules/extensions/libglx.so: libGL.so.1: wrong ELF class: ELFCLASS32
[  1049.129] (EE) Failed to load module "glx" (loader failed, 0)
[  1049.129] (II) Applying OutputClass "Radeon" to /dev/dri/card0
[  1049.129] 	loading driver: radeon
[  1049.129] (==) Matched radeon as autoconfigured driver 0
[  1049.129] (==) Matched ati as autoconfigured driver 1
[  1049.129] (==) Matched modesetting as autoconfigured driver 2
[  1049.129] (==) Matched fbdev as autoconfigured driver 3
[  1049.129] (==) Matched vesa as autoconfigured driver 4
[  1049.129] (==) Assigned the driver to the xf86ConfigLayout
[  1049.129] (II) LoadModule: "radeon"
[  1049.129] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[  1049.131] (II) Module radeon: vendor="X.Org Foundation"
[  1049.131] 	compiled for 1.21.1.1, module version = 19.1.0
[  1049.131] 	Module class: X.Org Video Driver
[  1049.131] 	ABI class: X.Org Video Driver, version 25.2
[  1049.131] (II) LoadModule: "ati"
[  1049.131] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[  1049.131] (II) Module ati: vendor="X.Org Foundation"
[  1049.132] (II) LoadModule: "modesetting"
[  1049.132] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[  1049.133] (II) Module modesetting: vendor="X.Org Foundation"
[  1049.133] 	compiled for 1.21.1.4, module version = 1.21.1
[  1049.133] 	Module class: X.Org Video Driver
[  1049.133] 	ABI class: X.Org Video Driver, version 25.2
[  1049.133] (II) LoadModule: "fbdev"
[  1049.133] (WW) Warning, couldn't open module fbdev
[  1049.133] (EE) Failed to load module "fbdev" (module does not exist, 0)
[  1049.133] (II) LoadModule: "vesa"
[  1049.133] (WW) Warning, couldn't open module vesa
[  1049.133] (EE) Failed to load module "vesa" (module does not exist, 0)
[  1049.134] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
	ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
	ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
	ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
	ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
	ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
	ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
	ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
	ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
	ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
	ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
	ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
	ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
	ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
	ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
	ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
	ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
	ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
	ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
	ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
	ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
	ATI Radeon 9800PRO, ATI Radeon 9800XT,
	ATI Radeon Mobility 9600/9700 (M10/M11),
	ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
	ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
	ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
	ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
	ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
	ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
	ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
	ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
	ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
	ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
	ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
	ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
	ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
	ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
	ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
	ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
	ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
	ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
	ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
	ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
	ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
	ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
	ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
	ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
	ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
	ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
	ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
	ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
	ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
	ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
	ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
	ATI FireGL V3350, ATI Mobility Radeon X1450,
	ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
	ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
	ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
	ATI FireGL V3400, ATI Mobility FireGL V5250,
	ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
	ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
	ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
	ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
	ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
	ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
	ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
	ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
	ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
	ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
	ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
	ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
	AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
	ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
	ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
	ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
	ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
	ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
	ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
	ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
	ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
	ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
	ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
	ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
	ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
	ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
	ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
	ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
	ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
	ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
	ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
	ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
	ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
	ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
	ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
	ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
	ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
	ATI FireGL V3600, ATI Radeon HD 2600 LE,
	ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
	ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
	ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
	ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
	ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
	ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
	ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
	ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
	ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
	ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
	ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
	AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
	AMD Radeon HD 6300 Series Graphics,
	AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
	ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
	AMD Firestream 9350, ATI Radeon HD 5800 Series,
	ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
	ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
	ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
	ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
	REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
	ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
	AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
	AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
	ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
	MULLINS, KAVERI, HAWAII
[  1049.138] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[  1049.139] (II) [KMS] Kernel modesetting enabled.
[  1049.139] (WW) Falling back to old probe method for modesetting
[  1049.139] (II) RADEON(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[  1049.139] (==) RADEON(0): Depth 24, (--) framebuffer bpp 32
[  1049.139] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[  1049.139] (==) RADEON(0): Default visual is TrueColor
[  1049.139] (==) RADEON(0): RGB weight 888
[  1049.139] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
[  1049.139] (--) RADEON(0): Chipset: "KAVERI" (ChipID = 0x1309)
[  1049.139] (II) Loading sub module "fb"
[  1049.139] (II) LoadModule: "fb"
[  1049.139] (II) Module "fb" already built-in
[  1049.139] (II) Loading sub module "dri2"
[  1049.139] (II) LoadModule: "dri2"
[  1049.139] (II) Module "dri2" already built-in
[  1049.210] (II) Loading sub module "glamoregl"
[  1049.210] (II) LoadModule: "glamoregl"
[  1049.210] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[  1049.222] (II) Module glamoregl: vendor="X.Org Foundation"
[  1049.222] 	compiled for 1.21.1.4, module version = 1.0.1
[  1049.222] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  1049.248] (II) RADEON(0): glamor X acceleration enabled on AMD KAVERI (LLVM 14.0.6, DRM 2.50, 5.15.60-1-MANJARO)
[  1049.248] (II) RADEON(0): glamor detected, initialising EGL layer.
