System Crash during update
Hello
System during update just crash and now I can’t log in. Downloaded manajro USB and I’m on manjaro-chroot -a
the errors are:
pacman-key --init
gpg: symbol lookup error: /usr/lib/libsqlite3.so.0: undefined symbol: exp, version GLIBC_2.29
awk: symbol lookup error: awk: undefined symbol: exp, version GLIBC_2.29
==> Generating pacman master key. This may take some time.
==> Updating trust database...
==> ERROR: Trust database could not be updated.
[manjaro-gnome pkg]#
pacman -Syyu
error: GPGME error: Invalid crypto engine
error: lib32-glibc: missing required signature
:: File /var/cache/pacman/pkg/lib32-glibc-2.36-5-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] ^[[A^[[B
error: xz: missing required signature
:: File /var/cache/pacman/pkg/xz-5.2.7-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: apache: missing required signature
:: File /var/cache/pacman/pkg/apache-2.4.54-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: cairomm: missing required signature
:: File /var/cache/pacman/pkg/cairomm-1.14.4-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] n
error: pango: missing required signature
:: File /var/cache/pacman/pkg/pango-1:1.50.11-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: hwdata: missing required signature
:: File /var/cache/pacman/pkg/hwdata-0.363-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] n^C
Interrupt signal received
[manjaro-gnome pkg]# pacman -U https://mirror.alpix.eu/manjaro/stable/core/x86_64/lib32-glibc-2.36-5-x86_64.pkg.tar.zst
loading packages...
error: '/var/cache/pacman/pkg/lib32-glibc-2.36-5-x86_64.pkg.tar.zst': invalid or corrupted package (PGP signature)
System can’t be updated :confused:
try running these from chroot of course:
rm -f /var/lib/pacman/sync/*
rm -rf /etc/pacman.d/gnupg
pacman -Scc
pacman-key --init
pacman-key --populate manjaro archlinux
pacman-key --refresh
pacman -Syu
can’t add new key because glib error
[manjaro-gnome pkg]# pacman-key --init
chmod: cannot access '/etc/pacman.d/gnupg//trustdb.gpg': No such file or directory
so exit chroot with:
exit
then run this:
sudo sed -i 's/ trap/#trap/' /usr/lib/manjaro-tools/util-mount.sh
exit | manjaro-chroot -a
sudo pacman-mirrors -f5
sudo pacman --sysroot /mnt -Qqn | sudo pacman --sysroot /mnt -Syu -
Packages are downloading
Could You explain all commands? The whole packages in the system are downloaded again?
did it already finished?
we used external pacman - from live usb - to repair your system … maybe reinstalling only glibc would be enough?
Packages are still downloading Current: 1600/2265
Maybe :confused:
But error again:
warning: Public keyring not found; have you run 'pacman-key --init'?
error: linux-api-headers: missing required signature
:: File /var/cache/pacman/pkg/linux-api-headers-5.18.15-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
so if you press y, what happens?
How do that?
I have still errors:
error: ca-certificates: missing required signature
:: File /var/cache/pacman/pkg/ca-certificates-20220905-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: brotli: missing required signature
:: File /var/cache/pacman/pkg/brotli-1.0.9-8-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libnghttp2: missing required signature
:: File /var/cache/pacman/pkg/libnghttp2-1.50.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpsl: missing required signature
:: File /var/cache/pacman/pkg/libpsl-0.21.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
:: File /var/cache/pacman/pkg/brotli-1.0.9-8-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package :: File /var/cache/pacman/pkg/zita-resampler-1.8.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: zsh: missing required signature
:: File /var/cache/pacman/pkg/zsh-5.9-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: zsh-completions: missing required signature
:: File /var/cache/pacman/pkg/zsh-completions-0.34.0-2-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package (PGP signature))
ok, so lets try this, instead of trying to fix the signatures issues with commands:
open this file:
kate /mnt/etc/pacman.conf and edit this line:
SigLevel = Required DatabaseOptional - its on the 45 line
to look like this:
SigLevel = Optional TrustAll
save the file and try running the update again
Changed the line to
The whole packages are downloading again :confused:
Total (   4/2221)
cancel it, and rerun update only:
Same error:
Do you want to delete it? [Y/n] Y
error: xkeyboard-config: missing required signature
:: File /var/cache/pacman/pkg/xkeyboard-config-2.37-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: code: missing required signature
:: File /var/cache/pacman/pkg/code-1.72.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: dconf-editor: missing required signature
:: File /var/cache/pacman/pkg/dconf-editor-43.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
:: File /var/cache/pacman/pkg/yelp-xsl-42.1-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
in pacman.conf there are lines:
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
Maybe sigLevel also change?
Changed this and rerun sudo pacman --sysroot /mnt -Syu and still the same error
chnaged to NEVER and packages are upgrading
ok good, hopefully no more errors
