I am unable to login into the live environment using virtualbox as it says that the default password manjaro
is wrong. This is using the latest minimal iso downloaded from the github page.
are you sure its the password? you can try and switch to another tty and try to log in there. Likely it is more of a e.g. driver thing that stops the swaywm from starting.
I will try and report. I remember the default tty was 2. Also the prompt for user name and password comes way before the messages are done for example while entering username it still shows started pacman mirrors
in red and white color.