[  1049.248] (II) RADEON(0): KMS Color Tiling: enabled
[  1049.248] (II) RADEON(0): KMS Color Tiling 2D: enabled
[  1049.248] (==) RADEON(0): TearFree property default: auto
[  1049.248] (II) RADEON(0): KMS Pageflipping: enabled
[  1049.361] (II) RADEON(0): Output VGA-0 has no monitor section
[  1049.362] (II) RADEON(0): Output HDMI-0 has no monitor section
[  1049.376] (II) RADEON(0): Output eDP has no monitor section
[  1049.487] (II) RADEON(0): EDID for output VGA-0
[  1049.489] (II) RADEON(0): EDID for output HDMI-0
[  1049.502] (II) RADEON(0): EDID for output eDP
[  1049.503] (II) RADEON(0): Manufacturer: BOE  Model: 61d  Serial#: 0
[  1049.503] (II) RADEON(0): Year: 2014  Week: 1
[  1049.503] (II) RADEON(0): EDID Version: 1.4
[  1049.503] (II) RADEON(0): Digital Display Input
[  1049.503] (II) RADEON(0): 6 bits per channel
[  1049.503] (II) RADEON(0): Digital interface is DisplayPort
[  1049.503] (II) RADEON(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[  1049.503] (II) RADEON(0): Gamma: 2.20
[  1049.503] (II) RADEON(0): No DPMS capabilities specified
[  1049.503] (II) RADEON(0): Supported color encodings: RGB 4:4:4
[  1049.503] (II) RADEON(0): First detailed timing is preferred mode
[  1049.503] (II) RADEON(0): Preferred mode is native pixel format and refresh rate
[  1049.503] (II) RADEON(0): redX: 0.585 redY: 0.347   greenX: 0.334 greenY: 0.569
[  1049.503] (II) RADEON(0): blueX: 0.164 blueY: 0.117   whiteX: 0.312 whiteY: 0.339
[  1049.503] (II) RADEON(0): Manufacturer's mask: 0
[  1049.503] (II) RADEON(0): Supported detailed timing:
[  1049.503] (II) RADEON(0): clock: 72.3 MHz   Image Size:  309 x 173 mm
[  1049.503] (II) RADEON(0): h_active: 1366  h_sync: 1414  h_sync_end 1446 h_blank_end 1526 h_border: 0
[  1049.503] (II) RADEON(0): v_active: 768  v_sync: 771  v_sync_end 777 v_blanking: 790 v_border: 0
[  1049.503] (II) RADEON(0):  BOE HF
[  1049.503] (II) RADEON(0):  NT156WHM-N12
[  1049.503] (II) RADEON(0): EDID (in hex):
[  1049.503] (II) RADEON(0): 	00ffffffffffff0009e51d0600000000
[  1049.503] (II) RADEON(0): 	011801049522137802fb0f955855912a
[  1049.503] (II) RADEON(0): 	1e4f5600000001010101010101010101
[  1049.503] (II) RADEON(0): 	0101010101013e1c56a0500016303020
[  1049.503] (II) RADEON(0): 	360035ad1000001a0000000000000000
[  1049.503] (II) RADEON(0): 	00000000000000000000000000fe0042
[  1049.503] (II) RADEON(0): 	4f452048460a202020202020000000fe
[  1049.503] (II) RADEON(0): 	004e5431353657484d2d4e31320a00e5
[  1049.504] (II) RADEON(0): Printing probed modes for output eDP
