Hi there its like my swap storage just doesn’t work and its 0 bytes of 17 GB
Swap is used well before RAM is full, it depends on swappiness parameter.
Mine is 60, means the kernel will copy RAM contents to swap when 60% of the RAM is used.
cat /proc/sys/vm/swappiness
By the way, I have no swap partition nor swap file on my system, lol ![]()
Welcome to Manjaro!
- Please read this:
How to provide good information
and press the three dots … below your post and press the
to give us more information so we can see what’s really going on.
Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
- An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
P.S. If you want to notify me that you did provide this information, please
this message and I’ll come back and have another look.
P.P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which exact CPU/GPU or Kernel, … you have without typing it every time.
