System doesn't boot after kernel update
Hi!
An update arrived for kernels 6.3 and 6.1(lts), after which the system stopped booting normally with these kernels. While switched to 6.2.
Boot log on 6.3:
journalctl -b-1 -p4 --no-pager
june 03 23:57:29 laptop kernel:   2  3  4  5  6  7  8  9 10 11 12 13 14 15
june 03 23:57:29 laptop kernel: ACPI BIOS Error (bug): Failure creating named object [\RESV], AE_ALREADY_EXISTS (20221020/dsfield-637)
june 03 23:57:29 laptop kernel: ACPI Warning: NsLookup: Type mismatch on RESV (IndexField), searching for (RegionField) (20221020/nsaccess-696)
june 03 23:57:29 laptop kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._PRR], AE_ALREADY_EXISTS (20221020/dswload2-326)
june 03 23:57:29 laptop kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20221020/psobject-220)
june 03 23:57:29 laptop kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._RMV], AE_ALREADY_EXISTS (20221020/dswload2-326)
june 03 23:57:29 laptop kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GP17.XHC1.RHUB.PRT3._PRR], AE_ALREADY_EXISTS (20221020/dswload2-326)
june 03 23:57:29 laptop kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.WLPS], AE_ALREADY_EXISTS (20221020/dswload2-326)
june 03 23:57:29 laptop kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PRWL], AE_ALREADY_EXISTS (20221020/dswload2-326)
june 03 23:57:29 laptop kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.BLPS], AE_ALREADY_EXISTS (20221020/dswload2-326)
june 03 23:57:29 laptop kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PRWB], AE_ALREADY_EXISTS (20221020/dswload2-326)
june 03 23:57:29 laptop kernel: pci 0000:00:08.1: can't derive routing for PCI INT A
june 03 23:57:29 laptop kernel: pci 0000:00:08.1: PCI INT A: not connected
june 03 23:57:29 laptop kernel: pci 0000:00:08.3: can't derive routing for PCI INT A
june 03 23:57:29 laptop kernel: pci 0000:00:08.3: PCI INT A: not connected
june 03 23:57:29 laptop kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
june 03 23:57:29 laptop kernel: pci 0000:00:00.2: PCI INT A: not connected
june 03 23:57:29 laptop kernel: hpet_acpi_add: no address or irqs in _CRS
june 03 23:57:29 laptop kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
june 03 23:57:29 laptop kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
june 03 23:57:29 laptop kernel: memfd_create() without MFD_EXEC nor MFD_NOEXEC_SEAL, pid=1 'systemd'
june 03 23:57:29 laptop systemd-journald[362]: File /var/log/journal/12cf7ec92b2846a19c5e8bd2cc5b9d8e/system.journal corrupted or uncleanly shut down, renaming and replacing.
june 03 23:57:29 laptop kernel: mt7921e 0000:01:00.0: sar cnt = 0
june 03 23:57:30 laptop kernel: BUG: kernel NULL pointer dereference, address: 0000000000000000
june 03 23:57:30 laptop kernel: PF: supervisor read access in kernel mode
june 03 23:57:30 laptop kernel: PF: error_code(0x0000) - not-present page
june 03 23:57:30 laptop kernel: Oops: 0000 [1] PREEMPT SMP NOPTI
june 03 23:57:30 laptop kernel: CPU: 0 PID: 20 Comm: kworker/0:1 Not tainted 6.3.5-1-MANJARO 1 cfdfa49425c1fa5e73cd569c5d56ac8fde9928c4
june 03 23:57:30 laptop kernel: Hardware name: ASUSTeK COMPUTER INC. Vivobook_ASUSLaptop M3402RA_M3402RA/M3402RA, BIOS M3402RA.305 02/16/2023
june 03 23:57:30 laptop kernel: Workqueue: events_long ucsi_init_work [typec_ucsi]
june 03 23:57:30 laptop kernel: RIP: 0010:ucsi_acpi_async_write+0x30/0x50 [ucsi_acpi]
june 03 23:57:30 laptop kernel: Code: 44 00 00 41 55 49 89 cd 41 54 49 89 d4 55 53 89 f3 e8 d4 5d fb ff 4c 89 e6 89 df 4c 89 ea 48 03 78 10 48 89 c5 e8 00 4b a8 f9 <49> 8b 04 24 48 89 ef be 01 00 00 00 48 89 45 50 5b 5d 41 5c 41 5d