[  1049.504] (II) RADEON(0): Modeline "1366x768"x60.0   72.30  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (47.4 kHz eP)
[  1049.504] (II) RADEON(0): Modeline "1280x720"x60.0   74.65  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.9 kHz)
[  1049.504] (II) RADEON(0): Modeline "1152x768"x59.9   71.95  1152 1216 1328 1504  768 771 781 798 -hsync +vsync (47.8 kHz)
[  1049.504] (II) RADEON(0): Modeline "1024x768"x59.9   63.53  1024 1072 1176 1328  768 771 775 798 -hsync +vsync (47.8 kHz)
[  1049.504] (II) RADEON(0): Modeline "800x600"x60.0   38.31  800 832 912 1024  600 603 607 624 -hsync +vsync (37.4 kHz)
[  1049.504] (II) RADEON(0): Modeline "848x480"x59.9   31.65  848 872 952 1056  480 483 493 500 -hsync +vsync (30.0 kHz)
[  1049.504] (II) RADEON(0): Modeline "720x480"x59.9   26.85  720 744 808 896  480 483 493 500 -hsync +vsync (30.0 kHz)
[  1049.504] (II) RADEON(0): Modeline "640x480"x59.9   23.98  640 664 720 800  480 483 487 500 -hsync +vsync (30.0 kHz)
[  1049.504] (II) RADEON(0): Output VGA-0 disconnected
[  1049.504] (II) RADEON(0): Output HDMI-0 disconnected
[  1049.504] (II) RADEON(0): Output eDP connected
[  1049.504] (II) RADEON(0): Using exact sizes for initial modes
[  1049.504] (II) RADEON(0): Output eDP using initial mode 1366x768 +0+0
[  1049.504] (II) RADEON(0): mem size init: gart size :7fb62000 vram size: s:40000000 visible:f4be000
[  1049.504] (==) RADEON(0): DPI set to (96, 96)
[  1049.504] (==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
[  1049.504] (II) Loading sub module "ramdac"
[  1049.504] (II) LoadModule: "ramdac"
[  1049.504] (II) Module "ramdac" already built-in
[  1049.504] (II) UnloadModule: "modesetting"
[  1049.504] (II) Unloading modesetting
[  1049.505] (II) RADEON(0): [DRI2] Setup complete
[  1049.505] (II) RADEON(0): [DRI2]   DRI driver: radeonsi
[  1049.505] (II) RADEON(0): [DRI2]   VDPAU driver: radeonsi
[  1049.506] (II) RADEON(0): Front buffer size: 4224K
[  1049.506] (II) RADEON(0): VRAM usage limit set to 221695K
[  1049.506] (II) RADEON(0): SYNC extension fences enabled
[  1049.506] (II) RADEON(0): Present extension enabled
[  1049.506] (==) RADEON(0): DRI3 enabled
[  1049.506] (==) RADEON(0): Backing store enabled
[  1049.506] (II) RADEON(0): Direct rendering enabled
[  1049.536] (II) RADEON(0): Use GLAMOR acceleration.
[  1049.536] (II) RADEON(0): Acceleration enabled
[  1049.537] (==) RADEON(0): DPMS enabled
[  1049.537] (==) RADEON(0): Silken mouse enabled
[  1049.537] (II) RADEON(0): Set up textured video (glamor)
[  1049.537] (II) RADEON(0): [XvMC] Associated with GLAMOR Textured Video.
[  1049.537] (II) RADEON(0): [XvMC] Extension initialized.
