System crashes every 1-2 days
I’m having trouble finding something. I have a rockpro64 running Manjaro. It has KDE on it but for the most part just hosts files, jellyfin, and homebridge. I saw it had an uptime of about 16-18 hours and it seemed to be running out of ram. plasmashell had a nasty memory leak. So I killed the desktop environment and ran it without to see if the problem went away.
It only lasted a few days before I had to power cycle it again. I’m not seeing anything weird in journalctl. What should I be looking for?
:+1: Welcome to Manjaro! :+1:
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  1. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
  2. Please read this:
    [HowTo] reboot / turn off your frozen computer: REISUB/REISUO
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel you have, …
I caught it! It crashed while my Mac was doing an automatic backup and complained about a lost connection with the server. I happened to be in front of it so I GOT IT! Finally, evidence!
I disabled the desktop environment to get it running longer. It doesn’t last as long with GNOME or KDE are running. By power cycle, it means I had to pull the power cord.
Well, while Plasmashell in general is pretty performant, it does tend to use more RAM as it’s been running.
Your issue, I think, is that you are also running Jellyfin, which is much more of a RAM hog, than Plasma is.
Jellyfin and Plasma can separately run on the RockPro64 for weeks (I know, since I do it) without running out of RAM, but if you run both, I would suspect it runs out quicker.
MayBe:
To me, that does not look like it is a memory error or an out of memory error. It looks more like a either a scsi driver bug or a hardware fault. Still 2G of free and no swap at all used by looking at what is left of the htop screen.
If it was me I would be upgrading the system. It looks like it has not been upgraded in a while. That kernel is at 5.10.17-1 now on the stable branch.
[ray@rock64 ~]$ uname -r
5.10.17-1-MANJARO-ARM
I have run it that way just fine for quite a while now. This problem is recent. Plasma only started gobbling memory recently but even with it closed out I crash. It just buys me more time.
I’ll give that a shot, though if I remember right, this all started after I ran an upgrade.
That is defiantly what I would do then. The kernel could very well be the issue not meshing with other program’s libs and at the same time there can be issues with the other programs lib’s so best to do a full system upgrade to try to alleviate any possible underlining issues that may be causing the kernel panic.
