recently I try to install hyperland on my manjaro linux system. what I have done is to run the command from https://github.com/prasanthrangan/hyprdots. in the installation process I notice that it replace two packages, which are linux66-nvidia to nvidia-dkms and pipewire-jack to jack2. after it install successfully, I reboot and go back, it just boot into a asus logo and stuck at it. I replace several drivers and it attaiined no significant change. So I come to the forum. Any help will be appreciated.
currently my drivers are video-linux, video-nvidia, video-modesetting, replacing video-nvidia to video-hybrid-intel-nvidia-prime won’t help.
Also, adding nomodeset to the boot params will not help either
forgot to say, my original desktop environment was kde plasma 6, so I guess it hasn’t crashed? so as a side request I want to know how to directly switch back to kde in tty? I guess it can bring me back to a graphical interface.
The installation script is designed for a minimal Arch Linux install, but may work on some Arch-based distros. While installing HyDE alongside another DE/WM should work, due to it being a heavily customized setup, it will conflict with your GTK/Qt theming, Shell, SDDM, GRUB, etc. and is at your own risk.
To (probably only partially) revert it, run the installer script with the “restore” option
You might need to edit the code for that - it would be on line 35, I guess.
But perhaps the script can be given an option when you run it - don’t know.
To be able to run the script again, you’d need to chroot into your system, since it apparently doesn’t boot on it’s own.
Need a bootable medium for that.
Afterwards - if you get there - make sure you switch to nvidia-dkms on your own and make sure it works,
before you try again.
I cannot figure out a way to give the content out of tty… Do you know how to give out that? I would use that as soon as I know how.
nope, I learn that lesson.
not quite sure how to do it. I indeed have a bootable usb pendrive, but it is not the one I install manjaro on that computer. besides, I read the issues on that github page and actually someone successfully installed it on manjaro, but it was like half a year ago, so I guess its just some conflict packages? or different drivers.
in this issue it seems that someone had sucess before with original manjaro kde plasma
And after all i actully wish to install hyperland successfully eventually
and it seems that there are many restore shell script in it. not quite sure which to run, they are:
What I meant was to edit the install.sh itself (set a value on that line 35 to 1 instead of zero)
But that was also only speculation.
How to send command output to a file or, in this case, to some online pastebin:
some_command | curl -F 'file=@-' https://0x0.st
I cannot really help here (hand holding seems to be needed)
since I do not even have a Nvidia card and all the very scant knowledge I have is from reading about it.
I have zero experience with them.
But if you do have a TTY, you don’t need chroot.
It should be quite easy to restore your previous graphics configuration.
But that is not all the script did.
It altered much more.
Yeah, you are right, it seems the script has go for a long way, so it is hard to revert it. The display-manager is fine so i guess i am close to it… But really need extra help. I actually don’t quite want to revert it.
As I said, i guess not much are needed to be done. Oh, the grub menu has also been changed by the scripts
I directly run Hyprland after logged into the system in tty, it allows me to going into it. But I first logged in tty to type that. I didn’t actually get a login page of hyperland. and I find no way to restart my kde either.
It is not quite a good solution, only temporarily
I also cannot have vscode started properly in hyprland it crashed, with the warning:
Warning: 'ozone-platform-hint' is not in the list of known options, but still passed to Electron/Chromium
this command gives me:
Failed to start hyprland.service: Unit hyprland.service not found
https://vimeo.com/manage/videos/1001468638
hmm, this is my current situation.
I guess we can easily switch between desktop env right? with graphic interface. I think I can have my kde back when I access at the login page. And I cannot start my vscode and obsidian both in hyprland, which is weird.
yes, to a certain degree, but I think it is not a smooth usage. And I just find that I cannot open my obsidian either
Another update, if I directly type the password blindly under the asus logo, it will login. so it means that the login page is totally not shown.
Hi @linux-aarhus
I have a few back and forth with developers of hyprdots in a github issue. We managed to find out that the problems is caused by not properly loaded sddm. You can refer for more detailed information in this github issue: boot into black screen after installation on manjaro linux · Issue #1767 · prasanthrangan/hyprdots · GitHub
but we still cannot manage to solve the sddm problems. Besides that, I found that I cannot load obsidian and vscode in hyprland, both of them are electron stuff. Can you help me with those two problems?
i.e.:
sddm cannot load.
obsidian and vscode cannot load. They will crash within the system.
As for the image problem, really sorry about that. I will keep the guidance in mind in the future.
any instructions on how to do it… I am not quite familiar with how to do it. My manjaro have about a year’s life, it indeed has a few switches and I used to reinstall sddm before, also consistently running sudo pacman -Syyu so I am not quite sure how to work with upstream before to get the default installation.