[  1049.552] (II) Initializing extension Generic Event Extension
[  1049.553] (II) Initializing extension SHAPE
[  1049.553] (II) Initializing extension MIT-SHM
[  1049.553] (II) Initializing extension XInputExtension
[  1049.554] (II) Initializing extension XTEST
[  1049.554] (II) Initializing extension BIG-REQUESTS
[  1049.554] (II) Initializing extension SYNC
[  1049.555] (II) Initializing extension XKEYBOARD
[  1049.555] (II) Initializing extension XC-MISC
[  1049.556] (II) Initializing extension SECURITY
[  1049.556] (II) Initializing extension XFIXES
[  1049.556] (II) Initializing extension RENDER
[  1049.557] (II) Initializing extension RANDR
[  1049.557] (II) Initializing extension COMPOSITE
[  1049.557] (II) Initializing extension DAMAGE
[  1049.558] (II) Initializing extension MIT-SCREEN-SAVER
[  1049.558] (II) Initializing extension DOUBLE-BUFFER
[  1049.558] (II) Initializing extension RECORD
[  1049.559] (II) Initializing extension DPMS
[  1049.559] (II) Initializing extension Present
[  1049.560] (II) Initializing extension DRI3
[  1049.560] (II) Initializing extension X-Resource
[  1049.560] (II) Initializing extension XVideo
[  1049.560] (II) Initializing extension XVideo-MotionCompensation
[  1049.561] (II) Initializing extension GLX
[  1049.561] (II) Initializing extension XFree86-VidModeExtension
[  1049.561] (II) Initializing extension XFree86-DGA
[  1049.562] (II) Initializing extension XFree86-DRI
[  1049.562] (II) Initializing extension DRI2
[  1049.565] (II) RADEON(0): Setting screen physical size to 361 x 203
[  1049.772] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[  1049.772] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[  1049.772] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  1049.772] (**) Power Button: Applying InputClass "system-keyboard"
[  1049.773] (II) LoadModule: "libinput"
[  1049.773] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[  1049.777] (II) Module libinput: vendor="X.Org Foundation"
[  1049.777] 	compiled for 1.21.1.3, module version = 1.2.1
[  1049.777] 	Module class: X.Org XInput Driver
[  1049.777] 	ABI class: X.Org XInput driver, version 24.4
[  1049.777] (II) Using input driver 'libinput' for 'Power Button'
[  1049.778] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 28 paused 0
[  1049.778] (**) Power Button: always reports core events
[  1049.778] (**) Option "Device" "/dev/input/event2"
[  1049.783] (II) event2  - Power Button: is tagged by udev as: Keyboard
[  1049.783] (II) event2  - Power Button: device is a keyboard
[  1049.784] (II) event2  - Power Button: device removed
[  1049.784] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[  1049.784] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  1049.784] (**) Option "xkb_layout" "us"
[  1049.786] (II) event2  - Power Button: is tagged by udev as: Keyboard
[  1049.786] (II) event2  - Power Button: device is a keyboard
[  1049.788] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[  1049.788] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[  1049.788] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[  1049.788] (**) Video Bus: Applying InputClass "system-keyboard"
[  1049.788] (II) Using input driver 'libinput' for 'Video Bus'
[  1049.790] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 31 paused 0
[  1049.791] (**) Video Bus: always reports core events
[  1049.791] (**) Option "Device" "/dev/input/event4"
[  1049.794] (II) event4  - Video Bus: is tagged by udev as: Keyboard
[  1049.794] (II) event4  - Video Bus: device is a keyboard
[  1049.795] (II) event4  - Video Bus: device removed
[  1049.795] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5/event4"
[  1049.795] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[  1049.795] (**) Option "xkb_layout" "us"
[  1049.798] (II) event4  - Video Bus: is tagged by udev as: Keyboard
[  1049.798] (II) event4  - Video Bus: device is a keyboard
[  1049.800] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[  1049.800] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[  1049.800] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  1049.801] (**) Power Button: Applying InputClass "system-keyboard"
[  1049.801] (II) Using input driver 'libinput' for 'Power Button'
[  1049.803] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 32 paused 0
[  1049.803] (**) Power Button: always reports core events
[  1049.803] (**) Option "Device" "/dev/input/event0"
[  1049.805] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  1049.806] (II) event0  - Power Button: device is a keyboard
[  1049.806] (II) event0  - Power Button: device removed
[  1049.806] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[  1049.806] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[  1049.806] (**) Option "xkb_layout" "us"
[  1049.808] (II) event0  - Power Button: is tagged by udev as: Keyboard
[  1049.808] (II) event0  - Power Button: device is a keyboard
[  1049.810] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[  1049.810] (II) No input driver specified, ignoring this device.
[  1049.810] (II) This device may have been added with another device file.
[  1049.811] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event6)
[  1049.811] (II) No input driver specified, ignoring this device.
[  1049.811] (II) This device may have been added with another device file.
