System Crash during update
awk: symbol lookup error: awk: undefined symbol: exp, version GLIBC_2.29
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.19-x86_64-fallback.img
==> WARNING: errors were encountered during the build. The image may not be complete.
error: command failed to execute correctly
(11/20) Updating Kernel initcpios for Nvidia-DRM...
(12/20) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.19-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.19-x86_64.img
Found initrd fallback image: /boot/initramfs-5.19-x86_64-fallback.img
fgrep: warning: fgrep is obsolescent; using grep -F
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sda1.  Check your device.map.
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
(13/20) Reloading system bus configuration...
  Skipped: Running in chroot.
(14/20) Warn about old perl modules
perl: symbol lookup error: /usr/lib/perl5/5.36/core_perl/CORE/libperl.so: undefined symbol: exp, version GLIBC_2.29
WARNING: '/usr/lib/perl5/5.36' contains data from at least 112 packages which will NOT be used by the installed perl interpreter.
 -> Run the following command to get a list of affected packages: pacman -Qqo '/usr/lib/perl5/5.36'
(15/20) Copy Firefox Distribution Settings
(16/20) Compiling GSettings XML schema files...
No such key “bulk-rename-tool” in schema “org.gnome.nautilus.preferences” as specified in override file “/usr/share/glib-2.0/schemas/50_nautilus-renamer.gschema.override”; ignoring override for this key.
(17/20) Updating icon theme caches...
gtk-update-icon-cache: symbol lookup error: /usr/lib/libtiff.so.5: undefined symbol: exp, version GLIBC_2.29
(18/20) Updating the info directory file...
(19/20) Updating the desktop file MIME type cache...
(20/20) Updating the vlc plugin cache...
Failed loading SDL2 library.
error: command terminated by signal 6: Aborted
ech how to reinstall this glib c :expressionless:
try with overwrite:
sudo pacman --sysroot /mnt -S glibc --overwrite '*'
warning: glibc-2.36-5 is up to date -- reinstalling
resolving dependencies...
Packages (1) glibc-2.36-5
Total Installed Size:  47.36 MiB
Net Upgrade Size:       0.00 MiB
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring        [#############################################################################] 100%
(1/1) checking package integrity        [#############################################################################] 100%
(1/1) loading package files        [#############################################################################] 100%
(1/1) checking for file conflicts        [#############################################################################] 100%
(1/1) checking available disk space        [#############################################################################] 100%
warning: could not get file information for var/db/Makefile
(1/1) reinstalling glibc        [#############################################################################] 100%
Generating locales...
  en_US.UTF-8... done
  pl_PL.UTF-8... done
Generation complete.
(1/5) Reloading system manager configuration...
(2/5) Creating temporary files...
Failed to open file "/sys/devices/system/cpu/microcode/reload": Read-only file system
(3/5) Arming ConditionNeedsUpdate...
(4/5) Restarting cronie for libc upgrade...
Running in chroot, ignoring command 'try-restart'
(5/5) Updating the info directory file...
hm… it is reinstalled?
yes it reinstalled, so rerun the update again:
sudo pacman --sysroot /mnt -Syu
[manjaro-gnome manjaro]# sudo pacman --sysroot /mnt -Syu
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
 there is nothing to do
oh … should I reboot?
I think I should run command to find the kernel and update the grub?
check first this:
mhwd-kernel -li
Currently running: 5.15.60-1-MANJARO (linux515)
warning: database file for 'core' does not exist (use '-Sy' to download)
warning: database file for 'extra' does not exist (use '-Sy' to download)
warning: database file for 'community' does not exist (use '-Sy' to download)
warning: database file for 'multilib' does not exist (use '-Sy' to download)
   * linux515
close the terminal, open terminal, chroot, and check kernels:
mhwd-kernel -li
    ~  manjaro-chroot -a                                                ✔
==> Mounting (ManjaroLinux) [/dev/nvme0n1p1]
 --> mount: [/mnt]
mount: /mnt: /dev/nvme0n1p1 already mounted on /mnt.
       dmesg(1) may have more information after failed mount system call.
 --> mount: [/mnt/boot/efi]
mount: /mnt/boot/efi: /dev/nvme0n1p4 already mounted on /mnt/boot/efi.
mount: /mnt/sys: sys already mounted on /sys.
[manjaro-gnome /]# mhwd-kernel -li
   * linux510
   * linux515
   * linux519
[manjaro-gnome /]# ^C
[manjaro-gnome /]#
so no end of life kernels, reboot and see if it helped
YEAH!!!
The kernel inux519 after picking shows errors but when I’ve changed to 5.15.72-1-MANJARO (linux515) the system STARTS!!
YOU R AWESOME! Thanks a lot.
Ech. Should I update the system again? What I did wrong?
yes rerun update again, then uninstall the linux519, then install it again, reboot and try boot with it…
i dont know what did you do when the system crashed during updating… maybe you didnt do anything and it just crashed, that happens…