june 03 23:57:30 laptop kernel: RSP: 0018:ffff9e01001c7d80 EFLAGS: 00010246
june 03 23:57:30 laptop kernel: RAX: ffff9e0100718f4c RBX: 0000000000000002 RCX: 0000000000000000
june 03 23:57:30 laptop kernel: RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff9e0100718f4c
june 03 23:57:30 laptop kernel: RBP: ffff8f6083a42828 R08: 0000000000000000 R09: ffff8f60ab1b7560
june 03 23:57:30 laptop kernel: R10: ffffffffba74fca0 R11: 0000000000000014 R12: 0000000000000000
june 03 23:57:30 laptop kernel: R13: 0000000000000000 R14: ffff8f608fa432b8 R15: 0000000000000000
june 03 23:57:30 laptop kernel: FS:  0000000000000000(0000) GS:ffff8f638e600000(0000) knlGS:0000000000000000
june 03 23:57:30 laptop kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
june 03 23:57:30 laptop kernel: CR2: 0000000000000000 CR3: 000000024ec20000 CR4: 0000000000750ef0
june 03 23:57:30 laptop kernel: PKRU: 55555554
june 03 23:57:30 laptop kernel: Call Trace:
june 03 23:57:30 laptop kernel:  <TASK>
june 03 23:57:30 laptop kernel:  ? __die+0x23/0x70
june 03 23:57:30 laptop kernel:  ? page_fault_oops+0x171/0x4e0
june 03 23:57:30 laptop kernel:  ? exc_page_fault+0x74/0x170
june 03 23:57:30 laptop kernel:  ? asm_exc_page_fault+0x26/0x30
june 03 23:57:30 laptop kernel:  ? ucsi_acpi_async_write+0x30/0x50 [ucsi_acpi c236ae5c5895bdc6a85745dd8cd4d6c9957ca2ef]
june 03 23:57:30 laptop kernel:  ucsi_exec_command+0x24e/0x2d0 [typec_ucsi 642b016471bc2c19d4cde20431192d8d7ef42737]
june 03 23:57:30 laptop kernel:  ucsi_send_command+0x4b/0xe0 [typec_ucsi 642b016471bc2c19d4cde20431192d8d7ef42737]
june 03 23:57:30 laptop kernel:  ucsi_init_work+0x72/0x9a0 [typec_ucsi 642b016471bc2c19d4cde20431192d8d7ef42737]
june 03 23:57:30 laptop kernel:  process_one_work+0x1c8/0x3c0
june 03 23:57:30 laptop kernel:  worker_thread+0x51/0x390
june 03 23:57:30 laptop kernel:  ? __pfx_worker_thread+0x10/0x10
june 03 23:57:30 laptop kernel:  kthread+0xde/0x110
june 03 23:57:30 laptop kernel:  ? __pfx_kthread+0x10/0x10
june 03 23:57:30 laptop kernel:  ret_from_fork+0x2c/0x50
june 03 23:57:30 laptop kernel:  </TASK>
june 03 23:57:30 laptop kernel: Modules linked in: snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils amdgpu(+) intel_rapl_msr snd_soc_core intel_rapl_common mt7921e edac_mce_amd mt7921_common snd_compress mt76_connac_lib ac97_bus snd_hda_codec_realtek kvm_amd snd_pcm_dmaengine mt76 snd_hda_codec_generic snd_hda_codec_hdmi snd_pci_ps snd_hda_intel joydev snd_rpl_pci_acp6x kvm uvcvideo snd_intel_dspcfg mousedev videobuf2_vmalloc drm_buddy irqbypass snd_acp_pci snd_intel_sdw_acpi mac80211 uvc crct10dif_pclmul gpu_sched btusb snd_hda_codec videobuf2_memops crc32_pclmul btrtl i2c_algo_bit snd_pci_acp6x asus_nb_wmi polyval_clmulni btbcm libarc4 polyval_generic snd_pci_acp5x snd_hda_core asus_wmi btintel gf128mul snd_rn_pci_acp3x snd_hwdep drm_ttm_helper btmtk ghash_clmulni_intel ledtrig_audio vfat videobuf2_v4l2 fat hid_multitouch sparse_keymap wmi_bmof cfg80211 ttm snd_acp_config sha512_ssse3 snd_pcm videodev bluetooth aesni_intel ucsi_acpi drm_display_helper snd_soc_acpi crypto_simd videobuf2_common snd_timer video
june 03 23:57:30 laptop kernel:  typec_ucsi sp5100_tco cryptd ecdh_generic snd crc16 mc rapl typec pcspkr ccp cec soundcore snd_pci_acp3x i2c_piix4 k10temp rfkill roles wmi i2c_hid_acpi amd_pmf amd_pmc platform_profile i2c_hid acpi_cpufreq acpi_tad mac_hid dm_multipath crypto_user fuse dm_mod loop bpf_preload ip_tables x_tables btrfs blake2b_generic xor raid6_pq libcrc32c crc32c_generic serio_raw nvme atkbd libps2 nvme_core vivaldi_fmap xhci_pci nvme_common i8042 crc32c_intel xhci_pci_renesas serio