[  1049.813] (II) config/udev: Adding input device Lenovo EasyCamera: Lenovo EasyC (/dev/input/event10)
[  1049.813] (**) Lenovo EasyCamera: Lenovo EasyC: Applying InputClass "evdev keyboard catchall"
[  1049.813] (**) Lenovo EasyCamera: Lenovo EasyC: Applying InputClass "libinput keyboard catchall"
[  1049.813] (**) Lenovo EasyCamera: Lenovo EasyC: Applying InputClass "system-keyboard"
[  1049.813] (II) Using input driver 'libinput' for 'Lenovo EasyCamera: Lenovo EasyC'
[  1049.815] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 33 paused 0
[  1049.815] (**) Lenovo EasyCamera: Lenovo EasyC: always reports core events
[  1049.815] (**) Option "Device" "/dev/input/event10"
[  1049.818] (II) event10 - Lenovo EasyCamera: Lenovo EasyC: is tagged by udev as: Keyboard
[  1049.818] (II) event10 - Lenovo EasyCamera: Lenovo EasyC: device is a keyboard
[  1049.819] (II) event10 - Lenovo EasyCamera: Lenovo EasyC: device removed
[  1049.819] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:13.2/usb2/2-1/2-1:1.0/input/input11/event10"
[  1049.819] (II) XINPUT: Adding extended input device "Lenovo EasyCamera: Lenovo EasyC" (type: KEYBOARD, id 9)
[  1049.819] (**) Option "xkb_layout" "us"
[  1049.822] (II) event10 - Lenovo EasyCamera: Lenovo EasyC: is tagged by udev as: Keyboard
[  1049.823] (II) event10 - Lenovo EasyCamera: Lenovo EasyC: device is a keyboard
[  1049.824] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event8)
[  1049.824] (II) No input driver specified, ignoring this device.
[  1049.824] (II) This device may have been added with another device file.
[  1049.825] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event7)
[  1049.825] (II) No input driver specified, ignoring this device.
[  1049.825] (II) This device may have been added with another device file.
[  1049.826] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event5)
[  1049.826] (**) Ideapad extra buttons: Applying InputClass "evdev keyboard catchall"
[  1049.826] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[  1049.826] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[  1049.826] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[  1049.829] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 34 paused 0
[  1049.829] (**) Ideapad extra buttons: always reports core events
[  1049.829] (**) Option "Device" "/dev/input/event5"
[  1049.832] (II) event5  - Ideapad extra buttons: is tagged by udev as: Keyboard
[  1049.832] (II) event5  - Ideapad extra buttons: device is a keyboard
[  1049.832] (II) event5  - Ideapad extra buttons: device removed
[  1049.832] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input6/event5"
[  1049.832] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 10)
[  1049.832] (**) Option "xkb_layout" "us"
[  1049.835] (II) event5  - Ideapad extra buttons: is tagged by udev as: Keyboard
[  1049.835] (II) event5  - Ideapad extra buttons: device is a keyboard
[  1049.836] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[  1049.837] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[  1049.837] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[  1049.837] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[  1049.837] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[  1049.839] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 35 paused 0
[  1049.839] (**) AT Translated Set 2 keyboard: always reports core events
[  1049.839] (**) Option "Device" "/dev/input/event3"
[  1049.842] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[  1049.842] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[  1049.844] (II) event3  - AT Translated Set 2 keyboard: device removed
[  1049.844] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[  1049.844] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
[  1049.844] (**) Option "xkb_layout" "us"
[  1049.847] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[  1049.847] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[  1049.850] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event9)
[  1049.850] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[  1049.850] (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
[  1049.850] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad"
[  1049.850] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[  1049.853] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 36 paused 0
[  1049.853] (**) ETPS/2 Elantech Touchpad: always reports core events
[  1049.853] (**) Option "Device" "/dev/input/event9"
[  1049.855] (II) event9  - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[  1049.858] (II) event9  - ETPS/2 Elantech Touchpad: device is a touchpad
[  1049.858] (II) event9  - ETPS/2 Elantech Touchpad: device removed
[  1049.858] (**) Option "Tapping" "on"
[  1049.859] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event9"
[  1049.859] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 12)
[  1049.861] (**) Option "AccelerationScheme" "none"
[  1049.861] (**) ETPS/2 Elantech Touchpad: (accel) selected scheme none/0
[  1049.861] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[  1049.861] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[  1049.863] (II) event9  - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[  1049.867] (II) event9  - ETPS/2 Elantech Touchpad: device is a touchpad
[  1049.868] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse0)
[  1049.868] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad"
[  1049.868] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[  1049.869] (**) ETPS/2 Elantech Touchpad: always reports core events
[  1049.869] (**) Option "Device" "/dev/input/mouse0"
[  1049.956] (II) mouse0  - not using input device '/dev/input/mouse0'.
