So when I switch to TTY with ctrl+alt+fn I get blackscreen. Then if I move mouse TTY works, but part of screen is in… strange state like on photo:
inxi --admin --verbosity=7 --filter --no-host --width:
Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=d3f930ec-9913-4731-964e-a92393a8c151 rw quiet splash
resume=UUID=791b97ed-d445-41a4-a423-e3993163db36 udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop System: Gigabyte product: B460MD3H v: -CF
serial: <superuser required>
Mobo: Gigabyte model: B460M D3H v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F5c date: 10/05/2021
System RAM: total: 16 GiB available: 15.56 GiB used: 4.32 GiB (27.8%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: no module installed
Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: 075d part-no: IRX2666D464L16S/8G
serial: N/A
Device-3: ChannelB-DIMM0 type: no module installed
Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
serial: N/A
Info: model: Intel Core i5-10400F bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 3 microcode: 0xFA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 848 high: 1268 min/max: 800/4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 919 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 1268 11: 800 12: 800 bogomips: 69629
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 550.78
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of
2024-04; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 01:00.0 chip-ID: 10de:1c82
class-ID: 0300
Device-2: Generalplus GENERAL WEBCAM driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:5
chip-ID: 1b3f:2247 class-ID: 0102
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3200x1080 s-dpi: 86 s-size: 945x319mm (37.20x12.56")
s-diag: 997mm (39.27")
Monitor-1: DVI-D-0 pos: bottom-r res: 1280x1024 hz: 60 dpi: 86
size: 376x301mm (14.8x11.85") diag: 482mm (18.96") modes: N/A
Monitor-2: HDMI-0 pos: primary,top-left res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1050 Ti driver: nvidia v: 550.78 device-ID: 10de:1c82
surfaces: xcb,xlib
Device-1: Intel Comet Lake PCH-V cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Device-3: Generalplus GENERAL WEBCAM driver: snd-usb-audio,uvcvideo
Device-4: C-Media CM108 Audio Controller
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-7:7 chip-ID: 0d8c:013c class-ID: 0300
API: ALSA v: k6.6.32-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d55 class-ID: 0200
IF-ID-1: br-e0fb13ebc2ac state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Local Storage: total: 931.53 GiB used: 161.19 GiB (17.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 00WD
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: WDC WDS250G2B0A
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 90WD scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD2500AAKX-083CA1 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1H19 scheme: MBR
ID-1: / raw-size: 456.87 GiB size: 448.63 GiB (98.20%)
used: 161.19 GiB (35.9%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: d3f930ec-9913-4731-964e-a92393a8c151
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
uuid: B6B8-0F52
ID-1: swap-1 type: partition size: 8.59 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 791b97ed-d445-41a4-a423-e3993163db36
ID-1: /dev/sdb1 maj-min: 8:17 size: 232.88 GiB fs: ntfs label: N/A
uuid: 4ACC5ACACC5AAFC5
ID-2: /dev/sdc1 maj-min: 8:33 size: 232.88 GiB fs: ntfs
label: HDD WD Blue 2 uuid: 5E68C9D368C9AA5B
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-4:2 info: Holtek Keyboard type: keyboard,HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:a096 class-ID: 0300
Device-2: 1-7:7 info: C-Media CM108 Audio Controller type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Device-3: 1-9:4 info: SteelSeries ApS Rival 3 type: mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 400mA chip-ID: 1038:184c class-ID: 0300
Device-4: 1-10:5 info: Generalplus GENERAL WEBCAM type: video,audio
Hub-2: 1-11:6 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
System Temperatures: cpu: 41.0 C mobo: 38.0 C gpu: nvidia temp: 32 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 45%
Processes: 343 Power: uptime: 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1707 libs: 465 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: yakuake inxi: 3.3.34