june 03 23:57:30 laptop kernel: ---[ end trace 0000000000000000 ]---
june 03 23:57:31 laptop kernel: amdgpu: SRAT table not found
june 03 23:57:32 laptop kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
june 03 23:57:32 laptop kernel: kauditd_printk_skb: 15 callbacks suppressed
june 03 23:57:32 laptop bluetoothd[544]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
june 03 23:57:32 laptop bluetoothd[544]: src/plugin.c:plugin_init() Failed to init vcp plugin
june 03 23:57:32 laptop bluetoothd[544]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
june 03 23:57:32 laptop bluetoothd[544]: src/plugin.c:plugin_init() Failed to init mcp plugin
june 03 23:57:32 laptop bluetoothd[544]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
june 03 23:57:32 laptop bluetoothd[544]: src/plugin.c:plugin_init() Failed to init bap plugin
june 03 23:57:43 laptop kernel: kauditd_printk_skb: 98 callbacks suppressed
june 03 23:58:02 laptop dbus-daemon[546]: [system] Connection has not authenticated soon enough, closing it (auth_timeout=30000ms, elapsed: 30002ms)
On 6.1 the same picture as on 6.3.
inxi --admin --verbosity=7 --filter --width
  Kernel: 6.2.16-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.2-x86_64
    root=UUID=c247bf58-3352-4679-abde-98bc71026a54 rw rootflags=subvol=@ quiet
    resume=UUID=a9953d13-c4c4-4d06-b498-b52c164dd271 udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 info: plank wm: kwin_x11
    vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop M3402RA_M3402RA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: M3402RA v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: M3402RA.305 date: 02/16/2023
  ID-1: BAT0 charge: 70.1 Wh (100.0%) condition: 70.1/70.2 Wh (99.9%)
    volts: 12.9 min: 11.9 model: K340258 type: Li-ion serial: N/A
    status: discharging
  System RAM: available: 14.89 GiB used: 3.17 GiB (21.3%)
  Info: model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404101
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 1569 high: 1600 min/max: 1600/4784 boost: disabled
    scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1600 2: 1600
    3: 1600 4: 1600 5: 1600 6: 1600 7: 1351 8: 1600 9: 1600 10: 1600 11: 1600
    12: 1354 13: 1600 14: 1600 15: 1600 16: 1600 bogomips: 102246
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
    ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
    tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
    vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
    v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
    DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:1681
    class-ID: 0300 temp: 38.0 C
  Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 13d3:5463
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2880x1800 s-dpi: 96 s-size: 762x476mm (30.00x18.74")
    s-diag: 898mm (35.37")
  Monitor-1: eDP-1 mapped: eDP model: Samsung 0x4171 built: 2020
    res: 2880x1800 hz: 90 dpi: 242 gamma: 1.2 size: 302x189mm (11.89x7.44")
    diag: 356mm (14") ratio: 16:10 modes: max: 2880x1800 min: 640x480
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (rembrandt
    LLVM 15.0.7 DRM 3.49 6.2.16-1-MANJARO) direct-render: Yes
  Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1
    chip-ID: 1002:1640 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
    driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.2.16-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF-ID-1: docker0 state: down mac: <filter>
  IF-ID-2: virbr0 state: down mac: <filter>
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:3563