[  1049.956] (EE) libinput: ETPS/2 Elantech Touchpad: Failed to create a device for /dev/input/mouse0
[  1049.956] (EE) PreInit returned 2 for "ETPS/2 Elantech Touchpad"
[  1049.956] (II) UnloadModule: "libinput"
[  1050.109] (**) Option "fd" "28"
[  1050.109] (II) event2  - Power Button: device removed
[  1050.109] (**) Option "fd" "31"
[  1050.109] (II) event4  - Video Bus: device removed
[  1050.110] (**) Option "fd" "32"
[  1050.110] (II) event0  - Power Button: device removed
[  1050.110] (**) Option "fd" "33"
[  1050.110] (II) event10 - Lenovo EasyCamera: Lenovo EasyC: device removed
[  1050.110] (**) Option "fd" "34"
[  1050.110] (II) event5  - Ideapad extra buttons: device removed
[  1050.110] (**) Option "fd" "35"
[  1050.110] (II) event3  - AT Translated Set 2 keyboard: device removed
[  1050.110] (**) Option "fd" "36"
[  1050.110] (II) event9  - ETPS/2 Elantech Touchpad: device removed
[  1050.112] (II) UnloadModule: "libinput"
[  1050.112] (II) systemd-logind: releasing fd for 13:73
[  1050.169] (II) UnloadModule: "libinput"
[  1050.169] (II) systemd-logind: releasing fd for 13:67
[  1050.196] (II) UnloadModule: "libinput"
[  1050.196] (II) systemd-logind: releasing fd for 13:69
[  1050.262] (II) UnloadModule: "libinput"
[  1050.262] (II) systemd-logind: releasing fd for 13:74
[  1050.316] (II) UnloadModule: "libinput"
[  1050.316] (II) systemd-logind: releasing fd for 13:64
[  1050.342] (II) UnloadModule: "libinput"
[  1050.342] (II) systemd-logind: releasing fd for 13:68
[  1050.383] (II) UnloadModule: "libinput"
[  1050.383] (II) systemd-logind: releasing fd for 13:66
[  1050.504] (II) Server terminated successfully (0). Closing log file.
:thinking:
the log looks ok …
reinstall the driver:
sudo mhwd -r pci video-linux
install it:
sudo mhwd -i pci video-linux
and also reinstall this, since its mentioned in the pic above:
sudo pacman -S libglvnd lib32-libglvnd
reboot
Nope. Did everything but it’s still the same.
post output from:
sudo find /usr/ -name libGL.so.1
/usr/lib32/libGL.so.1
/usr/lib/libGL.so.1
/usr/share/Cg/examples/Trace/libGL.so.1
post output from:
ls -l /usr/lib64/libGL.so*
pacman -Qs nvidia
those libgl.so.304 shouldnt be there, i think they are related to nvidia …
remove this:
sudo pacman -R nvidia-cg-toolkit
reboot
Still the same. Any way we can like reset Xorg? I have a strong feeling Xorg is what is causing all of this. Also, startx still displays the same error from before.
i think its because of this: libGL.so.1
post again output from this:
to see if it was removed but not the symlink
Exact same output from before. So it didn’t remove?
no it didnt …
does this return something?:
pacman -Qo /usr/lib64/libGL.so.304.132
error: No package owns /usr/lib64/libGL.so.304.132
ok so probably create the proper symlinks should fix it, so post output from this, then we create the symlinks to the proper libGL:
ls -l /usr/lib/libGL.so*
ls -l /usr/lib32/libGL.so*
ok so run this:
ln -s /usr/lib64/libGL.so.1 /usr/lib64/libGL.so.1.7.0
ln -s /usr/lib/libGL.so.1 /usr/lib/libGL.so.1.7.0
then check again with:
if they look like this:
/usr/lib64/libGL.so.1 -> libGL.so.1.7.0
/usr/lib/libGL.so.1 -> libGL.so.1.7.0
reboot and see if it helped, if not we try reinstall xorg, mesa, opengl …