  Local Storage: total: 953.87 GiB used: 91.91 GiB (9.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL41T0HBLB-00BTW
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HXC70W1Q temp: 27.9 C
    scheme: GPT
  ID-1: / raw-size: 937.19 GiB size: 937.19 GiB (100.00%) used: 91.9 GiB (9.8%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: c247bf58-3352-4679-abde-98bc71026a54
    used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: D996-9F65
  ID-3: /home raw-size: 937.19 GiB size: 937.19 GiB (100.00%)
    used: 91.9 GiB (9.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  ID-4: /var/cache raw-size: 937.19 GiB size: 937.19 GiB (100.00%)
  ID-5: /var/log raw-size: 937.19 GiB size: 937.19 GiB (100.00%)
  Kernel: swappiness: 1 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 16.38 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: a9953d13-c4c4-4d06-b498-b52c164dd271
  Device-1: 1-3:12 info: Realtek USB2.0 Finger Print Bridge FocalTech
    Fingerprint Device type: <vendor specific> driver: N/A interfaces: 1
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
    chip-ID: 2808:a658 class-ID: 0000
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
  Device-1: 3-3:2 info: IMC Networks Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: IMC Networks USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 13d3:5463 class-ID: fe01 serial: <filter>
  Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-10: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
  Processes: 356 Uptime: 5m wakeups: 291 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: 1399 pm: pacman pkgs: 1388 libs: 354 tools: pamac pm: flatpak
  pkgs: 11 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.27
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already searched for your problem in the forum ? (Wisdom lies in reading :wink: )
Hello.
I added information.
In general, I studied the log more closely. The problem is in the ucsi_acpi module, I added it to the blacklist and everything worked.
But I don’t think it’s normal. What is this module for?
usb type-c support, ACPI = some sort of autoconfiguration issue for it?
I need usb type-c(
the problem is that kernel 6.1, 6.3, 6.4 are not loaded with this module, 6.2 and 5.15 are loaded.
I attached the log in the first post.
can you try booting without any usb-c devices attached and see if it works?
The issue manifests itself without connected devices.
the log in the first post was taken without connected devices.
Maybe manjaro team can chime in and tell if there was anything special in kernel 6.2 config, otherwise it seems you need to take the issue upstream.
The problem appeared after a recent kernel update. before that everything was working correctly.
which kernels do you know it worked on before?
edit: the reason it works on 6.2 might be that it was not updated, as it is EOL?
5.15, 6.1, 6.2, 6.3
I used 6.3 when the problem appeared
It’s working for 5.15 too.
did 5.15 get updated at same time when the other ones stopped working?
no, a little later. but 5.15 was also updated
if my suspicion is correct that 6.2 has not been updated due to being EOL, and therefore works, then there is some issue with modern kernel point releases on your system (unless manjaro did some config changes, which i doubt). From what i can see, you need to take the issue to kernel.org
but you might want to wait for a second opinion.
*upd
type-c works correctly with the module disabled.
yeah i would think acpi relates to power management or similar
edit: Linux Kernel Driver DataBase: CONFIG_UCSI: USB Type-C Connector System Software Interface driver
